the Kunnin' of using your comrade as a shield which the Ork driver weaves behind seems to have very, very narrowly prevented destruction.
@Mazer Rackham - GM, does that mean that the Wrecka is headed towards Enkush?
Correct, hence why Incario's shots were resolved against the front armour.
What Ag has the Ork Driver got? Considering it was dealing with -20 for Enormous and -10 for Driving on Sand, that must have been a pretty damn good roll to Pass and get a DoS! :biggrin:
He gets bonuses for being green and fast, plus he gets to add manoeuvrability of the vehicle to the dodge, so he's not that badly off.
Edited by Mazer Rackham
@Trokair I'm not sure about anyone else, but Incario took 3 Wounds Impact to the Body (fluffed as non-penetrating damage, just bruised ribs or whatever?) if you fancy doing some First Aid Medicae tests?
(If anyone else was hurt worse, sort them out first, obvs)
Sure, no problem, Kur-Dawa will be providing some first aid when he is back in camp shortly (ie whenever I have time to get the post up today/tomorrow.
Anybody else need a band aid as well shout up.
9 hours ago, Mazer Rackham said:
Players may roll the following:
  • 1D3 HB Rounds
  • 1D5 Bolt Rounds
This represents the odds and sods falling down the back of a crate.
Is this a and or a or choice of rolls?
Edited by Trokair
Oh, I assumed each player could roll for 1 of those options? (Hence I obviously went HB for my roll, and the joke about getting others to also roll for HB ammo!)
If it's only 1 roll for the whole team, I'll take it back until we've agreed which to roll for.
And if it's 1 roll for each option, then someone else can roll for the regular Rounds?
Edited by Lysimachus
So, there are currently 4 seats, and 6 team members who are on foot (I assume the 2 Bikers don't need a ride?)
So, does that mean we should select 2 less of the available equipment options in order to make 2 more seats available?
Or...
Should we assume that we are all happy to go at a walking pace (with the Bikes acting as outriders) and load as much useful gear into the Rhino as it can take?
Or...
A topographical view of a Damocles Rhino will show that it only carries 4 Space Marines. Driver and Commander in the front, and two in the back sat along one wall opposite a cogitator bank that controls the Comms Array.
The only way to make more room is to is to get rid of the cogitator bank and that puts the kibosh on getting anything on the Second List.
Yes but also, no. This is the reason I okay'd two Techmarines, and I usually never would. Those cogitators will be networked, and possibly entombed within the same panel, a Techmarine should know how re-wire and reconnect, re-weld, solder and apply flux and heat-shrink, otherwise there's no point in having a Tech around.
I mean, sure, it'll be techno-blasphemy, and if you botch it, the whole thing could explode, but you've got a spanner and teeth to suck air through, so where's your sense of lubricated-elbow adventure? :whistling:
Indeed we aren't on Mars anymore, we have been released back to our Chapters with a degree of laissez-faire.
It's got a luggage rack up top innit?
