3 hours ago, Akylas said:
Should I avoid using the reaper launcher this turn since it's likely to be noisy? I can try to position for next turn, or use my sidearm instead.
The one I shot at dodged so will probably raise the alarm - may as well hit the most dangerous target you can see before the advantage is lost.
Took the shot on that kabalite.
I think he migth be dead now. By some margin.
I'll get a IC thread reply up in the next day or so, don't have time right now.
I think that leaves only @Black Cohort and @Aknoby to take their actions.
Posted (edited)
1 hour ago, A.T. said:
I think Ialandranth might be mispositioned on the map (didn't he jump west?)
Directly west would not have given you the line of sight to shoot the Deathspinner (you would have been in the trees), so I moved you more West South West diagonal.
Regardless the two purple dots to the south past the single DE and the single purple dot to the south east - are these distinct somehow?
The light purple is Saoirse's Phantom, the dark grey are the dead from last round (as points of reference).
The map image is quite large by default (1440 by 1080) but the forum dose srink it a bit in thread depednign on how you view the thread. Clicking hte map (or opening it in a seperat tab/window) should display the full sized one).
Edited by Trokair
Is the Phantom incorporeal? Can I shoot through it without effect?
I'm debating three red targets. One is "obscured" by the phantom, one is directly in front of the human slaves, and another is just short of 160 m.
Edited by Mike Zulu
From the description of the power I would say you may be able to see through it to an extend (though it would be difficult) but shooting though it would hit it instead. It is material enough to cleave foes in part with its phantom copy sword.
I see Maser has provided a solution so for now it is moot, but for future reference, given the size of map and scale as long as the intended target is not to close/obviously behind any intervening targets then you may be able to see past (with potentially a modifier thrown in or such as appropriate).
This round so far the only ones that died where: one red in the center of the map, and one orange on a riader.
The red one in the bush near the group is in melee with Ialandranth.
So the red near the three orange and venoms/raiders is alive, as is the red near the 4 ornage and 8 humans.
Technically not, but I am goign to let it stand as Kelman and Saoirse are at the same initiative step.
So I imaging you both steped forward more or less at the same time and attacked that Kabalite, I seem to recall that fluff wise reaper micro missile things have limited homing capabilities, so just goign chalk it up to that.
The tree will however be a casulty as well.
True, true, but Saoirse's changed her mind you know, she's not really ready for an 'intense' relationship like that at the moment, she doesn't have her hair done, her cloak is a mess, I mean, come on...:tongue:
That was my intent but my Suppressive Fire range is 40m (half weapon’s range), so I’ll need to get closer first.
I can set up in the brush to the west and try to lock down that portion of hostiles (or pick them off until they get closer).
