TrawlingCleaner Posted June 1, 2023 Share Posted June 1, 2023 Greetings Archons, Succbui and Fleshsmiths! @Grotsmasha and @Triszin are putting on a Forum wide event from the 1st July (1 month from now) until 30th September to celebrate 10th Edition's release! The forum is split up into 3 Strongholds: Imperium, Chaos and Xenos with all 3 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the WIP Section which I will link once it's live. We can use thread to cross post in and track/give motivation to those participating. Check out the full rules here If you've got any questions, give one of the Mods a shout! Grotsmasha and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/ Share on other sites More sharing options...
Chainsword Cookie Posted July 3, 2023 Share Posted July 3, 2023 Here is the first model I have painted for the challenge. It has been years since I have painted. I have followed the Hand of the Archon, Kabalite Archsybarite tutorial by GW. I am not that convinced on the scheme. What say you? Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5967975 Share on other sites More sharing options...
The Yncarne Posted July 3, 2023 Share Posted July 3, 2023 I am not familiar with that tutorial. My main criticisms are around the color. I feel it needs an alternative color block. The weapon is muted and good color choices but with that dark blue they probably get lost on the tabletop. Consider the helm in a different color. Maybe make the tiny tube really bright like a pink or yellow. Also a semi-finished base might help inform the choices. I've been experimenting with making limbs different colors on my drukhari and corsairs to give some visual interest. Hope this helps. Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5968009 Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Share Posted July 4, 2023 It's a Raider/Reaper crew yeah? I think as long as it stands out from the colour scheme of the Vehicle itself it will be fine. Considering you've said it's you're first model in years, clearly your skills are still present. In regards to the colour scheme in general, what is it that gives you pause? Are the colours a little off from the tutorial, or you aren't sure about the scheme in general? Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5968274 Share on other sites More sharing options...
Chainsword Cookie Posted July 4, 2023 Share Posted July 4, 2023 I think I am not settled on the scheme. I have basecoated some spare models so I will try my hand at a red and a purple color scheme. Overall I don't want to paint a named kabal. I am not much into the blue scheme. I really like the old blue warriors from the cover art of the first codex but I have to see how it works out on a model. In terms of contrast I am considering to paint the weapon casings white as the ones from the Corsairs Voidreavers from GW. I have time to test a few more models. I will come back with some more pictures this week. Grotsmasha, TrawlingCleaner and The Yncarne 3 Back to top Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5968538 Share on other sites More sharing options...
TrawlingCleaner Posted July 5, 2023 Author Share Posted July 5, 2023 Was it these ones you were modelling the scheme after? If so, I think you did a fantastic job! Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5968722 Share on other sites More sharing options...
Chainsword Cookie Posted July 5, 2023 Share Posted July 5, 2023 Indeed, I have tried to replicate the look of the Hand of the Archon Kill Team. Here is the second test model. I went for a purple scheme. TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5968951 Share on other sites More sharing options...
TrawlingCleaner Posted July 6, 2023 Author Share Posted July 6, 2023 How're you feeling about this one? It's a fantastic colour IMO! Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5969280 Share on other sites More sharing options...
Chainsword Cookie Posted July 6, 2023 Share Posted July 6, 2023 I find the purple scheme better, but it gets lost on the smaller models. I have painted a third scheme. So far purple is what I think I will go for but maybe the purple should be more pinkish. Here is a yellow one. Link to comment https://bolterandchainsword.com/topic/378811-event-call-to-arms-drukhari/#findComment-5969372 Share on other sites More sharing options...
