Blindhamster Posted April 9, 2023 Share Posted April 9, 2023 Been building the brutalis, goodness me it’s painful, nothing QUITE fits together correctly, some parts fit flush then the same part doesn’t at a different point like it’s warped, and the mood lines too, it’s crazy to have such bad mold lines on such a modern kit Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5931669 Share on other sites More sharing options...
Orange Knight Posted April 9, 2023 Author Share Posted April 9, 2023 9 hours ago, Blindhamster said: Been building the brutalis, goodness me it’s painful, nothing QUITE fits together correctly, some parts fit flush then the same part doesn’t at a different point like it’s warped, and the mood lines too, it’s crazy to have such bad mold lines on such a modern kit Wow, I really hoped that my experience wouldn't be this common. I still can't bring myself to paint the thing. I know it could look OK once sprayed and painted but I still have the experience of building it burned into my mind. Blindhamster 1 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5931858 Share on other sites More sharing options...
Khornestar Posted April 10, 2023 Share Posted April 10, 2023 Is it obvious based on the sprue if yours is miscast or not? I’m looking at mine on the sprue and nothing odd stands out. Don’t/won’t have time to build it for a little while. Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932177 Share on other sites More sharing options...
Guest Triszin Posted April 10, 2023 Share Posted April 10, 2023 5 minutes ago, Khornestar said: Is it obvious based on the sprue if yours is miscast or not? I’m looking at mine on the sprue and nothing odd stands out. Don’t/won’t have time to build it for a little while. For me. It's obvious they were taken out before the sprues could fully cure. There's a bunch of tension marks on my sprues. Bent/warped bits. Deformed joints that you need to shave Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932186 Share on other sites More sharing options...
Guest Triszin Posted April 10, 2023 Share Posted April 10, 2023 (edited) You see the "lines" on theleft arm? Those aren't mold lines. Those are tension lines and are deformed. You can tell which ones are mold lines, which ones are tension. I have tons of tension lines Edited April 10, 2023 by Triszin Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932189 Share on other sites More sharing options...
Sir Clausel Posted April 10, 2023 Share Posted April 10, 2023 Totally unrelated but that pose is hilarious/awesome! But im glad i havent bought that kit yet Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932229 Share on other sites More sharing options...
Blindhamster Posted April 10, 2023 Share Posted April 10, 2023 Yeah mine had the same tension lines Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932282 Share on other sites More sharing options...
Khornestar Posted April 10, 2023 Share Posted April 10, 2023 (edited) 6 hours ago, Triszin said: You see the "lines" on theleft arm? Those aren't mold lines. Those are tension lines and are deformed. You can tell which ones are mold lines, which ones are tension. I have tons of tension lines Thank you and OH MY GODS that is cool! I got my Agastus set for quite cheap, and hadn’t looked too close at the contents yet. After reading this thread I was sure I got screwed by someone who knew about this problem, as there was no shrink wrap on the box. However, I seem to have lucked out and got a normal sprue. Maybe customs opened ‘er up, as I ordered it from the UK. Who knows. Definitely doesn’t look like that, though. Edited April 10, 2023 by Khornestar Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932382 Share on other sites More sharing options...
Orange Knight Posted April 10, 2023 Author Share Posted April 10, 2023 That Brutalis pose is simply incredible lol Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932395 Share on other sites More sharing options...
Guest Triszin Posted April 11, 2023 Share Posted April 11, 2023 18 hours ago, Blindhamster said: Yeah mine had the same tension lines I'll look for a barcode/production code and post it here. Maybe we can identify the problem batch Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932590 Share on other sites More sharing options...
Burni Posted April 11, 2023 Share Posted April 11, 2023 For what it's worth, mine doesn't have the lines and has gone together fine. And to answer my own question, the vengor launcher will fit on other models, not just the one pointed up. Khornestar, Lemondish and Sea Creature 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932600 Share on other sites More sharing options...
Lemondish Posted April 11, 2023 Share Posted April 11, 2023 On 4/10/2023 at 10:19 AM, Triszin said: You see the "lines" on theleft arm? Those aren't mold lines. Those are tension lines and are deformed. You can tell which ones are mold lines, which ones are tension. I have tons of tension lines I'm stealing this idea and including the new Tyranid models in my plans here. This is just pure awesome. Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5932969 Share on other sites More sharing options...
b1soul Posted April 15, 2023 Share Posted April 15, 2023 On 3/6/2023 at 6:15 AM, Captain Idaho said: The size isn't the issue. It's how they're holding the absurdly large weapons. The weapon on the right is proportionally even larger...so the different ways of holding are acceptable (to me) Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5934813 Share on other sites More sharing options...
War of the Eagle Posted April 23, 2023 Share Posted April 23, 2023 My brutalis went together rather smooth, but my friends had some fitting issues especialy around the arms so I think maybe an entire run of them had some issues. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5938691 Share on other sites More sharing options...
Karhedron Posted April 23, 2023 Share Posted April 23, 2023 Looks like I have a dodgy one. The tension lines that look like mold lines but actually aren't seem to be the give away. The arms do not fit as intended. I am going to have to shave them down and probably glue them in a fixed position. Nothing I can't handle but I really shouldn't have to. Definitely quality control issues with this model. I am half-tempted to ask GW for a replacement but I bought it from a splitter on eBay so I don't know where that leaves me on the replacement front. Orange Knight 1 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5938738 Share on other sites More sharing options...
Blindhamster Posted April 23, 2023 Share Posted April 23, 2023 Advice for the arms: trim the inside of the slot on the body, on an angle. Don’t do the arm and it’ll fit. mine too so long, but actually looks pretty decent sprayed and painting started Lemondish, Karhedron and Orange Knight 3 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5938796 Share on other sites More sharing options...
Orange Knight Posted April 24, 2023 Author Share Posted April 24, 2023 I ended up glueing the arms into place also. It ended up being an issue for the storage foam I had planned to use on the model but it couldn't be helped. I was short on patience by the time I got to the arms so I gave up on doing any more trimming or fitting lol. Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5938952 Share on other sites More sharing options...
JeffJedi Posted May 12, 2023 Share Posted May 12, 2023 Do we think the Desolation Squad will be 5 or 10 men in a box? Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5946877 Share on other sites More sharing options...
Marshal Reinhard Posted May 12, 2023 Share Posted May 12, 2023 10. Just like intercessors and hellblasters. Khornestar 1 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5946913 Share on other sites More sharing options...
Helias_Tancred Posted May 22, 2023 Share Posted May 22, 2023 The desolator kit needs more "open" hatch bits for the kraken missile launchers. Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5950030 Share on other sites More sharing options...
Marshal Reinhard Posted May 22, 2023 Share Posted May 22, 2023 16 hours ago, Eilio Tiberius said: The desolator kit needs more "open" hatch bits for the kraken missile launchers. Funny, here I was thinking they need more closed ones. Matching my marines facing with the facing of the top gadget.. Wanted to model my marines so that only forward facing ones have open hatches Sea Creature and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5950287 Share on other sites More sharing options...
Helias_Tancred Posted May 22, 2023 Share Posted May 22, 2023 My Brutalis built easily. I didn't have all those mondo mold lines either. Guess they had some bad batches? Sea Creature and Khornestar 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5950362 Share on other sites More sharing options...
Blindhamster Posted May 23, 2023 Share Posted May 23, 2023 Yeah I saw plenty of pictures of ones which looked absolutely fine Helias_Tancred and mel_danes 2 Back to top Link to comment https://bolterandchainsword.com/topic/377798-models-from-strike-force-agastus-positives-and-some-real-problems-first-impression/page/2/#findComment-5950553 Share on other sites More sharing options...
