Karhedron Posted April 11, 2022 Share Posted April 11, 2022 I have seen some number-crunching that suggests Avengers with HoD are not far behind Fire Dragons for killing vehicles on a point-per point basis. You can buy almost exactly 2 Avengers for each Fire Dragon so let's run some numbers against T8, 3+ save. Fire Dragon has 1 shot, hitting on a 3+, wounding on a 3+, negating any non-invuln saves and doing D6+2 wounds. That gives an average of 2.44 wounds per Dragon. 2 Avengers get 6 shots, hitting on 3+, wounding on a 6, negating any non-invuln saves and doing 1 wound but 6s to hit automatically go through. That is 1 automatic wound, and 3 hits that wound on a 6. This gives and average of 1.5 wounds OK, so Dragons are better "big game" hunters than HoD Avengers (which you would expect) but the difference is not actually that huge. Fire Dragons cause about 10 wounds per 100 points to vehicle targets while Avengers cause about 6 wounds per 100 points. But the Avengers are far more flexible and will shred infantry far more effectively than the Dragons and also benefit more from Doom. Avengers also bring more warm bodies to the field (although they are T3 4+ rather than T4 3+). I was wondering what to do with my 20 Avengers, I think I may have found an answer! :D Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5814536 Share on other sites More sharing options...
Plague _Lord Posted April 11, 2022 Share Posted April 11, 2022 I have seen some number-crunching that suggests Avengers with HoD are not far behind Fire Dragons for killing vehicles on a point-per point basis. You can buy almost exactly 2 Avengers for each Fire Dragon so let's run some numbers against T8, 3+ save. Fire Dragon has 1 shot, hitting on a 3+, wounding on a 3+, negating any non-invuln saves and doing D6+2 wounds. That gives an average of 2.44 wounds per Dragon. 2 Avengers get 6 shots, hitting on 3+, wounding on a 6, negating any non-invuln saves and doing 1 wound but 6s to hit automatically go through. That is 1 automatic wound, and 3 hits that wound on a 6. This gives and average of 1.5 wounds OK, so Dragons are better "big game" hunters than HoD Avengers (which you would expect) but the difference is not actually that huge. Fire Dragons cause about 10 wounds per 100 points to vehicle targets while Avengers cause about 6 wounds per 100 points. But the Avengers are far more flexible and will shred infantry far more effectively than the Dragons and also benefit more from Doom. Avengers also bring more warm bodies to the field (although they are T3 4+ rather than T4 3+). I was wondering what to do with my 20 Avengers, I think I may have found an answer! I have seen some number-crunching that suggests Avengers with HoD are not far behind Fire Dragons for killing vehicles on a point-per point basis. You can buy almost exactly 2 Avengers for each Fire Dragon so let's run some numbers against T8, 3+ save. Fire Dragon has 1 shot, hitting on a 3+, wounding on a 3+, negating any non-invuln saves and doing D6+2 wounds. That gives an average of 2.44 wounds per Dragon. 2 Avengers get 6 shots, hitting on 3+, wounding on a 6, negating any non-invuln saves and doing 1 wound but 6s to hit automatically go through. That is 1 automatic wound, and 3 hits that wound on a 6. This gives and average of 1.5 wounds OK, so Dragons are better "big game" hunters than HoD Avengers (which you would expect) but the difference is not actually that huge. Fire Dragons cause about 10 wounds per 100 points to vehicle targets while Avengers cause about 6 wounds per 100 points. But the Avengers are far more flexible and will shred infantry far more effectively than the Dragons and also benefit more from Doom. Avengers also bring more warm bodies to the field (although they are T3 4+ rather than T4 3+). I was wondering what to do with my 20 Avengers, I think I may have found an answer! You know what's better at killing vechicles than HoD Avengers? Mobile warriors Avengers. Theoretical - a guided 10 man avengers squad is shooting at a doomed Leman Russ, the squad uses bladestorm strat. HoD - 10 damage on average (rounded down) MW - 12 damage on average (rounded up). If the squad has the shredding fire exarch power then on both occasions they will take out the Leman Russ. I think mobile warriors is more flexible in a mechanized list since it gives slightly better returns vs vechicles with Avengers, while also working in the fight phase and actually buffing other units like striking scorpions. HoD has it's own merit in not needing a vechicle to work and will work in turns where the unit is objective camping. So if you are playing a mobile, aggressive force and want to alpha strike on turns 1/2 then I would rather go with mobile warriors and fore example savage blades - since mobile warriors still works in the fight phase, your 10 dire avengers are putting out 21 rerollable ws3+ attacks that have +1 to wound and -1 ap. These guys can be a nice ace up your sleeve that can catch opponents off guard. There might actually be some merit to either the dire sword or power glaive on the exarch. Don't want to do the maths but Mobile warrior/savage blades striking scorpions are probably extremely potent on the charge. Ok fast maths - 9 scorps without a an exarch will do around 24 unsaved wounds vs space marines that don't use transhuman :D I have seen some number-crunching that suggests Avengers with HoD are not far behind Fire Dragons for killing vehicles on a point-per point basis. You can buy almost exactly 2 Avengers for each Fire Dragon so let's run some numbers against T8, 3+ save. Fire Dragon has 1 shot, hitting on a 3+, wounding on a 3+, negating any non-invuln saves and doing D6+2 wounds. That gives an average of 2.44 wounds per Dragon. 2 Avengers get 6 shots, hitting on 3+, wounding on a 6, negating any non-invuln saves and doing 1 wound but 6s to hit automatically go through. That is 1 automatic wound, and 3 hits that wound on a 6. This gives and average of 1.5 wounds OK, so Dragons are better "big game" hunters than HoD Avengers (which you would expect) but the difference is not actually that huge. Fire Dragons cause about 10 wounds per 100 points to vehicle targets while Avengers cause about 6 wounds per 100 points. But the Avengers are far more flexible and will shred infantry far more effectively than the Dragons and also benefit more from Doom. Avengers also bring more warm bodies to the field (although they are T3 4+ rather than T4 3+). I was wondering what to do with my 20 Avengers, I think I may have found an answer! You know what's better at killing vechicles than HoD Avengers? Mobile warriors Avengers. Theoretical - a guided 10 man avengers squad is shooting at a doomed Leman Russ, the squad uses bladestorm strat. HoD - 10 damage on average (rounded down) MW - 12 damage on average (rounded up). If the squad has the shredding fire exarch power then on both occasions they will take out the Leman Russ. I think mobile warriors is more flexible in a mechanized list since it gives slightly better returns vs vechicles with Avengers, while also working in the fight phase and actually buffing other units like striking scorpions. HoD has it's own merit in not needing a vechicle to work and will work in turns where the unit is objective camping. So if you are playing a mobile, aggressive force and want to alpha strike on turns 1/2 then I would rather go with mobile warriors and fore example savage blades - since mobile warriors still works in the fight phase, your 10 dire avengers are putting out 21 rerollable ws3+ attacks that have +1 to wound and -1 ap. These guys can be a nice ace up your sleeve that can catch opponents off guard. There might actually be some merit to either the dire sword or power glaive on the exarch. Don't want to do the maths but Mobile warrior/savage blades striking scorpions are probably extremely potent on the charge. Ok fast maths - 9 scorps without a an exarch will do around 24 unsaved wounds vs space marines that don't use transhuman :D Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5814576 Share on other sites More sharing options...
BLACK BLŒ FLY Posted April 11, 2022 Share Posted April 11, 2022 Has anybody used the new Avatar yet ? Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5814679 Share on other sites More sharing options...
Dwango Posted April 11, 2022 Share Posted April 11, 2022 Has anybody used the new Avatar yet ? I've not yet but I will be running it against some nids in a few weeks time. Waiting for their new dex to drop. Mithrilforge and BLACK BLŒ FLY 2 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5814705 Share on other sites More sharing options...
Iron Father Ferrum Posted April 11, 2022 Share Posted April 11, 2022 I have not, but I've seen a few reports in FB groups. Oddly, every report seems to come from either end of the bell curve: either the Avatar is super tough and absolutely mercs half the enemy army, or it gets blinked off the table in the first turn without harming anything. BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5814746 Share on other sites More sharing options...
Xenith Posted April 13, 2022 Share Posted April 13, 2022 Oddly, every report seems to come from either end of the bell curve: either the Avatar is super tough and absolutely mercs half the enemy army, or it gets blinked off the table in the first turn without harming anything. Sounds like a terrain issue to me - usually a factor in bipolar performances. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815238 Share on other sites More sharing options...
Karhedron Posted April 14, 2022 Share Posted April 14, 2022 Warlord trait is meh though for sure lol I will be honest, most of the WLTs and Relics seem pretty underwhelming. When I am playing Marines, I regularly splash 2-3CPs on extra traits and Relics but I don't feel the urge to do the same for Eldar. A couple of the Exarch Shrine relics look like they have some mileage though. Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815462 Share on other sites More sharing options...
KnightofSigismund Posted April 14, 2022 Share Posted April 14, 2022 Help me out here guys, my buddy says there is a loophole that lets a wave serpent carry wraith knights….is that true? Thanks in advance. If there is one he’s found he’s gonna try and use it on me. Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815658 Share on other sites More sharing options...
The Yncarne Posted April 14, 2022 Share Posted April 14, 2022 (edited) Help me out here guys, my buddy says there is a loophole that lets a wave serpent carry wraith knights….is that true? Thanks in advance. If there is one he’s found he’s gonna try and use it on me. relying on the "wraith construct" keyword? Edited April 14, 2022 by The Blood Raven Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815700 Share on other sites More sharing options...
Khulu Posted April 14, 2022 Share Posted April 14, 2022 The Wave Serpent says it transports Infantry. It does say Wraith Constructs take up the space of 2 Infantry models but nothing allows the Wraithknight to embark to take up two slots in the first place Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815719 Share on other sites More sharing options...
KnightofSigismund Posted April 14, 2022 Share Posted April 14, 2022 Yes! It was the wraith construct rule he was on about. So the wave serpent says infantry. Well that’ll fix that nonsense you guys are great! The Yncarne 1 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5815869 Share on other sites More sharing options...
9x19 Parabellum Posted April 15, 2022 Share Posted April 15, 2022 Guys, 4 (7?) questions about the new codex: 1. Dire Avenger Exarch appears to have the option to use and + fire 2 Avenger Shuriken Catapults. Is that correct? (therebye getting 6 shots) 2. Guardians' Heavy Weapon Platform; -counts as a model for purposes of taking up space in transport, right? -still qualifies as an infantry model so suffers -1 move and shoot penalty for heavy weapons? 3. Strands of Fate dice; -go away at the end of the Battle Round and are never carried over. -can be used more than once in any given phase/turn as long as I have the respective dice. (ie, if my Autarch gets hit and wounded by 2 meltaguns in the same shooting phase, I can use 2 Strands of Fate "6's" (ie, saves) to auto-pass 2 of his invuln saves, right? 4. Wireweave Grenades Stratagem (pg 101)....Read this stratagem very carefully. After you roll a d3, you consult the bulleted points below that. The wording does NOT suggest to me that the affect you get is based on the result of your roll, rather that you get all 3 affects. Is my reading correct? Also...regarding the first bullet....What would happen if you rolled 3 mortal wounds but against a multi-wound model/unit. So for example, your die roll is 5 (ie, 3). The enemy unit would suffer 3 mortal wounds, to a max of 1 mortal wound per model the enemy unit. Does that mean, for a unit of 5 terminators, the controlling player would choose 3 terminator models, each of whom received 1 wound? Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5816290 Share on other sites More sharing options...
Karhedron Posted April 15, 2022 Share Posted April 15, 2022 4. Wireweave Grenades Stratagem (pg 101)....Read this stratagem very carefully. After you roll a d3, you consult the bulleted points below that. The wording does NOT suggest to me that the affect you get is based on the result of your roll, rather that you get all 3 affects. Is my reading correct? Also...regarding the first bullet....What would happen if you rolled 3 mortal wounds but against a multi-wound model/unit. So for example, your die roll is 5 (ie, 3). The enemy unit would suffer 3 mortal wounds, to a max of 1 mortal wound per model the enemy unit. Does that mean, for a unit of 5 terminators, the controlling player would choose 3 terminator models, each of whom received 1 wound? No, you are not allowed to have multiple models in a unit all partially wounded. The maximum limit it applied to the total number of mortal Wounds. For example, if you are targetting a unit of 2 models, you would only get 2 MWs max, you cannot get 3. However if the unit conists of models with more than one wound, the MWs can (and must) be applied to wounded models first until they die. Only then can remaining MWs start to be applied to fresh models. Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5816319 Share on other sites More sharing options...
Dr. Clock Posted April 17, 2022 Share Posted April 17, 2022 Well... despite Armour of Contempt - we still got it, people... List last night into Death Guard was WLord, 2 d-cannons, Prism, 2 serpents (DA + Scorps + Dragons + warlock), more Scorps, Spiders, Shroudrunners, scatter bikes, 2x5 rangers, 1x15 guardians, and 2 farseers. Got Turn 1, grabbed 4/5 objectives, and was able to move block enemy rhino advance something fierce with Serpents and feed in outflankers to keep the line wide... Game stopped after my turn 3 after I'd shot him off his objective and he still hadn't been able to push on to any others. He needed a bunch more terminators, and Armour of Contempt is annoying sometimes, but any rash of 2s on saves still kills 'em dead. Hilariously in turn 2 my 5 dragons did exactly nothing to the Daemon prince due to hot daemon saves, but then he promptly failed three saves vs the serpent laser, was unable to kill dragons because of Strands saves and my own 5++, and they fell back and fried him turn 3. If anything armour of contempt made the scatter laser better lol, so I'm not complaining. D-cannons are just... so much fun, you guys. Cheers, The Good Doctor. Mithrilforge, TrawlingCleaner and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5816711 Share on other sites More sharing options...
Xenith Posted August 2, 2022 Share Posted August 2, 2022 Struggled last night v Chaos Knights. Not enough firepower, and they move fast enough to chase even grav tanks down. TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5852614 Share on other sites More sharing options...
The Yncarne Posted August 2, 2022 Share Posted August 2, 2022 It’s a shame the fleeters don’t have as much haywire as their laughing brethren. I’m unfamiliar with chaos knights, but thanks for the write up and pictures. It looked like an uphill battle with that terrain. Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5852636 Share on other sites More sharing options...
Xenith Posted August 2, 2022 Share Posted August 2, 2022 We played the forests as obscuring, and everythig as impassible to the knights, so it wasn't as bad as it looked - stripping 112 T7+ wounds, often with a 4++ was a monumental task though. I might have to go back to running dual prisms. The issue there is that the link fire has to be on a single target, which is then potentially wasted on wardogs/armigers (average 24 wounds on 4 hits+wounds). The Avatar would be able to take something out in melee, however T8, 14W isn't that strong in the face of knights. Link to comment https://bolterandchainsword.com/topic/373509-aeldari-codex-first-impressions/page/5/#findComment-5852640 Share on other sites More sharing options...
