Fajita Fan Posted February 6, 2020 Share Posted February 6, 2020 (edited) Put on some goggles and drill one set out with a power drill. I can rip off magnets that stick out from a surface with pliers but getting superglued magnets out of a recess requires some aggressive measures. Neodymium magnets have a nasty habit of breaking up when you clamp them with pliers or try drilling them out, especially the cheap Chinese nickel coated ones like mine so put on goggles. I was yanking a 6mm x 3mm magnet off the waist of a Telemon dread that I bloody NAILED to the torso with glue and trying to yank it off with linesman pliers (not hobby pliers, actual pliers) was actually causing sparks as pieces broke off. It was like working a cigarette lighter. Edited February 6, 2020 by Fajita Fan Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473440 Share on other sites More sharing options...
Mendi Warrior Posted February 6, 2020 Share Posted February 6, 2020 Woaw, that's indeed an aggressive method. With resin no experience using magnets yet but with plastic models, the easiest is to drill into the plastic next to the magnet so to be able to put a blade behind it. It might require drilling / cutting all around the magnet of course. Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473445 Share on other sites More sharing options...
Taxidermied Posted February 6, 2020 Share Posted February 6, 2020 (edited) You can buy super glue debonder bud. I had to remove a few magnets when they dadn’t set quite flush. It will strip paint mind so go easy with it and I’d recommend drilling a 0.5 or 1mm hole next to it to let it get to the bottom of the socket. Edited February 6, 2020 by Taxidermied Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473462 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020 Woaw, that's indeed an aggressive method. With resin no experience using magnets yet but with plastic models, the easiest is to drill into the plastic next to the magnet so to be able to put a blade behind it. It might require drilling / cutting all around the magnet of course. I've broken more blades using them to lever things than I care to, I took a piece of shrapnel to my eye as a kid (luckily no vision problems today) so I'm hesitant to do that much anymore. The drill is nice because I go in perpendicular with safety glasses and the magnet usually crumbles to where I can go in with pliers. The shoulder joints of AT Warlords doesn't give me much real estate if I went in drilling to the side but there's plenty of ways to do things depending on how strong your gluing was. Murphy's rule of superglue bonds: The more you want it to stay in place the easier the bond comes loose. The more you need to get it apart to fix something it may be welded on for all intents and purposes. Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473506 Share on other sites More sharing options...
Rabenga Posted February 7, 2020 Share Posted February 7, 2020 Try freezing it. The cyanoacrylate should end up quite a bit more brittle than the polystyrene at relatively low temps...much easier to pry off. Debonder works a trick as well... Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473521 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020 Okay fine, look at you all with your pragmatic albeit slower solutions. I fire up a power tool and get 'r done. Also, tonight's task is to paint pistons on my claws to keep up with the Jones' here Captain Semper and Interrogator Stobz 2 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473531 Share on other sites More sharing options...
Rabenga Posted February 7, 2020 Share Posted February 7, 2020 I painted my pistons too...fyi. it's what all the cool kids are doing. Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473557 Share on other sites More sharing options...
Captain Semper Posted February 7, 2020 Author Share Posted February 7, 2020 Well thank you for all those responses! :woot: Sooo.... Let's assume that someone (let's say a cousin of mine) glued the magnets on the carapace weapons so as to repel instead of attract... Any remedies for that short of super-gluing them? *HE* might be interested... Which size are the magnets in the carapace weapons? 3mm or 5mm? Super glue I would assume? One trick is to drill one or several small holes next to the magnet and then insert a thin but strong blade and apply leverage to try to get the magnet out. Depending on how much glue and how deep they are inserted, it ranges from annoying but relatively easy to annoying and hard. Some swearing mandatory of course Yeah, drilling might not be possible -due to the shape of the shoulder (the shoulder magnet is the bit I want to remove - not the weapon... Superglueing might be the only way forward - inelegant as it may be... :rolleyes: Put on some goggles and drill one set out with a power drill. I can rip off magnets that stick out from a surface with pliers but getting superglued magnets out of a recess requires some aggressive measures. Neodymium magnets have a nasty habit of breaking up when you clamp them with pliers or try drilling them out, especially the cheap Chinese nickel coated ones like mine so put on goggles. I was yanking a 6mm x 3mm magnet off the waist of a Telemon dread that I bloody NAILED to the torso with glue and trying to yank it off with linesman pliers (not hobby pliers, actual pliers) was actually causing sparks as pieces broke off. It was like working a cigarette lighter. Put on goggles and drill... :o OK, power tools mayyyyybe not the way to go for me. Zero experience, I do not own one currently (or ever) and I do not plan to start acquainting myself with this technique with the Warlord where everything can go wrong - as it would be the first time for me... You sir really mean business! :lol: Woaw, that's indeed an aggressive method. With resin no experience using magnets yet but with plastic models, the easiest is to drill into the plastic next to the magnet so to be able to put a blade behind it. It might require drilling / cutting all around the magnet of course. Yeah, this drilling and cutting is what scares me... You can buy super glue debonder bud. I had to remove a few magnets when they dadn’t set quite flush. It will strip paint mind so go easy with it and I’d recommend drilling a 0.5 or 1mm hole next to it to let it get to the bottom of the socket. ALRIGHT!!! Now this is something that I might be able to use... I don't care about the stripped paint - this is easily remedied. The drilling of a hole is more of a concern - but I'll give it a go. I didn't even know that such de-bonders even existed... Can you get them from a hobby shop? Or a DIY store? This actually opens up new prospects - thanks man! :) Woaw, that's indeed an aggressive method. With resin no experience using magnets yet but with plastic models, the easiest is to drill into the plastic next to the magnet so to be able to put a blade behind it. It might require drilling / cutting all around the magnet of course. I've broken more blades using them to lever things than I care to, I took a piece of shrapnel to my eye as a kid (luckily no vision problems today) so I'm hesitant to do that much anymore. The drill is nice because I go in perpendicular with safety glasses and the magnet usually crumbles to where I can go in with pliers. The shoulder joints of AT Warlords doesn't give me much real estate if I went in drilling to the side but there's plenty of ways to do things depending on how strong your gluing was. Murphy's rule of superglue bonds: The more you want it to stay in place the easier the bond comes loose. The more you need to get it apart to fix something it may be welded on for all intents and purposes. Thanks Fajita... As you said the shoulder joints on the Warlord are a difficult area to work - especially given their bucket-like shape. And the glueing was perfect... Murphy's law indeed. :( Try freezing it. The cyanoacrylate should end up quite a bit more brittle than the polystyrene at relatively low temps...much easier to pry off. Debonder works a trick as well... Yeah, maybe the de-bonder is the way... Thank you man! :) Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473559 Share on other sites More sharing options...
Mendi Warrior Posted February 7, 2020 Share Posted February 7, 2020 I thought the inverted magnet was in the weapon. As it is in the shoulder socket and you are basically done with painting the upper part of the titan, it is trickier. Now, the shoulder socket could be cut parallel to the magnet using a jeweler saw. Then access to the magnet becomes much easier. It is precision work, not something to rush and some precautions must be taken to avoid messing up other things. I tend to glue my magnets during the building phase, before applying any paint at all. RipOffProductions 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473603 Share on other sites More sharing options...
Taxidermied Posted February 7, 2020 Share Posted February 7, 2020 You can pick up debonders at the larger DIY stores usually. It’ll be right with the super glues. If you’re UK based bud Toolstation sell it for a couple of pounds. Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473674 Share on other sites More sharing options...
Captain Semper Posted February 7, 2020 Author Share Posted February 7, 2020 JUSTICIA IMPERIALIS WARLORD CLASS TITAN OF LEGIO ATARUS I gave up and just glued it... Oh, well... Here are some additional pics: and I see your Warlord and raise you Reaver and two Warhounds!!! I will post and update the Titans event tomorrow... exhausted right now... Dosjetka, Grotsmasha, Chaeron and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473925 Share on other sites More sharing options...
DuskRaider Posted February 7, 2020 Share Posted February 7, 2020 Looking good Cap, nice clean stripes! Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473928 Share on other sites More sharing options...
Mendi Warrior Posted February 7, 2020 Share Posted February 7, 2020 Sublimissime! Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473932 Share on other sites More sharing options...
schoon Posted February 7, 2020 Share Posted February 7, 2020 Have been catching up on this thread. Amazing work. Having an airbrush makes certain aspects of painting SO much faster! Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473937 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020 Looks badass, those look fantastic together. Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5473944 Share on other sites More sharing options...
Chaeron Posted February 8, 2020 Share Posted February 8, 2020 It's the precision - such great work as always! Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474129 Share on other sites More sharing options...
Interrogator Stobz Posted February 8, 2020 Share Posted February 8, 2020 AWESOMESAUCE!!! Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474318 Share on other sites More sharing options...
Captain Semper Posted February 9, 2020 Author Share Posted February 9, 2020 Thank you guys! I'm now working on an extra Belicosa for Justucia and already started on the Reaver! Have been catching up on this thread. Amazing work. Having an airbrush makes certain aspects of painting SO much faster! Thanks schoon! And true enough, airbrush certainly has a positive impact on the time! However, I have not used an airbrush for the Atarus at all. In fact my airbrush suffered my anger management issues and needs to be replaced. Asmodai would have been proud... Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474632 Share on other sites More sharing options...
Fajita Fan Posted February 9, 2020 Share Posted February 9, 2020 I love picturing you as your avatar and winging an airbrush around in frustration. Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474646 Share on other sites More sharing options...
Sherrypie Posted February 9, 2020 Share Posted February 9, 2020 Justicia is looking sweet n' creamy, Cap. Atarus is always a pleasing sight to see. Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474691 Share on other sites More sharing options...
Captain Semper Posted February 9, 2020 Author Share Posted February 9, 2020 Thx Sherrypie, the trick as you say is to the "creaminess" of the white... However, I've seen interpretations with really sharp white - they look quite cool too. But my take is that creamy look... And a very dark red. Like Khorne Red red. :) Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474714 Share on other sites More sharing options...
Mendi Warrior Posted February 9, 2020 Share Posted February 9, 2020 And a very dark red. Like Khorne Red red. Ain't no better red than Khorne Red red (or maybe Blood for the Blood God?) Captain Semper 1 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5474778 Share on other sites More sharing options...
Captain Semper Posted February 16, 2020 Author Share Posted February 16, 2020 NOT IDLE! Mendi Warrior, Mandragola, ToyShip and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5477818 Share on other sites More sharing options...
Guest Posted February 16, 2020 Share Posted February 16, 2020 Looking great Good Captain.. You getting yourself any Warbringers? Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5477826 Share on other sites More sharing options...
Captain Semper Posted March 1, 2020 Author Share Posted March 1, 2020 MORIOR INVICTUS REAVER CLASS TITAN OF LEGIO ATARUS And the family pic so far... The two Warhounds are well underway and a Warbringer Nemesis is in the post! RedRowan, Reyner, TheDreadfulSagittary and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/350330-captain-sempers-adeptus-titanicus-project/page/19/#findComment-5484011 Share on other sites More sharing options...
