Machine God Posted August 9, 2025 Share Posted August 9, 2025 IIRC they are in the Combat section, only Pistols and Melee Weapons can be used in close quarters combat. Mazer Rackham and Trokair 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127102 Share on other sites More sharing options...
Akylas Posted August 9, 2025 Share Posted August 9, 2025 13 hours ago, Trokair said: In addition to Mike’s comment about extra hits I just wanted to point out that on hit 2 you rolled a natural 10 on the D10, and this triggers Righteous Fury (see p 195 of the DH rulebook). Essentially think of this of a ‘Crit’ in that it allows you to add an extra D10 damage if you can successfully roll another WS or BaS (as appropriate) Check. The extra roll has all the same modifiers as your initial attack so in this case you would need to roll equal or less than 64 on a D100 to get the extra damage. I don’t think I can justify the extra hits hitting the other Ur-ghul in this combat due to relative location and Saoirse’s phantom is also in the way. This dose however mean that even if the Ur-ghul dodges one hit the other three will kill it, so consider it dead. @Black Cohort next, and then surviving ghuls can have a go... Thanks! Even if they're dead regardless I went ahead and added the hits for practice. No Righteous Fury this time but pretty happy. Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127193 Share on other sites More sharing options...
Trokair Posted August 10, 2025 Author Share Posted August 10, 2025 (edited) Session 1 Player Rewards All Players may choose one of these two options: One simple characteristic advance of your choice (add +5 to any one stat and mark the simple advance in the first little box below said stat on your sheet) Upgrade one Trained Skill to the +10 version Individual Player Rewards Each player may then make one choice from the option presented for them below. A quick note, as Evil Eye was unfortunately not able to play the team is a little unbalanced on the ranged vs melee capabilities, even with Saoirse pet phantom. As such, out of the aspects available, Dire Avengers and Wrap Spiders madke the most sense to go hybrid ranged/melee. As such in addition to the planed rewards Mike Zulu and A.T. will have the option to take a Diresword/Arm Mounted Power Blades (respectively) as a reward instead. If you do take the weapon then my thinking is that your Exarch has recently started training you in the aspects melee weapon of choice and you had packed said weapon, but in the immediate aftermath of the crash you did not have chance to retrieve it from the Featherflight hold, but now you have. Ialandranth Veilseeker Exotic Wepaon Training (Arm Mounted Power Blades) + 1 set of Arm Mounted Power Blades Arm Mounted Power Blades: Melee, Damage 1d10 + 10, Pen 6, Balanced, Power Field Forsight Sprint Ialathial Duskstrider Exotic Wepaon Training (Diresword) + 1 Diresword Direwsord: Melee, Damage 1d10 + 3, Pen 6 Balanced. Grants +10 to WS tests when using it. This weapon is immune to the effect of Powerfields (so no one with a power weapon can break your sword when they parry you). Combat Master Double Team Kelman Orach Sharpshooter (essentially upgrading your Deadeye Shot) Rapid Reaction Saoirse Firebright Lightning Reflexes Assassin's Strike Venkarryn Marksman A Ballistic Skill Advance Edited August 10, 2025 by Trokair I know which player is which, honest .... Mazer Rackham and Mike Zulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127274 Share on other sites More sharing options...
Mazer Rackham Posted August 10, 2025 Share Posted August 10, 2025 Much obliged, GM. I choose you, Pikachu er: +5 Strength Lightning Reflexes. Black Cohort and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127277 Share on other sites More sharing options...
A.T. Posted August 10, 2025 Share Posted August 10, 2025 I assume that Ialandranth and Ialathial are the wrong way around it that list :p Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127331 Share on other sites More sharing options...
Trokair Posted August 10, 2025 Author Share Posted August 10, 2025 25 minutes ago, A.T. said: I assume that Ialandranth and Ialathial are the wrong way around it that list :p Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127333 Share on other sites More sharing options...
Black Cohort Posted August 10, 2025 Share Posted August 10, 2025 Ven will take +5 BS advance for the first option, and Marksman for the second I have updated the character sheet Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127348 Share on other sites More sharing options...
Akylas Posted August 11, 2025 Share Posted August 11, 2025 Kelman will take +10 to pilot and Sharpshooter. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127363 Share on other sites More sharing options...
Mike Zulu Posted August 11, 2025 Share Posted August 11, 2025 Neat, I will take the Diresword. I will also add +5 to Toughness. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127420 Share on other sites More sharing options...
A.T. Posted August 11, 2025 Share Posted August 11, 2025 Going to have to be agility and the blades for Ialandranth. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127422 Share on other sites More sharing options...
Mazer Rackham Posted August 14, 2025 Share Posted August 14, 2025 (edited) Does anyone have any suggestions on the question asked for the purposes of Augury? EDIT: And not a suggestion by some wag like: 'Who will win the 3;30 at Kempton?', or 'What's next week's winning Lotto numbers?' Edited August 14, 2025 by Mazer Rackham Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6127975 Share on other sites More sharing options...
Trokair Posted August 15, 2025 Author Share Posted August 15, 2025 The obvious follow up to Ialandranth's question would be 'Who also treads our path?' or something along those lines, but it is not for me to say on this or otherwise until the dice consent. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128068 Share on other sites More sharing options...
Mazer Rackham Posted August 15, 2025 Share Posted August 15, 2025 37 minutes ago, Trokair said: The obvious follow up to Ialandranth's question would be 'Who also treads our path?' or something along those lines, but it is not for me to say on this or otherwise until the dice consent. I agree - I was just hanging fire in case someone else had a better idea...! Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128072 Share on other sites More sharing options...
Mazer Rackham Posted August 16, 2025 Share Posted August 16, 2025 Since nobody has chimed in on this, I'll roll it up and post shortly. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128252 Share on other sites More sharing options...
Mazer Rackham Posted August 16, 2025 Share Posted August 16, 2025 (edited) Well played. Edited August 16, 2025 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128262 Share on other sites More sharing options...
Trokair Posted August 16, 2025 Author Share Posted August 16, 2025 To be honest I have no idea if that is worth of a 6 DoS Augary or not. ImmediateFrog and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128302 Share on other sites More sharing options...
Mazer Rackham Posted August 16, 2025 Share Posted August 16, 2025 (edited) Don't sweat it, GM, there's a decent bit to go at there, and the memery above is firmly tongue-in-cheek. I'm just glad I didn't blow us all up with a greater daemon..! Edited August 16, 2025 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128304 Share on other sites More sharing options...
Trokair Posted August 17, 2025 Author Share Posted August 17, 2025 I am going to wait a few days, say Wednesdayish, before moving things along so that anybody who wants to respond can do so. I presume Soairse will rest for the 30 or so min until the next time mark, so should be a little refreshed (or at least less weary) by then. Now a question for you all. I did not think opening the portal would have been as problematic as it has proven, my bad, I should have just asked for a single test or maybe two. Do you want me to railroad the adventure through this setback to continue the main plot, or do you want to go off the rail and see where the B plot (that at this point was just meant to provide a bit if tension/sense of urgency, not actually hinder) takes you from this juncture. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128383 Share on other sites More sharing options...
Trokair Posted August 19, 2025 Author Share Posted August 19, 2025 I may have been procrastinating a little last night on the next update, but it should still go live tonight/early tomorrow. Akylas, Mazer Rackham, Mike Zulu and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128637 Share on other sites More sharing options...
Mazer Rackham Posted August 19, 2025 Share Posted August 19, 2025 I have decided, from this picture, that we are actually a travelling band of Troubadours, where I look suspiciously like a backing singer, and everyone else has Solo Bass-Guitarist Pose. Florence & The Machine (Gunners)? Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128639 Share on other sites More sharing options...
Mike Zulu Posted August 19, 2025 Share Posted August 19, 2025 I have no preference either way, but generally I prefer to avoid resets. Fate brought us this far… Trokair and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128640 Share on other sites More sharing options...
Mazer Rackham Posted August 19, 2025 Share Posted August 19, 2025 3 minutes ago, Mike Zulu said: I have no preference either way, but generally I prefer to avoid resets. Fate brought us this far… I agree - I think the Fail State adds to the narrative - we rock it how it rolls. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6128641 Share on other sites More sharing options...
Trokair Posted August 22, 2025 Author Share Posted August 22, 2025 50 minutes ago, Mazer Rackham said: Soairse: Intelligence attempt: INT 39 - 10 (Diff) = 29 D100: 13 (unlucky for some...) Ok so you have passed the test to use the controlls, now what do you want to chaneg about hte portal? Size, permuability, end location, somethign else? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6129170 Share on other sites More sharing options...
Mazer Rackham Posted August 22, 2025 Share Posted August 22, 2025 20 minutes ago, Trokair said: Ok so you have passed the test to use the controlls, now what do you want to chaneg about hte portal? Size, permuability, end location, somethign else? @Akylas, @Mike Zulu, @A.T., @Black Cohort What do you think, gang? Feel free to call the shot. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6129173 Share on other sites More sharing options...
Mike Zulu Posted August 22, 2025 Share Posted August 22, 2025 @Mazer Rackham We need an exit, it seems. Going back would likely expose us to more of that radiation. I assume the portal’s destination is “correct”, just unfortunately underwater now. How much control would we have over an alternate exit? Perhaps making the portal semi-permeable would make it easier to approach from our side, and we would need to be ready to swim once we cross over. Mazer Rackham and Akylas 2 Back to top Link to comment https://bolterandchainsword.com/topic/385923-a-knocking-afar/page/8/#findComment-6129185 Share on other sites More sharing options...
