Bit of advice needed on this. While this is more of a list based around 'things I already have and/or think are cool', any tips of making this a relatively balance POTL list would be appreciated.
Oh, and I am 83 points over (or, you know, could just add some units to make it up to 2,500).
XIII Legion - Pride of the Legion - 2,083 points
HQ
Legion Praetor [180]
  • Paragon Blade, Digital Lasers, Grenade Harness, Volkite Charger, Tartaros Terminator Armour.
Legion Warmonger Consul [142]
-Lightening Claw, Combi-Melta, Digital Lasers, Iron Halo, Tartaros Terminator Armour.
Damocles Command Rhino [115]
  • Dozer Blade, Extra Armour, Hunter Killer Missile.
TROOPS
Legion Terminator Squad [256]
  • Legion Terminator Sergeant [1]: Twin Lightening Claws, Grenade Harness.
  • Legion Terminators [4]: Lightening Claws, Volkite Chargers, Plasma Blaster [1].
  • Tartaros Terminator Armour.
Legion Veteran Tactical Squad [265]
  • Legion Tactical Sergeant (1): Power Axe, Bolt Pistol, Artificer Armour, Melta Bombs.
  • Legion Tactical Marines (9): Bolters, Combi-Plasma [3], Power Swords [2], Melta Bombs.
Legion Rhino Armoured Carrier  [45]
  • Twin-Linked Bolter, Smoke Launcher, Extra Armour, Dozer Blade.
Legion Veteran Tactical Squad [225]
  • Legion Tactical Sergeant (1): Power Sword, Combi-Melta Artificer Armour, Melta Bombs.
  • Legion Tactical Marines (9): Bolters, Nuncio Vox, Melta Bombs.
FAST ATTACK
Anvillus Pattern Dreadclaw Drop Pod [115]
  • Frag Assault Launchers.
HEAVY SUPPORT
Fulmentarus Terminator Strike Squad [255]
  • Decurion [1]: Power Fist, Combi-Melta.
  • Fermantarus [4]: Power Axe, Combi-Melta.
Leviathan Pattern Siege Dreadnought [325]
- Leviathan Storm Cannon, Grav Flux Bombard, Twin Volkite Calivers, Armoured Ceremite.
https://bolterandchainsword.com/topic/359100-xiii-pride-of-the-legion/
The Praetor and his unit of Tartaros Terminators don't fit into a Dreadclaw. Are they ... footsloggin' ? Or deepstriking with the Warmonger ? But where does the Praetor go in the later case ?
Speaking of drop pods in general ... always bring an uneven number, so the larger amount of pods (2 out of 3 ... 3 out of 5 ... etc.) arrives on turn one.
I wouldn't run the Legion Terminators with all Claws. Your list needs more anti-tank both in melee as well as in shooting options.
Fulmentarus get better the bigger their unit size. A unit of 5 with Combi Meltas might as well be replaced by 5 regular Legion Terminators with the right gear. Don't need Fulmentarus for that.
What / who will be ridin' in the pods ?
Sorry but I see nothing but bullet points on this post
I just see empty bullets
That's really odd? Reposted below, does it work now?
Thanks for this! Tweaked the list a little below.
My reason behind the Fulmentarus was that I felt I needed at least one UM specific unit. No tactical reason behind it. Have replaced them with a standard Cataphractii unit.
In terms of transports etc, one unit of Terminators in one Dreadclaw, the Praetor and Command Squad in the other. Warmonger and Tartaros Terminators deep striking. Leviathan now has a Dreadnought Drop Pod. So now there are three pods.
What do you suggest re anti-tank? Added the Xiphon to help bump it up to 2,500 so far.
HQ
Legion Praetor [163]
Paragon Blade, Digital Lasers, Combi-Bolter, Tartaros Terminator Armour.
Legion Command Squad [180]
Legion Standard Bearer [1]: Power Sword, Combi-Bolter, Legion Standard.
Legion Chosen [3]: Power Fists [2], Thunder Hammer [1], Combi-Bolters.
Damocles Command Rhino [105]
Extra Armour.
TROOPS
Legion Terminator Squad [215]
Legion Terminator Sergeant [1]: Power Fist, Combi-Melta.
Legion Terminators [4]: Power Axe, Combi-Meltas.
Cataphractii Terminator Armour
FAST ATTACK
Xiphon Pattern Inceptor [215]
Twin Lascanons [2], Xiphon Rotary Missile Launcher, Ground Tracking Auguries.
HEAVY SUPPORT
Legion Dreadnought Drop Pod [100]
On mobile the list appears as white font against the white background, meaning I need to highlight the text to make it appear. That's why it's invisible for many people :smile.:
Hadn't even thought of that!! Changed it all back to Default text colour now so hopefully it'll be fine?
Mini-bump here, did some more thinking and have streamlined the list a little bit. Think it is a bit more balanced now?
XIII Legion - Pride of the Legion - 2,338 points
HQ
Legion Tartaros Terminator Command Squad [180]
Extra Armour.
TROOPS
Legion Cataphractii Terminator Squad [215]
Legion Tactical Marines (9): Bolters, Combi-Melta [3], Power Swords [2], Melta Bombs.
FAST ATTACK
HEAVY SUPPORT
Fire Raptor Gunship [230]
Twin Avenger Bolt Cannon [1], Reaper Autocannon Batteries [2], Armoured Ceremite.
