If I'm reading this right, with the Orbital Assault Detachment, you can finally Deep Strike Hammerfall Bunkers, like the God-Emperor intended.
Quote
Detachment Rule
Rapid-drop Deployment
Through the use of teleportation, Drop Pods and gunship insertion, entire strike forces of Space Marines and even their armoured support can deploy from orbit in a matter of moments, a capability that in and of itself has won entire wars.
At the start of the Declare Battle Formations step, select a number of ADEPTUS ASTARTES units (excluding TITANIC units) from your army based on the battle size, as shown below. Models in those units have the Deep Strike ability.
BATTLE SIZE NUMBER OF UNITS
Incursion 2
Strike Force 3
Onslaught 4
Each time an ADEPTUS ASTARTES model from your army makes an attack, if it was set up on the battlefield this turn, re-roll a Wound roll of 1. If it disembarked from a DROP POD this turn, re-roll a Hit roll of 1 as well.
Hammerfall Bunkers
Quote
FACTION KEYWORDS:
ADEPTUS ASTARTESKEYWORDS: FORTIFICATION, VEHICLE, IMPERIUM, HAMMERFALL BUNKER
I don't see anything that says it's not permissible. Do you?
Edited by Lathe Biosas
Forgot some important words.
Register a new account
Sign in
