Grotsmasha Posted June 22, 2023 Share Posted June 22, 2023 (edited) The B&C Presents: The Call to Arms 2023 CHAOS STRONGHOLD What better way to celebrate a new edition of our favourite table-top wargame than to have a big Inter-Forum Painting Event, amiright? Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!! What is The Call to Arms, I hear you ask? The Call to Arms is a new multi-forum event designed to celebrate the coming of Warhammer 40,000's new, 10th Edition, and encourage us all to start a new army, or bring our current armies into the new edition. The Forums of the B&C are divided up into three Strongholds; The Imperium Stronghold Adepta Sororitas Adeptus Astartes Adeptus Mechanicus Astra Militarum Imperial Knights Talons of the Emperor The Imperium of Mankind Age of Darkness Loyalists The Chaos Stronghold Chaos Daemons Chaos Knights Heretic Astartes The Realms of Chaos Age of Darkness Traitors The Xenos Stronghold Aeldari Drukhari Genestealer Cults Leagues of Votann Necrons Orks T'au Empire Tyranids These three Strongholds will act as the hub for each of the three main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the two other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the three Strongholds will face off, and overall winners will be declared. Start Date: End Date: So, how is it all going to work? As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all three Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds. Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models from the Other Games Forum (Aeronautica, Titanicus, Necromunda etc), these models / units may be pledged to any Stronghold. You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow. Once recorded, Vows may not be altered, however special considerations may be made upon request. There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted. In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed. How do I join in? Each model has a point value based upon it's size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below, 1pt Infantry 2pts Cavalry/Bikers/Heavy Weapons Teams 3pts Walkers (Dreadnaughts, Sentinals) 4pts Skimmers / Light Vehicles (Landspeeders, ATV, Armigers) 5pts Small Tanks (Leman Russ, Rhino Variants) 6pts Large Tanks (Rogal Dorn, Sicaran, Land Raider) 8pts Superheavies (Baneblades etc) 10pts Imperial Knight etc 5pts Leader and Unit Composition: 1 OR Epic Hero 10pts Primarchs NOTE: Characters with Retinue, I.E. Saint Celestine. Celestine is the EPIC HERO, and is worth 5pts, her two Sister Superiors are Seraphim, which are worth 1pt each. 20pts Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to only one FORUM. Please make your vows in this thread in the following format; "I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of {insert Forum} and the Imperium Stronghold on or before30th September, 2023 or bear the badge of failure until years end." example; I, Grotsmasha, heed the Call to Arms and pledge to paint 20 Bloodletters, 5 Raptors, 1 Terminator Lord, and 1 Helbrute for 29pts for the Glory of the Chaos Daemons and Chaos Stronghold on or before September 2023, or bear the badge of failure until year's end." The post that contains your Vow must include starting pictures that contain all the models from the Vow. Starting models may be in any of the following conditions; In the box On the Sprue Assembled Single Colour Primed For Tanks / Titans, Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour. Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so. Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation. Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow, please post these within Spoiler / Hidden tags. Once you have made your vow, pop this badge of Participation into your Signature, Will there be any awards? Yes!! There will be similar Badges and Achievements available from all 3 Strongholds, Event Failed: Spawn 10 points: Servant of Chaos25 points Chosen of Chaos45 points: Aspiring Champion75 points: Champion of Chaos 100+ points: Warmaster of Chaos Artificer - Top 1, 2, or 3 best painted models from each Forum, chosen by the Moderators. Princeps - Awarded to all completed Titans Chaos Champion - Awarded to the Frater who individually paints the most points worth of models in the Chaos Stronghold Champions of the Horde - The Chaos Forum with the highest overall points worth of models Champion of the Call - The Chaos Forum that has the Highest Participation vs. Completion Percentage. As to the overall competition between the Strongholds, there will also be Badges awarded for the following; Masters of the Horde - The Stronghold that completes the highest overall points worth of models. Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage. Master Artificer - Voted best painted Model, chosen from the 3 Stronghold Artificers. In addition to the Badges and Achievements above, Triszin has provided / organised some Sponsored Physical Prizes, which will awarded in the following categories; Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so within their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool.. 1 Combat Patrol Box (1 Prize across all three Strongholds) Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so within their Vows. 1 Leviathan Starter Box (1 Prize across all three Strongholds) Stronghold Artificer - Best Painted Model 1 Character Model Blister/Clam (3 Prizes total, 1 Prize per Stronghold, chosen by Frater Poll) Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds 1 Character Model Blister/Clam (1 Prize across all three Strongholds) That's it, you've done it, you've made it to the end!!! If you have any questions or queries, just @Grotsmasha or @Triszin and we'll be more than happy to help you out, now, go on, get, don't you have models to be painting? F.A.Q.s Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians? A- Yes, this is acceptable. Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos? A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum. Q- Are 3D prints allowed? A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent. Edited June 26, 2023 by Grotsmasha Darnok 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/ Share on other sites More sharing options...
Grotsmasha Posted June 22, 2023 Author Share Posted June 22, 2023 (edited) PARTICIPANTS Chaos Daemons - Pledged: 000pts / Complete: 000pts / Secured: 000pts Participants: 0 Chaos Knights - Pledged: 66pts / Complete: 66pts / Secured: 66/66pts (100%) Participants: 1 Boc - Vow 1: 24pts - Complete - Group | Vow 2: 42pts - Complete | Spoiler 1x Knight Tyrant, 1x Knight Rampager, 1x War Dog Karnivore Spoiler 10 Cultists( 10) 32 Accursed Cultists (32) Heretic Astartes - Pledged: 559pts / Complete: 528pts / Secured: 528/559pts (94%) Participants: 18 Brother Argent - Vow 1: 10pts - Not Completed | Spoiler 1 Warpsmith (5pts) 1 Maulerfiend (5pts) Brother Captain Arkley - Job's a Big'Un: 10pts - Complete | Vow 1: 6pts - Complete | Vow 2: - 3pts - Complete | Vow 3: 5pts - Complete Spoiler Jobs a Big'Un / Master of the Forge - Daemon Primarch Perturabo (10pts) Spoiler 3 LI Fellblades Spoiler 3 LI Predators Spoiler Azrakh the Annihilator Cactus - Vow 1: 5pts - Complete | Spoiler BSF Obsidious Mallex (5pts) Celtic_cauldron - Vow 1: 11pts- Complete | Job's a Big'Un: 20pts - Complete | Spoiler 5 Terminators (5) 1 Spartan (6) Job's a Big'un: Mortarion (10) Job's a Big'un: Abaddon (10) Cpt.Danjou - Vow 1: 1pt - Complete | Vow 2: 9pts - Complete | Vow 3: 12pts - Complete | Spoiler 1 Terminator (1) Spoiler 4 Chaos Terminators (4pts) 1 Master of execution (5pts) Spoiler 10 Horrors (10) 1 Seeker of Slaneesh (2) crimsondave - Vow 1: 31pts - Complete | Vow 2: 88pts - Complete | Vow 3: 39pts - Complete | Spoiler 10 Terminators, (10) 3 Rhino Chassis tanks, (15) 1 Spartan Super-heavy tank (6) Spoiler 1 Iron Warriors Terminator Lord, (5) 1 Black Legion Chaos Lord, (5) 1 Black Legion Aspiring Champion (Terminator Sorcerer substituted), (5) 1 Iron Warriors Leviathan Dreadnought, (3) 1 Iron Warriors Predator, (5) 1 Iron Warriors Vindicator, (5) 30 Black Legion Legionaires, (30) 20 Cultists (20) Job's a Big'un - Abaddon, (10) Spoiler 4 Black Legion Rhinos 1 Black Legion Helbrute 1 Black Legion Demon Prince 1 Iron Warriors Chaos Lord 1 Fabius Bile, 1 Acolyte Dr_Ruminahui - Vow 1: 30pts - Completed | Spoiler 1x chaos lord 1x master of possession 1x necromunda fuel tanks 6x possessed Master of the Forge - Lucius Dwango - Vow 1: 31pts - Complete | Vow 2: 5pts - Complete | Spoiler Magos on Abeyant (5) 1 Magos (5) 3 Myrmidon Secutors (6) 3 Thallax (6) 3 Castellax (9) Spoiler Azrakh the Annhilator (5) gaurdian31 - Vow 1: 25pts - Complete | Vow 2: 15pts - Complete | Spoiler 10 CSM 1 Hell Brute 5 Havocs 1 Dark Apostle and 2 Dark Disciples Spoiler Master of Possession (5) Chaos Lord (5) Sorcerer (5) Legoman - Vow 1: 32pts - Complete | Spoiler Chaos Lord (5) Dark Apostle (5) 14 Cultists (14) 5 Havocs (5) Venomcrawler (3) Metzombie - Vow 1: 11pts - Complete | Vow 2: 11pts - Complete | Spoiler 3 Deathshroud Terminators (3) 8 Plaguemarines (8) Spoiler Master of the Forge, Job's a Big'Un - Patient Zero (Spartan + Plague Furnace) (11) Muskie - Vow 1: 12pts - Completed | Spoiler 1 spawn, 1 plague surgeon, 1 stand of Nurglings, 1 objective (terrain) 2 plague marines Plaguecaster - Vow 1: 11pts - Complete - Complete | Spoiler Rottigus (5) 1 Predator (6) Sitnam - Vow 1: 10pts - Complete - Complete | Vow 2: 14pts - Complete | Job's a Big'Un: 10pts - Complete | Group Spoiler Master of the Forge: 1 x Lord Discordant 5 x Scarab Occult Terminators Spoiler 9 Beastmen (9) 1 Fateskimmer (5) Spoiler Job's a Big'Un: Counts as Lord of Change spiros14 - Vow 1: 20pts - Complete - Complete - Complete - Complete | Vow 2: 7pts - Complete | Spoiler 4 Legionnaires, (4) 3 Havocs, (3) 1 Predator, (5) 4 Gallowdark walls (8) Spoiler 7 Cultists (7) Stef Coudou - Out of Competion Vow - Completed | Spoiler 7 Rubric Marines 1 Sorcerer 2 Plague Marines 1 Poxwalker 1 Deathshroud Terminator Tallarn Commander - Vow 1: 5pt - Complete | Vow 2: 15pts - Complete | Vow 3: 19pts - Complete | Spoiler 1 Mind Witch (5) Spoiler 2 Chosen Decimus, Taloghast (10) Spoiler 10 Legionaries, (10) 1 Eightbound, (5) 4 Traitor Guard/Chaos Renegades/Heretics Militia (4) Teetengee - Vow 1: 5pts - Complete | Spoiler Master of the Forge - 1 Lord on Juggernaught Valkia the Bloody - Vow 1: 21pts - Not Completed | Spoiler 10 Khorne cultists, (10) Deimos Pattern Rhino, (5) 3 Gallowdark Walls, (6) The Realms of Chaos - Pledged: 20pts / Complete: 20pts / Secured: 20pts (100%) Participants: 1 renegadeguard - Vow 1: 5pts - Complete | Vow 2: 10pts - Complete | Vow 3: 5pts - Complete | Spoiler 1 Leman Russ (5) Spoiler 10 Mutant Guard (10) Spoiler 1 Primaris Psyker (5) Age of Darkness Traitors - Pledged: 12pts / Complete: 12pts / Secured: 12pts (100%) Participants: 1 Trixie - Vow 1: 12pts - Complete | Spoiler 6x Legionary Skyhunters (12) Edited October 4, 2023 by Grotsmasha Muskie 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5963882 Share on other sites More sharing options...
Grotsmasha Posted June 23, 2023 Author Share Posted June 23, 2023 * NOTE: THIS THREAD WILL BE UNLOCKED AND OPEN FOR VOWS JULY 1ST * Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5964531 Share on other sites More sharing options...
Boc Posted July 1, 2023 Share Posted July 1, 2023 (edited) I, Boc, heed the Call to Arms and pledge to paint 1x Knight Tyrant, 1x Knight Lancer, and 1x war dog karnivore for 24 points for the Glory of Chaos and the Chaos Stronghold on or before 30th September, 2023 or bear the badge of failure until years end. Knight Lancer will be delivered tomorrow War Dog Knight Tyrant Lancer Edited July 19, 2023 by Boc Switched Lancer for Rampager TrawlingCleaner, Dr_Ruminahui, crimsondave and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967010 Share on other sites More sharing options...
Brother Argent Posted July 1, 2023 Share Posted July 1, 2023 I, Brother Argent, Master of the Lost (Thought Process), Shepherd of the Damned and Unofficial Dark Apostle of the Liber, heed the Call to Arms and pledge to paint: - Warpsmith x1 (5pts) -Maulerfiend x1 (5pts) for 10 pts for the Glory of Heretic Astartes and the Chaos Stronghold on or before 30th September, 2023 or bear the badge of failure until years end I know. Not much compared to the others but I think I will be fairly busy as it is... Also, nawww.... I wasn't able to be first across all three strongholds.... Rusted Boltgun, Grotsmasha, sitnam and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967020 Share on other sites More sharing options...
Teetengee Posted July 1, 2023 Share Posted July 1, 2023 (edited) Noises, echoes of some long lost time, where the sleeping are as still as the dead. But there is movement here, and life still. Something stirs, awakens to the beating of the war drums. Awakens to the clarion call. The blood stirs and blood will be spilt! Upon a scarlet steed, breath steaming in the cold mists of time, and stampeding forward to call out the hounds of war, drawn forth from the warp the forsworn, the forsaken, the forgotten, they come. Arise, arise, warriors of Chaos! Fell deeds awake: fire and slaughter! Spear shall be shaken, shield be splintered, a sword-day, a red day, ere the galaxy burns! March now, march now! March to Terra!I, Teetengee, heed the Call to Arms and pledge to paint 1 dude on a juggernaut for 2pts(?)5 pts for the Glory of the Heretic Astartes and Chaos Stronghold on or before September 2023, or bear the badge of failure until year's end. This is a Master of the Forge entry Edited July 7, 2023 by Teetengee master of the forge Lord Raven 19, gaurdian31, Trokair and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967021 Share on other sites More sharing options...
Muskie Posted July 1, 2023 Share Posted July 1, 2023 I, Muskie, heed the Call to Arms and pledge to paint one spawn, one plague surgeon, one stand of Nurglings, one objective (terrain) and two plague marines for 12 pts for the Glory of Heretic Astartes and the Chaos Stronghold on or before 30th September, 2023 or bear the badge of failure until years end. Tallarn Commander, gaurdian31, TrawlingCleaner and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967304 Share on other sites More sharing options...
Dr_Ruminahui Posted July 1, 2023 Share Posted July 1, 2023 (edited) I, Dr_Ruminahui, heed the Call to Arms and pledge to paint: 1x chaos lord 1x master of possession] 1x Lucius 1x necromunda fuel tanks and 12x possessed for 30 points for the Glory of Chaos and the Chaos Stronghold on or before30th September, 2023 or bear the badge of failure until years end. Just noticed that I need to declare for entering the running for Master or the Forge. I would like to enter with Lucius and my second squad of possessed (the ones on the left) as seperate entries, or if that doesn't work, just Lucius. Edited July 5, 2023 by Dr_Ruminahui gaurdian31, Tallarn Commander, TrawlingCleaner and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967330 Share on other sites More sharing options...
sitnam Posted July 1, 2023 Share Posted July 1, 2023 I, Sitnam, pledge to the changer of ways: 1 x Lord Discordant 5 x Scarab Occult Terminators For a total of 15 points TrawlingCleaner, crimsondave, Boc and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967375 Share on other sites More sharing options...
Dr_Ruminahui Posted July 1, 2023 Share Posted July 1, 2023 17 hours ago, Teetengee said: Noises, echoes of some long lost time, where the sleeping are as still as the dead. But there is movement here, and life still. Something stirs, awakens to the beating of the war drums. Awakens to the clarion call. The blood stirs and blood will be spilt! Upon a scarlet steed, breath steaming in the cold mists of time, and stampeding forward to call out the hounds of war, drawn forth from the warp the forsworn, the forsaken, the forgotten, they come. Arise, arise, warriors of Chaos! Fell deeds awake: fire and slaughter! Spear shall be shaken, shield be splintered, a sword-day, a red day, ere the galaxy burns! March now, march now! March to Terra!I, Teetengee, heed the Call to Arms and pledge to paint 1 dude on a juggernaut for 2pts(?) for the Glory of the Heretic Astartes and Chaos Stronghold on or before September 2023, or bear the badge of failure until year's end." As a character, I think he should be 5 points - otherwise, 2 points would have been correct. Boc and gaurdian31 2 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967405 Share on other sites More sharing options...
Teetengee Posted July 2, 2023 Share Posted July 2, 2023 7 hours ago, Dr_Ruminahui said: As a character, I think he should be 5 points - otherwise, 2 points would have been correct. I'll take more if worth more, but I'm not terribly fussed either way. @Grotsmasha? (I've not bought the rulebooks since.....the transition to 8th because I've not had the time to play, so I don't really know what things are called anymore) gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967495 Share on other sites More sharing options...
gaurdian31 Posted July 3, 2023 Share Posted July 3, 2023 (edited) I, gaurdian31}, heed the Call to Arms and pledge to paint the Chaos Combat Patrol of 10 CSM, 1 Hell Brute, 5 Havocs and the Dark Apostle with 2 Dark Disciples for 25pts. for the Glory of Heretic Astartes and the CHAOS Stronghold on or before 30th September, 2023 or bear the badge of failure until years end. 10 CSM 1 Hell Brute 5 Havos 1 Dark Apostle and 2 Dark Disciples Total of 25 pts I believe, 23 if the Dark Disciples don't count. Spoiler Edited July 3, 2023 by gaurdian31 sitnam, TrawlingCleaner, Dr_Ruminahui and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5967961 Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Author Share Posted July 4, 2023 On 7/2/2023 at 2:32 PM, Teetengee said: I'll take more if worth more, but I'm not terribly fussed either way. @Grotsmasha? (I've not bought the rulebooks since.....the transition to 8th because I've not had the time to play, so I don't really know what things are called anymore) I'd have it at 5pts gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968179 Share on other sites More sharing options...
Dr_Ruminahui Posted July 4, 2023 Share Posted July 4, 2023 12 hours ago, gaurdian31 said: Total of 25 pts I believe, 23 if the Dark Disciples don't count. I think 25 is right, as my understanding is that the disciples do count - but check with @Grotsmasha to be sure. gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968196 Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Author Share Posted July 4, 2023 @gaurdian31 25pts gaurdian31 and Teetengee 2 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968198 Share on other sites More sharing options...
Teetengee Posted July 4, 2023 Share Posted July 4, 2023 2 hours ago, Grotsmasha said: I'd have it at 5pts ok, I will edit gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968215 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 * UPDATED TO THIS POINT * gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968642 Share on other sites More sharing options...
Cactus Posted July 5, 2023 Share Posted July 5, 2023 I, Cactus, heed the Call to Arms and pledge to paint Obsidius Mallex, Lord of the Servants of the Abyss, for 5 points for the Glory of the Heretic Astartes and the Chaos Stronghold on or before 30th September 2023 or bear the badge of failure until years end. WrathOfTheLion, gaurdian31, Tallarn Commander and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5968705 Share on other sites More sharing options...
legoman Posted July 6, 2023 Share Posted July 6, 2023 (edited) I Legoman, heed the call to arms and pledge to paint the following for the glory of the Dark Gods: Chaos lord 5Dark apostle 514 cultists 145 havocs 5Venomcrawler 3Total 32 If I fail may my soul be consumed by the fell denizens of the warp. Edited July 6, 2023 by legoman Sp TrawlingCleaner, Firedrake Cordova, WrathOfTheLion and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969391 Share on other sites More sharing options...
Teetengee Posted July 6, 2023 Share Posted July 6, 2023 I also didn't see the details regarding master of the forge. Is it too late to throw my hat in, @Grotsmasha? gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969414 Share on other sites More sharing options...
Grotsmasha Posted July 7, 2023 Author Share Posted July 7, 2023 4 hours ago, Teetengee said: I also didn't see the details regarding master of the forge. Is it too late to throw my hat in, @Grotsmasha? Not at all, added above gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969451 Share on other sites More sharing options...
sitnam Posted July 7, 2023 Share Posted July 7, 2023 (edited) WIP update. Basing for last, I got the sorc done and am steadily working on the dusty boys. Spoiler I'd also like to put in for Master of the Forge. This pledge has my Lord Discordant that I tzeentched up, but my next will have something else. how many entires can we put foward for MotF? Edited July 7, 2023 by sitnam Firedrake Cordova and gaurdian31 2 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969693 Share on other sites More sharing options...
Grotsmasha Posted July 8, 2023 Author Share Posted July 8, 2023 14 hours ago, sitnam said: WIP update. Basing for last, I got the sorc done and am steadily working on the dusty boys. Hide contents I'd also like to put in for Master of the Forge. This pledge has my Lord Discordant that I tzeentched up, but my next will have something else. how many entires can we put foward for MotF? So submitted, I'll update gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969850 Share on other sites More sharing options...
Cpt.Danjou Posted July 8, 2023 Share Posted July 8, 2023 I, Cpt.Danjou, heed the Call to Arms and pledge to paint a Chaos Terminator for 1 pts for the Glory of the Heretic Astartes and the Chaos Stronghold and the Imperium Stronghold on or before30th September, 2023 or bear the badge of failure until years end. Grotsmasha, TrawlingCleaner and gaurdian31 3 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969979 Share on other sites More sharing options...
Dr_Ruminahui Posted July 8, 2023 Share Posted July 8, 2023 (edited) Great to see everybody who has made a vow! @Boc - 3 knights! Can't wait to see what you are going to do to them! @Brother Argent - A warpsmith and a maulerfiend seem like a good combo. Looking forward to seeing what options you give them. @Teetengee - A converted juggerlord, looking forward to seeing what you do. Though, I note that by seeking the Master of the Forge, while still my ally you've also made yourself my competitor - which requires an appropriate response (see below). @Muskie - A real mixed bag of models you are doing up, but all of them nurgly! Look forward to seeing them and the names you give them. @sitnam - Good to seeing some dusty boys showing up to fight! Look forward to seeing how they and your discolord turn out and what conversions you are making to it. I note that you too are my competitor for Master of the Forge. @gaurdian31 - A patrol box is a great way to start things off! @Cactus - A hammerlord! A number of those in the running this event - I look forward to seeing how yours turns out. @legoman - You're top chaos dog at the moment, with a bid of 32 points, edging out my own 30. You are also a competitor @Cpt.Danjou - A small bid of a single termie to start, but that's one point more than we would have otherwise! Better to bid what you know you can complete rather than to fly to close to the sun - thoug the latter is far more characterful for a follower of chaos. I look forward to seeing all your vows progress - be sure to share photos! For all my competitors (currently Teegengee, sitname and legoman), I note that as a chaos player I'm contractually obligated to try to sabotage you now that we are competing for the same prize(s). For each of you, my prayers to Slannesh have started - so if you are distracted by a sexy new girl and/or boyfriend, or by the best and/or most sex you've ever had, you know who to blame. Painted the first 3 of my possessed - really happy with them. 3 in one week is really quick for me - it did help that last weekend was a long weekend due to Canada day. No conversions on these guys other than for the backback swap for the guy on the left. Edited July 9, 2023 by Dr_Ruminahui sitnam, Grotsmasha, madlibrarian and 5 others 4 4 Back to top Link to comment https://bolterandchainsword.com/topic/379216-call-to-arms-chaos-stronghold/#findComment-5969996 Share on other sites More sharing options...
