Ghorgul Posted August 1, 2017 Share Posted August 1, 2017 Kizzdougs - Where did you find the art work? I think I've seen sort same style for a few other, I rememeber one for the Iron Warriors I've got save somewhere. They do look cool & if there ever any new plastic wouldn't mind them been release. Do you mean this piece? It's by Mikhail Savier. A super talented dude NL trait is nice, but it isn't that awesome. Many armies can ignore morale (AM, Tyranids, Orcs to some level), and then if playing against Space Marines and they go MSU, 5 man max in one unit the Ld modifiers dont probably do anything at all. Lets see, you get 2 NL units next to 5 man space marine squad and kill 1-2, then enemy will roll a die, in this case they would lose more if they roll 5+, but then they have a re-roll due to ATSKNF so it is not very likely that you do much at all. Then if you stack up 3 units within 6" its overkill, or if you kill 3 the unit is almost done for already. I don't think the NL trait is that awesome. I disagree. Put two 5 man units in a Rhino, disembark and charge with both + maybe a character and you already got a -3 modifier. Now you only need to kill one of the enemy unit to cause additional casualties on average despite their re-roll. Well then you are using 2x 5 man CSM squads + rhino + character with Jump pack or Bike to kill one 5 man squad? Doesn't sound very efficient to me. That amount of units should be able to wipe that unit out anyway. It's common that people for some reason have the misconception that you have to fight units 1v1. It's WAY better to let 2 of your units fight 1 of the enemy units so you have less casualties instead of having two units punch each others faces until both are depleted. Do you need the Ld modifier tricks if you attack single squad with 2 squads, rhino and character? Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840361 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 (edited) NL trait is nice, but it isn't that awesome. Many armies can ignore morale (AM, Tyranids, Orcs to some level), and then if playing against Space Marines and they go MSU, 5 man max in one unit the Ld modifiers dont probably do anything at all. Lets see, you get 2 NL units next to 5 man space marine squad and kill 1-2, then enemy will roll a die, in this case they would lose more if they roll 5+, but then they have a re-roll due to ATSKNF so it is not very likely that you do much at all. Then if you stack up 3 units within 6" its overkill, or if you kill 3 the unit is almost done for already. I don't think the NL trait is that awesome. I disagree. Put two 5 man units in a Rhino, disembark and charge with both + maybe a character and you already got a -3 modifier. Now you only need to kill one of the enemy unit to cause additional casualties on average despite their re-roll. Well then you are using 2x 5 man CSM squads + rhino + character with Jump pack or Bike to kill one 5 man squad? Doesn't sound very efficient to me. That amount of units should be able to wipe that unit out anyway. It's common that people for some reason have the misconception that you have to fight units 1v1. It's WAY better to let 2 of your units fight 1 of the enemy units so you have less casualties instead of having two units punch each others faces until both are depleted. Do you need the Ld modifier tricks if you attack single squad with 2 squads, rhino and character? Need? No, you barely need anything. Does it help tho? Yes. Yes it does. Edited August 1, 2017 by sfPanzer Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840370 Share on other sites More sharing options...
Ghorgul Posted August 1, 2017 Share Posted August 1, 2017 Well I agree to disagree with you about this matter. :) Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840375 Share on other sites More sharing options...
the jeske Posted August 1, 2017 Share Posted August 1, 2017 It can help vs armies with big squads and lower Ld. If you drop orcs to ld1 and kill enough of them whole units can die from being scared. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840387 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 Iron Warrior article is up. Same Legion Trait as IW. Warlord Trait that makes IW within 6" immune to morale. Relic that gives a 2+ armor and heals a wound per turn (that's sick on a Daemon Prince!). And they revealed the Tzeentch Psychic Power which improves a units invul save by 1 until the casters next psychic phase...or gives a 5+ invul if the unit didn't have one before. Iron Sage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840392 Share on other sites More sharing options...
Iron-Daemon Forge Posted August 1, 2017 Share Posted August 1, 2017 Iron Warrior article up & here some of the part from it. - Enemy units do not gain any bonus for saving throws & can re-roll wounds against building - Talk about Terminators & using Tzeentch power, give you +1 to the Inv save - Fleshmetal Exo armour back, 2+ armour & you get a 1 wound back that the start of each of your turn - Warlord trait allow friendly Iron Warriors with in 6 inch of the Warlord to pass morale test. So by the look of it, the Legions are allow mark? Know when the codex is release. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840395 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 Hah, got you there, Insane Psychopath! :P Well I for one don't think there are Mark restrictions for the undivided Legions anymore but even if there were one could simply take a Tzeentch Sorcerer in a second detachment and use the power. Even World Eater could do that. EDIT: which would be true if the power wouldn't specify Tzeentch Heretic Astartes.... :D So yeah I think the Mark restrictions are gone for good for undivided Legions. ;) Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840404 Share on other sites More sharing options...
Galron Posted August 1, 2017 Share Posted August 1, 2017 Ill have to check it out on my phone in a bit. Still thinking a couple horde squads backed up by havocs, chosen, a typhon, and contemptors or a Dorrito. Really considering a renegade detachment with a pair of Bombards. Wish Spartans weren't so stupidly overpriced. I might bring Perturabo as a Daemon Prince or foot chaos lords with the hordes. I have kinda yawned on loyalist marines and my project there, especially since I have unfinished traitor legions. I use very little if anything in the way of chaos stuff so am I simply traitor legions or chaos? Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840412 Share on other sites More sharing options...
Iron-Daemon Forge Posted August 1, 2017 Share Posted August 1, 2017 Just to point out Warhammer 40,000 facebook page has posted up one of the command point part & it allow Iron Warriors to get a 6+ feel no pain again that 1: command point. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840413 Share on other sites More sharing options...
Iron Sage Posted August 1, 2017 Share Posted August 1, 2017 Just to point out Warhammer 40,000 facebook page has posted up one of the command point part & it allow Iron Warriors to get a 6+ feel no pain again that 1: command point. do you have a link? And is that for 1 turn (then it is crap) or is it 1 command point before the game starts to make them more durable for the entire battle? Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840426 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 It's not that bad. Only use it when you really need to. It's no Chapter Tactic like the IH one, we have Ignore Cover instead. It's also pretty nasty on a Daemon Prince with the IW relic. ;) Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840433 Share on other sites More sharing options...
Archaeinox Posted August 1, 2017 Share Posted August 1, 2017 I really hope Weaver of Fates is in the Thousand Sons book, that thing is sick. Currently, Hellblasters are going into my high priority units and a 4++ with re-rolling 1s on Scarabs or a big block of Rubricae would really help them. MyD4rkPassenger 1 Back to top Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840437 Share on other sites More sharing options...
Iron Sage Posted August 1, 2017 Share Posted August 1, 2017 It's not that bad. Only use it when you really need to. It's no Chapter Tactic like the IH one, we have Ignore Cover instead. It's also pretty nasty on a Daemon Prince with the IW relic. Maybe you are right. Anyway, do you have a link for this? Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840442 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 Why would you need a link? It's just that picture in a comment on their facebook page, nothing more. ^^ Also just a thought, since Undivided Legions can take marks now....Slaanesh Iron Warriors so they can benefit from the 5+ FnP Slaanesh Power....on top of their Stratagem! :D Iron Sage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840447 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 Oh and not to forget, if you have a Slaanesh Iron Warrior unit you can use the Endless Cacophony Stratagem as well to let them shoot twice. ;) Iron Sage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840457 Share on other sites More sharing options...
OPTIMVSCHRISTVS Posted August 1, 2017 Share Posted August 1, 2017 Do we know if there's going to be alternate detachments that will get us more CP a bit more easily? Right now I find myself just using command rerolls/auto pass morale and not even thinking about strategems... Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840469 Share on other sites More sharing options...
Iron Father Ferrum Posted August 1, 2017 Share Posted August 1, 2017 I doubt it? CPs are supposed to be a limited resource, that's why they're fairly scarce. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840472 Share on other sites More sharing options...
Ghorgul Posted August 1, 2017 Share Posted August 1, 2017 Well newest leaks: https://war-of-sigmar.herokuapp.com/bloggings/2289 I am not impressed. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840475 Share on other sites More sharing options...
Panzer Posted August 1, 2017 Share Posted August 1, 2017 No alternate Detachments at the moment. Only the ones from the rulebook. Well newest leaks: https://war-of-sigmar.herokuapp.com/bloggings/2289 I am not impressed. You are rather late. That got posted like 5 or 6 times just in this thread and the one in the news&rumour subforum alone already. :D Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840476 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted August 1, 2017 Share Posted August 1, 2017 Why would you need a link? It's just that picture in a comment on their facebook page, nothing more. ^^ Also just a thought, since Undivided Legions can take marks now....Slaanesh Iron Warriors so they can benefit from the 5+ FnP Slaanesh Power....on top of their Stratagem! Slaanesh Havocs addicted to making things go boom.... Between that, the combat drugs, and the natural IW mental illness...... Their entire life is Apocalypse Now on infinite repeat. "We build it during the day, Charlie come and blow it up at night." "Smells like victory....." Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840499 Share on other sites More sharing options...
Sception Posted August 1, 2017 Share Posted August 1, 2017 Iron warriors article is up. Trait is copy paste from the imperial fists, unfortunately. And no unit tidbits like the possessed last time, which is unfortunate, as i had my fingers crossed for knews of obliterator improvements. On the positive side, the tzeentch power was previewed and is ok, a boost to inv saves, or a 5+ save if the target tzeentch heretic astartes unit has none. Does that mean iron warriors arent prohibited from taking marks this time? Its unclear. More exciting, the IW command ability and artifact look very nice. The former is outright immune to morale for IW units w/in 6" of your general, very nice for a static gunline force using cultist screens to keep enemy melee units at bay. The latter is a suit of 2+ armor that also restores a lost wound every turn. As the article points out, a pretty nice upgrade for daemon princes in particular, though not bad for lords, either. All in all, not as exciting as yesterday's article, imo, but still some good stuff. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840505 Share on other sites More sharing options...
Iron-Daemon Forge Posted August 1, 2017 Share Posted August 1, 2017 On the positive side, the tzeentch power was previewed and is ok, a boost to inv saves, or a 5+ save if the target tzeentch heretic astartes unit has none. Does that mean iron warriors arent prohibited from taking marks this time? Its unclear. Yes mark are now allowed with the Legion, so Iron Warriors, Word Bearer, Night Lords, Alpha Legion can now take mix marks. There was a reply on facebook. Iron Warriors where once class as follow Slannesh & Night Lords once had Khorne marks on there banner back in the Rouge Trader era. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840510 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted August 1, 2017 Share Posted August 1, 2017 (edited) It's not that bad. Only use it when you really need to. It's no Chapter Tactic like the IH one, we have Ignore Cover instead. It's also pretty nasty on a Daemon Prince with the IW relic. They stated that their goal was to encourage large squads for IW. This gets much more efficient when you're spending it on a unit of 20.....that happens to be ignoring Morale because your Warlord is somewhere in the middle. Also, on the Legion Trait, it fits because if I remember correctly, the IW Havocs favored HB frag shells that did just that during the Heresy. Against other power armor, the cover thing's OK. Against, say, Scouts, it's awesome. Since that's what lots of people use for board control and deep strike denial, that allows us to clear an LZ so some of our heavy hitters can come down on Turn 2. It's funny that our Cultists can possibly outlast Guardsmen in a war of attrition.....between denying them their cover when exchanging autogun/lasgun shots and careful use of Iron Without, Iron Within on big units, plus the Morale thing. Edited August 1, 2017 by GreaterChickenofTzeentch Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840511 Share on other sites More sharing options...
balordazul Posted August 1, 2017 Share Posted August 1, 2017 The only issue I see is being able to buy auto-gun cultist at a reasonable cost. They are still only selling the snap fit dark vengeance junk. I guess you can convert the ugly old IG models but it would be nice if GW would give chaos some updated models and filled in the holes for some of the kits. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840536 Share on other sites More sharing options...
RapatoR Posted August 1, 2017 Share Posted August 1, 2017 Ok so I read the comments bellow the EC preview and apparently not only can undivided legions take marks, but you can choose a mark during a game via a stratagem. Marks no longer give stat boosts however, thats reserved for mark-specific stratagems and psychic powers. Link to comment https://bolterandchainsword.com/topic/337245-chaos-codex-release-date-8517/page/8/#findComment-4840551 Share on other sites More sharing options...
