Shaezus Posted November 27, 2020 Share Posted November 27, 2020 @Indefragable that sanguinor - sacrifice combo is indeed a perfect troll on somebody's perfect charge. Keen to try it Yes one death vision per battle unless you pop the strat. Which I assume means using the hit reroll and the invulnerable save visions. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636863 Share on other sites More sharing options...
BrotherAetherick Posted November 27, 2020 Share Posted November 27, 2020 -I’m excited about the design space of the different Death Visions...but will have to see how they play out, You can only use 1 per turn per character, unless you use that Strategem, is that correct? Each death vision can only be used once per battle. A death company character can only use death visions once per battle. There is a strat to let a death company character use two in one fight, or if they have already used a death vision, use a death vision that has not been used before. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636868 Share on other sites More sharing options...
BAjim Posted November 27, 2020 Share Posted November 27, 2020 Unless there's a change in the Supplement we haven't seen, Red Rampage can only be activated from T3 onwards. A Sanguinary Priest can use their Blood Chalice to change the active Doctrine to Assault Doctrine prior to Turn 3. Happy times Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636871 Share on other sites More sharing options...
SnorriSnorrison Posted November 27, 2020 Share Posted November 27, 2020 Just realised, with the combination of UWoF and the Death from Above stratagem, you can score the 2 points multiple times continuously instead of only up to turn 3. Which means either delaying a lot of resources to make sure that you clap your opponent’s units out of DS, or having the bodies on the table to score objectives. Interesting. Death from above seems like a little bit of a trap though. You need to kill a unit EVERY turn to get a max of only 10, unless its a character, in which case you can get more. I dont think this is a good option It’s only 2 points per killed unit, however any unit that came from reserves at any given time during the game can score these during the battle. So if you committed half your army to a Deepstrike in turn 2, all of those units can continue getting points for you, probably including a character at one point. This also includes strategic reserves and outflank. So yes, UWoF isn’t needed for this, and can indeed be a trap. But still, if that means the opponent desperately needs to take out the killy melee units (or even stuff like inceptors since it’s not restricted to close combat kills) to stop all of them from scoring, I suppose the units taking primary objectives could remain a bit safer overall. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636873 Share on other sites More sharing options...
Morticon Posted November 27, 2020 Share Posted November 27, 2020 You have to kill with a unit that came down from reinforcements, which isn't happening T1 unless it's the Sanguinor. As noted previously, until we get a FAQ saying otherwise, we're still bound by the wording of reserves rule which in Matched Play doesnt allow this. Ulike Drop Pods for example which can do this! Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636875 Share on other sites More sharing options...
Morticon Posted November 27, 2020 Share Posted November 27, 2020 Unless there's a change in the Supplement we haven't seen, Red Rampage can only be activated from T3 onwards. A Sanguinary Priest can use their Blood Chalice to change the active Doctrine to Assault Doctrine prior to Turn 3. Happy times Correct, but unfortunately this does not change the wording of Red Rampage, which requires the ARMY be in Assault Doctrine. So, Red Rampage cannot be used until T3. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636877 Share on other sites More sharing options...
Morticon Posted November 27, 2020 Share Posted November 27, 2020 Just realised, with the combination of UWoF and the Death from Above stratagem, you can score the 2 points multiple times continuously instead of only up to turn 3. Which means either delaying a lot of resources to make sure that you clap your opponent’s units out of DS, or having the bodies on the table to score objectives. Interesting. Death from above seems like a little bit of a trap though. You need to kill a unit EVERY turn to get a max of only 10, unless its a character, in which case you can get more. I dont think this is a good option It’s only 2 points per killed unit, however any unit that came from reserves at any given time during the game can score these during the battle. So if you committed half your army to a Deepstrike in turn 2, all of those units can continue getting points for you, probably including a character at one point. This also includes strategic reserves and outflank. So yes, UWoF isn’t needed for this, and can indeed be a trap. But still, if that means the opponent desperately needs to take out the killy melee units (or even stuff like inceptors since it’s not restricted to close combat kills) to stop all of them from scoring, I suppose the units taking primary objectives could remain a bit safer overall. Good catch!! Hadn't realised that! That's a LOT better. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636879 Share on other sites More sharing options...
SnorriSnorrison Posted November 27, 2020 Share Posted November 27, 2020 Also, to get relentless assault and linebreaker, send 2x5 tactical squads and a drop pod into the opponent‘s DZ on turn 1, while other troops rush forward to get primary objectives. The opponent has the option of moving into your DZ to stop these tactical marines from scoring, or they must dedicate some firepower to get rid of them and the pod. Potentially a lot of secondary points there. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636881 Share on other sites More sharing options...
Xenith Posted November 27, 2020 Share Posted November 27, 2020 What might be fun is a biker captain with Chapter Master TH/SS Angel's Artifice [RELIC] +1T, +1W Iron Resolve [TRAIT] +1W, 6+++ Then either Foresight for the reroll, or Artisan for Adamantine mantle and a 5+++ 14" move, 1+/4++/6+++, T6, 8W, with innate self rerolls to hit, and a single free invun reroll per turn, or a D4 hammer. Id take Imperium's Sword over the +1 - but wow, is this tanky! Sword is much better, and gives the critical reroll, but this was a fun build for max toughness. You can sacrifice some killy power to take adamantine mantle to give an effective 10 wounds, however I think foresight is better for the save reroll, as that can potentially block multiple damage per roll. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636910 Share on other sites More sharing options...
Diagramdude Posted November 27, 2020 Share Posted November 27, 2020 Soulwarden WL trait might be an auto include now that the Standard of Sacrifice is gone, and the FNP affects all units not just infantry. Might be great on a Libby Dread? Could any BA vehicles see play inside a 5+++ bubble? Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636913 Share on other sites More sharing options...
Karhedron Posted November 27, 2020 Author Share Posted November 27, 2020 The Iron Resolve trait also gives a 6+ FNP which effectively takes the 8W to 9.33W Actually it's better than that. Each time you make the 6+++, that is an extra wound that you can save against the next time. Someone did the maths a 6+++ actually works out as a 20% increase in the number of wounds so it is pretty 10W. Of course you could use Artisan of War to get an Adamantine Mantle for a 5+++. You would be starting at 7W but the effect of a 5+++ is nearly a 50% increase in effective wounds so you would be well over 10W in practice. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636919 Share on other sites More sharing options...
Karhedron Posted November 27, 2020 Author Share Posted November 27, 2020 Soulwarden WL trait might be an auto include now that the Standard of Sacrifice is gone, and the FNP affects all units not just infantry. Might be great on a Libby Dread? Could any BA vehicles see play inside a 5+++ bubble? It only affects Mortal Wounds, not normal damage so I don't think it is a real replacement for SoS. Not that it is bad, but not auto-take IMHO. Might be good against some armies that spam MWs. I think the Sanguinary Priest with his 6+++ is the closest we get to a substitute SoS. Considering he also applies his resurrection magic and healing, he might actually make a unit tougher to remove than SoS as well as applying a combat bonus on T1/2 with the Blood Chalice. I have only run a Jump SP once so far with my Sanguinary Guard but it was really amazing and I will be doing it again. At 125 points, I can't see my Sanguinary Ancient coming out much in this edition. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636925 Share on other sites More sharing options...
Diagramdude Posted November 27, 2020 Share Posted November 27, 2020 Good catch Karhedron, nevermind! Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636946 Share on other sites More sharing options...
smileyjim Posted November 27, 2020 Share Posted November 27, 2020 What might be fun is a biker captain with Chapter Master TH/SS Angel's Artifice [RELIC] +1T, +1W Iron Resolve [TRAIT] +1W Then either Foresight for the reroll, or Artisan for a D4 hammer. 14" move, 1+/4++/6+++, T6, 8W, with innate self rerolls to hit, and a single free invun reroll per turn, or a D4 hammer. I can't find angels artifice relic, where is that? Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636978 Share on other sites More sharing options...
Shaezus Posted November 27, 2020 Share Posted November 27, 2020 Chapter Master relic in the SM codex p. 98 Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636987 Share on other sites More sharing options...
Karhedron Posted November 27, 2020 Author Share Posted November 27, 2020 2+ save, 1+W and +1T. Pretty tidy, particularly if you combine it with a Bike for T6 and a Storm Shield for a 1+ save. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5636994 Share on other sites More sharing options...
Indefragable Posted November 27, 2020 Share Posted November 27, 2020 On a humorous note I always get tennis neck looking at all the different comments of “check out this sweet combo!” “Umm, you can’t actually do that...” “..actually if you read closer you can!” “Oh yea, good catch!” “Technically you can, but you want option A76$B12 instead” ...one of the fun parts of new books coming out. ****** Regarding gear and WLT combos, realistically AP-3 is the most a dude will face, meaning 4++ will block that as well as AP-2 on a Sv2+. Thus effective Sv1+ is kind of a luxury/nice to have that really only helps out against massed AP-1 (aka chainswords and bolt rifles outside of their buffed doctrines). I mean, yes it will still give you a Sv3+ against AP-2, but I feel Smart Cover positioning helps against ranged, and most character killers have AP-3, right? Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637144 Share on other sites More sharing options...
Diagramdude Posted November 27, 2020 Share Posted November 27, 2020 The base 1+ allows you to still have a 2+ in cover against AP2 and a 3+ against AP3, and you can take cover saves in melee if you’re in Heavy Cover Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637146 Share on other sites More sharing options...
Hintzy Posted November 28, 2020 Share Posted November 28, 2020 Somebody elsewhere pointed out that technically, RAW, not only can you use Forlorn Fury more than once, but you can use it on the same unit. So, provided there's space to land 9" away from enemy units to end each move, you could hop a DC unit all the way into your opponent's deployment zone before the first turn. Now, I'm certain that's not intended, but do with that what you will. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637213 Share on other sites More sharing options...
SnorriSnorrison Posted November 28, 2020 Share Posted November 28, 2020 Despite the heavy-felt losses of our core stratagems coming from 8th, the secondary objectives from the book seem all quite decent, and for the most part easily enough achieved.The Death Visions are very flavourful, but mostly "eh" since they're once-per-battle abilities and have a few restrictions. They'd probably do well in crusade, but I haven't looked into that at all.I'm still uncertain on some wordings. Artisan of War, Master-crafted weapon - can you actually give that to the hammer of Baal?? It sounds too good to be true, and then it usually isn't. I just can't imagine it's intended to upgrade the usually set profile of a relic further. I'd gladly be proven wrong, for I might actually equip that MC hammer and go to town... Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637244 Share on other sites More sharing options...
Brother Cruoris Posted November 28, 2020 Share Posted November 28, 2020 Why dont we get the special limited set with a framed art print like space wolves and deathwatch got? Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637256 Share on other sites More sharing options...
Blindhamster Posted November 28, 2020 Share Posted November 28, 2020 would appear not. Bit of a shame as I liked the art for our codex a lot. Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637261 Share on other sites More sharing options...
Shaezus Posted November 28, 2020 Share Posted November 28, 2020 Despite the heavy-felt losses of our core stratagems coming from 8th, the secondary objectives from the book seem all quite decent, and for the most part easily enough achieved. The Death Visions are very flavourful, but mostly "eh" since they're once-per-battle abilities and have a few restrictions. They'd probably do well in crusade, but I haven't looked into that at all. I'm still uncertain on some wordings. Artisan of War, Master-crafted weapon - can you actually give that to the hammer of Baal?? It sounds too good to be true, and then it usually isn't. I just can't imagine it's intended to upgrade the usually set profile of a relic further. :ermm: I'd gladly be proven wrong, for I might actually equip that MC hammer and go to town... Sadly not! The wording for Master - Crafted says it can't be given to anything considered to be a relic. Too good to be true indeed I know what you mean about the death visions. The last one on the list makes no sense. Throwing away all your attacks for a 50% chance to do 4-6 mortal wounds? Weird but fun I suppose. The other two are superb for helping to get 15 VP for the "blade of sanguinius" secondary. One use is all you'll need Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637296 Share on other sites More sharing options...
Shaezus Posted November 28, 2020 Share Posted November 28, 2020 Just pre - ordered my collector's Ed. supplement and datacards. Bring on this new era for the Blood Angels! From one of the photos: "The Blood Angels fear neither heretical abomination nor xenos monstrosity. We have faced the terrors that lurk in our own minds, and seen the snarling beasts that seek to claw their way up from the depths of our souls What can the foe threaten us with compared to that?" That right there is why I've stayed BA since I started 30 years ago. Roll on 9th ed!! Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637301 Share on other sites More sharing options...
Cleon Posted November 28, 2020 Share Posted November 28, 2020 I know what you mean about the death visions. The last one on the list makes no sense. Throwing away all your attacks for a 50% chance to do 4-6 mortal wounds? Weird but fun I suppose. The other two are superb for helping to get 15 VP for the "blade of sanguinius" secondary. One use is all you'll need The last one is actually pretty useful - use it on a character who is completely outmatched (say a DC Lt versus Abaddon), if it passes, fun times 4-6 MW, if you fail it then nothing happens, no attacks from either character (and unless I'm missing something it doesn't stop others piling attacks on) Link to comment https://bolterandchainsword.com/topic/367838-9th-edition-codex-supplement/page/7/#findComment-5637414 Share on other sites More sharing options...
