Mike Zulu Posted August 24, 2025 Share Posted August 24, 2025 Ialathial Duskstrider “Let us make haste,” Ialathial announced, certain of the way forward. He slung his catapult and approached the dark-azure membrane of the gate, limbering himself in readiness for the swim ahead… Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6129471 Share on other sites More sharing options...
A.T. Posted August 24, 2025 Share Posted August 24, 2025 Ialandranth Veilseeker Spiders and water were not a favoured combination but what was water compared to the chill of the warp. "I will forge ahead and signal from the surface" Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6129546 Share on other sites More sharing options...
Trokair Posted August 25, 2025 Author Share Posted August 25, 2025 As Ialandranth stepped through the portal was at first resistant, as if waking into a strong wind, then the gate relented. The gravity shift almost caused you to misstep, not stronger or weaker to a noticeable degree, but at an inconvenient angle. The imposed slowness of the water and Eldar agility allows you to catch yourself and rebalance instead of falling back through the portal. Taking a few steps and turning back you can see the cause. The gate mechanism on this side had slid and half fallen and now lay at an angle. Perhaps its foundations had been undermined by the water over time, so that it tilted and sunk. The surface if not as far above you as it had appeared; maybe half your height again, without your armour you could have easily drifted up. Instead you had no choice but to trudge up slope and into the shallows, each step blooming up slick and debris. Breaching the surface your helmet lenses adjust, you emerged facing the dawn and the landscape ahead of you is hidden by sunlight. With darkened lenses you can see a little better but still light obscured. Gentle vegetation grew along the shore edge to the left and right as far as you can see. Some trees scattered about but a little light to be a forest. Ahead, and al little to your left, there are some structures, or ruins perhaps. You would need to wait for the sun to rise further, or get closer to properly see. Your armour’s system report a breathable atmosphere, if a little more oxygenated then craftworld norm. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6129608 Share on other sites More sharing options...
A.T. Posted August 26, 2025 Share Posted August 26, 2025 Ialandranth Veilseeker 'Habitable, silent, shrouded.' The communication of the suits shared thoughts as much as words, the danger of the shallow water should a fresh ambush strike while they were silhouetted against the sky. But for now things were still. Mazer Rackham, Mike Zulu and Trokair 3 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6129785 Share on other sites More sharing options...
Trokair Posted August 27, 2025 Author Share Posted August 27, 2025 One by one you step through the portal, acclimatising to the other side and wading into the shallows. With the last of you through the portal it closes by itself, the mechanism having sensed that there were no further travellers in your party. As you are about half way out of the water, the gentle ripples of your disturbance lapping around and between you, you find the first corps. Face down and tangles in kelp it bobbed back and forth. It does not take you long to discern that this xenos is one of the Human kind, and its death had been violent. By now you can also make out more of the shoreline, where there are wrecked vehicles amongst the ruins, and further corpses scattered about. As you step onto dry land and get a chance to properly look at the scene it becomes apparent that the corpses are recent, and yet a few are older than the others, by a good few days. Of the Guardians that were supposed keep a watch on the Gate on this side there had been no sign by the gate, for even in the water and if buried by slick and sand you would have sensed them. So the question was, were these dead Xenos responsible? Lysimachus, Mike Zulu and Mazer Rackham 3 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6129943 Share on other sites More sharing options...
Akylas Posted August 29, 2025 Share Posted August 29, 2025 Kelman looks at one of the more recently dead humans. Something about them always unsettled him, like some half finished child's depiction of an Eldar. He looks over the Xenos body in hopes of telling whether it was slain by shuriken fire. Mike Zulu and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130115 Share on other sites More sharing options...
Trokair Posted August 29, 2025 Author Share Posted August 29, 2025 A Easy (+30) relevant* test will reveal more information. *I am not 100% sure which skill is bested suited here, but anything in the Investigation group might be reasonable, as would perhaps be skills like Search (to search the belonging/equipment of the corpse, or to search out things lost in the undergrowth or some such), or Scrutiny or Tracking (to try and trace movements). Remember even if you don’t have a skill, if it is Basic (denoted by the (B) on your character sheet after the skill) you can use it at half your stat. The Easy (+30) is applied after the halving. So yes, pick a skill you think would work and describe what you want to do with and we can see. Mazer Rackham and Mike Zulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130125 Share on other sites More sharing options...
Mike Zulu Posted August 29, 2025 Share Posted August 29, 2025 Ialathial Duskstrider Ialathial had unslung his catapult and raised it to scan the shoreline, alarmed by the sight of mass death. He cautiously approached the beach, stepping around the bouyant carrion and keeping line with the other warriors. These pitiful creatures had been caught in an ambush, and Khaine-willing they would not be next... Scrutiny: Ialathial will search the shoreline for potential amush positions or signs of other combatants, presently or previously... Spoiler Scrutiny Test: 37(Per, Trained) + 30 = 67 required Roll d100: 56 = Pass, 1DoS Trokair and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130139 Share on other sites More sharing options...
Mazer Rackham Posted August 29, 2025 Share Posted August 29, 2025 Soairse: Emerging from the water, the wieght of her raiment was once again apparent. A moment of self-deprecation assailed, thinking herself some kelp-clad sludge-trekker was dispelled b the corpse. The warriors in front stung the communal senses with caution, concerns, professional deportment, and she hardened down on the latter. Keeping her hands free for balance, she broached the surface and took in the battlefield. Death blew in psychic after-murmur, a zephyr of sacrifice and loss. Fear and pain a suble slice across the knuckles of her reaching conscious. Caution. Tempted to exercise her powers to gain information, detail, a warning in the back of her mind travelled instantly to the front. Thier enemies were not always psychically blunt. No need to warn them. Good, old-fashioned eyes and ears would suffice. She scanned the shadows for darting eyes, flitting shapes. Spoiler Awareness: Per 41 +10 (HS) = 51 D100: 43, PASS. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130162 Share on other sites More sharing options...
A.T. Posted August 29, 2025 Share Posted August 29, 2025 Ialandranth Veilseeker Whatever had happened here had been chaotic, tracks of many types with no unity of action, sign of combat and habitation and chasms carved into the ground by blasts and tools overlapped. Such fury for a place abandoned. Tracking: 59 vs 30 = fail Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130187 Share on other sites More sharing options...
Akylas Posted August 30, 2025 Share Posted August 30, 2025 18 hours ago, Akylas said: Kelman looks at one of the more recently dead humans. Something about them always unsettled him, like some half finished child's depiction of an Eldar. He looks over the Xenos body in hopes of telling whether it was slain by shuriken fire. Scrutiny roll for above Perception 42 + 30 (easy test) = 72 Roll 1d100 = 36 = Pass Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130222 Share on other sites More sharing options...
Trokair Posted August 30, 2025 Author Share Posted August 30, 2025 Kelman As you take a closer look at this fresher body you can see that the clothing and armour of the individual has many small fine cuts. Perhaps this is what had drawn your eye to begin with, for a shuriken storm would caused similar damage. However the body is not shredded underneath. Indeed the many cuts appear to have been made by blades, and none of them lethal either, jet deep enough that they should have bleed profusely. The cause of death instead is a series of three solid slug wounds to the back, almost in a line from shoulder to neck and finally head. Ialathial As you search you find several clumps of corps in what could otherwise have been great ambush position, or defensive positions as seems to have been the case judging by how the bodies lay. You even find a group that might have been civilians of some sort, for there were no weapons near them at all, and they appeared to have been cowering in particular thick undergrowth. In fact only the disturbance where some of them had been dragged out, an attempt to move injured ones perhaps, revealed this particular bolt hole to you. Soairse Your vigilance and carful scanning only reveals more dead humans. No living ambushers waiting to spring, just corpse of one’s trying to seek cover or even just hide. Carrion eaters must have been here, for you spot several of the older bodies marked with bite marks and rended flesh. However if such beast are here now they are stealthier then Eldar, more likely is that they have sated themselves and are now elsewhere, to return in time. Ialandranth As you trace the tracks and disturbances in the ground and vegetation little can be read from the utter chaos of the battlefield. It is towards the edge of the engagement site that things are a little clearer to you. There is evidence of large number of vehicles, but in a somewhat organised manner, arriving from the south south easterly direction. Not quite as a disciplined column, but certainly a convoy carving a way through the grassland beyond. You also find multiple sets of vehicle and foot tracks that lead of into random direction away from the battlefield. From contextual clues such as the way the foliage is bent and torn and dropped items, you speculate that some are form fleeing humans. A few others looked more like they were pursuers of the former, overlapping and covering older tracks. Akylas and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130252 Share on other sites More sharing options...
Mazer Rackham Posted August 31, 2025 Share Posted August 31, 2025 Soairse: +We must not tarry here. If these soldiers had allies, we shall be blamed for the slaughter should they arrive.+ She looked around. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130456 Share on other sites More sharing options...
Trokair Posted August 31, 2025 Author Share Posted August 31, 2025 Morai-Heg is clearly blessing you this day, for no sooner had the Warlock spoken her words that the sounds of mechanical engines came to you from the south. One, no two, human vehicle crept over the southern horizon. Simple and rugged construction, with a cabin for a drive and perhaps two passengers, then a curved tarpaulin covered back, whether it was supplies or more humans under the canvas you could not tell from here. They were moving fairly slow, and while it was possible that they were headed elsewhere their trajectory would pass rather close, if it was not directly headed for the battlefield. They have not spotted you yet, what would you like to do? Withdraw, set an ambush, hide and observe, head away from the lakeside, wait? Mike Zulu, Mazer Rackham and Akylas 3 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130475 Share on other sites More sharing options...
Black Cohort Posted September 2, 2025 Share Posted September 2, 2025 "We should try to figure out what is happening here before we kill the wrong people." Mazer Rackham, Mike Zulu, Akylas and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130717 Share on other sites More sharing options...
Mike Zulu Posted September 3, 2025 Share Posted September 3, 2025 Ialathial Duskstrider Ialathial could not finish his dry jest in reply to the Warlock, for he too sighted the oncoming convoy. Their dirty contraptions sputtering and rumbling, with no subtlety or stealth as they came closer. "+We should try to figure out what is happening here before we kill the wrong people+”, Venkarryn suggested. The ‘wrong people’? Despite that slip of the tongue the idea was sound. If these humans failed to return it would only alert others to their last location. “+Then we go to ground+” Ialathial replied. “+Observe for now. Only engage if sighted+” Trokair, Akylas and Mazer Rackham 3 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130752 Share on other sites More sharing options...
Mazer Rackham Posted September 3, 2025 Share Posted September 3, 2025 Soairse: To her mind, the 'wrong people' were the Aeldari... She nodded in agreement with Duskstrider's assessment. Belting her robes about her waist, she prepared to follow in their footsteps to hide their true numbers. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130772 Share on other sites More sharing options...
A.T. Posted September 3, 2025 Share Posted September 3, 2025 Ialandranth Veilseeker "The guardians leave no tracks beyond this place, at least not upon the land. Nor is there sign of the battle save for that of the humans." If the guardians had not been at the gate when they were awoken it would might their silence, though it seemed unlikely that the crude technology of the natives could have subdued them without conflict that would have scarred this beach in recognisable ways. Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130788 Share on other sites More sharing options...
Trokair Posted September 3, 2025 Author Share Posted September 3, 2025 Finding places from which to observe but remain unseen takes a little time, especially as you each take care to obscure any trace of your presence. By the times the Truck roll to a halt and humans jump out you have all found a place, perhaps in the shallows amongst the reads, or up in a canopy, some of you may even have crested a nearby hill to observe from a higher vantage point. The human meanwhile emerged cautiously, weapons raised they fanned out across the ruins and battlefield, checking the bodies as they went, much like yourself not long ago. Once satisfied that they were the only ones there an officer of some sort ordered the others about. Small groups begun to retrieve the fallen and lay them out by the side of the truck in a neat row. One human would then examine the dead, leaning in with instruments and tools. Once this one was done with a corpse some more soldiers would strip them of anything useful, draging the remains over to where another team had begun to dig a fair seized hole. A few of the dead however were not looted and discarded, instead placed in bags while still in uniform and gear, and then loaded into the rear of the second truck. It takes you some time and quite conversation over the squad coms to conclude that those dead that where being prepared for transport were, with a few exceptions that you had yet to puzzle out, the older ones, and that as far as you could judge, they may will have been the better equipped ex-humans as well. Mazer Rackham, Akylas and Mike Zulu 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6130821 Share on other sites More sharing options...
Mazer Rackham Posted September 6, 2025 Share Posted September 6, 2025 Soairse: Crouched in the ferns and bushes, she stilled her mind. No immediate touch of another Weave-Seeker could be discerned, but these humans had caused ripples of their own. On the surface, a curiosity, perhaps some petty internecine squabble. However, weeds rarely presented a problem to uproot singly, but gatehred togather formed quite a thicket of wretched gardening. The old Seer predicted doom, and to ignore such things was a mistake. She focused, the time and peace of mind allowing the humans to gain time and distance as they carted the dead kin away, closing her mind about her in a cloak, fingers reaching into the skein to snag a thread as quietly as she could. OOC: Whilst waiting for the humans to clear out, should take a short while. Augury: Fettered Auto-passes, no DoS - basically just asking for a compass pip. GM: 'Which way to our objective?' Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131110 Share on other sites More sharing options...
Trokair Posted September 6, 2025 Author Share Posted September 6, 2025 (edited) The gentle rippling of the reeds in the wind as the morning ripens begin to whisper, a susurrus, repeating in chorus with itself. “Here not now, now not here.” EDIT: @Mazer Rackham, it occourse to me that migth not be as usefull an answer as I wanted, so if you have a follow up question/thought let me know. Edited September 6, 2025 by Trokair Mazer Rackham and Mike Zulu 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131148 Share on other sites More sharing options...
Mike Zulu Posted September 7, 2025 Share Posted September 7, 2025 Ialathial Duskstrider: Spoiler Self-test to confirm Ialathial’s knowledge on humans… Common Lore (Xenos) = 33(Int) +0 = 33 required Roll d100: 29 = Pass, 0DoS Such selective reverence for the dead was not human behaviour Ialathial was familiar with. No matter their clan or faction, all were simultaneously dispensable and worthy in the eye of whatever deity they venerated. Why were the ones in bags so important over the others? “+A stench more foul than the decay about.+” Ialathial muttered nasally for effect. “+Should we pursue with discretion?+” Mazer Rackham and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131212 Share on other sites More sharing options...
A.T. Posted September 8, 2025 Share Posted September 8, 2025 Ialandranth Veilseeker "To pursue the vehicles themselves would be impractical, but they scar the ground in their wake." He indicates to those more isolated, "one could be taken, but would tip our hand." Mazer Rackham and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131265 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2025 Share Posted September 8, 2025 Soairse: A prisoner would be useful....but as the Warp Spider said....a risk so early in the expedition, but the weave was being fickle, and her attunement incomplete. The objective lay somewhere further on, perhaps long to the distance, but an understanding of the situation here would be useful. Besides, Duskstrider's words had unsettled her. Why would anyone value ripe and rot? The answer to that question was best not dwelled upon. She thought-sent communally in reply, his question a backwash. =Does anyone speak their guttural tongue?= Soairse could possibly prise answeres from the Human's mind, but without an interpreter it would be nought but babble. =If so, perhaps I can cause a distraction? What say you, friends?= She let her question attach to her thoughts, the impression of the crude Human vehicle. It would be a moment to find the ignition....or the handbrake. An Eldar vehicle was not so vulnerable, being activated by mental stimulus to stir the song of war within. Here though, just lights and clockwork - a child's toy. Their weapons were the same. A misfire....a grenade pin. A Pollineach. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131284 Share on other sites More sharing options...
Trokair Posted September 8, 2025 Author Share Posted September 8, 2025 (edited) I think you guys are working out a plan of sorts, good good, keep going. While one or two of the humans may have strayed close to your hidden position they had not discovered you. Their initial alertness and weariness eroded by the droll of collecting the dead. After a while a few of the work teams begun to examineing the wrecked vehicles scattered about, retrieving anything that seemed half way intact, and a few more corpses as well. Spoiler Map in case it is of help. Trees, bushes, shore and such are I hope self-explanatory. Brown lines are ruined stone wall segments and similar. Blue/Grey rectangle are the two trucks, humans from the trucks in the same colour with a darker one denoting the ‘officer’ and the lighter one denoting the ‘examiner’. The hexagon on the eastside is the pit being dug to for the striped bodies. Black rectangles are wrecked/damaged vehicles that where there when you arrived. Black circles are human corpses (individual or clumps) that you had as a team found in your initial short survey that are still there now (either becouse the humans had not found them yet, or just not gotten to them yet). The smaller rectangles in the north corner are some burned/damaged tent remains. Edited September 9, 2025 by Trokair Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386075-a-knocking-afar-ic-thread/page/7/#findComment-6131400 Share on other sites More sharing options...
