Zephaniah Adriyen Posted May 6, 2020 Share Posted May 6, 2020 I'm looking into making a spider-Armiger - how do they size-compare? Simple question. Could anyone with an AdMech and Knights army send a picture or something? Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/ Share on other sites More sharing options...
N1SB Posted May 6, 2020 Share Posted May 6, 2020 This is kinda turning your ask upside down, but it might also be the clearest answer on size comparisons. Our much respected Redshirt made this on a lark: Zephaniah Adriyen 1 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5517832 Share on other sites More sharing options...
Zephaniah Adriyen Posted May 7, 2020 Author Share Posted May 7, 2020 This is kinda turning your ask upside down, but it might also be the clearest answer on size comparisons. Our much respected Redshirt made this on a lark: Very clear, thank you. If Redshirt can do that, I can certainly do the opposite. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5517854 Share on other sites More sharing options...
Tichinde Posted May 7, 2020 Share Posted May 7, 2020 I'm planning on doing this in the future ( I have all the relevant parts). The only issue I recall from test fitting is the "ball" joint on the legs is slightly bigger than the "socket" on the armiger body. As noted above it works fine the other way round! I can provide photos of you like. Zephaniah Adriyen 1 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5517975 Share on other sites More sharing options...
Doghouse Posted May 7, 2020 Share Posted May 7, 2020 Scroll down on this article: https://www.warhammer-community.com/2018/06/22/22nd-june-you-asked-for-chaos-knights-you-got-emgw-homepage-post-1/ Dr_Ruminahui and Zephaniah Adriyen 2 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5518041 Share on other sites More sharing options...
Tichinde Posted May 7, 2020 Share Posted May 7, 2020 Scroll down on this article: https://www.warhammer-community.com/2018/06/22/22nd-june-you-asked-for-chaos-knights-you-got-emgw-homepage-post-1/ yup, that shows it exactly, forgot about that one. Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5518068 Share on other sites More sharing options...
Zephaniah Adriyen Posted May 7, 2020 Author Share Posted May 7, 2020 Very helpful, thank you! Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5518122 Share on other sites More sharing options...
Bung Posted May 7, 2020 Share Posted May 7, 2020 Or you could save yourself some work and look at Fallout Hobbies, they have Spider Legs for Knights and Armigers https://www.fallouthobbies.com/bits Zephaniah Adriyen, Elzender and walter h 3 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5518189 Share on other sites More sharing options...
walter h Posted May 17, 2020 Share Posted May 17, 2020 Bung ,you should post that to the Mechanicus, subforum. I, am also interested in the legs. I would have been checking there for that info. Thank you. Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5522619 Share on other sites More sharing options...
Bung Posted May 17, 2020 Share Posted May 17, 2020 Bung ,you should post that to the Mechanicus, subforum. I, am also interested in the legs. I would have been checking there for that info. Thank you. Haha, i never set a foot in the Mechanicus Subforum as i actually only play Heresy. Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5522689 Share on other sites More sharing options...
Elzender Posted May 17, 2020 Share Posted May 17, 2020 Apologies to Zephaniah for kidnapping the thread, but would anyone be able to show a comparison between a Leman Russ tank and an onager? I am considering the idea of using Onagers as proxies for Solar Auxilia, but I would lile to see if they would be comparable size-wise. Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5522853 Share on other sites More sharing options...
Zephaniah Adriyen Posted May 17, 2020 Author Share Posted May 17, 2020 Apologies to Zephaniah for kidnapping the thread, but would anyone be able to show a comparison between a Leman Russ tank and an onager? I am considering the idea of using Onagers as proxies for Solar Auxilia, but I would lile to see if they would be comparable size-wise. Not a hijack, I'm curious now too. Could use the Start Collecting! photos as a reference point, since AM Infantry and Skitarii are about the same size. Elzender and walter h 2 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5522856 Share on other sites More sharing options...
walter h Posted May 21, 2020 Share Posted May 21, 2020 (edited) Bung ,you should post that to the Mechanicus, subforum. I, am also interested in the legs. I would have been checking there for that info. Thank you. Haha, i never set a foot in the Mechanicus Subforum as i actually only play Heresy. I would hope you might at least try the Mech, forums once. There are some very interesting threads there. Some even have the Heresy period ,as a backdrop. What about the houses that served the ,Emperor, or those that chose the fallen Primarchs. Take a peek. It's free No charge! Seriously please visit. Edited May 21, 2020 by walter h Magos Takatus 1 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5524937 Share on other sites More sharing options...
Bung Posted May 21, 2020 Share Posted May 21, 2020 Bung ,you should post that to the Mechanicus, subforum. I, am also interested in the legs. I would have been checking there for that info. Thank you.Haha, i never set a foot in the Mechanicus Subforum as i actually only play Heresy. I would hope you might at least try the Mech, forums once.There are some very interesting threads there. Some even have the Heresy period ,as a backdrop. What about the houses that served the ,Emperor, or those that chose the fallen Primarchs. Take a peek. It's free No charge! Seriously please visit. Thanks, but to be honest, 40k lost me at the start of 7th Edition, thats why i am only visiting the Forge and Age of Darkness parts. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/363714-onager-dunecrawler-and-armiger-size-comparison/#findComment-5525026 Share on other sites More sharing options...
