Warsmith Uveron Posted February 6, 2016 Author Share Posted February 6, 2016 What you need. 1- Parts for a Earthshaker gun from the Basilisk kit. 2- Gunshield from the Basilisk kit. 3- Warp Lightning Cannon kit 4- Extra Wheels, and other parts to make it more ‘Solid’ (The spare metal plates from the Chimera kit is what I use) For the most part you will be assembling the Warp Lighting Cannon Kit as per Option 5 in the book. But with the following extra steps. Like the Warp Lighting Cannon Kit, the first step is to build the weapon. The first step in our case is to glue together the Earthshaker gun. Following this you will need to clip part of the base of the gun to allow it to fit to the weapon mounting in the Warp Lighting Cannon Kit. See Image Bellow. Next up add “Long Beam’ that the Warp Lighting Cannon kit uses to mount the Warp Lighting Cannon too. The attach the ‘Wheel/Hinges’ to the side of the assembly, unlike the Instructions in the Warp Lighting Cannon kit, use Glue, and also glue to the top of the wheel to the sides of the Earthsaker Cannon as this ensures that it will stay attached to the housing. See the following Images Bellow. Build the Frame as per the instructions in the Warp Lighting Cannon Kit. Important note! Do not glue the Wheel/Hinges to the frame as the instructions tell you to do. (As you glued the hinge in the other spot to improve the bond with the Cannon its self). Place the ‘short wooden board’ as shown on the following image, this will become the mounting for the Gunshield. Finally once the two sides of the frame have been put together slide the final board in (Don’t put it where the Warp Lighting Cannon Kit instructions tell you) slide it into a spot at the back of the model to use a firing step behind the breach of the gun. Final Stages will be up tomorrow (I hope) Hellrender, Pearson73, Kythnos and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4296466 Share on other sites More sharing options...
Warsmith Uveron Posted February 7, 2016 Author Share Posted February 7, 2016 First up using parts from the Chimera Kit, and City’s of Death kits I added some more structure to the main body of the frame. I then check then that the Gun Shield fits, I do not glue it until after painting. I then raided by bits box or a few extra details pieces. And then I have one finished Earthshaker Emplacement. MrBear, Khornestar, Thrillhouse and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4298553 Share on other sites More sharing options...
Warsmith Uveron Posted February 18, 2016 Author Share Posted February 18, 2016 Ok Update time. Real Life has been killing me of late, being painting just not spending much time on my PC. I thought I would write this update up now, as I sit by the phone waiting to see if I am being made redundant.. So what have I being working on. The first is another kit-bash. I decided I needed some Rapier Laser Destroyers, and decdied to see if I could make something to act as a counts as.. So using spare parts from the Warpfire Cannon kits that are making my earthshaker emplacements (and bits from the bits box). I have built the following pair of Guns. What do you think? (They are less Rapier Destroyers and some Dark-mecacancum Tec-Magic things, I see them lobbing balls of Darkness out something like that) I have also started getting some paint on my next battle tank, still some detail to go. May get it finished tonight depending how drunk Iam… Kythnos, Khornestar, Pearson73 and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4310692 Share on other sites More sharing options...
Pearson73 Posted February 18, 2016 Share Posted February 18, 2016 Nice rapiers, what are you thinking of using for crew? I'd think that slightly altered skaven or some such would work well as twisted mechanicum slaves. Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4310778 Share on other sites More sharing options...
Thousand Eyes Posted February 19, 2016 Share Posted February 19, 2016 (edited) Well done on the rapier kitbashes, I think those fit rather well. Looking forward to seeing the crew on them. Hope real life eases up on you. Edited February 19, 2016 by Thousand Eyes Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4311747 Share on other sites More sharing options...
Warsmith Uveron Posted February 26, 2016 Author Share Posted February 26, 2016 (edited) Update time: So about 20 mins after my last post I was contacted by my job and made redundant, which has somewhat taken the wind out of my sails somewhat this last week. But I have got some things done. Just starting to get moving again, and taking stock on what stuff I own as I doubt I will be getting many more miniatures till i have a new job. (Not that is an issue as I have quite the stock pile of things to build and paint) I finished the Exterminator… (It’s also being kicking ass and taking names on the table). I also finished painting the second earth shaker. And then I have been working on building another 40+ Mutants and Regidages. This is a Photo of the work mat, and a close up of the mutants Edited February 26, 2016 by Uveron deathspectersgt7, Pearson73, MrBear and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4319663 Share on other sites More sharing options...
MrBear Posted February 27, 2016 Share Posted February 27, 2016 The tank and artillery looks good and those mutants are promising. Too bad about the work situation though, hope you'll manage to land on your feet and move on to something new. Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4320360 Share on other sites More sharing options...
Khornestar Posted February 27, 2016 Share Posted February 27, 2016 Best of luck finding a better situation, Uveron. Hopefully it won't be long. Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4320401 Share on other sites More sharing options...
Warsmith Uveron Posted March 12, 2016 Author Share Posted March 12, 2016 Well I have not been updating this anywhere as much as I used to, I have actually been able to start geting things done again. The First Big Project I had was 'saving' an old Leaman Russ Battle Tank. Then following this I went back and touched up all my R&H infantry, adding some Nurgles Rot paint to all the bases. (I also painted another enforcer and 5 other Renegades) The finialy last night I printed these guys as a test for future projects (and the ETL) MrBear 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4333759 Share on other sites More sharing options...
Warsmith Uveron Posted March 15, 2016 Author Share Posted March 15, 2016 (edited) Yesterday I did some work converting up some Rogue psykers For my R&H army. 2 were complete kit-bashes, another was based on the Dark emissary from the old Dark Shadows Campaign, and the other is a rebased necromancer... who kinda fits with my Gothicy feeling R&H army anyhow. Edit: I plan on painting the Extra Head on the two headed one to appear to be ethereal/other worldly as if he is pushing a Psychic form from his body. Edited March 15, 2016 by Uveron Pearson73, deathspectersgt7, Thousand Eyes and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4336305 Share on other sites More sharing options...
Thousand Eyes Posted March 16, 2016 Share Posted March 16, 2016 Really looking forward to seeing how you pull off the paint job for the two headed one, it is a wonderful idea. Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4337196 Share on other sites More sharing options...
Warsmith Uveron Posted March 16, 2016 Author Share Posted March 16, 2016 Really looking forward to seeing how you pull off the paint job for the two headed one, it is a wonderful idea. Well I do have these WIP shots... Iam mostly happy with the head, need to dry brush very lighty some grey, or white onto the 'extra head' I think.. Pearson73 and Thousand Eyes 2 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4337355 Share on other sites More sharing options...
Warsmith Uveron Posted March 18, 2016 Author Share Posted March 18, 2016 (edited) Last night I was able to get the Cabal finished.. They shall soon be on the field of battle fighting some Grey Knights.. Note: This photo came out very bright, will try and take some better ones today at the game Edited March 18, 2016 by Uveron Khornestar, Space Truckin, Soric and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4339454 Share on other sites More sharing options...
Soric Posted March 19, 2016 Share Posted March 19, 2016 That is a well thought out use for mutated split head. Reminds me of the necromunger lord marshal from Chronicles of Riddick. Those converted pyskers look great. Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4340201 Share on other sites More sharing options...
Warsmith Uveron Posted March 21, 2016 Author Share Posted March 21, 2016 That is a well thought out use for mutated split head. Reminds me of the necromunger lord marshal from Chronicles of Riddick. Those converted pyskers look great. Thanks! I didnt think about the Chronicles of Riddick till you mentioned it... but yes that just adds to the greatness! Now Tonight I decided that I needed to build some more Power Armoured Guys So first up I have some bikers with the Mark of Khorn, used raptors heads for the bikers as it made them look more 'Fast'.. I also made some Raptors. Aiming to have 2 Melta Gun and 2 plasma pistol Raptors to join the squad with no special weapons I have built and painted already. Pearson73, Biohazard and deathspectersgt7 3 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4341622 Share on other sites More sharing options...
Pearson73 Posted March 21, 2016 Share Posted March 21, 2016 Nice use of the Raptor heads on the bikers. Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4341626 Share on other sites More sharing options...
Warsmith Uveron Posted March 24, 2016 Author Share Posted March 24, 2016 Hey All. So over the last few days I have been building units for the ETL First I fixed up my Warp Tallons Then some Missile Launcher Havocs, kit bashed from a whole pile of kits And then some Thousand Sons, and Sorcerers Finally, today was my birthday, and my wife got me a whole stack of presents, the start of a new Nurgle army... and the last Sentinel I needed for my R&H army! Pearson73, Biohazard, deathspectersgt7 and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4345473 Share on other sites More sharing options...
Biohazard Posted March 24, 2016 Share Posted March 24, 2016 Bikers look great with the Raptor heads. The latest update looks good as well buddy. Happy birthday btw Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4345492 Share on other sites More sharing options...
deathspectersgt7 Posted March 24, 2016 Share Posted March 24, 2016 Happy Birthday Traitor !!!!! Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4345521 Share on other sites More sharing options...
Darkroy Posted March 25, 2016 Share Posted March 25, 2016 Happy birthday Uveron, enjoying your thread, keep it up! Warsmith Uveron 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4345771 Share on other sites More sharing options...
Warsmith Uveron Posted March 26, 2016 Author Share Posted March 26, 2016 Ok ETL Prep 1! Last night I spent the night working on building a whole stack of models! Trying to get everything ready for the ETL so I don't need to waist time on the building of models! So First I finished another Havoc Unit, this one with Heavy Bolters) The a collection of HQ's. (One Terminator Lord, One Dark Apostel, and one Lord of Khorn with a Jump Pack) Then 10 Blood Letters, I have stripped paint from these after the first failed painting attempt Then there was a whole pile of Horrors 15 in all, 10 plastic with 5 old metal ones. Then I built 12 bases of Nurgelings, I had quite alot of the old style base and 3 of the newer style, so I added some of the new plastic ones to the metal bases to bulk them out I wasnt able to get them all, but it gives the effect that the Nurgelings are clustered in a more random way... And then Finally, I built two Heralds One is the standard one from the box, the second is a headswap with the Lord of Plagues, its a lazy conversion I know but its effective. Now I just have 30+ Plague Bearers to put together! Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4346758 Share on other sites More sharing options...
Pearson73 Posted March 26, 2016 Share Posted March 26, 2016 Nice Herald conversion, a simple one but a good one! A slightly late Happy Birthday to you too. Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4346765 Share on other sites More sharing options...
Warsmith Uveron Posted March 27, 2016 Author Share Posted March 27, 2016 Another evening of ETL prep down. and 14 plague Bearers complete. Pearson73 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4347413 Share on other sites More sharing options...
Warsmith Uveron Posted March 31, 2016 Author Share Posted March 31, 2016 (edited) So, I picked up some River Trolls today to convert up to Beasts of Nurgle. I then used some Green Stuff and spare heads from the Plague Drones kit to convert them up I also have finished puting togther my plauge drones (no pictures, I was a little drunk)... and I also managed to get 20 more plague bearer's together. Edited March 31, 2016 by Uveron Pearson73 1 Back to top Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4350505 Share on other sites More sharing options...
Pearson73 Posted March 31, 2016 Share Posted March 31, 2016 Nice conversions with the trolls. Nice amount of points there for the ETL too. Link to comment https://bolterandchainsword.com/topic/311813-uverons-black-crusade-wip-log/page/6/#findComment-4350553 Share on other sites More sharing options...
