Painting Khorne Armour
hackziden
Hi all,
I am currently painting an army of Khorne Berserkers (as well as a warhammer fantasy box of chaos knights) and have got a basic army paint scheme that I need help with perfecting.
My basic paint scheme looks a bit like this:
Base Coat: Mephiston Red
Wash: Nuln Oil
Layer: Mephiston Red
That's what my current paint scheme looks like...but it needs a bit of modifying nuke.gif, for example, what colour should I use to edge highlight the model? And also, is there a better colour for me to use as my layer instead of Mephiston Red?
hackziden
https://bolterandchainsword.com/topic/271087-painting-khorne-armour/
Though I can't tell you what GW colors were used, this thread shows my base red in the first post, and then about half way down the first page, there is a fully done model in World Eaters colors. I washed the full model in brown (which works well with the golds), and then used the original red, a red-orange, and white to (extreme) hilight.
http://www.bolterandchainsword.com/topic/249710-my-upcoming-chaos-army/
I like the way that you painted those khorne berserkers, they look really cool :) . When you say that you can't tell me the GW colours, is that because you didn't use GW? or because it's top secret? :P
From what I see - start from some sort of warm dark brown colour and slowly build up highlights by adding red and then orange.
So, I think that if I followed your scheme, it may end up doing something like this:
Base: Baneblade Brown
Shade: Nuln Oil
Edge Highlight: Troll Slayer Orange
I think that sounds like it would work...agreed?
If you want to invest a bit ( ok, very much :D) time then this tutorial might be helpful. http://chestofcolors.com/forum/viewtopic.php?f=37&t=5888
This one is also very nice. http://platoonbritannica.com/index.php?threads/finished-stuff.533/page-4
Both are the product of two great and very experienced artists but even an imperfect implementation of these tutorials should offer good results.
If you want to invest a bit ( ok, very much biggrin.png) time then this tutorial might be helpful. http://chestofcolors.com/forum/viewtopic.php?f=37&t=5888
That is an awesome guide, that is the boon that I have been searching the warp for: thank you VERY much :)
It primarily depends on how deep you want your reds to be. Mephiston is a good base, or maybe like some have suggested go with browns first, then deep reds. I did Huron (which is admittedly a more vibrant orangey red than you're probably looking for) with Mephiston Red base, a layer of Evil Sunz Scarlet, some Nuln Oil, and a med/heavy drybrush of more ESS on top, it came out looking almost exactly like the shade on the clam shell insert, and I used one less paint pot than the WD recommended. I was surprised.
Looked at GW paints, Moonfang Brown seems to be closer match to what I've meant. I don't know how it will look on the miniature, though. You can use diluted Nuln Oil to wash it a bit, but I suggest to use something like Agrax Earthshade instead. Also, what primer will you use?
Layer and highlight seems to be good, but first use 1:1 mix of Red and Orange.
Cheers, hope I somehow helped you.
Im using a skull white spray to base, and im also aiming to use as littlr a range of paints as possible, as im still at school so cant reallu buy much, that scheme sounds fairly simple too. My only problem is mixing, how do i consistantly and effectively mix...i like this ides by the way :)
Oh, andd what is your profile picture? It seems familiar :( it feels like something ill kick myself over when i find out XD
I like the way that you painted those khorne berserkers, they look really cool smile.png . When you say that you can't tell me the GW colours, is that because you didn't use GW? or because it's top secret? tongue.png
I don't use GW paints. I prefer to mix my own colors.
Oh, with white primer I don't think you really need brown base :)
For less confusing in the future - what paints do you have right now? Mixing is a little bit tricky with GW paints, pallete and accurate eye is required.
Sloth :)
At this moment in time, i only have the fang, fenrisian grey, lead belcher and nuln oil and some old withered paint pots :p im goinv to buy a wider range of new paintx so i dont mind a few colours...but not say, £30 worth that wont be used ever again :)
