Reinforcements have arrived!!
No need to sweat! Valhallans are here! Chill out
Sorry for the glacial pace of arrival, I was watlaid by Orks en route and the beasts had to be iced with extreme prejudice.
They were met with an avalanche of ertillery, and put down with a hail of lasfire and cold fury.
Bastards made us LATE!
Still, time to let it go. The cold will never bother them again, anyway.
I Ravening Harlot rise to the challenge of E TENEBRAE LUX on the side of the Imperial Guard and vow to complete:
- Tank Commander Leman Russ Punisher [Polar Vortex] with sponson Heavy Bolters and a hull Heavy Bolter, Stormbolter
- Tank Commander Leman Russ Exterminator [Glacial Fury] with sponson Plasma Cannon and hull Heavy Bolter, Heavy Stubber
- Leman Russ Demolisher [Frigid Indignation] with sponson Heavy Flamers and hull Heavy Bolter, Stormbolter
- Leman Russ Battlecannon [inexorable Chill] with hull Heavy Bolter
- Leman Russ Battlecannon [intractable Frost] with hull Heavy Bolter
of total value 952 points on or before August 1st, 2018. Success will bring me eternal glory and failure will doom me to wear the Badge of the Oathbreaker until the year-end.
Hi! Just a friendly reminder that there’s 20 points worth of track guards in that photo, in case you forgot to include them :)
Hey guys,
Is it possible to vow after June 1st seeing as I am already entered?
If not I have a full day of hitting up the local shops tomorrow and the start of the Warriors championship parade puts a hard deadline at 6.
If you have already made a vow you're in. You can make a subsequent vow whenever you like until the end of the event. :)
I'd like to pledge some stuff, but since I'm currently putting quite a bit into deathwatch, I want to be clear on the rules.  Say I were to do 750 points of deathwatch, to have it count on this forum, I would just need to do more than 750 point of guard?
Also, I've got a vulture base coated green, nothing else.  Can I use that?
When you pledge for IFOR you must a choose a Forum as the Forum of preference. In each of your vows you may use units from other IFOR Forums provided they do not exceed the number of units from your Forum of preference. As correctly stated above, it's the number of units that matters, not the points or the model count...
I Chris521 rise to the challenge of E TENEBRAE LUX on the side of the Astra Militarum and vow to complete Imperial Guard and Deathwatch units of total value 703 points on or before August 1st, 2018. Success will bring me eternal glory and failure will doom me to wear the Badge of the Oathbreaker until the year-end
3 Company Commanders- bolter/power axe- 36 points each
Scout Sentinel-Heavy flamer-chainsaw-54 points
Vulture gunship-Twin Punisher Cannnons-160 point
Watch Captain-Jump pack, Thunder Hammer, Storm Bolter-119 point
2 identical Kill teams each 131 points
sarge-storm bolter/chainsword
blackshield-storm bolter/chinsword
veteran-storm bolter/ storm shield
verteran-Frag Cannon
I have more planned for each faction, but I just wanted to get a vow in.  Hoping to post some pictures tomorrow.
But be quick, Chris, you have to be in before June 1, at 23:59 GMT! GET THAT FIRST PLEDGE IN NOW BROTHERS!
It's June 1st, 17:00 GMT...
Welcome aboard Chris and good luck with your Kit teams. Now that you have made the Astra Militarum your Forum of preference, in your vows you may add units from other IFOR Forums but they should never exceed the number of Astra Militarum units...
UPDATED TO THIS POINT!
I, Captain Titus rise to the challenge of the ETL on the side of the Astra Militarum and Adeptus Custodes and vow to complete a 1616 pts force:
  • Company Commander (30pts)
  • Tempestor Prime (45pts)
  • Conscripts 20 (80pts)
  • Infantry x3 (120pts)
  • Scions w/ plasma x2 and vox-caster (79pts)
  • Commissar x2 w/ plasma pistol and bolt pistol (44pts)
  • Platoon Commander (20pts)
  • Veterans w/ heavy flamer, plasma gun, melta gun (112pts)
  • Leman Russ x2 w/ battle cannon x2, heavy bolter sponsoons x2, heavy stubber x2, hull mounted lascannon x2 (368pts)
  • Wyvern w/ augur array (117pts)
  • Taurox Prime w/ gatling cannon, autocannons (124pts)
  • Chimera w/ dozer blades (98pts)
  • Aegis Defence Line w/ quad gun (105pts)
  • Custodian Guard Squad w/ sentinel blades x2, storm shield x2, guardian spear x3 (274pts)
1warham2
1warham1
(almost everything is still boxed but there will be more wip pictures in the future)
Welcome to the ETL Titus - you're the last for the Guard to join! Keep in mind that the sprue in the box is perfectly acceptable "before" pic! Strong vow  there - good luck with it! :tu:
I Snorkle rise to the challenge of E TENEBRAE LUX on the side of the Astra Militarum and vow to complete the following units on or before August 1st:
Astra Militarum: 4 Units
Leman Russ Punisher: Lascannon, Heavy Bolter Sponsons, Heavy Stubber
182
Leman Russ Annihilator: Lascannon, Heavy Bolter Sponsons, Heavy Stubber
202
Leman Russ Battle Tank: Lascannon, Heavy Bolter Sponsons, Heavy Stubber, Track Guard
182
Leman Russ Battle Tank: Battle Cannon, Lascannon
164
Imperial Knights: 2 Units
Armiger Warglaives: x2, Meltaguns
480
Knight Paladin: Heavy Stubber, Meltagun, Thunderstrike Gauntlet, Rapid-fire Battle Cannon, Stormspear Rocket Pod
521
Adeptus Custodes: 2 Units
Captain-General Trajann Valoris
250
Vertus Praetors: 3x, Hurricane Bolters, Misericordias
282
For a total of 2263 points.
IMG 3314
IMG 3316
IMG 3318
IMG 3325
Edit: Added another LRBT to equal 4 units for the guard
Just a couple quick questions-
I can’t add models to my existing vow, right? I was hoping to vow a couple armigers before the price drop with next week’s Codex, but wont be able to finish my existing vow before then, unfortunately.
I cant vow for normal Astartes, correct? Can I vow my normal Chapter as “counts as” Deathwatch in that case, assuming that they are WYSIWYG Deathwag legal, gear-wise?
Thanks!
