Inquisitor_Lensoven Posted January 11, 2023 Share Posted January 11, 2023 (edited) Here’s the list I’m looking at right now. Army traits veteran geurrilas elite sharp shooters WLT grand strategist HQs castellan w/ plas pistol powersword command squad bolter, power sword, relic vox, plasma gun, GL, banner tank commander- demolisher PCs, lascannon troops CST x2 vox, plas, melta, autoguns IS x2 HB plasma vox. RL melta vox Elites kasrkin plasma, flamer, power sword FA scout sentinel multilasers x2 chainsaw, HK HS FOB malleus transports chimera heavy stubber, HB total 975 I told opponent to bring whatever they want, could be knights or deamons of tzeench if you have any suggestions other units I have available exterminator 2 battle tanks basilisk 3 HWS AC, mortars, lascannons taurox w/ ACs baneblade Edited January 17, 2023 by duz_ Added tag Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/ Share on other sites More sharing options...
Santaclauswitz Posted January 12, 2023 Share Posted January 12, 2023 As is I'd be tempted to fill the points with an astropath for the command squad. It's just a way use up those last 25 points and that might give you a command point. For a deeper dive I'd question using the demolisher over the battle tank because the commander would benefit from the gatekeeper relic and because of the short range and swing nature of the demolisher. Also what units are you hoping to buff with it's order? The chimera or sentinels? The chimera would benefit from reroll 1's but is a poor target for an order because it's not a damage dealer. The sentinels would probably prefer the take aim infantry order and the buffs it can take from infantry aura. Do you actually need a commander? I'd also be tempted to replace the PCS with HBS to save an extra 10 points. Have you chosen power swords because of modeling? Is so ignore this... Power swords are a bit rubbish. 15 points could be spent elsewhere. I'd be tempted to swap out the IS heavy weapons for lascanons. What trait have you given the kasrkin? Are the weapons choices modeling as well? I'm looking at the flamer as well as the power sword. Same question for the sentinels.... is that how they're modeled? The HK's are ok but I'd lose the chain swords. I'd be interested in how the fob does. No real opinion on them at the moment. What are you planning on doing with the chimera? If you're not using it for a squad and the officer (I wouldn't!), then why not use the taurox? I just figure you could probably afford a HWT with potential savings. Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899511 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 12, 2023 Author Share Posted January 12, 2023 (edited) 34 minutes ago, Santaclauswitz said: As is I'd be tempted to fill the points with an astropath for the command squad. It's just a way use up those last 25 points and that might give you a command point. For a deeper dive I'd question using the demolisher over the battle tank because the commander would benefit from the gatekeeper relic and because of the short range and swing nature of the demolisher. Also what units are you hoping to buff with it's order? The chimera or sentinels? The chimera would benefit from reroll 1's but is a poor target for an order because it's not a damage dealer. The sentinels would probably prefer the take aim infantry order and the buffs it can take from infantry aura. Do you actually need a commander? I'd also be tempted to replace the PCS with HBS to save an extra 10 points. Have you chosen power swords because of modeling? Is so ignore this... Power swords are a bit rubbish. 15 points could be spent elsewhere. I'd be tempted to swap out the IS heavy weapons for lascanons. What trait have you given the kasrkin? Are the weapons choices modeling as well? I'm looking at the flamer as well as the power sword. Same question for the sentinels.... is that how they're modeled? The HK's are ok but I'd lose the chain swords. I'd be interested in how the fob does. No real opinion on them at the moment. What are you planning on doing with the chimera? If you're not using it for a squad and the officer (I wouldn't!), then why not use the taurox? I just figure you could probably afford a HWT with potential savings. Don’t have an astropath or psyker. power swords just because that’s what the models have. since idk which army he’s bringing right now I figured the demolisher would be better at killing knights. i don’t want to spend CP on a second relic for the TC tbh. I plan on using a lot of strats if necessary. If he brings the demons I’ll probably swap the demolisher for an executioner since AP doesn’t play a role in killing demons I’d rather have the reliable shots and damage. i figured with the TC I could provide tank or regimental orders to the sentinels depending on the situation. (For example would I rather -1 to his shooting, or lower his movement to keep him at bay? the chimera is going to transport the Kasrkin and castellan. kasrkin are getting mechanized. also the chimera could benefit from full throttle. Advance the chimera and get the infantry closer. Edited January 12, 2023 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899524 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 12, 2023 Author Share Posted January 12, 2023 Just spoke to my opponent. demons got broken. If he can’t dice them he’ll bring his eldar. so seems he’s not bringing knights. only one sentinel will have the saw because the second one isn’t modeled with one. the saw seems like it could make a bit of a difference if he chooses to tie up the sentinels in melee. Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899528 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 12, 2023 Author Share Posted January 12, 2023 Was also just referring back to the codex, the Kasrkin sgt can be hitting at on 3s at S4 AP-4 under fix bayonets which makes him pretty mean against those eldar. Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899535 Share on other sites More sharing options...
Santaclauswitz Posted January 12, 2023 Share Posted January 12, 2023 (edited) So I was thinking about your list and what you've got in your collection.... how about this Armoured superiority Mechanized infantry HQ Castellan wt superior tactical training Troops CST x1 Elite Kasrkin x1 Fast attack Scout sentinels x2 Transport Chimera Taurox Heavy LR x3 Bulk it with vehicle upgrades and tank ace. The strength of your collection is armour. You could do something with your list without the chimera but with a couple of heavy weapons squads but it feels a bit static. Edited January 12, 2023 by Santaclauswitz Typo Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899591 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 13, 2023 Author Share Posted January 13, 2023 1 hour ago, Santaclauswitz said: So I was thinking about your list and what you've got in your collection.... how about this Armoured superiority Mechanized infantry HQ Castellan wt superior tactical training Troops CST x1 Elite Kasrkin x1 Fast attack Scout sentinels x2 Transport Chimera Taurox Heavy LR x3 Bulk it with vehicle upgrades and tank ace. The strength of your collection is armour. You could do something with your list without the chimera but with a couple of heavy weapons squads but it feels a bit static. My main goal is to test out the new units from the cadia stands box. i plan on going mech infantry in general for my army going forward after getting my hands on a few more transports. Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5899608 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 24, 2023 Author Share Posted January 24, 2023 Game got postponed due to weather. 3rd times the charm right? Hopefully nothing happens in the next 4 hour to get it cancelled now. And it’s been confirmed against demons. Let the purge begin 1 Back to top Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5902960 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 25, 2023 Author Share Posted January 25, 2023 Ok, so finished the game. first 2 turns mostly went my way. his blood thirsted failed a 5” charge. i killed a bunch of demonettes shooting. killed 2 fiends(?) an exalted flamer. Kasrkin and chimera wiped a unit of 5 dogs. sentinels didn’t do much but grab an objective with their forward deployment. exterminator did pretty good, chimera did pretty good, and malleus rocket launcher did ok before he hopped a unit 10” plus charge destroyed them in melee(normal tzeench flamers I think? He was proxying them so can’t even describe what they looked like) in the end I was actually playing for objectives this time, but I lost by a few points. the combination of small board and terrain heavy just gives too much advantage to melee armies. Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5903048 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 25, 2023 Author Share Posted January 25, 2023 (edited) I think I could have done much better if I had more transports and gone full mech. And I just realized i completely forgot about my sharpshooters rerolls -_- idk what they can change aside from table size and recommended terrain layouts i'm not sure how they can balance the game for ranged shooty armies for it to be fairer when they face off against fast melee armies. Edited January 25, 2023 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/377309-1000-pt-game-against-demons/#findComment-5903049 Share on other sites More sharing options...
