Empire great cannon to replace knight battle cannon?
zefig
Just a rough eyeball, but the barrel would look a bit 'stumpy', but the diameter seems like it might be correct, which'd be the big issue. If they mated up well, maybe use the battle cannon (in part or whole) to extend the great cannon - that'd give it the 'right' length, while still adding the ornamentation.
Actually, I was just eyeballing based on the image on the GW site and using the gunners for scale. Base of the Battle Cannon, against a Marine, comes up to the top of the knee - about 10mm-12mm. Looking at the Empire Great Cannon, it also appears to be roughly knee height in diameter scaled to the gunners shown with it.
  • 2 weeks later...
I have returned with size comparison pics! It turns out to be a reeeaaally good match when used to replace the forward barrel.
http://images.dakkadakka.com/gallery/2015/6/29/725095_sm-.jpg
http://images.dakkadakka.com/gallery/2015/6/29/725094_sm-Rapid%20Fire%20Battle%20Cannon%20vs%20Empire%20Great%20Cannon.jpg
Thanks everyone for the support!
  • 2 weeks later...
Thanks! It's a super easy swap too, just a bit of cutting and filing and gluing, and then you can still potentially use the original barrel for something. I would recommend being careful with sanding the cylinders down though, because it's easy to get a large axial misalignment of the barrels which is pretty noticeable. Mine is by no means perfect but I think it looks pretty good.
I've considered trying to give the bolt cannon some more ornamentation in a similar manner but I'm not sure where to go with it. I considered trying to use some sort of gargoyle/Dragon/skill head on the end of each barrel, so the gun would fire out of the mouths. I'm not sure if there are any appropriate bits though.
