Here's part of the next set of Mesoamerican-themed bits, a set of pauldrons with Maya number glyphs for you to use as squad numbers!
The numbers, from left to right, are 1 through 10.
I should be able to get these and the backpacks (and maybe a few new heads) uploaded this weekend (I'm aiming for Friday).
I have some parts for dreadnoughts in progress as well, I hope to have them up sometime late next week.
https://linktr.ee/wulfsheademiniatures
Here's a big preview of (most) of the parts for the next Mesoamerican Bits set.
I still have the smaller "tilt" shields to finish up and will post pics of them later.
So far the set will have:
3 heads
4 backpacks
80 "numbered" pauldrons
35 pauldrons with new icons
tilt shields (not sure how many yet)
I decided to release the Sci-fi Beastmen Squad through my Gumroad shop instead of Patreon, and it's now available!
I'll be releasing the Command Models sometime in September as well and will post updates.
The newest set of Mesoamerican-themed bits has been posted!
There are STL files for:
4 Backpacks
5 Helms
5 Small "Tilt" Shields
80 Pauldrons - - There are 8 different pauldrons, each style has Maya glyphs for the numbers 1-10 so you can use them as squad numbers.
35 Pauldrons with Icons - - 7 Pauldron styles each with 5 different icons.
You can get it here:
https://wulfsheademiniatures.gumroad.com/l/nxfrcs
3 hours ago, Viridia said:
Those Beastmen really make me want to fix my printer! Loving the Mesoamerican themed parts as well.
I'll be expanding the Beastmen set with a Command Squad soon, and eventually other units and vehicles.
  • 3 weeks later...
While I'm still working on the Mesoamerican Dreadnought parts, I had some inspiration from reading about the dig in Mexico City and decided to make some terrain, the Hueyi Tzompantli.
It's not quite done, I still have some details to add to the base, and also the circular columns of skulls.
The skull racks have skulls from various races; Humans, Orc, Eldar, Genestealer, Ogre etc.
The 4 braziers will have flames in them, I still have to add those.
This is more of a scenic piece, but you cold use it on a tabletop or maybe part of a decorative army base.
  • 2 weeks later...
I knocked out some Rogue Trader era Chaos and Techmarine pauldrons over the weekend.
You can get them from my Shapeways shop, or if you want to print them yourself you can get the STL files from my Gumroad shop.
1 hour ago, Slave to Darkness said:
I need those Chaos pads!!! They are perfect. Any chance of some old style Chaos heads and backpacks or are you just sticking with the pads?
I'm working on the heads right now. I should be able to get them posted by the end of the week. I'll probably do backpacks as well, but that will come later.
  • 4 weeks later...
A Commercial Print License is now available!
A 1-year license to sell prints of my designs is now available from my Gumroad shop here:
Ill be grabbing the Chaos pads and heads when you finis them. :thumbsup:
Out of interest how far have you gotten with the heads?
I want to make 10 total, I have 7 so far. I should be able to finish them up this weekend and get them posted next week.
You know you wanna do a version of the old Giger inspired dreadnought dontcha?? :wink:
I have been thinking about that as well, but I want to change up the design a bit so I'm not just copying the GW model. I was thinking about making something like the old RT Chaos Dread, but using the newer Castraferrum style chassis.
I'll still mulling over the design, but will come up with something soon (probably after I finish up the Mesoamerican-themed dreadnought parts).
275 Mesoamerican themed pauldrons now available!
Yes, 275 designs. It took FOREVER to get these uploaded! Prints are available from my Shapeways store, the STL files are available from my Gumroad shop.
There are:
8 plain
51 icons
48 Assault Squad
48 Tactical Squad
48 Devastator Squad
48 Veteran
24 Command
  • 3 weeks later...
BLACK FRIDAY SALE!
From November 21 through November 30th you can get 30% off all STL files from my Gumroad shop here:
Just enter the code WHMBFS2022 at checkout.
Also, the first set of Mesoamerican terminator pauldrons is now available!
#40k #warhammer #spacemarine #primarismarine #primaris #powerarmor #imperium #mesoamerican #maya #aztec #inca #toltec #olmec #pauldron #conversion #bloodjaguars #rainbowwarriors #imperium #terminator #firstborn #cruxterminatus #powerarmor #eldar #tau #aeldari #necron #necrontyr #astra militarum #imperial guard #beastmen #abhuman
The Sci-fi Beastmen Command Squad is now available!
This set comes with components to create Command models for your Imperial Guard Abhuman army. These parts are also compatible with the Sci-fi Beastmen Squad so you have plenty of variations to make your army with!
All of my STL files are also on sale till the end of November, use the code WHMBFS2022 to get 30% off your purchase!
#40K #beastmen #astramilitarum #imperialguard #roguetrader #miniature #abhuman #warhammer #imperium #lasgun #bolter #melta #powersword #chainsword #commandsquad #cadian
The STL files for the Beastmen Command Medics are now available!
The set comes with new parts for Medics that are compatible with the Beastmen and Command components.
The Black Friday Sale is also continuing till November 30th! Use the code WHMBFS2022 to get 30% off all STL files.
  • 3 weeks later...
I took a break from the Mesoamerican bits to make some Lion-themed Helms for powered armor models (Dark Angels, etc).
There are 60 helms total.
You can get the STL files for this set here:
Register a new account
Sign in
