Cpt_Reaper Posted June 12, 2018 Share Posted June 12, 2018 So I've been trying to make the Malcador tanks a little bit better in the 41st Millennium. Here are the 3 variants I have cooked up, being the Malcador Assault Tank, Malcador Tank Commander and Malcador Siege Tank (that last name is a placeholder). Malcador Assault Tank Point Values Heavy Support Malcador Assault TankPoint Values Heavy Support Unit Models per Unit Points per Model (does not include wargear) Malcador Assault Tank 1 190 Malcador Assault Tank Damage Remaining W M BS A 10 – 18+ 10" 4 3 5 – 9 7" 5 D3 1 – 4 4" 6 1 NAME M WS BS S T W A Ld Sv Malcador Assault Tank * 6 * 7 8 18 * 8 3 A Malcador Assault Tank is a single model equipped with a Battle Cannon, a Heavy Bolter and two Heavy Stubbers. Weapon Range Type S AP D Abilities Autocannon 48" Heavy 2 7 -1 2 - Battle Cannon 72" Heavy D6 8 -2 D3 - Conqueror Battle Cannon 48" Heavy D6 8 -2 D3 - Eradicator Nova Cannon 36" Heavy D6 6 -2 D3 Units being attacked by this weapon do not get any bonuses to their saving throws for being in cover. Heavy Bolter 36" Heavy 3 5 -1 1 - Heavy Stubber 36" Heavy 3 4 0 1 - Hunter-Killer Missile 48" Heavy 1 8 -2 D6 A Hunter-Killer Missile can only be fired once per battle Lascannon 48" Heavy 1 9 -3 D6 - Storm Bolter 24" Rapid Fire 2 4 0 1 - Vanquisher Battle Cannon 72" Heavy 1 8 -3 D6 Roll two dice when inflicting damage with this weapon and discard the lowest result. Wargear Options This model may replace its Battle Cannon with a Conqueror Battle Cannon, Eradicator Nova Cannon or Vanquisher Battle Cannon This model may replace its Heavy Bolter with a Lascannon This model may replace its two heavy Stubbers for two Autocannons or two Lascannons This model may take a hunter-killer missile This model may take a storm bolter or heavy stubber Abilities Explodes: If this model is reduced to 0 wounds, roll a D6 before removing the model from the battlefield; on a 6 it explodes and each unit within 2D6" suffers D6 mortal wounds. Assault Tank: This model does not suffer the penalty to hit rolls for moving and firing a Battle Cannon, Conqueror Battle Cannon, Eradicator Nova Cannon or Vanquisher Battle Cannon. Unreliable Engine: If this model is reduced to 8 wounds or less it loses the Assault Tank rule unless armed with a Conqueror Battle Cannon. Smoke launchers: Once per game, instead of shooting any weapons in the Shooting phase, this model can use its smoke launchers; until your next Shooting phase your opponent must subtract 1 from all hit rolls for ranged weapons that target this vehicle Faction Keywords IMPERIUM, ASTRA MILITARUM, <REGIMENT> Keywords VEHICLE, MALCADOR, MALCADOR ASSAULT TANK Assault Tank CommanderPoint Values Heavy Support Unit Models per Unit Points per Model (does not include wargear) Assault Tank Commander 1 235 Assault Tank Commander Damage Remaining W M BS A 10 - 18+ 10" 3 3 5 – 9 7" 4 D3 1 – 4 4" 5 1 NAME M WS BS S T W A Ld Sv Malcador Assault Tank * 6 * 7 8 18 * 8 3 An Assault Tank Commander is a single model. He rides to battle in the cupola of a Malcador Assault Tank, which is equipped with a Battle Cannon, a Heavy Bolter and two Heavy Stubbers. Weapon Range Type S AP D Abilities Autocannon 48" Heavy 2 7 -1 2 - Battle Cannon 72" Heavy D6 8 -2 D3 - Conqueror Battle Cannon 48" Heavy D6 8 -2 D3 - Eradicator Nova Cannon 36" Heavy D6 6 -2 D3 Units being attacked by this weapon do not get any bonuses to their saving throws for being in cover. Heavy Bolter 36" Heavy 3 5 -1 1 - Heavy Stubber 36" Heavy 3 4 0 1 - Hunter-Killer Missile 48" Heavy 1 8 -2 D6 A Hunter-Killer Missile can only be fired once per battle Lascannon 48" Heavy 1 9 -3 D6 - Storm Bolter 24" Rapid Fire 2 4 0 1 - Vanquisher Battle Cannon 72" Heavy 1 8 -3 D6 Roll two dice when inflicting damage with this weapon and discard the lowest result. Wargear Options This model may replace its Battle Cannon with a Conqueror Battle Cannon, Eradicator Nova Cannon or Vanquisher Battle Cannon This model may replace its Heavy Bolter with a Lascannon This model may replace its two heavy Stubbers for two Autocannons or two Lascannons This model may take a hunter-killer missile This model may take a storm bolter or heavy stubber Abilities Explodes: If this model is reduced to 0 wounds, roll a D6 before removing the model from the battlefield; on a 6 it explodes and each unit within 2D6" suffers D6 mortal wounds. Assault Tank: This model does not suffer the penalty to hit rolls for moving and firing a Battle Cannon, Conqueror Battle Cannon, Eradicator Nova Cannon or Vanquisher Battle Cannon. Unreliable Engine: If this model is reduced to 8 wounds or less it loses the Assault Tank rule unless armed with a Conqueror Battle Cannon. Smoke launchers: Once per game, instead of shooting any weapons in the Shooting phase, this model can use its smoke launchers; until your next Shooting phase your opponent must subtract 1 from all hit rolls for ranged weapons that target this vehicle Tank Orders: This model can issue one order each turn to a friendly <REGIMENT> MALCADOR at the start of your Shooting phase. To issue a tank order, pick a target MALCADOR within 6” of this model and choose which order you wish to issue from the table on the right. Each MALCADOR can only be given a single order each turn. TANK ORDERS ORDER Full Throttle! Instead of shooting this phase the ordered model immediately moves as if it were the Movement phase. It must Advance as part of this move, and cannot declare a charge this turn. Gunners, Kill on Sight! Re-roll hits rolls of 1 for the ordered model until the end of the phase. Strike and Shroud! This order can only be issued to a model that has not yet used its smoke launchers during the battle. The ordered model can shoot its weapons and use its smoke launchers during this phase. Faction Keywords IMPERIUM, ASTRA MILITARUM, <REGIMENT> Keywords CHARACTER, VEHICLE, MALCADOR, MALCADOR ASSAULT TANK, OFFICER, TANK COMMANDER Malcador Siege TankPoint Values Heavy Support Unit Models per Unit Points per Model (does not include wargear) Malcador Siege Tank 1 190 Malcador Siege Tank Damage Remaining W M BS A 10 - 18+ 10" 4 3 5 – 9 7" 5 D3 1 – 4 4" 6 1 NAME M WS BS S T W A Ld Sv Malcador Assault Tank * 6 * 7 8 18 * 8 3 A Malcador Assault Tank is a single model equipped with a Twin Lascannon, a Demolisher Cannon and two Heavy Stubbers. Weapon Range Type S AP D Abilities Autocannon 48" Heavy 2 7 -1 2 - Demolisher Cannon 24" Heavy D3 10 -3 D6 When attacking units with 5 or more models, change this weapon's type to Heavy D6. Executioner Plasma Cannon Standard Supercharge 36” 36” Heavy D6 Heavy D6 7 8 -3 -3 1 2 - For each hit roll of 1 the bearer suffers 1 mortal wound after all this weapon's shots have been resolved. Heavy Bolter 36" Heavy 3 5 -1 1 - Heavy Stubber 36" Heavy 3 4 0 1 - Hunter-Killer Missile 48" Heavy 1 8 -2 D6 A Hunter-Killer Missile can only be fired once per battle Lascannon 48" Heavy 1 9 -3 D6 - Storm Bolter 24" Rapid Fire 2 4 0 1 - Twin Lascannon 48" Heavy 2 9 -3 D6 - Wargear Options This model may replace its Twin Lascannon with a Executioner Plasma Cannon This model may replace its two heavy Stubbers for two Autocannons or two Lascannons This model may take a hunter-killer missile This model may take a storm bolter or heavy stubber Abilities Explodes: If this model is reduced to 0 wounds, roll a D6 before removing the model from the battlefield; on a 6 it explodes and each unit within 2D6" suffers D6 mortal wounds. Assault Tank: This model does not suffer the penalty to hit rolls for moving and firing a Battle Cannon, Conqueror Battle Cannon, Eradicator Nova Cannon or Vanquisher Battle Cannon. Unreliable Engine: If this model is reduced to 8 wounds or less it loses the Assault Tank rule unless armed with a Conqueror Battle Cannon. Smoke launchers: Once per game, instead of shooting any weapons in the Shooting phase, this model can use its smoke launchers; until your next Shooting phase your opponent must subtract 1 from all hit rolls for ranged weapons that target this vehicle Faction Keywords IMPERIUM, ASTRA MILITARUM, <REGIMENT> Keywords VEHICLE, MALCADOR, MALCADOR ASSAULT TANK Naturally I broke the formatting...working on making it look like the nice word document that I have. Link to comment https://bolterandchainsword.com/topic/348105-making-a-better-malcador/ Share on other sites More sharing options...
