So I'm going to fire up this tactica because I caved in and pre-ordered two of these and I want us to have a good understanding of favourable loadouts for Ultra's (or marines in general I suppose).
Here's what I do know:
Heavy Onslaught Gatling Canon
  • Range: 30 inches
  • Type: Heavy 12
  • Strength: 5
  • AP: -1
  • Damage: 1
Onslaught Gatling canon
  • Range: 24"
  • Type: Heavy 6
  • Strength: 5
  • AP: -1
  • Damage: 1
Redemptor power fist
  • Range: Melee
  • Type: Melee
  • Strength: x2
  • AP: -3
  • Damage: d6
Icarus rocket pods
  • Range: 24 inches
  • Type: Heavy d3
  • Strength: 7
  • AP: -1
  • Damage: 1
  • +1 to FLY units, -1 to non-FLY units
Macro Plasma incinerator
  • Range: 36 inches
  • Type: Heavy d6
  • Strength: 8
  • AP: -4
  • Damage: 1
Overcharge:
  • Range: 36 inches
  • Type: Heavy d6
  • Strength: 9
  • AP: -4
  • Damage: 2
  • If 1 rolled to hit, takes a mortal wound
Fragstorm Grenade Launcher
  • Range: 18"
  • Type: Assault d6
  • Strength: 4
  • AP: 0
  • Damage: 1
Heavy flamer
Storm bolters
The bad news is that this dread degrades from damage unlike the vanilla dread.
I'm probably running a pair - perhaps with a Techpriest, and intend on being mobile with them.
Hobby Note: Warhammer TV has uploaded a video on painting the Redemptor!
Edited by Prot
added paint tutorial
https://bolterandchainsword.com/topic/337000-codex-redemptor-tactica/
The plasma incinerator seems best. They're definitely durable but I'm unsure as to their points. How cost efficient they are will determine their usefulness.
I do think that running two will give plenty of headaches to the enemy. Particularly if they flank Guilleman.
I agree, but the heavy Onslaught is no slouch... that being said I was originally thinking of using my Gravis Captain with 3 CPs to upgrade for the re-roll to hit Aura (Not sure if I can try to refund these 3 CP's on a 5+).
The Redemptors I assume are probably in the neighbourhood of... 230 a piece? Just a guess. This means I have  save points on HQ's where I can. I still feel a Libby is vital in my meta (and I don't know the new powers yet.)
They need a Chapter Master's Aura or else moving them will render them all sorts of meh. Hitting on 4s with 18 Heavy Bolter shots?
I'm already starting to think they could be good marching up the table alongside my Captain for rerolls. Maybe I'll give him the Chapter Master upgrade or run Calgar?
That makes the 18 shots much more useful and the assault potential is always good.
I don't know about a bargain. I'm thinking much of the cost is the powerfist and strength 14, which for a shooting platform means it has some teeth if charged.
What role is a Redemptor going to play? Is it a shooting platform with counterattack capacity, in which case it can operate close to your other support elements.
Is it an assault unit, in which case what will you take to support it as when it moves it becomes limited in firepower. Character support can get expensive just to get the most out of a 200pts unit, so the trick is to ensure you're also getting the most out of the character.
A Chapter Master/Captain with Vanguard/Terminators/Sternguard moving up the table alongside this can make for quite the hammer.
The plasma is actually cheaper than the Gatling Cannon.
A Dread equipped with Plasma, Onslaught Gatling Cannon, Rocket Pod and two Storm Bolters is only 197 points.
Swapping the Plasma for the Heavy Onslaught Gatling Cannon puts it up to 202.
This Dread is actually significantly better in CC than regular Dreads thanks to Str14 and D6 damage (although a bad roll could hurt it)
Adding re rolls into the mix would boost it significantly.
Edited by Ishagu
What is S14 doing better against that S12 isn't good enough? Large creatures of course but infantry and models up to T6 it performs the same.
197pts for a weapon that fires D6 shots that hit on a 4+ if the thing moved and only causes a single wound is pretty poor. The Heavy Onslaught cannon is superior by a long way.
Think of it another way. Would you take a Leman Russ Punisher without Pask? Most would say no since it hits so feebly.
That's what you got with the Redemptor without points investment in characters.
I don't like hero-spamming around one part of the battlefield to hope for success. It seems that this Dreadnought can't operate on its own which is a shame with all our Dreadnoughts bar the Venerable and Contemptor.
Of course if your tactics are to clump then the Redemptor is for you. I'm considering it for my footsloggers as I'm rolling a Captain amongst Tactical squads and he is great back up.
I just don't want anyone to be told that this model is going to be the best thing since sliced Xenos when it actually requires careful army composition and use.
Now that I see the options and if Ishagu is reporting the right costs, that's better than I thought.
I think the re-roll aura is our thing no matter if you love or hate Redemptors. I do play some pretty assaulty opponents and right now I feel like I always have to go to Reboute for that home base protection against the baddies.... Orks/Nids... they are terrifying this edition. The Redemptor -might- be the solution for a mid range, mid power shooting, and then counter assault the wave of attackers... and still be able to withdraw and unload again.
I think our main tactic of being able to withdraw from CC and shoot (at a penalty) is already rewarding us for auras. These guys further encourage that.
The Macroplasma is going to encourage Command Point use in certain situations, but again this gels with our traits because it might be refunded.
Tactically speaking the set up of bookends with an aura allow a strong base protection but moving at 8" a turn and considering deployments now.... it's really not that long before these guys will be able to swing in CC.
Against the 100+ conscript armies I've played I can't tell you how much I'm looking forward to testing this. It might now work but you have to do more than shoot those conscripts up, you have to engage them, make the retreat back, and weather a billion flashlights, and repeat the process until they are backed right up and then the parking lot of tanks start becoming valid CC targets for the S14.
Right now my Ultra's cannot engage that kind of army and it's incredibly frustrating.
The bad side is I can see one of these guys replacing my Assault Bolter Inceptor squad which has been a very mediocre unit for more points.
I'm primarily going to use the Dreads for their dakka against said hordes.
I really like the look of the Plasma weapon but I'd rather run dedicated anti Tank/MC ranged units.
That being said, it's so valuable to have units that are effective in close combat - it's why these Dreads are so impressive to me. That and the use of Chapter Tactics which really benefit them especially in our case.
Strength 14 is actually more significant than it first appears; with the exception of a few Heavy tanks you are now wounding most things, including other Dreadnoughts, on a 2+.
Edited by Ishagu
I get auras are a thing, I really do and I love it. But I'm noticing a trend of people using all their armies within Auras for maximum benefit.
I'm considering this, for Marines in particular, is a problem. You are essentially becoming predictable and clumping your army around a few models.
Ultramarines in particular can get rerolls of 1s (or all dice for Tactical and Intercessor squads) for a mere 1 Command Point. We don't need to clump and in Maelstrom games that is a strength.
Of course, the Redemptor can use said Command Point for rerolls of a 1, which is something I am considering along with a Captain tag team to protect my Tactical squads.
I think, for my wedge of Tactical Marines and Cataphractii Terminators moving up the centre, a Redemptor can accompany a Contemptor for a solid battle line. My Captains will lead from the front and there will be a solid counter attack.
Okay I just heard about a command point that I believe any marine force can use in game. Basically you use a command point during the game which we may get discounted and there is a six inch radius around the dread that allows the re roll of ones to hit. Like the captain aura.
Now while any dread can do this the redemptor has quite the foot print and makes it not need as much babysitting.
I don't know if I have the details right but it sounded encouraging.
Regarding this new Dreadnought and Auras, there's a Stratagem in the book thats called 'Wisdom of the Ancients', for 1CP a single dreadnought allows for units with the <Chapter> keyword to reroll 1s to hit. I am assuming that it also applies to Dreadnought itself which would certainly help with moving and firing stuff or overcharging plasmas.
Yup, that's the one. I do recall that was the name. I think I'll be using that.
Ultramarines Strategum, combined with the Wisdom of the Ancients one, combined with Lieutenants, means I'm buying a Redemptor.
Also, because they neutered my Assault Cannon/twin Autocannons combo on the Venerable :(
But new toys!
Colour me convinced of the worth of a Redemptor now. Amen to cordial discourse.
I have not read the codex yet, or caught up with the new FAQs.
I currently run 3 dreads as a Vanguard Detachment with a standard captain, how does this compare to taking 2 Redemptors instead.
  • Total Wounds is roughly the same
  • Attacks would be 4 less for the Redemptors
  • Strength of Attacks would be 12 vs 14
  • BS & WS gets worse for the Redemptors
  • The Redemptors can move further, but do start to slow down
So a guess it just comes down to actual Firepower. The Assault Canon on a Dread is Strength 6 (3 dreads do 18 shots), the Heavy Onslaught Gatling Canon is Strength 5 (2 Redemptors do 24 shots).
Seems to be a close decision unless I am missing something.
fyi - One another note, can I just take an Army that is made up of 3 Vanguard Detachments - i.e. 9+ dreadnoughts and 3 HQs (captains)
Edited by wako1302
If you do the points neutral swap of onslaught cannon in exchange for heavy flamer *each redemptor fires 18 str 5 AP -1 shots.
So two redemptors is 36 shots.
They still have a few other guns after that as well and their fists do d6 damage.
Register a new account
Sign in
