Fajita Fan Posted February 5, 2020 Author Share Posted February 5, 2020 The middle shoulder plate doesn't look like it has a lion Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5472717 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Share Posted February 5, 2020 It seems it has the Collegia Titanica symbol, doesn't look like a transfer. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5472960 Share on other sites More sharing options...
Fajita Fan Posted February 5, 2020 Author Share Posted February 5, 2020 So a lot of the time when I really don't like a model I end up coming around and accepting the design decisions, the more I look at the psi-titan the more I dislike it. The blank head is really distracting, a different faceplate is totally acceptable but blank? I understand that the princeps is a psychic blank but that doesn't mean the titan's face should be, it still needs the same sensors and camera lenses. It doesn't have the silver lions on the shoulders! I guess the silver lining (ha!) is that I'm even more motivated to finish mine now. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5472972 Share on other sites More sharing options...
Guest Posted February 5, 2020 Share Posted February 5, 2020 So a lot of the time when I really don't like a model I end up coming around and accepting the design decisions, the more I look at the psi-titan the more I dislike it. The blank head is really distracting, a different faceplate is totally acceptable but blank? I understand that the princeps is a psychic blank but that doesn't mean the titan's face should be, it still needs the same sensors and camera lenses. It doesn't have the silver lions on the shoulders! I guess the silver lining (ha!) is that I'm even more motivated to finish mine now. Its had the opposite effect on me the more I look at it the more I like it... The blank faceplate makes to look more sinister to me. But I have 5 Warlords I really don't need 6 so I want the upgrade kit. But then I don't need 7 Reavers but i will have 7 with that new starter set :P Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5472975 Share on other sites More sharing options...
Fajita Fan Posted February 5, 2020 Author Share Posted February 5, 2020 To be honest it looks like a rushed job, especially until I see the (what I assume to be) psi-emitter on top. Psi-titans can emit energy around them to demoralize troops, one of the quelled a rebellion simply by walking through a city with it on. I'm going to reeeeally hope the rules for this book weren't rushed either with an overpowered monster like the Acastus knights. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5472993 Share on other sites More sharing options...
Burni Posted February 6, 2020 Share Posted February 6, 2020 The new scenery is just so full of small bits. If I get some I think I’d have to make little industrial scenes with multiple bits together on a base. I’ve never used styrene plasticard. Does it work with normal plastic glue or do you use superglue? Anyone got a UK source for some with an embossed pattern that would suit an AT industrial area? Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473110 Share on other sites More sharing options...
Mendi Warrior Posted February 6, 2020 Share Posted February 6, 2020 I use superglue, it works perfectly. You should google for textured / embossed plasticard, a quick search returned these 3 in the UK https://www.newmodellersshop.co.uk/plasticard.htm https://www.ema-models.co.uk/index.php/sheet-materials/plastikard-embossed-styrene.html https://www.modelscenerysupplies.co.uk/scratch-build/building-paper-card-sheets/Plastic%20sheet/Plastic-Sheets I typically buy mine from http://www.greenstuffworld.com/ Also, if you plan to incorporate the AT industrial scenery bits into something bigger, have a go at your local DIY store (e.g. electric tubes, plumbing bits, insulation board, mdf, ...). Mixing things can produce nice results. And compare prices and also dimensions, there can be some "huge" differences. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473116 Share on other sites More sharing options...
Mandragola Posted February 6, 2020 Share Posted February 6, 2020 For the UK go to 4D model shop. They're an architectural model shop and have awesome stuff, including plasticard in all kinds of textures. If I ever build my buildings I'm planning to use some ridged stuff they sell for roof tiles, for example. It's where I got my the brass etched trees for my bases. Plastic glue does work on styrene sheet, so it's what I'd recommend. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473166 Share on other sites More sharing options...
Burni Posted February 6, 2020 Share Posted February 6, 2020 Great advice thanks. Not 100% I’m getting it yet as I don’t often use the stuff I have already. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473334 Share on other sites More sharing options...
schoon Posted February 6, 2020 Share Posted February 6, 2020 I really like the new scenery. It gives off a factorum vibe that was missing from the previous sets. Looking forward to making some industrial/promethium sites! Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473403 Share on other sites More sharing options...
Gore Crow Posted February 7, 2020 Share Posted February 7, 2020 I hope Reaver arms don't look too stubby on the Nemesis. Fists should be ok though Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473738 Share on other sites More sharing options...
Guest Posted February 7, 2020 Share Posted February 7, 2020 They are the same weapons. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473740 Share on other sites More sharing options...
shipmonkey Posted February 7, 2020 Share Posted February 7, 2020 I hope Reaver arms don't look too stubby on the Nemesis. Fists should be ok though No fists for these, per their current 30k/40k rules Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473744 Share on other sites More sharing options...
Gore Crow Posted February 7, 2020 Share Posted February 7, 2020 I was looking at the warbringer arm joints. They are similar to the reaver close combat joints, but dissimilar to the ranged weapon ones which are thinner. Not suggesting the weapons themselves are different, or that fist are a good idea - I should have fleshed out what I was saying better. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473777 Share on other sites More sharing options...
BolterZorro Posted February 7, 2020 Share Posted February 7, 2020 The new psi-titan is not "pre order today" as stated in the recent warhammer comunity article. But the forgeworld facebook confirmed earlier today that it'll be due for pre order tomorrow. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473794 Share on other sites More sharing options...
Mendi Warrior Posted February 7, 2020 Share Posted February 7, 2020 For those interested, NZ pre-orders are up, the Warbringer Nemesis comes with weapons cards also https://www.games-workshop.com/en-NZ/Warbringer-Nemesis-Titan-With-Quake-Cannon-2020 Alternative carapace weapon is a belicosa volcano canon Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473930 Share on other sites More sharing options...
schoon Posted February 7, 2020 Share Posted February 7, 2020 Yes, tomorrow is going to be painful for my wallet! Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473959 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Author Share Posted February 7, 2020 I think the Warbringer would look much better without the carapace armor, maybe a beefed up Reaver carapace? And I hate the head, maybe a spare Reaver or Warlord head would work better. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473977 Share on other sites More sharing options...
Guest Posted February 7, 2020 Share Posted February 7, 2020 2 Warbringers, Starter set and book for me :) Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5473979 Share on other sites More sharing options...
Mendi Warrior Posted February 8, 2020 Share Posted February 8, 2020 Psi-titan is out at £85 / €106 https://www.forgeworld.co.uk/en-GB/Adeptus-Titanicus-Warlord-Sinister-Psi-Titan-2020 This kit contains everything you need to build one Warlord-Sinister Psi-Titan and use it in your games of Adeptus Titanicus: – 1x Adeptus Titanicus Warlord Battle Titan with Plasma Annihilator and Arioch Power Claw. This 144-part plastic kit builds a towering god-machine and includes optional extras. It is supplied with a 120mm oval base.– 23 resin components to turn your Warlord into a Warlord-Sinister Psi-Titan– 8 Warlord Sinister Psi-Titan weapons cards: 1x apocalypse missile launchers, 2x belicosa volcano cannon, 1x paired laser blasters, 2x sunfury plasma annihilators, 1x Arioch Titan power claw, 1x Sistramanus Tenebrae– 1x Warlord-Sinister Psi-Titan command terminal Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474091 Share on other sites More sharing options...
Chaeron Posted February 8, 2020 Share Posted February 8, 2020 Goes without saying I really want both the Nemesis and the Psi-Titan :lol: Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474123 Share on other sites More sharing options...
Fajita Fan Posted February 8, 2020 Author Share Posted February 8, 2020 The gun has a 120” range and it’s 685 points which I assume includes the gun. “ The Warlord-Sinister Psi-Titan is available to Loyalist Titan Legions in Adeptus Titanicus. One Warlord in a maniple may be replaced with this terrifying war engine. ” And it replaces a Warlord in a maniple so I assume that means it gets the maniple bonus but does that mean it can’t be taken as an extra solo support titan? Call me crazy but that seems inverted to me. Also the stats for the carapace laser blaster is changed, it’s now +1 accuracy at long range instead of -1 at short IIRC. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474132 Share on other sites More sharing options...
Sandlemad Posted February 8, 2020 Share Posted February 8, 2020 I like both the sinistrmanus tenebrae more having seen the 360. The gun has some cool details that do make it weirdly esoteric. Volcano cannons, gatlings, these you can look at and parse. This gun has things that look like they might spin, odd ridges, a gap before the emitter, those four things on the back might be caskets for bound pyskers (might be misremembering the Ordo Sinister short story though). It's bizarrely slender and 1950's style for a titan-sized weapon. Same with the head. Viewed in profile it's not too big and gives me some Doctor Fate vibes. It's appropriately different to other GW blank masks. Not sure about the ciricrux though, looks rather flimsy and added on. I can see the braincase associations they're trying for but I would have rathered a more fundamental rebuilding of the shield generator part of the model. £20 over the regular warlord... doesn't actually seem that bad? By FW standards at least, considering it has a gun (normally £10), a head and the ciricrux, some cards and a terminal. I think? Or am I irreparably damaged by years of FW prices so I can't see sense anymore? Rules-wise, this thing's 300 pts over the cost of a bare warlord. It does seem to come with the gun built into the cost though but that's a lot. “ The Warlord-Sinister Psi-Titan is available to Loyalist Titan Legions in Adeptus Titanicus. One Warlord in a maniple may be replaced with this terrifying war engine. ”And it replaces a Warlord in a maniple so I assume that means it gets the maniple bonus but does that mean it can’t be taken as an extra solo support titan? Call me crazy but that seems inverted to me. The preview of the rules in Shadow and Iron put it the other way, they seem to mandate that it's used as a support titan and can't be part of a maniple. The FW description is probably just boilerplate text in error. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474137 Share on other sites More sharing options...
Sherrypie Posted February 8, 2020 Share Posted February 8, 2020 The gun has a 120” range and it’s 685 points which I assume includes the gun. “ The Warlord-Sinister Psi-Titan is available to Loyalist Titan Legions in Adeptus Titanicus. One Warlord in a maniple may be replaced with this terrifying war engine. ” And it replaces a Warlord in a maniple so I assume that means it gets the maniple bonus but does that mean it can’t be taken as an extra solo support titan? Call me crazy but that seems inverted to me. Also the stats for the carapace laser blaster is changed, it’s now +1 accuracy at long range instead of -1 at short IIRC. Why are you assuming the gun is included? This has not been the case with anything thus far and the terminal says "685 + weapons". It also doesn't replace anything, the picture from the book with some of their rules says they are never part of the maniples and are always support. The replacing thing is just another case of website writers not knowing the game they are talking about. Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474138 Share on other sites More sharing options...
Sherrypie Posted February 8, 2020 Share Posted February 8, 2020 Interestingly, the Warbringer cards include the "15+ critically disabled" result that is not dublicated in the Sinister weapons, so it is not a universal change. Might we see the first interaction with "special" hit location or just a thing to show a heavy artillery titan can blow its magazines extra hard when its gun take hits? Link to comment https://bolterandchainsword.com/topic/361583-new-stuff/page/3/#findComment-5474143 Share on other sites More sharing options...
