Posted (edited)
large.XenosTopper2026.png.d439db89abcac8
The Call to Arms 2026
XENOS STRONGHOLD
Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!!
large.Divider1.png.5809d6fbe0dcab748400d
What is The Call to Arms, I hear you ask?
The Call to Arms is a multi-forum event designed to  encourage us all to start a new army, or bolster our current forces.
The Forums of the B&C are divided up into five Strongholds;
The Astartes Stronghold
The Imperium Stronghold
The Chaos Stronghold
The Xenos Stronghold
The Heresy Stronghold
These five Strongholds will act as the hub for each of the five main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the four other Strongholds. At the end of the 3 months, the five Strongholds will face off, and overall winners will be declared.
Dates
Start Date: 15th JUNE 2026
End Date: 15th SEPTEMBER 2026
(Timezone will be GMT -8 [so, North American Pacific Coast time], please make local adjustments for time)
large.Divider2.png.7d9729ad45e63692f872c
So, how is it all going to work?
1.   As each of the Strongholds are treated independently (except for final rankings), you may choose to focus within a single Stronghold, or participate in several. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds.
2.  Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are 30K/40K scale Titans and models not associated with a given faction (such as Necromunda models and terrain), which may be pledged to any Stronghold.
3.  You may join in any of the Strongholds at any time within the 3 Month time-frame of The Call to Arms.
4.  For each Stronghold, you have a MAXIMUM of 3 Vows.  For each of these vows, you must finish your active vow before pledging to a second or third vow.  In addition, there are the following additional vows:
       a)  Job's a Big'Un:  you can vow a model with a value of 10 or more points, which you can work can work on alongside your other vows and complete at any time.
       b)  Rapid Deployment: this vow can be for any number of points and can be made at any time even if you have an uncompleted vow.  However it must be completed before completing any other vows (including any Job's a Big'Un vow).
5.  Once recorded, Vows may not be altered, however special considerations may be made upon request.
6.  There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing ANY vow in a Stronghold will invalidate ALL completed vows for that Stronghold.
large.Divider3.png.6fac4ec1dc2bf61028f71
How do I join in?
Each model has a point value based upon its size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model.  More specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below,
1/2pts  GW provided markers and token (for example, teleport homers, eldar shrine tokens, mine tokens, grot orderlies, squig bombs, etc.)
1pt   Infantry
2pts   Cavalry/Bikers
3pts   Heavy Weapons Teams / Walkers (Dreadnaughts, Sentinels)
4pts   Skimmers / Light Vehicles (Landspeeders, ATV, Armigers)
5pts   Small Tanks (Leman Russ, Rhino Variants)
6pts   Large Tanks (Rogal Dorn, Sicaran, Land Raider)
8pts   Superheavies (Baneblades etc)
10pts  Imperial Knight etc
Characters
5pts   Leader/Character models
10pts Primarchs
Note 1: Characters with Retinue, I.E. Saint Celestine.  The Leader model is worth 5pts, the other models are pointed as to their type - for example, Saint Celestine and her bodyguard would be 7 points - 5 for the Saint (leader), 1 each for her 2 seraphim buddies.
Note 2: "Named" models are only characters for Call to Arms if they have the character keyword (or equivalent) in their game rules.  For example, the named models in the Wardens of Ultramar, while Epic Heroes, do not have the character keyword and are not characters for this event.
30K/40K Scale Titans
20pts Warhound Titan
30pts Reaver Titan
40pts  Warbringer Titan
50pts Warlord Titan
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Mortalis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Mortalis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechanicus Transterranic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshrine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Mortalis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
Subfactions
In any Stronghold in which you have vowed, you have to choose which SUBFACTION you support with your vows.  This Subfaction must be one of the appropriate subfactions (listed above) for that Stronghold, and is chosen at the time of your first vow in a Stronghold (though may be changed upon request).
NOTE: Your chosen Subfaction doesn't have to correspond to your vowed models, although it typically does - for example, if you support the Necrons subfaction you can still paint Orks or Tau as part of your Xenos Stronghold vows.
How to Vow
Please make your vows in this thread in the following format;
"I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of the {Subfaction name} and the {Stronghold name} Stronghold on or before 15th September 2025, or bear the badge of failure until year's end."
In addition, please indicate if you vow as a Young Blood or if it contains an entry for the Master of Forge (see below for both).
For example:
"I, Dr Ruminahui, heed the Call to Arms and pledge to paint 6 pathfinders, an ethereal, a converted Imotekh and a Necromunda Fuel Tanks for 19 pts for the Glory of the T'au and the Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
The converted Imotekh is my Master of the the Forge submission"
The post that contains your Vow must include starting pictures that contain all the models from the Vow.
Starting models may be in any of the following conditions;
  • In the box
  • On the Sprue
  • Assembled
  • Single Colour Primed
  • Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour.
Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so.
Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown.
Required Completion Pictures: Each vow completion must contain pictures of all completed models - either in the form of a "group" photo or of each model/unit individually.  Indeed, both is recommended, as the group photo really shows off your progress, and the individual photos best show your hard work and facilitates choosing candidates for best painted.  All completed entries for Master of the Forge (see below) must have their own photos.
Once you have made your vow, pop this badge of Participation into your Signature:
large.XenosParticipation2026.png.21cab86
large.Divider4.png.6adec73db0aa2014beefe
Will there be badges?
Yes!!  There will be Badges awarded for various achievements during the event - many members put the badges they have earned in their signatures.  Note, these are separate and different from the ranks and achievements tracked by the forum software.
Badges are awarded for the following:
Event Failed: Xenocide
1-9 points: Completed
10-24 points: Warden of the Stars
25-44 points  Warrior of the Stars
45-76 points:  Hero of the Stars
75-99 points:  Champion of the Stars
100+ points:  Master of the Void
Princeps - Awarded to all completed 30K/40K scale Titans
[Stronghold] Champion - Awarded to the member who individually paints the most points worth of models in the Stronghold
Champions of the Horde - The Subfaction with the highest overall points worth of models in a Stronghold
Champion of the Call - The Subfaction that has the Highest Participation vs. Completion Percentage in a Stronghold.
As to the overall competition between the Strongholds, there will also be Badges awarded for the following;
Masters of the Horde - The Stronghold that completes the highest overall points worth of models.
Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage.
Grand Marshall - Individual with the Most Points of Models Painted across all Strongholds.
Finally, the following will be chosen by vote by the members:
Favourite Young Blood - This category is for participants who have been building and/or painting models for less than 12 months.  Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so when making their Vows.
Artificer - Top 3 best painted models from each Stronghold, chosen from a selection of models from the Stronghold made by the forum Moderators, Administrators and Librarians.
[Stronghold] Artificer - Best painted model/unit for each Stronghold, chosen by the members from the 3 Artificers for the Stronghold.
Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge will need to specifically declare that they are doing so when they vow the model.  Each member can only submit one model/unit
Master Artificer - Best painted model/unit for Call to Arms 2026, as chosen between the 5 Stronghold Artificers.
That's it, you've done it, you've made it to the end!!!
If you have any questions or queries, contact me,  @Dr_Ruminahui and I'll be more than happy to help you out.
F.A.Q.s
Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians?
A- Yes, this is acceptable.
Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos?
A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum.
Q- Are 3D prints allowed?
A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent.
THIS THREAD WILL REMAIN LOCKED UNTIL JUNE 15, 2026, AT WHICH TIME VOWS MAY COMMENCE.
In the meantime, please continue to use the main announcement thread and the Faction rally points to discuss your participation and to ask questions.
Edited by Dr_Ruminahui
  • 2 weeks later...
Posted (edited)
PARTICIPANTS
TOTAL STRONGHOLD RESULTS - Pledged: 950 pnts / Completed: 633.5 pnts / Secured: 528.5 pnts / 55.6 % Secured (66.7 % Completed) - 22 Participants, 16 (72.7 %) completed all Xenos vows
Aeldari - Pledged:  25.5 pnts / Completed:  25.5 pnts / Secured: 25.5 pnts / 100 % Completed
Participants:  1 Total, 1 Secured - 100 %
 Halandaar - Vow 1: 25.5 pnts - Complete
1x Warboss (5)
1x Bigboss (5)
1x Bannernob (5)
1x Painboy & Grot Orderly (5.5)
1x Dakkarig (5)
Drukari - Pledged:  75 pnts / Completed:  5 pnts / Secured: 5 pnts / 6.7 % Completed
Participants: 2 Total, 1 Secured - 50 %
Galron - Vow 1: 70 pnts- Incomplete
10x Wyches (10)
1x Succubus (5)
1x Lady Malice (5)
15x Scourges (15)
5x Incubi (5)
10x Hand of the Archon (10)
1x Raider (5)
1x Ravager (5)
1x Venom (4)
2x Chronos (6)
 Grotsmasha - Vow 1: 5 pnts - Complete
1x Drazhar (5)
Genestealer Cults - Pledged:  144 pnts / Completed: 144 pnts / Secured: 144 pnts /100 % Completed
Participants: 2 Total, 2 Secured - 100 %
 Malice Jr. - Vow 1: 27 pnts - Complete
1x Patriarch (5)
5x Genestealers (5)
2 xAbominants (10)
2x Aberrants (2)
1x Goliath Truck (5)
Sgtsharp - Vow 1: 117 pnts - Complete
40x Gretchin (40)
4x Runt herds (4)
1x Warboss (5)
10x Termagaunts (10)
11x Neuroguants (11)
1x Patriarch (5)
1x Neurotyrant (5)
1x Saboteur (5)
1x Primus (5)
1x Screamer Killer (5)
10x Neophyte hybrids (10)
5x GSC bikers (10)
4x assorted tokens (2)
Leagues of Votann - Pledged:  82 pnts / Completed: 82 pnts / Secured: 82 pnts / 100 % Completed
Participants: 3 Total, 3 Secured - 100 %
 AvePicante - Vow 1: 69 pnts - Complete
1x Khal (5)
1x Behrek Stornbrow (5)
1x High Grimnyr (5)
3x Thunderkyn (3),
24x Cthonian Beserks (24)
5x Hearthguard (5)
10x Hearthkin Warriors (10)
3x Pioneers (6)
12x Cthonian tokens (6)
Dr. Clock - Vow 1: 8 pnts- Complete
3x Berserks (3)
3x Thunderkyn (3)
2x Ironkyn (2)
Lord Ikka - Vow 1: 5 pnts - Completed
1x Buri Aegnirssen (5)
Necrons - Pledged:  29.5 pnts / Completed: 6.5 pnts / Secured: 6.5 pnts / 22 % Completed
 Metzombie - Vow 1: 23 pnts - Incomplete
9x Ophydian Destroyers (18)
1x Dynastic Conqueror (5)
Spazmolytic - Vow 1: 6.5 pnts - Complete
3x Scorpekh Destroyers with plasmacyte (6.5)
Orks - Pledged: 317 pnts / Completed:  140.5 pnts / Secured: 109.5 pnts / 34.3 % Secured (44 % Completed)
Participants: 6 Total, 4 Secured - 66.7 %
 Agnostic Doggo - Vow 1: 71 pnts- Incomplete
10x Grots + Herder (11)
12x Bikers (24)
18x Deff Coptas (36)
 Andes - Vow 1: 33 pnts - Complete 1,2,3,4,5,6
1x Warboss (5)
1x Bannernob (5)
1x Bigboss (5)
1x Painboy (5)
1x Weirdboy (5)
1x Wartrakk (3)
1x Big Mek Dakkarig (5)
Brother Lutheriel - Vow 1: 25 pnts - Complete
10x Beast Snaggas (10)
1x Snikrot (5)
1x Warboss (5)
1x Wurrboy (5)
Focslain - Vow 1: 31 pnts - Complete;  Vow 2: 105.5 pnts - Incomplete
19x Boyz (19)
3x Deff Coptas (6)
1x Deff Dread (3)
3x Brokyr Thunderkin (3)
20x Boyz (20)
10x Grots (10)
6x Deffcoptas (6)
3x Killa-kans (9)
1x Warboss (5)
1x Bigboss (5)
1x Painboy with orderly (5.5)
1x Weirdboy (5)
1x Waauugh banner (5)
1x Wartrike (5)
1x Dakkarig (5)
1x Wartrakk (3)
1x Wazbom Blastajet (6)
1x Squigbuggy (5)
1x Kustom Boosta-blasta (5)
 Heraclite - Vow 1: 0.5 pnts - Complete
1x Kommando grot token (0.5)
 Madao - Vow 1: 51 pnts - Complete
2x Warbosses (10)
1x Mek (5)
1x Painboy (5)
1x Painboss (5)
1x Kaptin Badrukk (5)
1x Zogstrog Grotsniffa (5)
1x Bigboss (5)
1x Bannermob (5)
1x Wierdboy (5)
2x Grot Orderlies (1)
T'au Empire - Pledged: 125 pnts / Completed: 100 pnts / Secured: 100 pnts / 80 % Completed
TPS - Vow 1: 61 pnts - Complete; Vow 2: 33.5 pnts - Complete; Vow 3: 5.5 pnts - Complete
1x Tigershark (20)
1x Twin lance and drones (11)
5x Crisis suits  (10)
10x Heathkyn (10)
5x Einhyr Hearthguard (5)
1x Einhyr Champion (5)
5x Stealthsuits + 3x drones/markers [6.5p]
10x Hernkin Yaegirs [10]
1x Kahl [5]
1x Grimnir + 2x drone friends [6]
1x Razorwing Jetfighter [6]
1x Magus (5)
1x Familiar (0.5)
 _Saracen - Vow 1: 25 pnts- Incomplete
3x Sunforge Crisis Battlesuits (6)
2x Broadside Battlesuits (6)
2x Ghostkeel Battlesuits (8)
1x Iridium Enforcer Commander (5)
Tyranids - Pledged:  152 pnts / Completed: 130 pnts / Secured: 130 pnts / 85.6 % Completed
Participants: 4 Total, 3 Secured - 75 %
 Brother Argent - Vow 1: 22 pnts - Complete
10x Termagants (10)
1x Ripper Swarm (2)
5x Barbgaunts (5)
1x Cryptek (5)
 kabaakaba - Vow 1: 22 pnts- Incomplete
10x Termagants (10)
1x Ripper Swarm (2)
1x Red Terror (10)
Khulu - Vow 1: 33 pnts - Complete; Vow 2: 45 pnts - Complete
1x Hive Tyrant (5)
1x Prime with Lash Whip (5)
1x Neurotyrant (with 2 neuroloids) (11)
6x Zoanthropes (12)
5x Hyperadapted Raveners (10)
5x Raveners (10)
10x Genestealers (10)
1x Broodlord (5)
1x Swarmlord (10)
Lautrec the Embraced - Vow 1: 30 pnts - Complete
20x Hormagaunts (20)
I, Focslain, heed the Call to Arms and pledge to paint 19 Boyz, 3 Deffcoptas, a Deffdread and 3 Brokyr Thunders for 31 pts for the Glory of the Ork Faction and the Xenos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
edit: Added picture
Edited by Focslain
I, Metzombie, heed the Call to Arms and pledge to paint 9 Ophydian Destroyers and a Dynastic Conqueror for 23 pts for the Glory of the Necrons and Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
Edited by Metzombie
I, Lord_Ikka, heed the Call to Arms and pledge to paint one Buri Aegnirssen for 5pts for the Glory of the Leagues of Votann and the Xenos Stronghold on or before 15th September 2026, or bear the badge of failure until year's end."
large.Buri1.jpg.fc657469c39739a9b3b6c9a9
"I, Agnostic Doggo, heed the Call to Arms and pledge to paint 10 gronts and their herder (11pnts) 12 war bikers (24 pnts) and 18 deff koptas (36 pnts) for 71 pts for the Glory of Gork  Mork the Wargh! and the Xenos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end."
So many plans for more orks. But I already have more points in a single vow then i planned but risking for imaginary biskets (ie badges)
Bad Moon Speed Wargh supporting my love of deff koptas. Regret or glory will be mine!
I Archon Galron pledge to complete a whopping 10 wyche squad, a succubus, Lady Malice, 15 Scourges, 5 incubi, 10 Hand of the Archon, 1 Raider, 1 Ravager, 1 Venom and two Chronos, for the Xenos strong hold.
Doing this from memory as I primed them last week on an increasingly rare-non humid day.
Edited by Galron
I, Brother Argent, swear my loyalties to the Great Devourer and vow to paint:
10x Termagants (10pts)
1x Ripper Swarm (2pts)
5x Barbgaunts (5pts)
1x Necron Cryptek (Store Anniversary Guy) (5pts)
For a total of 22 pts for the Tyranids Sub Forum.
large.XenosCTABefore1.jpg.8e0ee685c382559ca46eedbaa4f277b3.jpg.adfe9d3291b12f7b91a626736da732d5.jpg
Going for all Five Subforums this year. And hoping to actually finish...  Wish me luck.
19 hours ago, Dr_Ruminahui said:
@kabaakaba - How big is the new Red Terror - do you have a picture of it next to winged hive tyrant?
i have no Hive tyrant. but it's as larger as the Redemptor dread. and it's an Epic Hero and a Character. 100mm base
Spoiler
I, kabaakaba, heed the Call to Arms and pledge to paint 10 termagants, a ripper swarm and the Red Terror for 22 pts for the Glory of the Great Devourer and the Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
Edited by kabaakaba
pts update
Posted (edited)
@kabaakaba - I'll give the Red Terror 10 points.
Note, in the future I'll be demoting ripper swarms to 1 point - they simply aren't on the scale of other 2 point models and are, in painting area, smaller than 1 point models like terminator (or the termagaunts in the above photo).  That said, as they are marked at 2 points at the beginning of the event, they'll remain at that value for this year.
Vow finished, Buri Aegnirssen (Ironkin variant). For the Votann!
Edit- might even have been first, unintentionally. Again, a win for the stubby warriors!!
large.20260619_190544.jpg.733c9e56100e1b
large.20260619_190554.jpg.307d0bd86c7976
large.20260619_190605.jpg.68321f4b074805
Edited by Lord_Ikka
I, Dr. Clock, heed the Call to Arms and pledge to paint 3 Beserks, 3 Thunderkyn and 2 Ironkyn assistants for 8 pts for the Glory of the Galber Clan, The Leagues of Votann and the Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
large.Galber_Vow1.jpeg.89c4d1d5cdde06931
(The Ironkyn are in 3 pieces each on the sprues)
Cheers,
The Good Doctor.
I am going to cheese my first vow, sorry. The next one will be more fair.
I, Madao, heed the Call to Arms and pledge to paint: two Warbosses, Mek, Painboy, Painboss, Kaptin Badrukk, Zogstrog Grotsniffa, Bigboss, Bannernob, Weirdboy and two Grot Orderlies for 51 pts for the Glory of the Greatest Waaaagh! and the Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
Edited by Madao
one missing grot
I, andes, heed the Call to Arms and pledge to paint the following Armageddon orks:
Warboss [5 points]
Bannernob [5 points]
Bigboss [5 points]
Painboy [5 points]
Weirdboy [5 points]
Wartrakk [3 points]
Big Mek Dakkarig [3 points]
for 31 pts for the Glory of the Orks and the Xenos Stronghold on or before September 15th, or bear the badge of failure until year's end.
Spoiler
Edited by andes
corrected points values
I, Brother Lutheriel, heed the Call to Arms and pledge to paint:
10x beast snaggas (10 points)
1x Boss Snikrot (5 points)
1x Warboss (5 points)
and 1x wurrboy (5 points)
for 25 points for the Glory of the Ork faction and the Xenos Stronghold on or before 15th September 2026, or bear the badge of failure until year's end.
I've received (somewhat convolutedly) a message from @kabaakaba that he's lost access to the site for the moment, so he may be submitting his completions through me.  Or, if that doesn't work, I won't be counting his entries for this year's Call to Arms.
@andes - The Wartrack is 3 pnts, not 5 and the Dakkarig is 5 pnts if it is a character (3 if it isn't, as it appears to be redemptor sized, and that's what a redemptor is pointed at).  So I have you at 33 pnts unless I need to demote the Dakkarig, in which case you'll be at 31.
@Lord_Ikka - that's the first completion of CtA 2026 - well done.
@Madao - don't feel too bad about all the characters, in the Astartes Stronghold there is a vow of 15 (!!!) Captains.
* PARTICIPANT ENTRIES UPDATED AS OF THIS POST *
Please double check the Participants post to ensure that your vow is recorded correctly, for the correct number of points, for the right subfaction, correctly marked as completed (if completed) and is linked to the right post(s).
I am hoping to be able to participate in a limited manner later in the Event, which one of the following three models would y'all like to see most?
The Termin-Ork?
large.PSX_20260624_131759.jpg.fed43eb9c0
The Pred-Doc?orlarge.PSX_20260624_131738.jpg.756c161a53
or Da Hel-Boy?
large.PSX_20260624_131812.jpg.0e6fc252b2
Edited by Grotsmasha
I, TPS, heed the Call to Arms and vow to paint the following:
- Tau Tigershark (20)
- The Twin Lance and their little drone friends (12)
- 5 Crisis Battlesuits (10)
- 10 Demiurg Hearthkyn (10)
- 5 Einhyr Hearthguard (5)
- 1 Einhyr Champion (5)
for a total of 62 points for the glory of the Tau'va and the Xenos stronghold until the 15. of September or bear the badge of failure until year's end.
Register a new account
Sign in
