Mercay's Raven Guard 5th company, Victorus aut Mortis!
Mercay
Hey ho!
Very long time lurker here who finally has gathered enough courage (and finally have something worth sharing, hopefully) to start my own WIP blog!
Making a long story short, since I bought my very first miniatures back in 2004, a space marine combat squad, I've lived and breathed Space Marines and IoM in general, having started but never finished more space marine armies than I can recall, I now feel that I for once should get something memorable going and completed.
I knew wanted to create a force of one of the first founding chapters but that was about it, so I sat down for quite some time to see what my options were. I wanted to use the regular marine codex, so that left out the Space Wolves, the Blood Angels and the Dark Angels, I also knew that I did not want to go with something as popular as the Ultramarines, for example.
In the past I had always gone for very... flamboyant color schemes, all the brightest of colors you could imagine, so I decided to go the opposite way this time which basically left me with either the Iron Hands or the Raven Guard.
I was extremely tempted to go with the Iron Hands due to their affinity for all things mechanical, the conversion possibilities regarding bionics and techmarine-inspired captains and the like almost made me go with them...
But then I got my hands on Deliverance Lost, and the deal was settled, I would depict the Raven Guard in all their sneaky-stealth glory!
After spending some time practicing painting black armor, as well as the white that goes with it, I'll hereby unveil my very first completed test model:
http://i.imgur.com/ZPqIrg7.jpg
Do note that he hasn't had his matte coat applied yet, so there is a bit of a glare on certain areas!
At first this model was actually destined to lead the force as 5th company's Shadow Captain Corvane Valar, but I have since ordered some more goodies from forgeworld which should arrive any day now. This will allow me to add a bit more detailed bling as befits a captain of the adeptus astartes. happy.png
I'll get around to setting up a proper lightbox soon as well.
Well that about rounds my very first post up, any constructive criticism is always very welcome!
Simple, arrogant, fierce, deadly looking.
Kudos Mercay, very neat job. I really want to see more of this project!
EDIT:
Criticism: It looks great as is, I wouldn't add much more bling. The colors and subtle weathering are very well done.
Thank you for the replies guys!
@Maximvs I was at first going with this model as my captain but I simply felt that he will blend in a bit too much with the "regular" marines, but I agree I'm not going to go crazy with the bling factor, going to use korvydae's body and legs, and possibly jump pack for my captain 2.0 happy.png
That looks real great. What'd you use to do the weathering/dust effect on his boots? Did you put dirt on his helmet as well?
Thanks man, I used the forgeworld weathering powders for the dust effect, namely the light earth one as well as a very thin dusting of light rust. And yes, I did dab a tiny bit of it on his helmet to break up the white a bit.
Good old RG
This force will be 41st millennium I'm afraid, although I have been thinking about making a proper heresy/pre-heresy force some time in the future, if they are to be raven guard is yet to be decided. happy.png
Awesome! Great use of bitz. One thing I personally dislike about the Mk IV armour is the skinny thighs, I usually try to add bulk with ammo pouches, holsters, knives and such.
I'm no expert on Raven Guard markings, but I think a black stripe on his helmet would look really cool, one like the veteran sergeants use to have.
Thank you very much for your kind words everyone, it means a lot to me! biggrin.png
I agree that the thighs do look a bit skinny, I should have gone with a pistol holster instead of the standard small pouches but oh well, its only a test model after all!
Regarding the markings, I will stick pretty closely to their "official" markings, while making sure that I'm first and foremost happy with the look of the model. The markings I'm most likely going with for the helmets will be:
Regular marines: all black.
Regular Sergeants: all white.
Veterans: one white stripe vertically down across the faceplate over the black.
Veteran Sergeants: one black stripe vertically down across the faceplate over the white.
So basically, veterancy is indicated by a vertical stripe, sergeants are indicated by an all white helmet.
This does leave the issue of how the new captains helmet will be done... unsure.png
Alternatively I might just go with all white helmets for all sergeants and veterans, since that will give them a more simplistic look.
Any ideas?
Great pose and nice paint job, looking forward to more.
How'd you paint your black?
Thanks!
I was aiming toward having a simple but effective way of painting the "ravens" black. The trick as I discovered was to have quite a dark highlight, darker than you usually see with black models such as the black templars.
This is how I do it:
1. After basecoating it black I paint the whole model with watered down abaddon black to cover any areas missed by the spray. It also gives the model a better finish compared to only having the basecoat.
2. Mix up some "RG black", around 2/3 abaddon black and 1/3 eshin gray and make sure to water it down quite a bit. Apply this as the first highlight quite liberally.
2.2 For the fancier models I add more gray to the mix here and start doing the finer highlighting, for the basic models I skip this step.
3. Pure, slightly watered down eshin gray in very thin lines as an extreme highlight.
4. Nuln oil wash in all the panel gaps that you feel need it, it gives them a bit more shadow/depth.
If I wasn't going with the weathered look I would most likely have to add more steps to the highlighting process to give the model the depth I'm looking for.
I'll soon have the first 5 man combat squad done, will post 'em up here as soon as they are!
Anyone have some fancy trick for applying decals? The raven guard ones are quite large so getting them to sit flat on the shoulderplates feels almost impossible. confused.gif
Right now I'm just going with gloss varnish on the shoulder, apply decal and more varnish to seal it in, are there any better ways of getting it done neatly?
Microset and Microsol will work wonders on the decal front. You can get them off eBay and tutorials are all over the web. They made my decals look like they'd been painted on so I really can't say enough good things about them, just try them out!
I'm a huge fan of that model. 100% how Raven Guard should look in my opinion. Love the subtle weathering, the minimal use of white, the crispness - really nice. Looking forward to seeing more!
I'd like to chime in and say this guy is great. Your has a depth and oiliness to it which is fantastic, and your white is gorgeously crisp. I'm a fan of the Raven Guard and I can't wait to see more if this is the standard they'll be at. Really lovely job on this guy.
