True Grit
Guest WG Vrox
I just use bolt pistol arms and hands then cut off the BP and attach a bolter. :D
The guy in the picture shows one of my 13th co. grey slayers with true grit, he's got it slung down while holding his chain sword up ready to use. ;)
http://img133.imageshack.us/img133/7260/truegritgreyslayerdi6.png
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747701
I want to make my new grey hunters have chainsword bayonets like in gears of war however I am unsure as to whether some players would be analy retentive in letting me use the models as grey hunters with a Bolter and close combat weapon. What do you guys think? In anycase I think that would be a cool idea in representing true grit.
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747703
There have been previous posts about true grit and how to represent it, and a lot of players have been using the bayonet method you just mentioned and they've had no trouble at all with other players using it. I say go for it, they looked pretty cool, just a combat knife on the end of the bolter. :D
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747708
@Vrox: You had been stupid enough to ask for pics. So i bore you all again with my old GH pics. :) ;)
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter6.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter5.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter4.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter3.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter2.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter1.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/GreyHunter7Front.jpg
At the end i used the bp and ccw arms from BC and Assault squad boxes.
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747738
Guest WG Vrox
Ok, I wanted to post a picture of the one I have so far, but I have never done such a thing. Went looking for how to/where to upload a picture and cant find a tutorial which prob means its easy as turning a screw, I just don't know where that screw is. Does anyone have a walk through on how to post/upload a picture?
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747783
hello, well there is a tutorial here on how to post pics
http://www.bolterandchainsword.com/index.p...howtopic=141716
as well as this there is something in the librarium on how to make chainsaw bayonets for bolters, if you havent already seen it. i dont think people will mind, you might have to point it out to them so no confusion, i would actually bet more people would ask how you did it cause as you said, it is a cool ide
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1747806
I typically model all my Grey Hunters with bolters in hand and one of the rather large Space Wolf knives from the accessory sprue somewhere on their armor. Usually they'll have it on their leg or waist for quick access. For Wolf Guard/power weapon guys, I just replace the bolt pistol on a bolt pistol arm with a bolter.
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1748036
Guest WG Vrox
Thanks Barek, working on more but will wait till I have the squad done for more pictures.
I was thinking of doing a model with a Bolter and a Bolt Pistol the Bolt Pistol being the CCW. Since C: SM now allows the use of either the BG or BP in combat, would this cause issues?
https://bolterandchainsword.com/topic/150380-true-grit/#findComment-1749334
