Spagunk Posted May 12, 2018 Share Posted May 12, 2018 Hello everyone, This is my ETL VI thread to toss in various pics and musing as I work through my vows. To start, here is my first vow and progress picture: Progress 1: Now currently I am working on the second half of this squad. In between what painting I can get in, I have been trying to update my transfer game a bit. So as a test I bought some Liquitex Gloss medium and did a 3:1 mix of gloss to water. Using Saint Duncans method of gloss coat, transfer then matte coat I set up a test figure to verify if that method will work for me. Once done, I then did some foam to stipple some layer red on the figure to nice effect. Here is my test mini: I think it works and so my next step is to use this method as often as I can. The trick for me is to be patient which is REAL difficult for me to master as the closer I get to finishing, the more I tend to power through all the detail work and stuff. Anyway, currently my eyes were dilated so no painting today for me. I should be better tomorrow and be able to get through some more of the second half of the squad. Need to start putting base color besides red (blacks, tabards/scrolls, silvers etc.) on them.After that, I can start working on detail work and the like. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/ Share on other sites More sharing options...
Ekfud Posted May 12, 2018 Share Posted May 12, 2018 Bit of a side question... what process do you do for working on bases separately? I tend to put pins in first, then build texture around (which is a bit fiddly & time consuming) - it looks like you use blutac or something to mask an area for the feet? Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079155 Share on other sites More sharing options...
Pearson73 Posted May 12, 2018 Share Posted May 12, 2018 Looking good, liking the stipple on the transfer. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079157 Share on other sites More sharing options...
Imren Posted May 12, 2018 Share Posted May 12, 2018 Looking good! If you want to improve on the decal "painted on" look, then I highly recommend using Micro Sol and Micro Set, they really make the transparent decal film "melt away". Here is a tutorial: Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079281 Share on other sites More sharing options...
Vraxka Posted May 12, 2018 Share Posted May 12, 2018 Nice work, look like they're coming together nicely. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079339 Share on other sites More sharing options...
Spagunk Posted May 12, 2018 Author Share Posted May 12, 2018 Looking good! If you want to improve on the decal "painted on" look, then I highly recommend using Micro Sol and Micro Set, they really make the transparent decal film "melt away". Here is a tutorial: Yeah, I already know about that. In fact, I know the recipe they use to make it. However I think the vial I have is partially evaporated because it was definitely not working as well as it had in the past. Definitely something people should be using often. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079522 Share on other sites More sharing options...
Spagunk Posted May 12, 2018 Author Share Posted May 12, 2018 Bit of a side question... what process do you do for working on bases separately? I tend to put pins in first, then build texture around (which is a bit fiddly & time consuming) - it looks like you use blutac or something to mask an area for the feet? Actually I don't use blue tack. I have course pumice from Vallejo and when i put them on the base, I kind of grind out a spot where the feet go. Then, when it dries, it leaves enough of an impression that I can glue the feet in afterwards. The reason you see the white paint in the first picture is that I had to pre-glue figures onto them to qualify for the Blood and Zeal competition so that's actually primer on the foot you're seeing. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5079527 Share on other sites More sharing options...
Ekfud Posted May 13, 2018 Share Posted May 13, 2018 Right - yeah, that makes sense. Do you get a good bond when sticking them back on later? Or does the older glue crust make that harder to stick? I had a few older ones pop off (mainly single-leg-on-ground poses) so have been a bit anal about pinning everything these days. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5080045 Share on other sites More sharing options...
Spagunk Posted May 13, 2018 Author Share Posted May 13, 2018 Right - yeah, that makes sense. Do you get a good bond when sticking them back on later? Or does the older glue crust make that harder to stick? I had a few older ones pop off (mainly single-leg-on-ground poses) so have been a bit anal about pinning everything these days. The bond is kind of weedy for the most part. But that's kind of the downside of using superglue. However given how I do this, I don't see a way to use plastic glue for a good grip. On the plus side, it helps that my older models are easy to pop off the base to transfer to 32mm instead of 25mm. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5080328 Share on other sites More sharing options...
Spagunk Posted May 14, 2018 Author Share Posted May 14, 2018 Another update: These are a bit late because I was messing around with transfers a bit but I got fed up and this is what I have - Second part of the first squad: Group Shot: Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5081323 Share on other sites More sharing options...
Brother Aether Posted May 14, 2018 Share Posted May 14, 2018 Thanks so much for posting these ETL updates, Spagunk. I was able to get some initial undercoats on my vows over the weekend (pics will be incoming on the other thread). I really like the effect on the black banner, I may need to steal that for a future vow... Anyway, these posts are inspiring and helping me get over any hesitancy to get some base coats slapped on! Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5081352 Share on other sites More sharing options...
Spagunk Posted May 14, 2018 Author Share Posted May 14, 2018 Thanks so much for posting these ETL updates, Spagunk. I was able to get some initial undercoats on my vows over the weekend (pics will be incoming on the other thread). I really like the effect on the black banner, I may need to steal that for a future vow... Anyway, these posts are inspiring and helping me get over any hesitancy to get some base coats slapped on! Happy to help any way I can. The black banner is actually a throw back from ye old 3rd edition days to mark veteran sergeants. I then opted to use yellow blood drop/wings for a bit more color. Red border instead of white because I think it works better with the model. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5081364 Share on other sites More sharing options...
Spagunk Posted May 20, 2018 Author Share Posted May 20, 2018 Made some more progress and finished the scouts for the group: Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5086369 Share on other sites More sharing options...
Majkhel Posted May 20, 2018 Share Posted May 20, 2018 Those classic hazard-stripes on the cables always bring a nostalgic smile to my face. Nice work! Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5086536 Share on other sites More sharing options...
Spagunk Posted May 29, 2018 Author Share Posted May 29, 2018 Quick update to show I am still working on this: I will work on getting the transfers on them but I really need to finish the vow off. 5 more guys and a captain to complete. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5093050 Share on other sites More sharing options...
Spagunk Posted June 6, 2018 Author Share Posted June 6, 2018 Sorry for little updates but I have a dying cat we've been trying to nurse and it's taking a lot of our free time. I was able to get a good amount done but we are still having a hard time. Hopefully will have an update tomorrow. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5099604 Share on other sites More sharing options...
brother_b Posted June 6, 2018 Share Posted June 6, 2018 Sorry for little updates but I have a dying cat we've been trying to nurse and it's taking a lot of our free time. I was able to get a good amount done but we are still having a hard time. Hopefully will have an update tomorrow. Sorry for that brother those are hard times indeed. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5099629 Share on other sites More sharing options...
Spagunk Posted June 6, 2018 Author Share Posted June 6, 2018 Here is my progress so far: So second tac squad done: That just leaves the promised foot captain to do. The slow progress has been mostly due to work searching stuff and in the past 2 weeks my cat dying. We had to put her down last night so I couldn't finish these guys yesterday. I am hoping that I can get the captain done in about 2 days so I can go slow enough to make him look decent. Then, it's on to vow 2 which, depending on how I accomplish it, may be quick. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100075 Share on other sites More sharing options...
Jolemai Posted June 6, 2018 Share Posted June 6, 2018 Sorry to hear of your loss :( Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100109 Share on other sites More sharing options...
Ekfud Posted June 6, 2018 Share Posted June 6, 2018 Potential to name/dedicate a squad after the cat? (I’m sure the tough BA legions have a squad called ‘fluffy’ somewhere). Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100257 Share on other sites More sharing options...
Arkhanist Posted June 6, 2018 Share Posted June 6, 2018 Sorry about your cat Spagunk. Losing a pet is always tough. I always try to tell myself that at least they're no longer hurting, but it does take time for the pain to ease. No need to apologise for painting slowly (you're still 10 times faster than me!) - real life trumps models, every time, we've all been there. But I do like the sound of Captain Tigger McFluffWhiskers (insert cat name here) Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100273 Share on other sites More sharing options...
Spagunk Posted June 7, 2018 Author Share Posted June 7, 2018 Her name was goose so I'm thinking a codename or something if I were to do so. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100313 Share on other sites More sharing options...
Bjorn Firewalker Posted June 7, 2018 Share Posted June 7, 2018 Beautiful works. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100367 Share on other sites More sharing options...
Arkhanist Posted June 7, 2018 Share Posted June 7, 2018 'Anseris' is my goose in pseudo-latin I think, or 'Anser' for a goose. Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5100432 Share on other sites More sharing options...
Spagunk Posted June 10, 2018 Author Share Posted June 10, 2018 Vow completed: Captain closeups: Link to comment https://bolterandchainsword.com/topic/347193-spagunks-etl-vi-paint-thread/#findComment-5102442 Share on other sites More sharing options...
