How to convert thunderwolves
Oldenhaller
Outstanding ideas all around! You guys got talent!
( passes around ale ) ... and make sure to throw your empty mug at the fireplace before leaving ;)
I'm not one for conversions myself, and the rare chance I do one its so slight that people just don't see it! :rolleyes:
I prefer using GW models, so I'm inclined to try my hand at using the white lions with wolf parts. I might go to as far as using the brass etchings from ForgeWorld to cover the high elf runes on the shoulders.
Just FYI, I've e-mailed ForgeWorld a few times with the suggestion of Thunderwolves/TWC. If, and when, I recieve a reply I'll post it here.
( passes around ale ) ... and make sure to throw your empty mug at the fireplace before leaving B)
I'm not one for conversions myself, and the rare chance I do one its so slight that people just don't see it! :)
You can easily cover the runes with a thin layer of Greenstuff...which you should probably do to get the shoulders the proper shaggy fur look anyways. The real problem I have found with doing the white lion models is getting the muzzle to look right.
http://cgi.ebay.com/Wolf-Mounts-for-Miniat...970312651073901
The older link was down, but I found same product I believe. Wondering if its worth $76 bucks for 5? Just got into 40k and been honing my skills, I really want to get into conversions and GS work.
They are same thing just being sold directly from maker, not through Pinoy Hobby Hub. Supposed to be better shipping and packaging now. This is mine I am working on now:
http://i150.photobucket.com/albums/s89/Grimtooth_photos/IMG_1046.jpg
From my counts-as SWs, DIY Storm Reavers chapter (medieval Germany theme)
http://img188.imageshack.us/img188/7770/dsc00742bw.jpg
http://img337.imageshack.us/img337/7282/dsc00743g.jpg
http://img375.imageshack.us/img375/3087/dsc00745.jpg
http://img192.imageshack.us/img192/4408/dsc00746sh.jpg
http://img59.imageshack.us/img59/816/dsc00747yh.jpg
http://img84.imageshack.us/img84/4870/dsc00748o.jpg
http://img39.imageshack.us/img39/2362/dsc00749h.jpg
  • 3 weeks later...
Today I recieved the Dire Wolf model from the Avatars of War. I will try to post some pics for size comparison with marines this evening - but looking at it now, it might work for TWL conversion. It needs sculpting the saddle however, If it will turn out smaller, at least I will have a mean looking Fenrisian wolf or Cyberwolf :eek
Taken from the other legit TWC thread:
Shameless plug.
They're in the Thunderwolf Cavalry post. I've been trying to make these for a while and they're 95% done, needing a bit of base work and transfers. I took them to a tournament last weekend and no-one had any problems with them.
They're all GW parts and are a decent size; you'll get an idea from the first pic with the Dread in between them.
http://i167.photobucket.com/albums/u134/StormbrowII/DSC01781.jpg
EDIT: Pics.
This is the dire wolf from the Avatars of War. I guess it's the same size as the Russian thunderwolves from e-bay.
A bit smaller than I expected but I hope to knock out some decent conversion out of him.
http://content21-foto.inbox.lv/albums136010859/emils_photo/Space-wolves/Image00003-1.jpg
http://content21-foto.inbox.lv/albums136010862/emils_photo/Space-wolves/Image00004-1.jpg
http://content21-foto.inbox.lv/albums136010864/emils_photo/Space-wolves/Image00005.jpg
  • 2 weeks later...
I have gotten the wolves from thunderbolt mountain and they would work great as a fenrisian wolf, but are a bit small for a thunder wolf. For my thunder wolves i used the D&D miniatures dire wolf.
How big are dire wolf bases? Do you need to slap a dreadnought 60mm base underneath the dire wolf base?
Because my conversion skills are non-existent, I think I am going to go with a cheap non-GW option, like these dire wolves. The resin models look nice, but require more work and are more expensive... and if I go the cheap way, I won't feel so bad if in a year or two I have to buy GW ones (if I want to play wolf cavalry in a tournament).
Hello past self, I can answer this question for you. The dire wolf base is probably around 45 mm. You either attach the wolf, base and all, to a 60mm dreadnought base, or you cut the dire wolf off its base and attach it to the dreadnought base directly. Knowing how lazy you are, I bet you will stick the two bases together.
i alway have around 6 HE converted War Lions. I (dont at times) like them much myself, cause i am a mix of lazy and my green stuff-fu is very very weak. i have seen several EXCELLENT conversions though, so it ultimately is with the modeler to do their best.
i keep them anyways, as they are a point of pride for me (no other Wolf in the area has TWC) and there is no official model yet.
WLK
Space Lions its like "Thunder Cats", would be cool to do for a lone wolf model being some big cats are single ambush hunters
  • 2 weeks later...
it has been a while since there has been a post on this topic, so here goes:
the upcoming plastic bloodcrushers have potential. the codex does mention mechanical thunderwolves with cybernetic parts. possibly a vid-steel convertion is in order :D
may get some myself ;)
