Dr_Ruminahui Posted May 14 Share Posted May 14 (edited) Greetings Hive Tyrants, Neurotyrants, Norn Emissaries, and particularly feisty Gaunts! Call to Arms is back this year, with @Dr_Ruminahui running it again. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes, Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for the new Rapid Deployment vow. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Edited June 2 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/387956-event-call-to-arms-2026-tyranids/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 2 Author Share Posted June 2 (edited) STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Tyranid go to The Xenos Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Tyranid The below list should cover every model for the Tyranid (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 0.5pt Spore, other tokens 1pt Horm/Term/Neuro/Barbagaunt, Gargoyle, Genestealer, Van Ryan 2pts Ripper Swarms, Warriors, Lictor, Venom/Zoan/Neurothropes, Ravenors 3pts Hive/Tyrant Guard, Pyro/Biovore 5pts Tervigon, Exo/Toxicrene, Maleceptor, Haruspex, Tyrannofex, Tyrannocyte, Carnifex, Screamer Killer, Psychophage, Norns 7pts Harpy, Hive Crone 8pts Dimacheron 5pts Broodlord, Tyranid Prime, Neurotyrant, Deathleaper 10pts Swarmlord, Winged/Hive Tyrant Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Termagaunts(1ptx20), 3 Ravenors(2ptsx3), a Tervigon (5pts), and a Winged Hive Tyrant (10pts), your vow would be worth 41pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Tyranid Empire and Xenos to Victory!!! After June 15th, please do the same in the Xenos Stronghold! Rules and Place your Vow => The Xenos Stronghold For those who haven't done so already and are able, please consider donating to Bolter and Chainsword, as the current fundraising drive has not yet met B+C's yearly financial needs. All the mods and event organizers do their work out of love for the site, and the funds being raised are to keep the servers running and the software up to date. Edited July 20 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/387956-event-call-to-arms-2026-tyranids/#findComment-6173384 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15 Author Share Posted June 15 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these faction rally points - if you have any questions, please ask me in the Strongholds, by messaging me, or by choosing my name from the dropdown menu when typing @ then my name (@Dr_Ruminahui). Link to comment https://bolterandchainsword.com/topic/387956-event-call-to-arms-2026-tyranids/#findComment-6175601 Share on other sites More sharing options...
Khulu Posted July 19 Share Posted July 19 @Dr_Ruminahui is the Biovore being 1pt correct? It is massive for a 1pt model. For comparison here it is beside a ripper swarm (which is worth 2pts) 1 Back to top Link to comment https://bolterandchainsword.com/topic/387956-event-call-to-arms-2026-tyranids/#findComment-6179954 Share on other sites More sharing options...
Dr_Ruminahui Posted July 20 Author Share Posted July 20 @Khulu - Yeah, 1 point is definitely wrong. Can't say what that point level is based on, but I suspect its one that predates me. Or I got it wrong, that happens too. I think 3 points is more appropriate, as it appears to be about the same size as a killa kan, which is 3. Incidentally, the ripper is a bad comparison as it is currently overpointed - its going down to 1 point next year. 1 Back to top Link to comment https://bolterandchainsword.com/topic/387956-event-call-to-arms-2026-tyranids/#findComment-6180012 Share on other sites More sharing options...
