Mithrilforge Posted May 3, 2023 Share Posted May 3, 2023 (edited) I guess if you don't have hardly any (Primaris) Space Marines in your collection then this would be ok?... price depending of course ..... If it's too dear then i guess I'd give it a wide berth... The latest Blind box marines are about $13.00 Aust , what's the expected price of these new ones?... if it's more than $20.00... i know where GW can stick them ... M. Edited May 3, 2023 by Mumeishi Khornestar and Vesalius 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943027 Share on other sites More sharing options...
JeffJedi Posted May 3, 2023 Share Posted May 3, 2023 Imagine if there was a Ork version that each came with a grot or squig extra. Tau or Eldar could be two per sprue. Any 25mm based model could be two on a sprue. Firedrake Cordova, skylerboodie, Mithrilforge and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943082 Share on other sites More sharing options...
frankendoodle65 Posted May 3, 2023 Share Posted May 3, 2023 Following the theme of the new edition box, could we get Tyranid heroes next? Maybe Genestealers would be a good fit, we know from spacehulk how cool and dynamic they can be. Or warriors, but they might be a bit big? Mithrilforge and Xenith 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943108 Share on other sites More sharing options...
Cactus Posted May 3, 2023 Share Posted May 3, 2023 I'll bet the next Warhammer Heroes are Stormcast. de Selby, LittlePlasticHomies, Blindhamster and 5 others 2 6 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943130 Share on other sites More sharing options...
Xenith Posted May 3, 2023 Share Posted May 3, 2023 Seems a bit uninspired - I mean, only the grenade chucker and the captain can't be made, or approximated from bits within the normal kits, right? Even the heads are pretty generic. Compare that to the Terminators or the Plague Marines. The intercessor base kits are already quite dynamic, so it doesn't even have that going for it in terms of altrnate poses like SMH 2 and 1/4. Like, even themost bog-standard loadout in SMH2 has a better pose than stock kits and unique headsculpt. Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943153 Share on other sites More sharing options...
Blindhamster Posted May 3, 2023 Share Posted May 3, 2023 The trouble with them is that the bar was higher for intercessors as the existing intercessors are generally better posed in the first place. that said, the grenade pose is unique, the reload is unique, even the aiming pose is different, albeit less so. the heads on them are unique too as are the adornments on the hips. It also feels a bit off to compare intercessors poses to terminators, one is veterans, the other is not. They’re comparable to the tactical, easily so. the heavy bolter marine has a heavy bolter, so fairly limited posing options. the eliminator is in a fairly standard sniper pose, but I’m not sure what would have been better? the captain is great, has a distinct appearance and pose from others, so that’s good. also, I agree with others, next will be stormcast, not more 40k Khornestar and jimbo1701 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943207 Share on other sites More sharing options...
Marshal Reinhard Posted May 3, 2023 Share Posted May 3, 2023 13 minutes ago, Blindhamster said: The trouble with them is that the bar was higher for intercessors as the existing intercessors are generally better posed in the first place. that said, the grenade pose is unique, the reload is unique, even the aiming pose is different, albeit less so. the heads on them are unique too as are the adornments on the hips. It also feels a bit off to compare intercessors poses to terminators, one is veterans, the other is not. They’re comparable to the tactical, easily so. the heavy bolter marine has a heavy bolter, so fairly limited posing options. the eliminator is in a fairly standard sniper pose, but I’m not sure what would have been better? the captain is great, has a distinct appearance and pose from others, so that’s good. also, I agree with others, next will be stormcast, not more 40k While I do agree with you I also feel they could and should have taken the opportunity to go wild with the poses. Bringing the heavy bolter to bare, maybe even reloading it, maybe a relocating pose for eliminator. Take the opportunity to do poses you really couldnt have done in the box Mithrilforge, Blindhamster and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943218 Share on other sites More sharing options...
Xenith Posted May 3, 2023 Share Posted May 3, 2023 26 minutes ago, Blindhamster said: It also feels a bit off to compare intercessors poses to terminators, one is veterans, the other is not. Don't see how that matters too much - as above, with the terms they went with poses and details not seen in the current box, while with these they largely went with things you can recreate from the box - I think there's a reloading marine in the intercessor box also? Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943227 Share on other sites More sharing options...
Blindhamster Posted May 3, 2023 Share Posted May 3, 2023 Different reloading pose, which doesn’t matter to some, but having more than one way to represent something is a good thing imo. The only pose that is probably identical is the aiming one, and looking at the tactical squad that was done, they have models that can be more or less perfectly recreated using assault squad and/or tactical squad bits Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943236 Share on other sites More sharing options...
Cleon Posted May 3, 2023 Share Posted May 3, 2023 I'm going to be a lone dissenting voice (and probably wrong), but I see these as staying 40K. AoS has underworlds and warcry which are continually pumping out these kind of character posed line troops and I don't think a 'Heroes' style range would appeal in the context (see for Stormcasts how many different Underworlds warbands they've had - what room is left for a Heroes range?). As for the removal of the 'Space Marine' tag, there are many places they could go - I wouldn't be massively surprised if the next range is Space Marines of some flavour anyway.... perhaps a Primaris DeathWatch Killteam - but if they finish the Eldar rework by then a set of cool more distinct alternate Exarchs for each aspect is where I'd go, if not then perhaps a set of Guard revisiting the old regiments (a Mordian, a Pretorian, a Valhallan etc.) or more Inquisition aides. Mithrilforge, Doctor Perils, DemonGSides and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943307 Share on other sites More sharing options...
davextreme Posted May 3, 2023 Share Posted May 3, 2023 On 5/2/2023 at 2:54 AM, MegaVolt87 said: Why is this a blind buy box ? Should be a regular KT, I actually like it. I would wager that the miniatures were designed first and then they decided to put rules with them. Like, they were always going to launch a series of Primaris blind buys and then said, "hey, what if you could do something with them?" Khornestar, ZeroWolf and Xanthous 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943348 Share on other sites More sharing options...
Wispy Posted May 3, 2023 Share Posted May 3, 2023 doing plain vanilla codex marines seems an utter waste of both Kill Team and Space Marine heroes. There's no character to these guys. I could make this Kill Team by pulling individual models out of my army. That's not exciting. If they're not aspiring to do something as characterful as Kill Team Cassius everytime they do Space Marine Heroes or Kill Team, it's all wasted effort, IMO. Castellan Wulfrik and Xanthous 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943352 Share on other sites More sharing options...
Doctor Perils Posted May 3, 2023 Share Posted May 3, 2023 2 hours ago, Cleon said: As for the removal of the 'Space Marine' tag, there are many places they could go - I wouldn't be massively surprised if the next range is Space Marines of some flavour anyway.... perhaps a Primaris DeathWatch Killteam - but if they finish the Eldar rework by then a set of cool more distinct alternate Exarchs for each aspect is where I'd go, if not then perhaps a set of Guard revisiting the old regiments (a Mordian, a Pretorian, a Valhallan etc.) or more Inquisition aides. Oh man, alternate exarchs as blind buys would be the death of me! Though I think it may be time for a stormcast version after these Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943360 Share on other sites More sharing options...
Marshal Reinhard Posted May 3, 2023 Share Posted May 3, 2023 8 hours ago, Xenith said: Seems a bit uninspired - I mean, only the grenade chucker and the captain can't be made, or approximated from bits within the normal kits, right? Even the heads are pretty generic. Compare that to the Terminators or the Plague Marines. The intercessor base kits are already quite dynamic, so it doesn't even have that going for it in terms of altrnate poses like SMH 2 and 1/4. Like, even themost bog-standard loadout in SMH2 has a better pose than stock kits and unique headsculpt. Ugh, arms way too high up on this one. Mithrilforge, Khornestar and blue_raptor55 3 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943367 Share on other sites More sharing options...
Noserenda Posted May 3, 2023 Share Posted May 3, 2023 Ill be interested to see how this plays v the existing intercessor KT seeing as its bigger, has bigger guns and a captain on board... Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943426 Share on other sites More sharing options...
TheMawr Posted May 4, 2023 Share Posted May 4, 2023 (edited) 8 hours ago, Cleon said: I'm going to be a lone dissenting voice (and probably wrong), but I see these as staying 40K. AoS has underworlds and warcry which are continually pumping out these kind of character posed line troops and I don't think a 'Heroes' style range would appeal in the context (see for Stormcasts how many different Underworlds warbands they've had - what room is left for a Heroes range?). Considering the new logo even has the Age of Sigmar twintailed comet mostly associated with stormcast currently ( the O is made of a hammer, a eagle and the twin tailed comet.) Id say you are probably wrong ;) (sadly) to add I think eldar are least likely to appear here, they are among those ( the only ones ?) to not appear among the collectible toy lineups, nor the MtG set, despite both having quite a huge representation of other armies. And these blindbuys are meant to appeal to the same audience. Edited May 4, 2023 by TheMawr painting.for.my.sanity 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943455 Share on other sites More sharing options...
Blindhamster Posted May 4, 2023 Share Posted May 4, 2023 11 hours ago, Noserenda said: Ill be interested to see how this plays v the existing intercessor KT seeing as its bigger, has bigger guns and a captain on board... I'm betting the gravis guy and the captain will both quite severely limit what else you can take in any given game Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5943552 Share on other sites More sharing options...
Kastor Krieg Posted May 7, 2023 Share Posted May 7, 2023 On 5/3/2023 at 9:23 PM, Marshal Reinhard said: Ugh, arms way too high up on this one. Terminators hunch forward a bit, it's not "way too high". Khornestar, Marshal Reinhard, Blindhamster and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5944739 Share on other sites More sharing options...
phandaal Posted May 7, 2023 Share Posted May 7, 2023 On 5/3/2023 at 2:23 PM, Marshal Reinhard said: Ugh, arms way too high up on this one. The SM Heroes Terminators are an improvement over older Terminator kits, but still have some of the older kits' issues. Main thing though, they are an improvement over the existing kits (until Leviathan comes out of course). Same with the SM Heroes Tactical Marines. This latest kit is just slightly different poses of existing models. Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5944777 Share on other sites More sharing options...
Marshal Reinhard Posted May 7, 2023 Share Posted May 7, 2023 (edited) 3 hours ago, phandaal said: The SM Heroes Terminators are an improvement over older Terminator kits, but still have some of the older kits' issues. Main thing though, they are an improvement over the existing kits (until Leviathan comes out of course). Same with the SM Heroes Tactical Marines. This latest kit is just slightly different poses of existing models. The improvements you speak of is because existing kits they're emulating are wrought with proportion issues not present in primaris. This series has nothing to fix in that regard. If the 2012 tactical kit had the same proportions as SM Heroes 1, "This latest kit is just slightly different poses of existing models." would pretty much have applied perfectly to them too: Edited May 7, 2023 by Marshal Reinhard Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5944811 Share on other sites More sharing options...
phandaal Posted May 8, 2023 Share Posted May 8, 2023 9 hours ago, Marshal Reinhard said: The improvements you speak of is because existing kits they're emulating are wrought with proportion issues not present in primaris. This series has nothing to fix in that regard. If the 2012 tactical kit had the same proportions as SM Heroes 1, "This latest kit is just slightly different poses of existing models." would pretty much have applied perfectly to them too: Yes. People had an extra incentive to buy the other Space Marine Heroes kits, because of those proportion issues. The fact that this latest series has nothing to fix with regards to the proportions means, ironically, that there is less incentive for people to get it. Marshal Reinhard 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5944909 Share on other sites More sharing options...
Blindhamster Posted May 8, 2023 Share Posted May 8, 2023 Yeah I think that’s fair, for me I’ll get them for the pose diversity, because contrary to what some have said, most of them are still unique poses WrathOfTheLion and DemonGSides 2 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5944949 Share on other sites More sharing options...
Marshal Reinhard Posted May 8, 2023 Share Posted May 8, 2023 12 hours ago, phandaal said: Yes. People had an extra incentive to buy the other Space Marine Heroes kits, because of those proportion issues. The fact that this latest series has nothing to fix with regards to the proportions means, ironically, that there is less incentive for people to get it. A good case of respectfully disagreeing. I know in my own case that having a squad thats proportioned differently than the rest would actually be a detriment. It's one of the reason i would never mix classic and primaris marines. Ill be the first to concede that this is not the case for everyone, im just saying it being scaled differently made it less interesting for some, those like myself in this regard. phandaal 1 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5945069 Share on other sites More sharing options...
Halandaar Posted July 3, 2023 Share Posted July 3, 2023 Something different from usual is obviously going on with how this product is releasing, as in addition to them already listed by various eBay vendors they are also now up for preorder on actual legit store Alchemists Workshop with a stated shipping date of September. Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-5968139 Share on other sites More sharing options...
Halandaar Posted November 10, 2023 Share Posted November 10, 2023 If anybody still after these, Dark Sphere has marked them down to £31.80 for the whole set for Black Friday. https://www.darksphere.co.uk/p.php?p=147747&fbclid=IwAR1MWgOsnh-2TH3oAK5pMHA3FtduuIG7IB26Jrf5A6i26zZyCXHqwuA48QQ Toxichobbit, Brother Dallo, firestorm40k and 4 others 3 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/378505-strike-force-justian-space-marine-heroes-kill-team/page/3/#findComment-6001448 Share on other sites More sharing options...
