Silver Skulls: Gideon Battle Tanks
SickSix
Very nice work, 'Six!
The gold(bronze?) on the Sternguard is particularly nice...care to share the recipe?
The green - particularly on the librarian - contrasts really nicely with the silver. And you did a good job on the face! Don't knock it. You could add a little flesh-grey mix as stubble across the top of his head, perhaps.
The VVs also look great and you've done a great job on those powerswords! The huge axe looks like the haft is a bit bent, which detracts from an otherwise very impressive weapon! Could you straighten it? Perhaps add a long trailing purity seal wrapped round the haft too? That would break up the featureless length.
Well there is a mixture of bronze and brass. To get a darker effect I used Vallejo Game Color Hammered Copper as a base and then a thinned highlight of VGC Brassy Brass and then a sepia wash. To get the brighter effect I used a base of VGC Brassy Brass and then a thinned highlight of VGC Bright Bronze with sepia wash.
I was very pleased with the green on the Libby. I am definitely going with green for my company color now. The face only looks 'decent' because the camera can't focus any closer! haha. I will work on it some more later.
Thanks. The power swords were a pain in the but! I used the airbrush and masking technique. I had one power sword totally fail on my though as a huge chunk of paint came off with the tape! Luckily it was on the underside of sword so you couldn't really see it. I am going to try wet blending next time. The axe is slightly bent, however the connection between it and the model is very fragile and it will probably stay as is. It's actually better than it was as I did straighten it a little in hot water. And I will look at adding more detail and effects to the weapon later.
Thanks for the compliments, tips and constructive critique!
So having all black vehicles sucks. I am glad they are not 100% black though as I did mix black and a dark grey color. Anyways, here's my first attempts at highlighting vehicles.
The pictures aren't great I know. But looking for feedback on whether it's too much or not enough or how to do it better. I don't know if you can really tell but there is a little 'bare metal' effect on the edges here and there so it looks like the paint was scraped away. Haven't attempted any real battle-damage effect yet. So any feedback is appreciated.
I think the highlighting is good. if you really want to make it pop, then go for the next shade higher of grey and do the extreme edges. But they do look good as it is.
For the battle damage, generally you need to have a colour underneath the metal stroke, like scorched brown or Charadon granite, to look like the paint had been scorched. I'd try one of these and then paint the metal. I think it will have a better effect than just going from black to metal.
  • 2 weeks later...
So I have problems with fine detail, proper paint thickness and fast drying paint. This trio of problems became a frustrating nightmare trying to paint these damn wings!
So I have to thin the paint a LOT (what you see is 4-5 coats) to avoid problems with the paint on the tip of the brush drying nearly instantly. I just can't figure out how some people seem to get good coverage in one pass and not have the paint dry on the brush. I guess white just really exasperates the problem.
Hi Six, with drying issues are you using a "wet palette" and a "flow aid"(or medium) to thin your paints?
I have tried a wet palette. The issue is once the paint is on the brush and moved toward the model. I use water and have tried using Vallejo's air brush thinner but it doesn't seem as effective when brushing.
Literally the paint on the end of the brush will dry while having a bulb of wet paint half way up the hairs. I am using a kolinsky brush.
Try some Winsor & Newton Acrylic Flow Improver or possibly better still with Vallejo paints some Vallejo Retarder Medium. The retarder will slow drying times quite a bit depending on how much you add but it is designed to help with wet blending so should cure quick drying too.
I suspect that your brush is actually too small. Try using a larger brush. I know it sounds counter-intuitive, but a larger brush holds more paint, keeping the paint wet longer in brush. The smallest brush I use usually is a WN Series 7 1 (full size). I use a 2 for the larger areas.
That's actually a very interesting point! I shall try a larger brush. I have been using a W&N 7 size 0. I believe I do have a size 1. I shall try it.
A small update. I have got some Vallejo Model Air Chrome and I think it really stands out as my 'silver' highlight. I tried it first on my Terminators.
And here is a WIP shot of the first two Dreadnoughts.
Where is the skull from on the termi's? They look great! My guest would be tom blords?
So I saw these posted on Dakka..... I must have some!
http://4.bp.blogspot.com/-Wg1hZkW9hw4/T3SWOge7rSI/AAAAAAAABDM/uCSdpfjCvCQ/s1600/warhammer40k_28mm_resin_skull_helmets_painted.jpg
Of course I will have to assemble MOAR marines to use them.....
  • 3 weeks later...
So I have come to a stopping point on the Furioso for my friend. I would like to do a little more detail work but it's already a month late. I know one thing, my edge highlighting needs a LOT of work. This thing taught me a lot and showed me a lot of areas I need more practice on.
I hope the receiver of this gift is pleased.
