apologist Posted July 21, 2023 Share Posted July 21, 2023 The combination of contrast paints and no round base insert on the infantry is going to be a game-changer for this era of Epic. The former will make painting infantry to game-ready standard a doddle, and the latter means that the bases can be done separately, and the models then glued on. SalamandersBro, Marshal Rohr, DuskRaider and 2 others 5 Back to top Link to comment Share on other sites More sharing options...
Colman Posted July 21, 2023 Share Posted July 21, 2023 55 minutes ago, Redcomet said: Contrast paints will be excellent for these small minis. I an probably doing blood angels, as I had thosw way back when. A white undercoat and then Blood Angels red contrast, maybe a light orange drybrush after. I'm on a surprisingly long (to me) Imperial Fist streak at the moment, so it'll be lots of tiny yellow troops courtesy of Imperial Fist Yellow and a quick shade of thinned Agrax Earthshade or equivalent. Interrogator Stobz, ZeroWolf, Redcomet and 1 other 2 2 Back to top Link to comment Share on other sites More sharing options...
Captain Idaho Posted July 21, 2023 Share Posted July 21, 2023 It's possible some of the vehicles could potentially have transfers but I think overall we'll probably be missing the insignia of the Legions. I'll definitely avoid the Agemo sigil on my infantry I think. ZeroWolf 1 Back to top Link to comment Share on other sites More sharing options...
Marshal Rohr Posted July 21, 2023 Share Posted July 21, 2023 (edited) 33 minutes ago, apologist said: The combination of contrast paints and no round base insert on the infantry is going to be a game-changer for this era of Epic. The former will make painting infantry to game-ready standard a doddle, and the latter means that the bases can be done separately, and the models then glued on. Where is your sense of needlessly making things harder for yourself by gluing them all really closely together on the round base and painting them together! Edited July 21, 2023 by Marshal Rohr apologist, Colman, Rik Lightstar and 3 others 6 Back to top Link to comment Share on other sites More sharing options...
Noserenda Posted July 21, 2023 Share Posted July 21, 2023 Strip bases FTW :D Link to comment Share on other sites More sharing options...
apologist Posted July 21, 2023 Share Posted July 21, 2023 29 minutes ago, Marshal Rohr said: Where is your sense of needlessly making things harder for yourself by gluing them all really closely together on the round base and painting them together! *Sob* :D Doctor Perils, ZeroWolf, batu and 7 others 1 1 8 Back to top Link to comment Share on other sites More sharing options...
Valkyrion Posted July 21, 2023 Share Posted July 21, 2023 You could use small denomination coins as bases. 1p, 2p, and 10p depending on size, spray white or gold with a thin wash and you have ornate bases with the queens head on it. (or the reverse if you're not a royalist!) apologist 1 Back to top Link to comment Share on other sites More sharing options...
BolterZorro Posted July 21, 2023 Share Posted July 21, 2023 1 hour ago, apologist said: The combination of contrast paints and no round base insert on the infantry is going to be a game-changer for this era of Epic. The former will make painting infantry to game-ready standard a doddle, and the latter means that the bases can be done separately, and the models then glued on. Where have you seen "no round base insert"? I'd be the first one to applaude if it where the case!!! Because I'd like all my tiny minis on a transparent base! Link to comment Share on other sites More sharing options...
apologist Posted July 21, 2023 Share Posted July 21, 2023 (edited) That's exactly what I do – and as well as being cheaper than most alternatives, it also serves a practical purpose of giving the stand some heft to withstand accidental knocks on the table. You can add PVA to add texture, or (my recommendation) use this stuff: Sand Texture Gel (from Winsor & Newton's Galeria range of acrylic mediums). It's the business for quickly adding texture. You just smear a thin layer over the surface and leave it to dry, leaving a subtly textured finish. It's a nice texture that works well for Epic scale (i.e. it doesn't look like your figures are clambering around a field of boulders), sticks well to pretty much any surface from metal to wood to plastic. You can also apply it more thickly and embed larger rocks/details in it. Once dried, it takes paint well, too; the texture picking up nicely through drybrushing. + Sand Texture Gel + + PVA and sand (left); moulded base from the E:A edition Eldar Court of the Young King (right)+ [+REDACTED+] Edited July 21, 2023 by apologist Crimson Longinus, Urauloth, Starlight_Wolf and 5 others 6 1 1 Back to top Link to comment Share on other sites More sharing options...
apologist Posted July 21, 2023 Share Posted July 21, 2023 7 minutes ago, BolterZorro said: Where have you seen "no round base insert"? I'd be the first one to applaude if it where the case!!! Because I'd like all my tiny minis on a transparent base! This is an informed guess, to be honest – but if you look at the feet of the new models you'll see an integrated 'pill/rock' between their legs, rather than underneath them: I'm also pretty confident that the bases are universal – that is, that there's no distinction between those for the infantry and the support stuff. Note that there are no recesses in the bases to take the old-style round base inserts. Link to comment Share on other sites More sharing options...
Rik Lightstar Posted July 21, 2023 Share Posted July 21, 2023 It's something of a shame they went for the city-fight style bases because the "pill" between the feet of infantry is pretty noticeable on those, if they'd gone for a flat base with some kind of texture it'd be easier to blend it in. I do really like it for the Dreadnoughts etc though. Rik Interrogator Stobz, apologist, Urauloth and 1 other 1 3 Back to top Link to comment Share on other sites More sharing options...
Marshal Rohr Posted July 21, 2023 Share Posted July 21, 2023 3 minutes ago, Rik Lightstar said: It's something of a shame they went for the city-fight style bases because the "pill" between the feet of infantry is pretty noticeable on those, if they'd gone for a flat base with some kind of texture it'd be easier to blend it in. I do really like it for the Dreadnoughts etc though. Rik I want to keep the strip for stability but I think I’m gonna use the thinner Astro granite to do scattered dirt and masonry in random spots to dirty up the base and hide it. Rik Lightstar, VanDutch, Interrogator Stobz and 1 other 4 Back to top Link to comment Share on other sites More sharing options...
BolterZorro Posted July 21, 2023 Share Posted July 21, 2023 I'll laser cut some transparent 1mm acrylic base so my armies blend on whatever table it is on. The miniatures are extremely light, you don't need that ugly 3mm thick base from GW which is an inheritance from the past (with the metal stripe on miniatures) Link to comment Share on other sites More sharing options...
Sherrypie Posted July 21, 2023 Share Posted July 21, 2023 3 minutes ago, BolterZorro said: I'll laser cut some transparent 1mm acrylic base so my armies blend on whatever table it is on. The miniatures are extremely light, you don't need that ugly 3mm thick base from GW which is an inheritance from the past (with the metal stripe on miniatures) The taller, hollow base isn't just for that, though. It is also much stabler on terrain that has sand, grit or other uneven features unlike a completely even plate. Noserenda, Lazarine and Oxydo 1 2 Back to top Link to comment Share on other sites More sharing options...
Urauloth Posted July 21, 2023 Share Posted July 21, 2023 4 hours ago, Rik Lightstar said: It's something of a shame they went for the city-fight style bases because the "pill" between the feet of infantry is pretty noticeable on those, if they'd gone for a flat base with some kind of texture it'd be easier to blend it in. It's really odd, the sculpted bases are gorgeous but the tactical rocks look pretty out of place on them. Rubble will be the way forward I think. Rik Lightstar and Interrogator Stobz 2 Back to top Link to comment Share on other sites More sharing options...
BolterZorro Posted July 21, 2023 Share Posted July 21, 2023 1 hour ago, Sherrypie said: The taller, hollow base isn't just for that, though. It is also much stabler on terrain that has sand, grit or other uneven features unlike a completely even plate. I don't know what you're plying on but it is a false problem....that GW try to encourage. There is no problem at all!. For a soldier sized miniature, you're looking at 7 grams of plastic and for a AT warlord 70g. Absolutely no need of stabilisation even if you're plying on sans on the beach. 99.99999999999% of the time, the playing table is flat. Oxydo and Noserenda 2 Back to top Link to comment Share on other sites More sharing options...
Noserenda Posted July 21, 2023 Share Posted July 21, 2023 54 minutes ago, BolterZorro said: I don't know what you're plying on but it is a false problem....that GW try to encourage. There is no problem at all!. For a soldier sized miniature, you're looking at 7 grams of plastic and for a AT warlord 70g. Absolutely no need of stabilisation even if you're plying on sans on the beach. 99.99999999999% of the time, the playing table is flat. I mean, just from playing lots of Titanicus thats just not true, its also not taking account of dramatic poses, conversions or not flat tables, which are pretty much the norm in a lot of places if they use realms of battle, (or similar) old school modular tables or even hills (Which are a lot more relevant at a smaller scale) which often have long slopes that Epic infantry HATE. I honestly hadnt given it much thought before but lipped bases might be a good idea actually, im certainly not sold on the sculpted ones so i could pass those off to someone else who might like em. Lazarine, Rik Lightstar, Oxydo and 1 other 1 3 Back to top Link to comment Share on other sites More sharing options...
Sherrypie Posted July 21, 2023 Share Posted July 21, 2023 2 hours ago, BolterZorro said: I don't know what you're plying on but it is a false problem....that GW try to encourage. There is no problem at all!. For a soldier sized miniature, you're looking at 7 grams of plastic and for a AT warlord 70g. Absolutely no need of stabilisation even if you're plying on sans on the beach. 99.99999999999% of the time, the playing table is flat. You might play on flat surfaces all the time, sure. Lots of people, myself included, play on a large and varied set of stuff that includes traditional foam and sand boards which tend to have rough surfaces as well as sloping hills that straight plate bases simply slip down from while lipped bases grip well enough to stay in place. This is not a problem, however you want to phrase it, just a regular state of things. Cool custom boards are a big part of the hobby while completely flat vinyl mats that dominate competitive media are more of a "it's fine I guess" solution for expedience. For Epic infantry, it doesn't really matter, but for even regular 28 mm dudes, let alone AT Warlords, I prefer my models not to keel over in wonky ways when a simple raised base handles this problem and keeps things aesthetically pleasing. Lazarine, DuskRaider, Rik Lightstar and 3 others 1 5 Back to top Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted July 21, 2023 Share Posted July 21, 2023 7 hours ago, Rik Lightstar said: It's something of a shame they went for the city-fight style bases because the "pill" between the feet of infantry is pretty noticeable on those, if they'd gone for a flat base with some kind of texture it'd be easier to blend it in. I do really like it for the Dreadnoughts etc though. Rik Luckily it's a simple fix, just add a little rubble to the clean city fight bases. It's not a city fight without fighting, and fighting wrecks cities. Noserenda 1 Back to top Link to comment Share on other sites More sharing options...
Rik Lightstar Posted July 22, 2023 Share Posted July 22, 2023 4 hours ago, Interrogator Stobz said: Luckily it's a simple fix, just add a little rubble to the clean city fight bases. It's not a city fight without fighting, and fighting wrecks cities. Yeah, it just runs the risk of ending up back in "Tactical Rock" territory, where every soldier has their own little patch of rubble. I completely accept that it's a really minor grumble, it certainly won't put me off adding a couple of Companies of White Scars, a bunch of tanks and probably some Imperial Army too to my existing White Scars Air Wing and Gryphonicus Titan Maniples. I'm all in for an Expedition Force! Just give me Battlefleet Heresy too! Rik DuskRaider and Interrogator Stobz 2 Back to top Link to comment Share on other sites More sharing options...
Noserenda Posted July 22, 2023 Share Posted July 22, 2023 Ill admit i got far too into basing some of my titans, different grades of rubble, tones to the rubble, the whole shebang. Its essentially not visible unless you stare real close (something my painting standards do not encourage) but i know its there lol Interrogator Stobz, tinpact and DuskRaider 3 Back to top Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted July 22, 2023 Share Posted July 22, 2023 Same here, I need to calm down. Noserenda 1 Back to top Link to comment Share on other sites More sharing options...
DuskRaider Posted July 22, 2023 Share Posted July 22, 2023 You’re telling me… now I worry the Marines on my Titanicus bases are way out of scale. Link to comment Share on other sites More sharing options...
Matcap86 Posted July 22, 2023 Share Posted July 22, 2023 42 minutes ago, DuskRaider said: You’re telling me… now I worry the Marines on my Titanicus bases are way out of scale. Jup, already have started plucking them off my bases... Link to comment Share on other sites More sharing options...
