Dantay's VI Legion. Hvarls Headtakers
Dantay VI
Thanks Quinnwolf... Yes I thought green would be pretty god and would stop te red from dominating the face masks.
Thanks grieux, maens a lot from someone as talented as yourself... It is just some Iron Warrior, Imperial Fist helms slightly changed and some stock Alpha Legion helms.
Oh, I saw this and thought about you discussions on Mastodons in the tactica section.... I think it is time to unleash the long boats :D
784ebd20b20985cfb794e9814ef8c127
The marines are from "troll trader" on ebay was £14 for a squad of 10 or 40 for 3 squads.
The rest of the bits came from bitzbox, bitsandkits and megabitzshop (Germany).
Micron pens on ebay from omghowcheap, and the transfers are from "sell-or-trade". He is a decent guy and if you message him with what you want he is responsive and can combine postage.
So got some plasitc dread bits in a hope to revitalise my old metal Bjorn, got some filing to do for the second panel.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170322_213403.jpg
Also tried a design on the assault marines.... Really not sure
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170322_213309.jpg
Thoughts??
Thoughts??
Yes on Bjorn! OMG totally forgot I also have the metal model I bought when I was 12 (like... 20+ years ago sigh). Might need to steal the idea!
And there's not enough definition in the pic for the assault marine to judge I'm afraid :/
As a trick, when photographing with my IPhone, rather than going up close I go as far away as I can, then zoom in and take the pic, I've found that helps heap with getting a more crisp shot because of... some kind of maleficarum science I really don't understand.
Hi Grieux,
I am struggling to get a decent picture of the rams-horn symbol on the pad, finally got a half decent shot and forgot to wipe dust off of the model
The more I look at it, I feel like it is wrong and is over complicating the design. A simple rune in the grey might look far better.
You don't learn if you do not try.
I have also done some more scraping on the models instead of chipping.. Along the leading edges of the hands elbows knees and lower legs, where the paint would have bee scraped down to bare ceramite.
Dust was caused by this fella...
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_111012.jpg
And with getting the newest assault squad done (barring bases), I realise that these guys need a bit of an update too
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_110920.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_110928.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_111036.jpg
As a quick update, begun glossing the left pads for the legion symbols.
Been buying up a lot of the RT transfer kits.
A lot o red and some of the white.
Why white?
Well looking at this image:
http://i1206.photobucket.com/albums/bb456/dantay_xv/1legionnary.jpg
The white wolf symbol, is used by reconissance units, so I am going to use the white wolf symbols for units such as recon marines, seekers and outrider/ jetbike & speeder units.
So for a start:
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_134513.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_134522.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170323_134531.jpg
I have a feeling the white is going to be too bright, so once the tidying up etc is done, then a blast of nuln oil or agrax might be needed to tone it down.
Thoughts??
SW1. In pure HH terms I am at
121 infantry incl characters
Russ
4 Flyers
4 Knights
6 Dreadnoughts
2 pods
4 tanks
Mastodon
Fell Glaive
Fellblade
Typhon
2 Spartas
3 Land Raiders
And still quite away from getting done.
Pure white? The transfers are pure white, but it is quite cool, that some of the armour colour shows through
The fit issues are probably a bit of my own devising.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202511.jpg
Had to replace the bottom section when the holder bits snapped off, also had to take a fair chunk off of the floor at the back a the rear door would not have worked.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202531.jpg
You can see where I had to drill through to get the brass rod in at the bottom right I can get the command section to fit better but it requires a fir bit of wiggling to do.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202557.jpg
Even though the fit on this side is pretty good.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202610.jpg
A bit banana shaped
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202641.jpg
Looking a bit lop-sided. Removed the front internal section because it will not fit in properly.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202651.jpg
This side not too bad
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170328_202657.jpg
Maybe hat this side up and pull it out and straighten it up a bit.
Hot bath time!!!
It is actually not that bad of a model, but I slightly messed up by trying to shape parts as I was going along which messed up the overall
However I do have a plan!!
 http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_202511.jpg
Crude but I am hoping effective... If I do not drop the model in the boiling water :D
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_204533.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_204550.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_204611.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_204620.jpg
Some jiggery pokery and looking a lot better. However one side is still curved
So a bit more bending later
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_210503.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_210509.jpg
And a scale shot beside the Spartan
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_210804.jpg
I also jazzed up some bases and got the Storm Eagle front hatch mostly done
http://i1206.photobucket.com/albums/bb456/dantay_xv/20170329_214037.jpg
Not too bad a nights work
