Lord_Mephistopheles Posted February 24, 2025 Author Share Posted February 24, 2025 (edited) 16 hours ago, Firedrake Cordova said: As something of an aside, I'm working my way through Interceptor City, which mentions an experimental Marauder variant which is stripped down and mounts a volcano cannon (it's specialised for taking down large bombers) ... so, flying volcano cannon (as seen in your flyer) are canon now Nice! Clearly i'm a prescient trend-setter! Now... where are those Lottery Numbers? Struggling to decide if i like the "turret" on top of the Warhawk or not. It was something i considered for the Seraphim and ruled out, so not sure it fits here either. Edited February 24, 2025 by Lord_Mephistopheles Firedrake Cordova and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6096578 Share on other sites More sharing options...
Lord_Mephistopheles Posted February 24, 2025 Author Share Posted February 24, 2025 A quick shot here of the Blood Angels flyers - the tiny little red thing in the middle being the Xiphon, and then from right-to-left we have a Thunderhawk; a Thunderhawk Transporter; A Sokar-pattern Stormbird; a Warhawk MK IV; and finally the custom gunship "Seraphim". The older Thunderhawk and Stormbird models clearly show where they need revisiting and redetailing - especially the Sokar Pattern which now needs to serve as more of a visual and evolutionary bridge between the non-STC Warhawk Mk IV and the STC-based Thunderhawk variants. Dr_Ruminahui, Firedrake Cordova and LameBeard 3 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6096588 Share on other sites More sharing options...
Lord_Mephistopheles Posted March 7, 2025 Author Share Posted March 7, 2025 In my last post here, i made the point that the older models of the Stormbird and the Thunderhawk weren't quite up to scratch in terms of the level of detail, and their overall appearance compared to the newer aesthetic. In addition, they'd lost their familial lineage - not that the Thunderhawk and Stormbird really had one to begin with. I've therefore been working in the background to correct this, and below is my current progress on the Stormbird update: An almost complete rebuild with the aim of being a clear step-down in size from the Warhawk, and starting to evolve to a more Thunderhawk-like design. The core troop area thus reduces in size, and only provides 4No. drop doors instead of 6No. The weapon loadout is reduced and changed. The cockpit and nose changed. Obviously a lot of panelling / armour plating etc. detailing work to be done still, but this shows the trend. Next task will be a Thunderhawk update to match. FYI - aside from the "Seraphim" which is a pimped-out custom ride, i've decided that Warhawk / Stormbird / Thunderhawk are general classifications for size of vehicle, rather than Stormbird being an encompassing term which also applies to the Warhawk etc. Hence: "Seraphim" - a custom gunship / dropship / light spacecraft originally used by Sanguinius during the Crusade. Warhawk-class, Nephilim-pattern dropship Stormbird-class, Ophanim-pattern dropship Thunderhawk-class, Malakim-pattern gunship Thunderhawk-class, Elohim-pattern transporter Firedrake Cordova, Tallarn Commander and LameBeard 3 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6098731 Share on other sites More sharing options...
Lord_Mephistopheles Posted March 14, 2025 Author Share Posted March 14, 2025 Today in the increasingly-inaccurately named "Legio Solaria Titans" topic... The latest updates to the Blood Angels air wings! All the below models have been rebuilt, starting from the Warhawk and trending / evolving towards the Thunderhawk. All models obviously require further detailing and panel work, so are very much WIP at this stage, but i think i've captured the design evolution. Thunderhawk-class, Malakim-pattern gunship The Thunderhawk itself is a local variation on the typical STC, being only a twin-engined flyer, but with significantly uprated engines over the standard Mars-pattern. In my head, i see this as the local Forge World adapting the design to simplify it and aid maintenance, as there is no longer a need to access a centrally located, ventral engine embedded in the main hull. Flare shields haven't yet been added but will be, along with secondary weapons. Stormbird-class, Ophanim-pattern dropship: In the next weight-class up, the larger Stormbird. As this is styled more of a dropship vs. the Thunderhawk which is a gunship with modest transport capability, there are more significant changes. The hull gets "fatter" to accommodate a larger troop capacity, with large drop-doors added. Missing for technical reasons are the void shields. Warhawk-class, Nephilim-pattern dropship: The Warhawk took a bit more getting right, as I wasn't happy with the nose or cockpit arrangement - there was no evolutionary path i could see, which i think i've now rectified. Otherwise, remains the same as previously, albeit some tweaks to the wing arrangement to hint at more commonality between the designs. All three have attempted to show wings slightly arcing round to the front in a pincer-type effect, designed to be somewhat evocative of the "bird of prey" from the naming conventions, and also that of another extremely-famous sci-fi franchise... Finally, the size comparison! There is a largely linear size differential between the three. The Thunderhawk Transporter won't fit in the same linear pattern, but as it's an entirely different type of vehicle i don't have an issue with that - albeit that is the next flyer i intend to block out to a similar standard as these before i start detailing. Raziel-TX, Firedrake Cordova and LameBeard 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6099916 Share on other sites More sharing options...
Lord_Mephistopheles Posted March 22, 2025 Author Share Posted March 22, 2025 Work on the flyers continues - but having found an hour to have a fiddle, i've finally gotten round to changing the material mapping for the 'Seraphim' to the Sanguinary gold colour scheme... My issue is that i'm now not sure it looks "Blood Angels" enough, and I'm wondering if keeping the engine pods red, along with the secondary wings would work, or whether that's veering toward Custodes territory? Or does it stay completely red, as that is after all the Legion colour scheme... Firedrake Cordova, Tallarn Commander, Dr_Ruminahui and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6101100 Share on other sites More sharing options...
Firedrake Cordova Posted March 25, 2025 Share Posted March 25, 2025 I think your right in that you need a bit more red on it to prevent it being mistaken for Custodes. Lord_Mephistopheles 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6101510 Share on other sites More sharing options...
Lord_Mephistopheles Posted March 26, 2025 Author Share Posted March 26, 2025 18 hours ago, Firedrake Cordova said: I think your right in that you need a bit more red on it to prevent it being mistaken for Custodes. It certainly needs something doing, but changing it to red engine cowling and red winglets didn't look right. I do like the "all-gold" look, but honestly, it gives me more "Imperial Fists" vibes than Custodes. I wonder if things like putting the BA logo on a big red circle might help. A bit more iconography on the wings. that sort of thing. Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6101660 Share on other sites More sharing options...
Firedrake Cordova Posted March 26, 2025 Share Posted March 26, 2025 What about red fuselage, gold everything else? Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6101665 Share on other sites More sharing options...
Lord_Mephistopheles Posted March 26, 2025 Author Share Posted March 26, 2025 I tried a couple of iterations. Red Fuselage, gold wings: All gold, red highlights: I think that i'm coming round to the idea that it's either got to be all red, or all gold. The "mix'n'match" approach isn't working for me. LameBeard, Firedrake Cordova, Dr_Ruminahui and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6101670 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 1, 2025 Author Share Posted April 1, 2025 Who wants a hi-res image? Anyone? Hi-res image sir? Anyone who spots the deliberate mistake will gain 10 points for their House. And no, it isn't the fact that the specular lighting i thought i'd included for the Doomstrike missile from the Warmonger hasn't actually worked so it just looks like an ICBM is floating in mid-air... Firedrake Cordova, Dr_Ruminahui, W.A.Rorie and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6103160 Share on other sites More sharing options...
Firedrake Cordova Posted April 1, 2025 Share Posted April 1, 2025 That looks pretty impressive. Unfortunately, it looks like the B&C's upload process debigulated the image a bit. Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6103218 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 1, 2025 Author Share Posted April 1, 2025 3 minutes ago, Firedrake Cordova said: That looks pretty impressive. Unfortunately, it looks like the B&C's upload process debigulated the image a bit. Really? That's vexing. It's meant to be a 12k x 5k render that you can zoom right in on... I'll stick the full version on a public Google Drive link tomorrow and post it. I want to try and get the armour plating and limited detail greeblies sorted on the flyers so I can re-render it and fix the "deliberate mistakes". Also if anyone has any experience in Photoshop or AfterEffects or similar and either wants to, or could be talked into, adding some SFX for things like lasers or something... I may also try to run an animation render at some point but we will see. I am just playing around at this point, but if anyone has any designs or ideas/concepts they want to see me tackle I'd be well up for it! LameBeard and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6103219 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 2, 2025 Author Share Posted April 2, 2025 Well, let's give this a go then: https://drive.google.com/file/d/1-w3JcC7CzaPzcc0pcGRn992FTxeNZnsU/view?usp=sharing Does that link to an absurdly-large *.png file of above image, at a 12k x 5.5k resolution? Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6103347 Share on other sites More sharing options...
Firedrake Cordova Posted April 3, 2025 Share Posted April 3, 2025 Yes, but you have to download it, rather than using the web viewer (it's a 70MB image file) Lord_Mephistopheles 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6103496 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 9, 2025 Author Share Posted April 9, 2025 Well, at least it's back to robots.... Got a bit bored of panel detailing the Blood Angels, so moved onto something else for the rapid dopamine fix! Previously, the Cybernetica contingent of the above consisted of a Thanatar and a Dominar... and nothing else. I was determined i wasn't going to get drawn in... and then i started reading Lexicanum articles... and i was done. Relatively recently, the model line got buoyed by the addition of the Thallax and Ursurax, and while i'm a huge fan of these models (the Thallaxi in particular), modelling them didn't interest me for a couple of reasons: 1) they're complex models, but small; 2) i love 'em just as they are so there's no room for me to do anything with them. While i've previously modelled a few things - mostly Astartes vehicles like the Rhino, Predator and Stormspeeders - that are as per the GW model, these have been done with future things in mind. Again, with the Thallaxi, there's no development of them, so no point. Where there IS development however, is in investigation of the "missing" classes of Cybernetica robots! Now the 40k Cybernetica models don't excite me, but the older 30k models do... and that is the time period where lots of different classes were hanging about, rather than the current setting, and also before the "... lost to Imperial Science..." deus ex occurred. Having already got the Thanatar and Dominar models, representing the ultimate evolutionary end-point of Mechanicum design before they become Knight- and Titan- sized, i started with the Castellax, and then moved on to the Cataphractii and Baharrat... and attempting to show design evolution through them all. The Castellax, on the RHS of the image, is pretty much as the GW model, save the affectation of the half-plated "head" to match the others. Bolt cannon, bolts and power claws - basic. The Cataphractii, which is the next robot in from the Castellax, has been re-imagined slightly from it's wiki entry and now fulfils the role of heavy weapons / fire-support. Bigger than the Castellax, and armed with a heavy bolter / power claw combi; a Cognis-pattern Lascannon; and a shoulder-mounted Tigris-pattern Heavy Conversion Beamer. The Baharrat, in the centre, is in the heavy assault role. Built on a similar chassis to the Cataphractii, it closely follows it's fluff and also departs from the deliberate asymmetry elsewhere. Armed with 2 Reaper-pattern rotary autocannon on the shoulders, this one still needs work to complete and the intention is it will have the "circular saw" close-combat weapon from the Castellax, and a flamer mounted on the other arm. The Dominar has been seen round these parts before, and again is largely as GW-designed, however i've tweaked the scale and added a substantial melta-destroyer to it's shoulder mount. The Thanatar - also previously seen - remains as-was, as a hybrid between the Thanatar and the Thanatar-Calix. I plan to complete some of the detailing on these - which is mostly completing the Baharrat, sorting material assignments throughout, and adding the "barcode" markings and a few glowing lenses etc. over the next week or so, and then i think that's Cybernetica completed. Tallarn Commander, Firedrake Cordova, Dr_Ruminahui and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6104397 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 11, 2025 Author Share Posted April 11, 2025 As it's the school Easter holidays in my part of the UK, meaning a lot of people are off work and it's quiet - combined with good weather - i've had some time this week to fiddle with the robots as there hasn't been a lot on. The detailing has thus come along, barring one minor issue where the drawing file corrupted for the Cataphract, hence i had to rebuild it from backups! Lenses added, albeit the glow effect isn't pronounced because of the lighting. Materials sorted, although looking at the render now i see i need to mirror the shoulder armour on the Baharrat to break the "right-shoulder bronze" continuity. Added the identifier barcoding, which i've decided is how the Tech-priests identify individual chassis and weapon configurations. Updated the Baharrat weapons. Left arm is now the circular cutter with a built-in flamer. Changed the shoulder rotary autocannons to make them look more autocannon-y and less bolter-y. Changed the head and chest armour on the Cataphract-class, as the previous version was too "Coneheads" (and didn't really show an evolutionary development of less "flattened dome in the torso" and more "distinct "head / facemask"): Tallarn Commander, LameBeard and Firedrake Cordova 3 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6104664 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 15, 2025 Author Share Posted April 15, 2025 Detailing now just about done in terms of lenses, weapons etc. I changed the circular blade arrangement on the Baharrat as the previous one was too small and out of scale. I've still not worked out how to get the shoulder-mounted weaponry fixed to the various chassis so they're all "floating" at the moment. I can't find a decent image of the actual models which makes it difficult to duplicate. Tallarn Commander, Firedrake Cordova and LameBeard 3 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6105268 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 23, 2025 Author Share Posted April 23, 2025 In a flurry of productivity, I went back to the Astartes flyers at the end of last week before the Easter weekend. I got some panelling work done on various craft, and a few other minor updates most of which are too boring to show on their own. But i'd never, ever been happy with the engine arrangements on the Warhawk and Seraphim. All these flyers are meant to be, to some greater-or-lesser extent, void-capable (they are dropships first and foremost after all!). I had always envisaged that although the Thunderhawk variants would utilise the magic "afterburning turbofan ramjet aerospikes that somehow also work in space" as they are meant to be purely short-range orbit-to ground craft, the larger craft would have distinct engines for different purposes. The Stormbird therefore has the same (but physically larger) engines as the Thunderhawk on the wings, with a variant engine optimised for high-atmosphere / edge-of-space to increase void performance on the vertical rudders. The larger-still Warhawk (and the one-off Seraphim) originally were modelled with engines in the tail of the fuselage meant to evoke pure void-use plasma engines. However they never quite fit the aesthetic, and just looked bolted on, wedged in the body wherever possible. Suffice to say i wasn't happy. I then found a cutaway image on t'interwebs of the main engines on the Millennium Falcon (yes yes, i know, don't cross the streams)... but having seen that image i could instantly see how they'd be integrated in a more pleasing way with the craft, and also provide a means for directional control when in void-flight, where obviously manipulating airflow with control surfaces isn't as effective as you might like! All this explanation is by way of the update to the modelling that i'm actually wanting to show: Firedrake Cordova, Tallarn Commander, LameBeard and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6106264 Share on other sites More sharing options...
Lord_Mephistopheles Posted April 25, 2025 Author Share Posted April 25, 2025 I had planned on being "done" with Astartesian flying craft... alas, while browsing the internet i saw something, and inspiration suddenly struck! Back in the Good Old Days of pre-Heresy, the Astartes were pretty much intended to be a self-contained force. They had their own fleets, far larger than the M41 setting, that were more general purpose than the current transport / landing craft they have now. While the books show they often had naval and fleet support, i also see them as having their own gear, either based on or basically identical to the Naval equipment. Thus, combined with the use of the Warhawks and Stormbirds more as dropships, the need for an Astartes Starfighter was born - so here is the Sagarus Starfighter. INtended to be a similar STC-style as the Xiphos, but more heavily armed than the single-seat interceptor. The Sagarus packs 2 banks of twin superheavy lascannon of the Solex-Magma variety, and is also currently armed with 2x rotary Sagarus torpedo launchers, designed to allow close-(ish)-ranged attack runs on "proper" capital ships. I will probably add some missiles as well if i can find a way to integrate them neatly. Raziel-TX, Firedrake Cordova, LameBeard and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6106636 Share on other sites More sharing options...
Lord_Mephistopheles Posted June 5, 2025 Author Share Posted June 5, 2025 I'm going through another quiet period with this project - not for lack of desire or anything at this point, but simply because i'm back in a position of having run out of ideas. As Natalie Imbruglia told us back in the late 1990s, "My inspiration has run dry... that's what's goin' on." I have made limited progress on bits and bobs, which i'll put here, and hope that it garners some comments which might contain the inkling of an idea! Failing that, I'll repeat my previous call of "Anyone got anything they want me to take a crack at reinventing in my 'style'?" First - an updated render of the Blood Angels aircraft, all in one place, including the now-updated Thunderhawk Transporter and the Sagarus Starfighter: Second - a quarter-ventral view of the Sagarus, showing the torpedo bay and the newly-added missile launchers, as derived from the Xiphon. Both medium- and short-range (and medium- and small-SIZE) missiles are shown: That's the lot for today! LameBeard, Tallarn Commander and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6114357 Share on other sites More sharing options...
Firedrake Cordova Posted June 5, 2025 Share Posted June 5, 2025 Oh man ... thanks for the earworm and making me feel old! They look good. That is a lot of missiles Lord_Mephistopheles 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6114409 Share on other sites More sharing options...
Lord_Mephistopheles Posted June 12, 2025 Author Share Posted June 12, 2025 On 6/5/2025 at 7:33 PM, Firedrake Cordova said: Oh man ... thanks for the earworm and making me feel old! They look good. That is a lot of missiles I think it's 16 or 18 (2x8 or 2x9) of the smaller missiles (models based on the AIM-9 Sidewinder), and 14 (2x7) of the larger missiles (based on the AIM-120 AMRAAM). It obviously has the big lascannon as well. You can see from the render it's only slightly smaller than my version of a Thunderhawk, and about twice the size of the Xiphon, but most of that space is power generators / reactors, engines, weapons storage. I think this is probably a 4-person crew, maybe less. Then 2x6 of the Sagarus Plasma Torpedoes. I envisage this as being a craft used as a Starfighter, so taking on similarly-sized craft, while also being launched in numbers to try to strip shields and/or damage an unshielded capital ship. Astartes aren't really known for taking out ships with ranged fire - their MO is more typically to strip shields, launch boarding torpedoes, and then Code 187 them from inside-out (points if you can name the film and make yourself feel old again!) So the theory here is that large-ish numbers of Sagarus will launch their plasma torps at the same time as the boarding torpedoes to strip shields, overwhelm point-defense systems, or generally provide covering fire / damage potential breaching points and shock defenders prior to taking a bolt round to the face at close range. LameBeard and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6115795 Share on other sites More sharing options...
Firedrake Cordova Posted June 13, 2025 Share Posted June 13, 2025 (edited) Sounds like a reasonable hypothesis of how they'd work. Can't say I recognise the film reference (I did Google it, but I know I haven't seen the film). I do remember a game by that name in the 1990s, though ... Edited June 13, 2025 by Firedrake Cordova Lord_Mephistopheles 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6116042 Share on other sites More sharing options...
Lord_Mephistopheles Posted June 13, 2025 Author Share Posted June 13, 2025 1 hour ago, Firedrake Cordova said: Sounds like a reasonable hypothesis of how they'd work. Can't say I recognise the film reference (I did Google it, but I know I haven't seen the film). I do remember a game by that name in the 1990s, though ... Basically like X-wings or TIE Fighters. I have been trying to keep the reimagined equipment reasonably sensible and with a defined purpose throughout, which is why weapon load-outs have changed in some cases, or why new vehicles have been invented to fill "gaps" that I could see. For example, the lack of ANY KIND of anti-air defence on the vast majority of ground vehicles; or the lack of secondary or point-defence equipment. Ludicrous. And I'm almost disappointed you've not seen the film, as that just makes me feel even older still given that it's one of my favourites purely for the cheese factor! Dr_Ruminahui and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6116053 Share on other sites More sharing options...
Dr_Ruminahui Posted June 18, 2025 Share Posted June 18, 2025 (edited) If it makes you feel any better, I'm old too and haven't heard of the movie either. I do remember the Murder Death Kill game, though - never played it, but my longtime 40K buddy was a programmer on it about the time we first met. If there was a Code 187 video game, I haven't heard of it either. Though, I think we are likely the same amount of old, as the movie Code 187 and the MDK video game came out in the same year. Edited June 18, 2025 by Dr_Ruminahui ZeroWolf and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/367969-legio-solaria-titans/page/5/#findComment-6116973 Share on other sites More sharing options...
