Blackadder Posted September 30, 2023 Author Share Posted September 30, 2023 Detail of the legs and the 8 deck levels at the rear of the superstructure. Alright we'll begin with the rear maintenance lower decks of which there will be four. The bottom two will be for the reactor core which will look like the Warlords reactor The three blue pipes are for the cooling system (glowing blue due to Cherenkov Radiation) the four vents two on either side are the heat exhaust ports... The octagonal shin below the knee joint mount has eight cathedral windows and will have four ball turret triple laser cannons Everything is lining up and coming out as if it were planned; go figure!!! EmprahsStrongestGuardsman, firestorm40k, Cactus and 7 others 4 1 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5992135 Share on other sites More sharing options...
Naryn Posted September 30, 2023 Share Posted September 30, 2023 Incredible work, the detailing is really breathtaking. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5992143 Share on other sites More sharing options...
Brother Carpenter Posted October 7, 2023 Share Posted October 7, 2023 One emoji says it all brilliant Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993453 Share on other sites More sharing options...
Terminatorinhell Posted October 7, 2023 Share Posted October 7, 2023 This is one of the coolest scratch builds I've ever seen Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993458 Share on other sites More sharing options...
Blackadder Posted October 8, 2023 Author Share Posted October 8, 2023 Thanks for the replies... In my previous post I mentioned how everything was coming together almost as if it were planned... Nothing could be further from the truth; witness the large blank area at the rear of this Titan. There was very little to go on in many areas of the rear elevation. Constant studying gave a glimmer of the detail. And how easily they could be reproduced with virtually no modification to the existing structure. Imagine my surprise to notice that the upper gallery relief could be duplicated on the lower two levels. The most outstanding feature were the huge flying buttresses that adorn the rear detail. Naturally the rear area cannot be made of stone but somehow the engineers incorporated this architectural feature purely for aesthetics. Likewise the numerous gothic windows have no place in a war machine and I suspect they're a mere façade. The corner turrets could also be incorporated with little trouble to the superstructure deck and the spacing of the buttresses allows for the gothic style windows. The Rear Nave will house another large caliber cannon under the 'A' frame roof albeit of a lesser diameter than the front main cannon. I may even make the windows stained "glass" (some sort of transparent metal alloy) perhaps a diamond material. Kythnos, Firedrake Cordova, Cactus and 9 others 4 8 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993517 Share on other sites More sharing options...
Brother Carpenter Posted October 8, 2023 Share Posted October 8, 2023 Yes updates Nice start of the rear end. Will you also build the interior power plant? Or is that cutting it a bit too close to insanity Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993521 Share on other sites More sharing options...
Blackadder Posted October 8, 2023 Author Share Posted October 8, 2023 (edited) 2 hours ago, Brother Carpenter said: Yes updates Nice start of the rear end. Will you also build the interior power plant? Or is that cutting it a bit too close to insanity Cat walks railing installed and the left side catwalk on cutting board showing the hook channel that holds it to the inner carapace frame and yet be removable because they are just too delicate to withstand the 'Dogs of War'. Note how far I had to move the gun stanchion inboard from its original proposed position. I have to put some sort of hatch there to cover the hole. Automatically Appended Next Post: I have been thinking about how I am going to make a sensible engineering department out of the two story area beneath the command deck and fit a viable fusion reactor deck in the cramped space above the command deck when suddenly this morning an epiphany!!!!! The lower space will be the reactor room and the upper space will be engineering. Egad! How simple and it totally makes sense that the extremely heavy reactor would be in the lowest level of the torso and the mechanic dedicated area where the high maintenance equipment is. Access to the armament and legs through the carapace and the huge cooling fans and vents at the rear of the reactor room exhausting outboard behind the lower deck.................. Simple right? so why did it take me a year to realize it? Automatically Appended Next Post: Reactor on line................. There's my Cherenkov radiation............. My warlord Titan has a full interior including a fusion reactor. This Titan will have an interior as well including a fusion reactor Edited October 8, 2023 by Firedrake Cordova Fixed images YoungWolf7, Firedrake Cordova, Knightsword and 8 others 2 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993564 Share on other sites More sharing options...
Blackadder Posted October 8, 2023 Author Share Posted October 8, 2023 (edited) Command Deck Front Bulkhead Redux: I was never satisfied with the future tech look of the front bulkhead that was not in keeping with the battle weary slapdash Gothic interior of the 40K universe. The main hull in my estimation is five decks high starting with the Void Generator housings not shown in the included images due to the fact that they must be removed for visual access of the lower decks. Deck four is the upper Observation gallery and the Adeptus Mechanicus Altar recently updated now with 28 MM scale figure. Deck three which I call the Command deck even though I have been advised that Titans do not require large spaces as they have a minimal crew. I rationalize Luteus Vexant is a tactical command vehicle that has a Command group of officers. Below that is the Fusion Reactor, I have no idea what a fuctioning Fusion Reactor would look like but I imagine it would glow with Cherenkov radiation represented by to central component on deck five. To either side of the Reactor deck is the triangular shaped cooling grids and coolant recovery system that recirculates the reactor's sodium transfer medium. Edited October 8, 2023 by Firedrake Cordova Fixed images Focslain, Kythnos, firestorm40k and 8 others 2 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993568 Share on other sites More sharing options...
Firedrake Cordova Posted October 8, 2023 Share Posted October 8, 2023 Fabulous work - I can't really say any more Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993577 Share on other sites More sharing options...
Studio Silvernale Posted October 9, 2023 Share Posted October 9, 2023 This thing is legendary Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993640 Share on other sites More sharing options...
Gnasher Posted October 9, 2023 Share Posted October 9, 2023 Agreed, & "Nobody expects the Spanish Iquisition!" pun just adds! I didn't! (VM Spanish Iquisition figures by the looks of em) Top drawer irony/humour methinks, good show old boy. Bring more! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993839 Share on other sites More sharing options...
Naryn Posted October 9, 2023 Share Posted October 9, 2023 Looks like a mod accidentally added in a bunch of pics from the last mega titan build? Nonetheless, Blackadder, your progress is amazjng and an inspiration to us all. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993858 Share on other sites More sharing options...
Firedrake Cordova Posted October 10, 2023 Share Posted October 10, 2023 9 hours ago, Naryn said: Looks like a mod accidentally added in a bunch of pics from the last mega titan build? Well, I hope that isn't what I did! There were links to images in the post, but they started "http" instead of "https" so weren't being embedded - I just added the "s". 9 hours ago, Naryn said: Nonetheless, Blackadder, your progress is amazjng and an inspiration to us all. That is very true! When it's done, it deserves to be in WD Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993893 Share on other sites More sharing options...
Blackadder Posted October 10, 2023 Author Share Posted October 10, 2023 A respondent (Brother Carpenter) asked me if I intended to install a reactor into the model. My answer was to show the interior of the Warlord Titan I built where I created a facsimile of what I thought a Nuclear reactor might look like . It is my hope to manufacture a complete interior similar to what I mad for my warlord as seen below... quote from February 2018 post: Before I get too smug and self-satisfied I just repaired the interior of my Warlord. and I was surprised at the lengths my OCD drove me three or so years ago. As I contemplate doing an interior for my Emperor Titan I thought I'd refresh myself on my previous construction. Over the years the glue had lost it's grip on the aluminum impregnated wall coatings I used for much of this model inside and out and pieces were rattling around inside. I found some two decks down in the Engineering bay. Anyway once all put together I fired up the interior lighting (surprisingly it all functioned) and took these images so I don't have to disassemble it again until when and if I decide to upgrade the paint. So here's five pictures of the Command deck and Tech Priest balcony replete with Altar to the Machine God, Omnissiah. Starting with the egress to the Command deck through the entry port. I don't know if I've posted these or not other than in the construction phase. Most certainly not on Facebook or any of the new forums I frequent. The upper left Gallery and a view of the Altar and the right Gallery....... I've gotta straighten that railing............. Never mind the railing Blackadder; What about that bloody great hole in the deck? Focslain, Dr_Ruminahui, firestorm40k and 8 others 6 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993908 Share on other sites More sharing options...
Firedrake Cordova Posted October 10, 2023 Share Posted October 10, 2023 I'm fast running out of superlatives here - that looks stunning Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5993952 Share on other sites More sharing options...
Brother Carpenter Posted October 12, 2023 Share Posted October 12, 2023 Wow. Nice. Thanks for the reply. Painting it all is going to be tough I recon? Keep it up Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5994428 Share on other sites More sharing options...
Blackadder Posted October 26, 2023 Author Share Posted October 26, 2023 (edited) On 10/12/2023 at 11:57 AM, Brother Carpenter said: Wow. Nice. Thanks for the reply. Painting it all is going to be tough I recon? Keep it up I painted my Warlord in a couple of days . I started with gray primer then a coat of flat black. I hand rubbed aluminum powder into the flat black paint. It came out so good I didn't do anymore to it. This Titan will be much more intricate but I'll be using the same technique for the mechanical parts. There will be gold powder ( dare I use powdered gold??? ) hand rubbed red powder, blues where needed and white also where needed. The white will get a Nuln oil finish. I hope to be painting by Christmas. Thanks for the reply. Edited October 26, 2023 by Blackadder Rusted Boltgun, firestorm40k, Focslain and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-5997820 Share on other sites More sharing options...
Blackadder Posted November 21, 2023 Author Share Posted November 21, 2023 Thousands of Bits of Plastic Literally thousands of bits of plastic added since last I posted and d*mn me if I can see a difference overall. I've carried out the closely spaced chest high crenellations theme to protect the combatants and added doors, ossuaries and scroll of departed crew members since the Titan was first constructed thousands of years ago. https://i.imgur.com/iHpNIwG.jpg There's still a tremendous amount of detail to be added to make this construct pop. LameBeard, YoungWolf7, Rhavien and 13 others 7 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6004514 Share on other sites More sharing options...
Naryn Posted November 22, 2023 Share Posted November 22, 2023 Looking good as ever! The attention to detail is what I admire most about your work. All those details might not be visible now, but will make all the difference when painting! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6004778 Share on other sites More sharing options...
ZeroWolf Posted November 26, 2023 Share Posted November 26, 2023 On 11/21/2023 at 5:19 PM, Blackadder said: Thousands of Bits of Plastic Literally thousands of bits of plastic added since last I posted and d*mn me if I can see a difference overall. I've carried out the closely spaced chest high crenellations theme to protect the combatants and added doors, ossuaries and scroll of departed crew members since the Titan was first constructed thousands of years ago. https://i.imgur.com/iHpNIwG.jpg There's still a tremendous amount of detail to be added to make this construct pop. Just caught up on this project from where I last seen. This is brilliant work. Firedrake Cordova and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6005624 Share on other sites More sharing options...
Blackadder Posted January 19, 2024 Author Share Posted January 19, 2024 (edited) Ready For Prime Well the back is finally done and I'm about to spray on the gray primer. https://i.imgur.com/6ePX0FE.jpg Once I see it in a uniform gray I will be better able to determine if it is detailed enough. Edited January 20, 2024 by Firedrake Cordova made text visible :) Elzender, ZeroWolf, Mostwanted and 12 others 6 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6017128 Share on other sites More sharing options...
Gnasher Posted January 19, 2024 Share Posted January 19, 2024 that looks amazing! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6017160 Share on other sites More sharing options...
Firedrake Cordova Posted January 20, 2024 Share Posted January 20, 2024 That does look great. I do love to see scratch-built things Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6017296 Share on other sites More sharing options...
Jings Posted January 21, 2024 Share Posted January 21, 2024 Never thought I'd see the day! Hyped Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6017501 Share on other sites More sharing options...
lhg033 Posted January 22, 2024 Share Posted January 22, 2024 Simply amazing! I am slightly sad to hear you say you'll be priming it soon as that means the building side is coming to an end. NiceGuyAdi 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/47/#findComment-6017825 Share on other sites More sharing options...
