Styles Posted September 22, 2021 Share Posted September 22, 2021 If a Deathguard Unit is hit and wounded by a single shot by a weapon with 3D3 Damage, does then Disgusting Resilience rule mean the unit suffers 3D3-1 damage or is the -1 to each of the 3 Dice. So for example if a 2,2 & 3 was rolled, it would be 4 damage instead of the 6 if it is -1 to the total instead of each D3? Which is the correct way? Total Dice or each D3? Link to comment https://bolterandchainsword.com/topic/371780-disgusting-resilience-rule-3d3-damage-question/ Share on other sites More sharing options...
Panzer Posted September 22, 2021 Share Posted September 22, 2021 A single wound with 3d3 damage would be 3d3-1 damage. 3 wounds a 1d3 damage would be 3d3-3 damage. Karhedron and Styles 2 Back to top Link to comment https://bolterandchainsword.com/topic/371780-disgusting-resilience-rule-3d3-damage-question/#findComment-5744743 Share on other sites More sharing options...
Xenith Posted September 22, 2021 Share Posted September 22, 2021 As above: Damage is 3D3, DR gives damage -1, so damage is (3D3-1). As with any single attack, this goes on a single model unless otherwise specified. Rik Lightstar, Styles and Karhedron 3 Back to top Link to comment https://bolterandchainsword.com/topic/371780-disgusting-resilience-rule-3d3-damage-question/#findComment-5744749 Share on other sites More sharing options...
