Blackadder Posted August 5, 2019 Author Share Posted August 5, 2019 Dribs and Drabs: But in these Summer months it's hard to not take advantage of the wonderful pool weather. Much too nice to be indoors working on plastic models. But here's a few images to tide over until the rains return. https://i.imgur.com/NIksL45.jpg First the superstructure deck now has forward battlements and the blocks are the beginnings of the center corner towers which do not seem to have any offensive capabilities. https://i.imgur.com/LxtL1cI.jpg Extending the deck allows for spacing the "Firestorm Redoubts" and also gives room for the fifteen meter tall statues on the Citadel base to be seen more clearly. Finally; https://i.imgur.com/STQutPo.jpg A bird's eye view of the Firestorm quad Laser Cannons base It's all coming together just as if I actually had, Some kinda Plan. Ha! Lasuria, k0nahrik, Huggtand and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5358357 Share on other sites More sharing options...
Blackadder Posted August 9, 2019 Author Share Posted August 9, 2019 Secondary Towers: The more I study the image of the Emperor Deck the more detail stands out on this marvelous 3D image by Joazzz2. I was aware of the smaller towers on the superstructure deck but I did not perceive there were ten of them until this week. https://i.imgur.com/NIksL45.jpg What was going to be a minor exercise in tedium has suddenly become a major pain in the arse. https://i.imgur.com/JgqhDUZ.jpg[ https://i.imgur.com/lgMG9De.jpg Doubly so because I really hate doing these tiny pyramidal end caps. https://i.imgur.com/gFX0ksH.jpg https://i.imgur.com/1U79qzG.jpg Studio Silvernale, Exilyth, Grotsmasha and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5362752 Share on other sites More sharing options...
Stercus Posted August 10, 2019 Share Posted August 10, 2019 I’m not sure if I’m more impressed by your attention to detail or your perseverance. Great work sir. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5364100 Share on other sites More sharing options...
Mechanist Posted August 12, 2019 Share Posted August 12, 2019 Your dedication to keep pushing through the tedious bits is inspiring. I have so many projects that fail because of my inability to push through. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5365105 Share on other sites More sharing options...
Blackadder Posted August 17, 2019 Author Share Posted August 17, 2019 Rediscovering the Wheel: Before I found the rear view of this version of Joazzz2's Emperor Titan I modeled certain components of the superstructure deck including the corner hanging bastions or turrets. I made only two and while quite successful on completion I'd forgotten how I actually built them :p Hence the title of this entry. When I obtained the back view I found I needed two more. https://i.imgur.com/4qFJy2Z.jpg Sagentus and Sgt. Blank 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5369253 Share on other sites More sharing options...
Bjorn Firewalker Posted August 17, 2019 Share Posted August 17, 2019 The spires look good. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5369316 Share on other sites More sharing options...
Blackadder Posted August 18, 2019 Author Share Posted August 18, 2019 Thanks for the reply. You know, on reviewing the image above I neglected to remark on the crudeness of the construction. When you are scratch building any model especially one as large as this Titan, you are bound to accumulate a large amount of scrap plastic. There is a lot of internal structure that no one will ever see and there is no point in sacrificing virgin plastic for internal bracing. I keep my scrap in sorted bins 0.015, 0.020, 0.030 and 0.040"/(0,1MM) and use it for internal structure as seen here. Once assembled I sand off the surface to obtain the shape I need. I find it much easier than meticulously building perfect inner components. The spires look good. Sgt. Blank and jester_prince 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5369620 Share on other sites More sharing options...
Sgt. Blank Posted August 18, 2019 Share Posted August 18, 2019 Thanks for the reply. You know, on reviewing the image above I neglected to remark on the crudeness of the construction. When you are scratch building any model especially one as large as this Titan, you are bound to accumulate a large amount of scrap plastic. There is a lot of internal structure that no one will ever see and there is no point in sacrificing virgin plastic for internal bracing. I keep my scrap in sorted bins 0.015, 0.020, 0.030 and 0.040"/(0,1MM) and use it for internal structure as seen here. Once assembled I sand off the surface to obtain the shape I need. I find it much easier than meticulously building perfect inner components. The spires look good. Good tip! I've never built anything on this scale but from smaller projects I can definitely see the sense of this, especially sorting by size to shim or gap-fit. Keep at it Blackadder! I'm sure it's tough to stay motivated on something that big but it's looking amazing Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5369718 Share on other sites More sharing options...
Blackadder Posted August 22, 2019 Author Share Posted August 22, 2019 Moment of Truth This is going to be Interesting. I've learned a lot building this model. It's the largest project I've ever tackled and I've had to innovate a lot of new techniques.It's been a year and a half since I made the first pair of turrets. These new turrets so far are put the old ones to shame and it'll be interesting to see how they top out. https://i.imgur.com/smVvP40.jpg Captain Caine 24th 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5372269 Share on other sites More sharing options...
Majkhel Posted August 26, 2019 Share Posted August 26, 2019 Hah, that's a Kill Team-size battlefield on his shoulders :) Lord Raven 19 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5374622 Share on other sites More sharing options...
Quixus Posted August 26, 2019 Share Posted August 26, 2019 Hah, that's a Kill Team-size battlefield on his shoulders All the work Blackadder is doing should at least also result in a kill Team board. The base could probably serve as another board Lord Raven 19 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5374641 Share on other sites More sharing options...
Blackadder Posted August 30, 2019 Author Share Posted August 30, 2019 Corner turrets and the intermediate pointy things are basically done. https://i.imgur.com/FtQnokO.jpg https://i.imgur.com/NkMrfj3.jpg Next up, the Citadel base. Radiation, Huggtand, Exilyth and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5378168 Share on other sites More sharing options...
Sagentus Posted September 1, 2019 Share Posted September 1, 2019 Really do enjoy watching this project come together and looking at the sheer size of it you could have games fighting on the titan lol Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5379163 Share on other sites More sharing options...
jester_prince Posted September 1, 2019 Share Posted September 1, 2019 As a ton people have stated you could probably have games on this titan. That would make for such a cool narrative game, make the titan all but invulnerable from external forces in a full scale Apocalypse game, while running a side game of kill team on its back with a team running around trying to lower void shields, disarm reactors ect so that it becomes actually killable to other titans/titan killer weaponry. I am really enjoying the progress you keep making on this project. It's nice to see such a mythical part of the 40k lore be realised to such a high standard. I know other people have tried but this is a whole other level of quality. You should be proud. Blackadder 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5379374 Share on other sites More sharing options...
Blackadder Posted September 25, 2019 Author Share Posted September 25, 2019 It's been a busy month and I'm afraid the Emperor has taken a back seat compared to my other more pressing endeavors. I did manage to cobble together the rear bastions of the superstructure which are virtually carbon copies of the front components. My grandiose idea of a kit bash citadel has been greatly reconsidered because such a structure would compromise the theme of the scratch work. "There is no shortcut to glory." It's a lesson I seem destined to relearn with every model I attempt. :D https://i.imgur.com/9BfcnfO.jpg On another aside I can't believe I only took one picture of this most recent construction! Marius Perdo, Augustus b'Raass, Brother Lunkhead and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5396047 Share on other sites More sharing options...
Mostwanted Posted September 25, 2019 Share Posted September 25, 2019 Good to see progress is still continuing. Looking forward to the next update. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5396371 Share on other sites More sharing options...
Sagentus Posted September 26, 2019 Share Posted September 26, 2019 the thing that always get me is the sheer size of the thing and how much detail you are creating is just epic!! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5396654 Share on other sites More sharing options...
Blackadder Posted October 4, 2019 Author Share Posted October 4, 2019 Flying Buttresses; Once again these seemingly simple constructs are labor intensive https://i.imgur.com/e5VczPX.jpg A box like structure seven times longer than it's wide and I need four of them. https://i.imgur.com/PpLwhLY.jpg https://i.imgur.com/Otr5DsO.jpg https://i.imgur.com/3BghGng.jpg Even with the egg crate material and the resources of industrial quality styrene 0.040" (1,0 millimeter) sheets it's taken a while to manufacture just one. but the next three should take much less time Grotsmasha, Majkhel, PeteySödes and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5401617 Share on other sites More sharing options...
AlexCrute Posted October 13, 2019 Share Posted October 13, 2019 At this point I feel like they owe you a six-page spread in White Dwarf and the services of the painting team for a week. Quixus 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5406583 Share on other sites More sharing options...
Kolgrim DeathHowl Posted October 14, 2019 Share Posted October 14, 2019 Wow man super great work, you are really talented! Can't wait to see this completed! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5406907 Share on other sites More sharing options...
Blackadder Posted November 23, 2019 Author Share Posted November 23, 2019 (edited) Thanks for the replies. Now It Can Be Told: https://i.imgur.com/eLje0ft.jpg After a month hiatus where I spent the time duplicating the upper works previously accomplished I am approaching the point where the four bastions are ready to have the surface sheets applied. https://i.imgur.com/t0LlSiP.jpg I took it on myself to spare my erstwhile readers the agony of enduring repetitive exposition and bit by bit gluing that which was previously documented ad nauseam. https://i.imgur.com/kvUFLCA.jpg So this is where we are on the superstructure and I have to say I am elated that this is finally approaching completion, component wise that is; there is still a load of detailing to do!!!! https://i.imgur.com/8xilcXF.jpg Edited November 26, 2019 by Blackadder Brother-serpent Tylydox, Grotsmasha, Llagos_Tyrant and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5432895 Share on other sites More sharing options...
lionofjudah Posted November 23, 2019 Share Posted November 23, 2019 Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5432920 Share on other sites More sharing options...
Naryn Posted November 23, 2019 Share Posted November 23, 2019 Absolutely glorious. Love following the progression on this! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5433005 Share on other sites More sharing options...
TheBlindPrimarch Posted January 29, 2020 Share Posted January 29, 2020 I truly hope we haven't seen the last of the great Blackadder. Has there been any progress? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5469632 Share on other sites More sharing options...
Blackadder Posted May 12, 2020 Author Share Posted May 12, 2020 Wow, it has been some time since I worked on this project but over the past week I've finally felt well enough to rekindle my interest in completing this effort. As some have perceived I may have contracted the Corona virus but I couldn't be tested for sure as yet. Today I am going to be tested for the presence of Covid 19 antibodies. https://i.imgur.com/Hh5qHUd.jpg Anyway over the past week or so I've made some inroads into how to proceed with the superstructure and begun to make the base for the rear pair of towers. Also for scale I've included the Skitarii figure and one of the decorative statures I ultimately plan to incorporate in the towers. https://i.imgur.com/aNZQPpL.jpg Without going back to view the last developments I posted regarding the interior engineering levels I've included this as well. Thanks for the replies, Blackadder Naryn, Majkhel, Augustus b'Raass and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/33/#findComment-5520323 Share on other sites More sharing options...
