*Furyou Miko Posted August 3, 2014 Share Posted August 3, 2014 That's a different way of doing the inferno pistol conversion. I don't like it, personally - looks like she's got meltaguns, I think, they're too big. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764698 Share on other sites More sharing options...
deathhasdignity Posted August 3, 2014 Author Share Posted August 3, 2014 They are a bit bigger than I would have ideally liked, but at the moment that's the best I can do with bits available, what would you suggest or use instead? Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764796 Share on other sites More sharing options...
*Furyou Miko Posted August 3, 2014 Share Posted August 3, 2014 Hand Flamer seraphim. Clip off the fuel tank and the pilot light, widen the holes in the muzzle slightly, and use GS to make a melta canister on the side of the pistol. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764820 Share on other sites More sharing options...
deathhasdignity Posted August 3, 2014 Author Share Posted August 3, 2014 Hand Flamer seraphim. Clip off the fuel tank and the pilot light, widen the holes in the muzzle slightly, and use GS to make a melta canister on the side of the pistol. Sounds cool, I'll give that a whirl sometime! Meanwhile finished 3 of the 6 http://i34.photobucket.com/albums/d117/deathhasdignity/Adepta%20Sororita/Troops/85E47869-07B1-4770-81B0-5CD3B7C55262_zpsgt3wslcw.jpg Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764828 Share on other sites More sharing options...
deathhasdignity Posted August 3, 2014 Author Share Posted August 3, 2014 Had a look about: Blood Angels Sanguinary Guard Infernus Pistol this might be an option for inferno pistols http://i34.photobucket.com/albums/d117/deathhasdignity/inferno_zps70e790bd.jpg Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764843 Share on other sites More sharing options...
*Furyou Miko Posted August 3, 2014 Share Posted August 3, 2014 The Sanguinary Guard one is about the same size as the ones you converted. ^^; Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764953 Share on other sites More sharing options...
deathhasdignity Posted August 3, 2014 Author Share Posted August 3, 2014 The Sanguinary Guard one is about the same size as the ones you converted. ^^; Thanks, hoping it was smaller! Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3764966 Share on other sites More sharing options...
oreaper84 Posted August 4, 2014 Share Posted August 4, 2014 i like the seraphim a lot, especially the way you mitigated those jumpy bases Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3765268 Share on other sites More sharing options...
deathhasdignity Posted August 4, 2014 Author Share Posted August 4, 2014 i like the seraphim a lot, especially the way you mitigated those jumpy bases Thanks, thats as good as my greenstuff skills get, lumps of rocks! Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3765284 Share on other sites More sharing options...
Eddie Orlock Posted August 4, 2014 Share Posted August 4, 2014 So, what your could consider if you had a razor saw is taking advantage of the thickness of the saw blade. First I'd drill straight and square down the centre of the barrel to insert a pin, not for strength, mind you, but alignment. Next, I'd probably make two cuts laterally through the heat shield barrel bit, one probably through the two outer holes and the stock end hole and once through the muzzle end hole. This should shorten your weapon two blade widths. If this isn't enough, repeat going through the two outer holes and the muzzle hole and the stock hole respectively for four blade widths. This is, of course, not how I crafted my own, but given that I recently uploaded a picture of mine I'll share it and talk about what I actually did do:You can see my inferno pistolier behind the Canoness, she wields weapons looted from the canoness kit back during, if I recall it correctly that poor, brief, window when bits order overlapped with the revised canoness model. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3766050 Share on other sites More sharing options...
deathhasdignity Posted August 6, 2014 Author Share Posted August 6, 2014 Still have a few essentials to paint up for my 1500pts plus swaps force I'm thinking after I'm done, just as an exercise cause there so cool painting up some repentia and making them a bling rhino transport or building a command rhino, as it happens found some laser transfer paper last night so had a pop at this, what do people think? http://i34.photobucket.com/albums/d117/deathhasdignity/Adepta%20Sororita/Troops/19E2D75D-C679-4A58-A8F6-A90420FC0ACC_zpst4cg3ima.jpg Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768261 Share on other sites More sharing options...
Ullr Direfang Posted August 6, 2014 Share Posted August 6, 2014 'nuf said Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768349 Share on other sites More sharing options...
*Furyou Miko Posted August 7, 2014 Share Posted August 7, 2014 That's pretty badass. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768450 Share on other sites More sharing options...
Naminé Posted August 7, 2014 Share Posted August 7, 2014 I must be showing my age here but what is laser transfer paper and how do I use it? :p Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768659 Share on other sites More sharing options...
WarriorFish Posted August 7, 2014 Share Posted August 7, 2014 Excellent, now do an entire vehicle in it! :lol: Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768707 Share on other sites More sharing options...
deathhasdignity Posted August 7, 2014 Author Share Posted August 7, 2014 I must be showing my age here but what is laser transfer paper and how do I use it? Waterslide decal paper especially for Laser printers Transfer your own images or text onto plastic, ceramics, metals or wood Create decals for model planes and vintage railway accessories. Print photo's onto mugs and plates or your own art onto glass coasters etc For our full range, type Mr Decal Paper into the Amazon search box Works a treat A4 sheets, done a full sheet with markings and icons http://i34.photobucket.com/albums/d117/deathhasdignity/Transfers_zps5db9654c.jpg Excellent, now do an entire vehicle in it! So tempted to try it!! Anyone know where I can get a scale line drawing of a rhino I could use as a template to lay up the transfer on, if yes I'm game Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768764 Share on other sites More sharing options...
*Furyou Miko Posted August 7, 2014 Share Posted August 7, 2014 Should be able to scan one in from Imperial Armour. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768813 Share on other sites More sharing options...
Solynnor Posted August 7, 2014 Share Posted August 7, 2014 Holy s.... I do need to test this asap !!!! As i'm a bad free hand painter, i want this. Thank you to show us this hint !! Amazing job :) Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3768841 Share on other sites More sharing options...
WarriorFish Posted August 7, 2014 Share Posted August 7, 2014 I wanted to try printing like this a while back, but the work laser printer is only B&W. They're getting a new one soon so perhaps my chance will yet come... :P What about transparency, is that more viable these days? Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3769363 Share on other sites More sharing options...
deathhasdignity Posted August 7, 2014 Author Share Posted August 7, 2014 Stuff I used was transparent, I'd still recommend micro sol and set as it softens the transfer and helps it mold to the surface, matt varnishing after really gives it a painted look. You can get an inkjet version of the same paper DHD Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3769532 Share on other sites More sharing options...
GamesEtc Posted August 8, 2014 Share Posted August 8, 2014 · Hidden by thade, August 11, 2014 - IP violation (paper replacement for a GW model) Hidden by thade, August 11, 2014 - IP violation (paper replacement for a GW model) Anyone know where I can get a scale line drawing of a rhino Check for papercraft rhino patterns. Here is one Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3769830
Duke Danse Macabre Posted August 13, 2014 Share Posted August 13, 2014 Wish I could do this myself but I will need a printer. Damn it, why are sisters always the most expensive to do anything with? :( Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3775279 Share on other sites More sharing options...
Dread Posted August 13, 2014 Share Posted August 13, 2014 Because they are awesome! Like the DE, hard to use but with a win so worth it. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3775463 Share on other sites More sharing options...
Duke Danse Macabre Posted August 13, 2014 Share Posted August 13, 2014 Have you ever considered for the inferno pistols just cutting away the mag from the bolt pistol and the gun breach and adding a melta gun muzzle where the bolt pistol one was? It gets the job done and is relatively simple. Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3776287 Share on other sites More sharing options...
deathhasdignity Posted August 13, 2014 Author Share Posted August 13, 2014 Have you ever considered for the inferno pistols just cutting away the mag from the bolt pistol and the gun breach and adding a melta gun muzzle where the bolt pistol one was? It gets the job done and is relatively simple. Thats what I did http://i34.photobucket.com/albums/d117/deathhasdignity/Adepta%20Sororita/Troops/85E47869-07B1-4770-81B0-5CD3B7C55262_zpsgt3wslcw.jpg Link to comment https://bolterandchainsword.com/topic/292884-deathhasdignitys-modeling-painting-work-merged/page/4/#findComment-3776383 Share on other sites More sharing options...
