Sawtooth Posted October 17, 2022 Share Posted October 17, 2022 I'm totally new to daemons and this edition, and I'd like to build a Tzeentch army. I don't really know where to start. Is taking a single horror unit and loading up on Flamers and other things a bad idea because of board control? Should I focus on multiple Horror units as the backbone of my force instead? What would you grab if you were starting such an army? Link to comment https://bolterandchainsword.com/topic/376278-mono-tzeentch-army-building-advice/ Share on other sites More sharing options...
Progenitor Posted October 18, 2022 Share Posted October 18, 2022 Depending on your detachments you're going to be taking multiple units of Horrors anyway as they are the only unit with ObSec and you'll need that for holding objectives. Kairos is super good for his points and because of this 3 casts a turn can easily score secondaries while still nuking the enemy, 3++ Daemonic Save and Ignoring wounds on a 5+ if you take his warlord trait are good too. Flamers are excellent and dropping them with a Burning Chariot that gives them +1S to the Flames, plus their strategem means you can melt big units too. For every Greater Daemon you can take a Herald without using up a slot so it wouldn't be hard to take Kairos, a regular LoC and then still get some heralds in without bothering with a second detachment. Melee will be tough but Screamers are pretty good there and can tank damage surprisingly well on the way in. Sawtooth and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/376278-mono-tzeentch-army-building-advice/#findComment-5876651 Share on other sites More sharing options...
Ulfast Posted October 18, 2022 Share Posted October 18, 2022 I would start with 2 units of pink horrors, one box of blue horrors so the basic is fixed. After that I would go with a Lord of change or/and herald and daemon prince. After that both flamers and screamers are good. Later one I would also get a soulgrinder or two. But not from the start. Dr_Ruminahui and Sawtooth 2 Back to top Link to comment https://bolterandchainsword.com/topic/376278-mono-tzeentch-army-building-advice/#findComment-5876660 Share on other sites More sharing options...
Closet Skeleton Posted October 20, 2022 Share Posted October 20, 2022 From what I can tell a Lord of Change +3 start collecting (if you can still find them) is basically 2k points in the new book so just buy that. Pretty much with any daemon faction you hit 1500 just by buying 1 of everything, its literally the easiest army to collect. Pink horrors are so expensive you literally run out of the ability to take toys if you bring more than 30 of them so no I don't think only having one squad is necesarily a bad idea. Its probably the only way to actually optimise the army. Just going for max flamers is the best army but its also the ***** move. Mithrilforge and Sawtooth 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/376278-mono-tzeentch-army-building-advice/#findComment-5877577 Share on other sites More sharing options...
