HQ:
• Legion Praetor - Paragon Blade, Iron Halo - 150pts
ELITES:
• Legion Veteran Tactical Squad - 9x Marines - 185pts
• Contemptor Dreadnought - Multi-melta - 175pts
TROOPS:
• Legion Tactical Squad - 10x Marines, Vexila, Sergeant w/Power Fist & Artificer Armor, Rhino APC - 200pts
HEAVY SUPPORT:
• Legion Heavy Support Squad - 5x Missile Launchers, Augury Scanner - 165pts
• Landraider Phobos - 250pts
TOTAL: 1500pts
Hey folks, here is my first attempt at a Heresy Blood Angels list, the idea is to have an adaptable armored strike force backed up by the Devastators and 2 Multi-Melta Contemptors. I kinda wanted an aggressive, assault feel that fits with the Blood Angels MO, but that also shows their tactical aptitude and rapid reactionary abilities.
Any advice from 30k veterans would be greatly appreciated, thanks for you time!
https://bolterandchainsword.com/topic/298196-blood-angels-1500pts/
Something to consider with Tac Vets is which special rule you'll be using.
For Example : 10 Tac Vets with 2 Heavy Bolters on Suspensor Webs (makes the Heavy rule Assault but halves the range in a weapons profile if desired) and the Sniper Rule can provide some really nasty Psuedo-Rending through Weight of Fire.
For the Preator, why a Jump Pack? Him being the only one to put its movement benefits to good use seems like a waste since he'll either never make use of it when stuck to another unit or be singled out when he does. At which point he becomes a pretty hefty loss of points. Since he has the Jump Pack, he also counts as Bulky (right?) and couldn't fit inside the LR Phobos with 9 Tac Vets if that was the case, as the Phobos is 10 slots.
Whoops! I meant to edit out that jump pack. He's gonna be on foot with the Tac Vets in the raider. As far as the special rule I figured I'd give them furious charge or fearless to fit with their role as assaulters alongside the Praetor.
Did you consider Outflank? An outflanking Land Raider could be pretty deadly.
Also, if you're running them stock I think its a Bit of a Wasted Potential since they are a pretty flexible unit, if you have the points.
Another thing, did you consider a Consul over the Preator or are you using a Rite of War? If not, getting a Preator just for the Paragon Blade seems kinda wasteful, points wise. Fluff wise, no complaints at all.
Yeah I liked the idea of str5 ap2 power blade carving up enemy hard units, I didn't know what else I could use for an assault unit seeing as most everything else comes in squad sizes of 10 so they won't fit in the raider with the Praetor. I'm not against using a centurion, but seeing as most of my opponents here are running nasty HQ's I wanted someone who could lay the smack down in CC.
I'd go as far to drop the vets in favor of some terminators. I know you can't do it with a regular squad to fit in the raider, but do a 4 man command squad.
Just give them all terminator armor so that they have power weapons base, an invulnerable save, and fearless with the banner to boot. According to the new red HH book, any legion without rules can take stubborn or furious charge, so taking the latter is pretty obvious - and is the force wide :)
That will also leave you with an additional 5 points.
I'd even suggest dropping the missile squad for a Sicaran battle tank as it can put out more deadly firepower, and fits with the mechanized list.
Okay so I changed it up a little by adding the Sicaran and dropping the Heavy Support Marines. I chose to keep the veteran Tacticals as I like having 9 guys with three attacks a piece, rather than 4 Terminators with only 2 Attacks a piece for the same price. I gave the Landraider an auxiliary drive as well just to make sure it gets where it needs to go.
HQ:
ELITES:
TROOPS:
HEAVY SUPPORT:
• Legion Sicaran Battle Tank - 155pts
• Landraider Phobos - Auxiliary Drive - 250pts
TOTAL: 1500pts
Yeah I was planning on magnetizing the Contemptor arms so I could do exactly that and have them be full-on Furiosos. Also no worries about the armored ceramite, no one here plays 30k (to my knowledge) unfortunately :( If any of my friends do eventually build Heresy armies then I'll probably switch it up a little.
If you ever want to scare someone who uses a lot of flyers you know what to do msn-wink.gif
And Furioso Contemptors. Hard to go back to box dreads after getting a few of them. Especially with the inevitable Legion Specific one that FW will make.
...in case you (or someone else reading this) don't : 2TLLC, 2 Kheres or 2 Autocannon Mortis Dreads
Alright so I finally got my hands on the 30k battlescribe files and I've been toying around with this list some more. Let me know what you guys think:
HQ:
• Legion Praetor - Paragon Blade, Iron Halo, Melta Bombs, Volkite Serpenta - 160pts
ELITES:
• Legion Veteran Tactical Squad - 9x Marines, 9x Melta Bombs, Furious Charge - 210pts
• Contemptor-Mortis Dreadnought - 2x Kheres Assault Cannons - 180pts
TROOPS:
• Legion Tactical Squad - 10x Marines, Vexila, Sergeant w/Power Fist & Artificer Armor, Rhino APC - 220pts
HEAVY SUPPORT:
• Legion Predator Executioner - Plasma Executioner Cannon, Heavy Bolter Sponsons - 130pts
TOTAL: 1500pts
