Mr. Oddity Posted January 19, 2021 Share Posted January 19, 2021 Greetings all, This is just going to be a small thread to track my progress on designing and modelling a replacement base for the Primaris Firestrike Servo-turret. I've loved the look of the thing since GW announced it and have been planning on slotting some into my eventual Imperial Fists successor army I'm also starting to work on. However, I do have one major issue with its design - the base. For a (theoretically) mobile weapons emplacement it looks incredibly static. And no, the "hover plates for feet" thing isn't enough for me. So what's a fellow to do during quarantine other than do some design work?My basic idea is to call back to the design and role of the Legion Rapier platforms of 30k, an appropriate parallel in my mind due to their combat roles and the inspiration the Primaris line has taken from the legion organization of yestermillenia. Using the Repulsor's proportions and general design as a basis, here's the concept sketches I've put together. And here is my initial modelling progress, with Repulsor side as a reference. Next up will be adding more panel details and working on the grav plates. Cheers! Link to comment https://bolterandchainsword.com/topic/368610-firestrike-turret-alternate-base/ Share on other sites More sharing options...
Bjorn Firewalker Posted January 19, 2021 Share Posted January 19, 2021 Is the Firestrike limited to weapons with little or no recoil, e.g., lasers and other directed energy weapons, missile and rocket launchers? If not, then how about adding retractable legs to the design, so the Firestrike may brace itself before firing powerful weapons? Link to comment https://bolterandchainsword.com/topic/368610-firestrike-turret-alternate-base/#findComment-5655827 Share on other sites More sharing options...
Mr. Oddity Posted January 19, 2021 Author Share Posted January 19, 2021 Is the Firestrike limited to weapons with little or no recoil, e.g., lasers and other directed energy weapons, missile and rocket launchers? If not, then how about adding retractable legs to the design, so the Firestrike may brace itself before firing powerful weapons? The Firestrike gets two Las-Talons or two autocannons as its loadouts. And while the legs would be interesting, since this is going to be an anti-grav platform like the Repulsor and Impulsor they would look out of place. Link to comment https://bolterandchainsword.com/topic/368610-firestrike-turret-alternate-base/#findComment-5655859 Share on other sites More sharing options...
Mr. Oddity Posted January 20, 2021 Author Share Posted January 20, 2021 Another update - grav plate tentatively done. Planning on using a key-and-hole setup from lineup and mounting to the platform. Link to comment https://bolterandchainsword.com/topic/368610-firestrike-turret-alternate-base/#findComment-5655908 Share on other sites More sharing options...
Guest Triszin Posted January 20, 2021 Share Posted January 20, 2021 Interesting, can't wait to see the outcome Link to comment https://bolterandchainsword.com/topic/368610-firestrike-turret-alternate-base/#findComment-5656177 Share on other sites More sharing options...
