Viking Slade Posted December 3, 2024 Share Posted December 3, 2024 Discussion thread for the Out of the Frying Pan campaign. Hello, all! Necronaut and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/ Share on other sites More sharing options...
Viking Slade Posted December 4, 2024 Author Share Posted December 4, 2024 (edited) Ok, I've sent invites out to those who have messaged me so far, I hope everyone gets them. I've set up character sheets with Players' names, so when you join, please rename your sheet to "[your character's name] - your name." If/when you check out the sheet itself, it can seem a bit confusing or daunting at first. Take a couple minutes, before you start adding in all your character's info, and familiarize yourself with it. It has a lot of formulas already built into it to calculate things like skills and available XP to spend. If you're uncertain of something, please don't be afraid to ask about it. I've added all the static bonuses from the Regiment to your sheets already, you only have to add in your choices for Characteristics, Equipment, and Talents options If your character is a "Guardsman," you begin with a total of 1100 experience to spend; update the "Total XP " amount to 3000. If your character is a "Support Specialist," you begin with 800 experience; update the "Total XP" amount to 3000, and the "Initial XP Spent" to 2200 from the dropdown menu. (This is the additional 500 experience from the Regimental bonuses.) Please be sure to utilize the XP Cost columns in each section. Finally, welcome to the Black Pa- ...the Guar- ...the Astra Militarum! Edited December 4, 2024 by Viking Slade Mazer Rackham, Lord_Ikka and Trokair 3 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6079044 Share on other sites More sharing options...
Mazer Rackham Posted December 5, 2024 Share Posted December 5, 2024 Currently working through my character sheet, which was obviously designed by Belisarius Cawl or the Emperor. Nested IF's? VLookups and SUMIF? What is this architectural marvel? And does it have a button to make coffee? Viking Slade and Trokair 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6079258 Share on other sites More sharing options...
Lord_Ikka Posted December 5, 2024 Share Posted December 5, 2024 I'll look it up tonight, see what I need to do to make Kordo ready to snipe the enemies of the Emperor. Mazer Rackham and Viking Slade 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6079259 Share on other sites More sharing options...
Mazer Rackham Posted December 6, 2024 Share Posted December 6, 2024 Chargen sheet is now finished, had to wiggle a few details to make the sheet fit, but it all calcs. Took Toughness as my 'duplicate' replacement, although probably should have gone for Ag. Anyway, took Parry, Dodge and buffed up my Comrade Hywell with the Righteous Oration Order. Necronaut and Viking Slade 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6079557 Share on other sites More sharing options...
Lord_Ikka Posted December 7, 2024 Share Posted December 7, 2024 Sheet done, will work on a character data post shortly. Took Ag/Per/BS simple advances, Lightning Reflex Talent, and then Comrade has Spotter, which should allow me to shoot with a fairly good chance of hitting reliably. Kordo will be hard to spot (+93 to Stealth with his cloak on, -40 to Hit if he's still), but will die to a wet noodle slap and probably shouldn't face any mind-bending psykers (11 Wounds and 25 WP). Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6079606 Share on other sites More sharing options...
Trokair Posted December 9, 2024 Share Posted December 9, 2024 I am slowly working through the Character creation steps and filling in the sheet for Pridbor the Ogryn (also known as Por for short). I have a few questions. First of All, with both the Universal Standard Kit and the Standard Regiment Kit. What do I do with the stuff a ogryn just cannot use (or use properly)? Non Ogryn proof weapons for example Secondly, Comrades, do they have to be human/guardsmen? I can imagine an Ogryn mistaking/adopting/whatever a animal as a comrade or even, and this is the idea I kind of like, have an imaginary comrade, perhaps someone that they knew and died and the ogryn just thinks is still around, just always out of sight, of on an errant or whatnot. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080116 Share on other sites More sharing options...
Machine God Posted December 9, 2024 Share Posted December 9, 2024 51 minutes ago, Trokair said: I am slowly working through the Character creation steps and filling in the sheet for Pridbor the Ogryn (also known as Por for short). I have a few questions. First of All, with both the Universal Standard Kit and the Standard Regiment Kit. What do I do with the stuff a ogryn just cannot use (or use properly)? Non Ogryn proof weapons for example @Trokair - Sell it for Grog just don't get caught! Necronaut, Mazer Rackham and Trokair 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080125 Share on other sites More sharing options...
Viking Slade Posted December 10, 2024 Author Share Posted December 10, 2024 4 hours ago, Trokair said: I am slowly working through the Character creation steps and filling in the sheet for Pridbor the Ogryn (also known as Por for short). I have a few questions. First of All, with both the Universal Standard Kit and the Standard Regiment Kit. What do I do with the stuff a ogryn just cannot use (or use properly)? Non Ogryn proof weapons for example Secondly, Comrades, do they have to be human/guardsmen? I can imagine an Ogryn mistaking/adopting/whatever a animal as a comrade or even, and this is the idea I kind of like, have an imaginary comrade, perhaps someone that they knew and died and the ogryn just thinks is still around, just always out of sight, of on an errant or whatnot. It's hand-waved a lot as the Comrade carrying it around, and we can do that here as well. But it's not going to be a lot of use in most cases in this game, at least until you move into the Bone 'Ead advanced specialty (if you choose), or you can purchase the advance without taking the specialty, but for double the normal cost. For ease of the game, I'm going to say yes, they have to be human-ish. We could definitely work with a "phantom" comrade that still functions the same mechanically, but your character is the only one who can actually "see" or perhaps just "hear" them. Do you happen to have the Shield of Humanity supplement for Only War? I'll let you trade out the GC Knife granted by the Regimental kit for a GC Mace-Fist from there. If not, let me know and I'll get you sorted. Trokair, Necronaut and Mazer Rackham 3 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080152 Share on other sites More sharing options...
Mazer Rackham Posted December 10, 2024 Share Posted December 10, 2024 I can see my spiritual workload is going to increase... Trokair and Necronaut 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080292 Share on other sites More sharing options...
Machine God Posted December 10, 2024 Share Posted December 10, 2024 1 hour ago, Mazer Rackham said: I can see my spiritual workload is going to increase... Well perhaps you have found your new Altar Boy? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080306 Share on other sites More sharing options...
Necronaut Posted December 10, 2024 Share Posted December 10, 2024 28 minutes ago, Machine God said: Well perhaps you have found your new Altar Boy? Stop drinking the communion wine! That's for paying customers only! I mean parishioners! Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080309 Share on other sites More sharing options...
Mazer Rackham Posted December 10, 2024 Share Posted December 10, 2024 (edited) Such a rowdy congregation! Let me see - vespers from 1800 until 0600 for all of you miserable sinners, followed by mass with - ah yes, a THREE HOUR letter from the archbishop, with my own homily upon the iniquities of the demon drink! Get that thurible swinging, boy - I want the incense putting hairs on these sinners' chests! Edited December 10, 2024 by Mazer Rackham Viking Slade and Necronaut 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080310 Share on other sites More sharing options...
Trokair Posted December 10, 2024 Share Posted December 10, 2024 (edited) 20 hours ago, Viking Slade said: Do you happen to have the Shield of Humanity supplement for Only War? I'll let you trade out the GC Knife granted by the Regimental kit for a GC Mace-Fist from there. If not, let me know and I'll get you sorted. I should do, I got a bunch of the Only War books in a Humble Bundle a while ago. Since a Regiment kit comes with a GC Mono Knife, would it be possible to have this knife be Ogryn sized and gain the Ogryn proof trait, but otherwise be the same as any other knife? 20 hours ago, Viking Slade said: For ease of the game, I'm going to say yes, they have to be human-ish. We could definitely work with a "phantom" comrade that still functions the same mechanically, but your character is the only one who can actually "see" or perhaps just "hear" them. Phantom Comrade it is. Por calls him Jarrow, he will be back any moment now, just running an errant for the Commissar. 20 hours ago, Viking Slade said: It's hand-waved a lot as the Comrade carrying it around, and we can do that here as well. But it's not going to be a lot of use in most cases in this game, at least until you move into the Bone 'Ead advanced specialty (if you choose), or you can purchase the advance without taking the specialty, but for double the normal cost. On my character sheet I have divided the Universal and regimental kits into what an Ogryn can use (weapon wise) and what made some sense(ish) for an Ogryn to have. The rest is listed separately as Other. While rules wise it is all my PC stuff, fluff wise I intend to play it as the items in the Other catogry is all stuff belonging to Jarrow (in Por’s mind) and Por is just keeping it for his friend for the moment. That seem ok? I still need to spend XP, but otherwise I think I have gotten to grips with the Character Sheet. Edit: One more question, is it intended that at Character Generation a Ogryn cannot make any melee attacks without the -20 for not having the right weapon training unless I spend some of the starting XP to get Weapon Training Low Tech? Edited December 10, 2024 by Trokair Machine God and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6080326 Share on other sites More sharing options...
Viking Slade Posted December 14, 2024 Author Share Posted December 14, 2024 We can give the knife the Ogryn-Proof quality, yes. The idea for your gear is good. Yes, it's intended to be that way. I believe their bonus to WS is supposed to offset this a bit, but I'll take an in-depth look later this evening/tonight, when I can get on my laptop. Trokair and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081116 Share on other sites More sharing options...
Viking Slade Posted December 15, 2024 Author Share Posted December 15, 2024 On 12/10/2024 at 2:14 PM, Trokair said: *snip* Ok, so having looked at it (good thing I did, or I'd have stuck my foot in my mouth), yes. Ogryn characters aren't inherently geared towards using melee weapons, hence not receiving one as part of the Specialty. You do have both the WS and Offence aptitudes, so you can get melee Weapon Training pretty cheap. Mazer Rackham and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081134 Share on other sites More sharing options...
Trokair Posted December 15, 2024 Share Posted December 15, 2024 XP spend so far: Weapon Training Low Tech 300 Agility Advance 250 Dodge 100 got 150 XP left, any suggestions? Other than that I think Por's sheet is done. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081238 Share on other sites More sharing options...
Viking Slade Posted December 15, 2024 Author Share Posted December 15, 2024 I apologize, I should have checked the aptitudes for Weapon Training. My advice is to think about what you want your character to do a little ways into the future and buy/plan according to that. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081248 Share on other sites More sharing options...
Trokair Posted December 18, 2024 Share Posted December 18, 2024 On 12/15/2024 at 11:04 PM, Viking Slade said: I apologize, I should have checked the aptitudes for Weapon Training. No worries, the regiment came with extra XP so it sorts itself out. I think I have settled on Athletics at 100XP as my last spend, with 50XP saved up for some point down the road. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081605 Share on other sites More sharing options...
Trokair Posted December 19, 2024 Share Posted December 19, 2024 Forgive me if this was mentioned somewhere and I just failed to see it, but are there any set colours for Wilson's Irregulars? Por conversion finished, will try and get him painted over the holidays. and a different angle Spoiler Mazer Rackham and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081848 Share on other sites More sharing options...
Viking Slade Posted December 19, 2024 Author Share Posted December 19, 2024 Maroon/dark red fatigues under dark grey carapace/armor pieces. But don't feel like you have to use those colors if you feel like something else would look better on the model. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081923 Share on other sites More sharing options...
Trokair Posted December 19, 2024 Share Posted December 19, 2024 3 hours ago, Viking Slade said: Maroon/dark red fatigues under dark grey carapace/armor pieces. But don't feel like you have to use those colors if you feel like something else would look better on the model. Will try and work those in somewhere then. Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6081947 Share on other sites More sharing options...
Trokair Posted December 22, 2024 Share Posted December 22, 2024 A little work in progress, looks better in person than my old camera can convey, the distinction between the dark red and the brown is much clearer. Next up are going to be the first metallic’s, thinking either the armoured plates on the upper trouser, buckles and such are silver/grey and the chainmail brass/bronze, or vice versa. Mazer Rackham and Necronaut 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6082344 Share on other sites More sharing options...
Trokair Posted December 29, 2024 Share Posted December 29, 2024 All finished up and ready. So how many players do we now have? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6083602 Share on other sites More sharing options...
Mazer Rackham Posted December 29, 2024 Share Posted December 29, 2024 Three or four, IIRC. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/384730-ow-out-of-the-frying-pan-oocdiscussion-thread/#findComment-6083604 Share on other sites More sharing options...
