A.T. Posted October 14, 2025 Share Posted October 14, 2025 In terms of setting a target I would guess the two areas I would put forward for questions would be for some kind of bearing on the guardians and whether or not the humans we encountered (or are following) are tied to them. As the results would give us some indication of where to turn next. Trokair and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6136643 Share on other sites More sharing options...
Mazer Rackham Posted October 14, 2025 Share Posted October 14, 2025 59 minutes ago, A.T. said: In terms of setting a target I would guess the two areas I would put forward for questions would be for some kind of bearing on the guardians and whether or not the humans we encountered (or are following) are tied to them. As the results would give us some indication of where to turn next. I'll go with that. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6136652 Share on other sites More sharing options...
Black Cohort Posted October 14, 2025 Share Posted October 14, 2025 (edited) Something getting more specifics about the state of our objective? edit: didn't notice that there were posts on another page. AT has good questions. Edited October 14, 2025 by Black Cohort Mazer Rackham and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6136668 Share on other sites More sharing options...
Trokair Posted October 15, 2025 Author Share Posted October 15, 2025 Thanks, I'll but something together with those in mind when I get home tonight. Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6136728 Share on other sites More sharing options...
Mazer Rackham Posted October 17, 2025 Share Posted October 17, 2025 What do folks think of the newer info - at least we aren't being followed! Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137156 Share on other sites More sharing options...
A.T. Posted October 17, 2025 Share Posted October 17, 2025 Seems like we have a direction - will add IC post later when I have a moment. Mazer Rackham, Trokair and Mike Zulu 3 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137171 Share on other sites More sharing options...
Akylas Posted October 21, 2025 Share Posted October 21, 2025 Tracking is an advanced skill so you have to at least be trained to attempt it, right? Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137699 Share on other sites More sharing options...
Trokair Posted October 21, 2025 Author Share Posted October 21, 2025 (edited) Correct, it is down to A.T. as I think he is the only one with it trained. Edit: Had a thought, away from the files so i am not sure if anybody has surface navigation skill but if you do that could help with the tracking So, if anybody has Navigation (Surface) then a pass on a +0 Navigation Test that will provide a +15 Assist to the Tracking Edited October 21, 2025 by Trokair Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137705 Share on other sites More sharing options...
A.T. Posted October 21, 2025 Share Posted October 21, 2025 14 hours ago, Trokair said: Correct, it is down to A.T. as I think he is the only one with it trained. Though quite bad at it - so if anyone has a way of assisting Ialandranth before I roll... Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137871 Share on other sites More sharing options...
Trokair Posted October 21, 2025 Author Share Posted October 21, 2025 I have checked and only Venkarryn has Navigation (Surface) (for some reason this mornign I though there may be two of you that had it) so if he can pass his test that will help. perhaps a bit of naration of the two of you workign togeter to find a way would set the right spirits. Also a 50/50 forthe trackign is not bad, just not great. Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137880 Share on other sites More sharing options...
Black Cohort Posted October 22, 2025 Share Posted October 22, 2025 I rolled a 93 on my Navigation (Surface) check, so Ven is of no use at this moment. Trokair and Akylas 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6137893 Share on other sites More sharing options...
Trokair Posted November 9, 2025 Author Share Posted November 9, 2025 2 hours ago, A.T. said: Ialandranth Veilseeker Run - 60m max distance - if the middle-east greenery offers full concealment he'll hide behind that, otherwise north into the heavier concealment Ok I played a little loose here, hope that is ok. I placed Ialandranth in the terrain I think you meant, as technically you would be hidden form the main Dark Eldar grouping, but one of them (Dark Kin 5) had just arrived before you, though on the north side of that terrain, taking cover between tree and rock. So you are hidden, but much closer then you might have liked. Also allowed me to add a bit of further information for the players as from where you now are you could see things that the character previously could not see, both in respect of the Raider and the nearby Dark Eldar. Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6141302 Share on other sites More sharing options...
Black Cohort Posted November 9, 2025 Share Posted November 9, 2025 would my speed be slowed going through the trees? Also would it help to take one of the dark kin alive for questioning? Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6141304 Share on other sites More sharing options...
Trokair Posted November 9, 2025 Author Share Posted November 9, 2025 15 minutes ago, Black Cohort said: would my speed be slowed going through the trees? I am going to say no, you are not slowed. This is partialy for simplicity, partialy that while the trees are close enough to provide plenty of cover opportunities they are not so dense to hinder movement. 15 minutes ago, Black Cohort said: Also would it help to take one of the dark kin alive for questioning? I'll leave that for you all to decide if a cpature attempt is worth your while. Black Cohort and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6141307 Share on other sites More sharing options...
Mazer Rackham Posted November 10, 2025 Share Posted November 10, 2025 (edited) Just an FYI everyone, I have been in discussion with the GM, and he's offered us a few options - we can take control of the guardian and maybe try to get info from it later on if it survives. I'll have Saoirse open a telepathic link so we can all see/commune? Do we want to try and 'control' the construct, or have the Mad Psychic Bomber doing Psychic bomber stuff? If I take control of it, do we want to wade it into combat, and maybe take the memories/info from it before it's blown up, or march it off somewhere? Edited November 10, 2025 by Mazer Rackham Akylas and Mike Zulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6141700 Share on other sites More sharing options...
Trokair Posted November 12, 2025 Author Share Posted November 12, 2025 (edited) Just to add to that, another option available is to get ' The Information' now, but doing so would exclude the other option of directing/controlling the Guardian. Also directing/taking control would not use up Saoirse's action for the turn (as she already gave up last turns action to establish the psychic connection) so Mad Psychic Bomber stuff can still happen. Note to sell check what range the doubleganger spell has. Edited November 12, 2025 by Trokair Mazer Rackham, Mike Zulu and Akylas 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6141949 Share on other sites More sharing options...
Mike Zulu Posted November 12, 2025 Share Posted November 12, 2025 Let us try to take control of it. It doesn’t seem like the dark kin are able to deal with it either way (less so now we’re engaging)… Mazer Rackham and Akylas 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142059 Share on other sites More sharing options...
Trokair Posted November 13, 2025 Author Share Posted November 13, 2025 (edited) 14 hours ago, Mike Zulu said: It doesn’t seem like the dark kin are able to deal with it either way (less so now we’re engaging)… For all that the DE have been struggling so far, they did manage to put 7 wounds on the guardian in round 3 (one of the reason why I provided the start of turn 4 update, so that you had the information) and had the Blaster hit it would have likely been dead twice over. Just so you are aware. Edited November 13, 2025 by Trokair Mazer Rackham, Mike Zulu and Akylas 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142142 Share on other sites More sharing options...
A.T. Posted November 13, 2025 Share Posted November 13, 2025 Ialandranth can pop in and out picking off DE from ambush using his warp jump from cover (at least until someone spots him doing it) but he won't be able to dive in on the blaster unless the numbers are thinned. Akylas and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142153 Share on other sites More sharing options...
Akylas Posted November 13, 2025 Share Posted November 13, 2025 IC would like to keep it "alive" if possible but I understand the value of trying to have the guardian help us. Getting the knowledge from it might be the top priority if it isn't long for this world. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142162 Share on other sites More sharing options...
Black Cohort Posted November 14, 2025 Share Posted November 14, 2025 yeah the knowledge is the most important thing. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142253 Share on other sites More sharing options...
Trokair Posted November 14, 2025 Author Share Posted November 14, 2025 If I am reading the room right I think we have an even split between controlling the guardian to try and save it vs get the information now. Yes? No? the GM doesn't know what he is doing? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142278 Share on other sites More sharing options...
Mike Zulu Posted November 14, 2025 Share Posted November 14, 2025 (edited) To break the tie I’ll change my choice: Let us get the information now. Edited November 14, 2025 by Mike Zulu Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142286 Share on other sites More sharing options...
Mazer Rackham Posted November 14, 2025 Share Posted November 14, 2025 (edited) The GM has given me a couple of directions lads, so I will pop something together asap, but I'm really busy today. Should be some time tomorrow. EDIT: had a few minutes. Edited November 14, 2025 by Mazer Rackham Akylas and Trokair 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142333 Share on other sites More sharing options...
Akylas Posted November 15, 2025 Share Posted November 15, 2025 Sorry everyone, I'm good to go for this turn. I read through the last couple turns a few times but just to clarify, which Dark Eldar has the splinter cannon? Want to make sure I'm aiming at the right one. Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/10/#findComment-6142453 Share on other sites More sharing options...
