Burni Posted June 17, 2024 Share Posted June 17, 2024 1 hour ago, Xirix said: To be fair, both the Contemptor and Deredeo look absolutely nothing like the classic Rogue Trader Dreads, this new dreadnought could easily adopt the Furibundus name. The video rumour calls it a Saturnine pattern and says it’s bigger than a Redemptor. Even if they call it a Furibundus, at that size it doesn’t fit my feeling of what a new Furi should be sadly. Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045841 Share on other sites More sharing options...
apologist Posted June 17, 2024 Share Posted June 17, 2024 1 hour ago, Razorblade said: Another Praetor to go with the Mk2s is nice. I look forward to seeing mk2 in plastic but this is almost certainly going to be another tactical frame which means still no plastic Despoilers/Recons/Breachers. Haven't been following releases particularly closely, but isn't the sequence of releases so far: Mark VI Tactical Heavy/special weapon upgrades Mark III Tactical Mark VI Assault Command and melee weapon upgrades ...with italic thus far previewed but unreleased? Looking for patterns in GW's release schedule is often a hiding to nothing, but I don't think it's beyond the bounds of possibility to see something like this: 2nd edition Mark VI Tactical Heavy/special weapon upgrades (multi-kit compatible) Mark III Tactical Mark VI Assault (jump packs) Command and melee weapon upgrades (multi-kit compatible) 3rd edition Mark II Tactical Mark III assault equivalent (e.g. Breachers) Upgrades of some sort (e.g. Breacher special weapons – lascutters, grav guns) (multi-kit compatible) Agramar_The_Luna_Wolf, Marshal Rohr and Doctor Perils 3 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045844 Share on other sites More sharing options...
Marshal Rohr Posted June 17, 2024 Share Posted June 17, 2024 40 minutes ago, Burni said: The video rumour calls it a Saturnine pattern and says it’s bigger than a Redemptor. Even if they call it a Furibundus, at that size it doesn’t fit my feeling of what a new Furi should be sadly. I imagine it will be a legion Telemon, same size but mass produced weapons and less special wargear. Doghouse, LSM, Arendious and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045845 Share on other sites More sharing options...
Razorblade Posted June 17, 2024 Share Posted June 17, 2024 21 minutes ago, Marshal Rohr said: I imagine it will be a legion Telemon, same size but mass produced weapons and less special wargear. That would make sense given rumors called it saturnine and the Telemon is distinctively egg-shaped Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045849 Share on other sites More sharing options...
Jings Posted June 17, 2024 Share Posted June 17, 2024 If the Saturnine termies turn out to be the classic eggos, I'm really hoping they'll be the shoot termies. Outside of single use or double shot low strength combis and special weapon options there's a severe lack of TDA firepower. Combi-bolters with Heavy Bolters on top default units that can upgrade to Culverins or Heavy Flamers with 1 in 5 Lascannons, Multis, or Plasma Cannons would fill that niche bigly. We got regular terms (and we need HQ options for those), we got speedy terms and we got bulky terms. Now is the time for shooty terms. Hellath and Lord Marshal 2 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045850 Share on other sites More sharing options...
Xirix Posted June 17, 2024 Share Posted June 17, 2024 The Telemon is actually bigger than the Redemptor (rumour says this new one is bigger), so the Legions getting some kind of version of it might be on the money. Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045851 Share on other sites More sharing options...
01RTB01 Posted June 17, 2024 Share Posted June 17, 2024 2 hours ago, Razorblade said: Another Praetor to go with the Mk2s is nice. I look forward to seeing mk2 in plastic but this is almost certainly going to be another tactical frame which means still no plastic Despoilers/Recons/Breachers. More Terminators are a massive L. There are already two plastic terminator units which struggle to see play. A power weapons/thunder hammers/command bling frame for the existing terminators would have been infinitely more useful. As is these are likely to either see little play at all or render the existing units obsolete. The Dreadnought is rumored to be bigger than a leviathan. This will render the already bad Knights and Demons obsolete at best and may have further implications for Leviathans and Thanatars. It doesn't address any niche whatsoever since there are 4 Dreadnought available in plastic and they are already plenty tough and scary. A Big Gun emplacement sounds interesting in principle but why one would release this instead of plastic rapiers is beyond me. Meanwhile, still no plastic Bikes, Speeders, Flyers or good Sicarans. This release would be a big time stinker The fact you're specifically calling out thunder hammers here really says a lot... Honestly, it's a great list of stuff and saturnine are a totally different style of armour so should hopefully play differently. There's lots still to come but it is what it is. The only real frustration is the lack of breachers. Personally, happy for those wanting mkii. Marshal Rohr 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045854 Share on other sites More sharing options...
Xenith Posted June 17, 2024 Share Posted June 17, 2024 HH3.0 is due in June 2025, so could be legit? Marshal Rohr 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045858 Share on other sites More sharing options...
Garrac Posted June 17, 2024 Share Posted June 17, 2024 (edited) I know GW loves their big summer releases, but, is there really such a need for a new HH edition? It feels like a game that needs more time between editions to build a proper playerbase. Theres barely a community in my country... Edited June 17, 2024 by Garrac jaxom, Marshal Rohr, ThaneOfTas and 9 others 1 11 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045893 Share on other sites More sharing options...
jaxom Posted June 17, 2024 Share Posted June 17, 2024 10 minutes ago, Garrac said: I know GW loves their big summer releases, but, is there really such a need for a new HH edition? It feels like a game that needs more time between editions to builds a proper playerbase. Theres barely a community in my country... I wouldn’t mind either a big FAQ and errata, or some sort of 2.25 updated rule book release. Definitely doesn’t need the sort of paradigm shift a completely new edition should be. Aarik and ThaneOfTas 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045895 Share on other sites More sharing options...
Doghouse Posted June 17, 2024 Share Posted June 17, 2024 5 hours ago, Marshal Rohr said: I imagine it will be a legion Telemon, same size but mass produced weapons and less special wargear. Totally agree, I can see that for sure. I would prefer to see something unique dating back to the Unification Wars to be honest but it would make more sense to put the terminator and dreadnought under the same name of Saturnine as a specific manufacturer of war gear in the same way we have Mars pattern. Marshal Rohr 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045917 Share on other sites More sharing options...
Lord Marshal Posted June 17, 2024 Share Posted June 17, 2024 (edited) 2 hours ago, Garrac said: I know GW loves their big summer releases, but, is there really such a need for a new HH edition? It feels like a game that needs more time between editions to build a proper playerbase. Theres barely a community in my country... If it is a new edition, my uneducated guess is it'll be a 40k 7th situation where it's closer to a 2.5 than a whole new edition, and one that's only happening because the beancounters desperately want something to fill the gap between 40k and AoS. They probably look at a graph and see the greatest amount of sales and new interest comes during their new edition marketing pushes. I wouldn't even be surprised if the Age of Darkness boxset remained as is, just with the core rulebook swapped out (akin to Dark Vengeance) - assuming this MkII box isn't it of course. Edited June 17, 2024 by Lord Marshal Aarik, Garrac and LSM 3 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045919 Share on other sites More sharing options...
Marshal Rohr Posted June 17, 2024 Share Posted June 17, 2024 I can see it being more of a Dark Uprising than an Ash Wastes. Consolidated and Changed rules in a “Book of Heresy”. Aarik and Matcap86 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045939 Share on other sites More sharing options...
Marshal Loss Posted June 17, 2024 Share Posted June 17, 2024 Not sure what to say other than "sounds awesome". I hope the Praetor is a bit better than the ones we received in the AOD box (having a handful of modular options & not being a giant would be enough for me). TheArtilleryman, Marshal Rohr, Aarik and 2 others 1 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045961 Share on other sites More sharing options...
Nephaston Posted June 17, 2024 Share Posted June 17, 2024 Saturnine Dreadnought? I guess that is implying it is shaped like a suit of saturnine armour, similar to how contemptors and tartaros armour kinda look similar. Either way it will be exciting. Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045962 Share on other sites More sharing options...
The Scorpion Posted June 17, 2024 Share Posted June 17, 2024 On 6/11/2024 at 11:50 AM, jimbo1701 said: Mk2. Crusade armour and saturnine pattern terminators were specifically mentioned. Excite! Hyped for crusade pattern armor. However, Saturnine is iffy to me. We still do not have a generic Tartaros Praetor, and we are going to intoduce yet another pattern of terminator armor? Petitioner's City 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045964 Share on other sites More sharing options...
m0nolith Posted June 18, 2024 Share Posted June 18, 2024 14 hours ago, Garrac said: I know GW loves their big summer releases, but, is there really such a need for a new HH edition? It feels like a game that needs more time between editions to build a proper playerbase. Theres barely a community in my country... I really don't want another edition any time soon. A big reason that 30k appeals to me is that I don't have to keep having to learn a new edition every 3 years. jaxom, Boytoy, Jazzbeaux and 8 others 4 7 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6045999 Share on other sites More sharing options...
apologist Posted June 18, 2024 Share Posted June 18, 2024 As a 'boxed game', my guess is that this rumoured box will follow the Necromunda release model, by which I mean that the rules will be an update (to incorporate any FAQs/updates, for example) rather than a new edition per se. Marshal Rohr, jaxom and Razorblade 3 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046099 Share on other sites More sharing options...
beefeb Posted June 19, 2024 Share Posted June 19, 2024 On 6/17/2024 at 4:40 PM, Garrac said: I know GW loves their big summer releases, but, is there really such a need for a new HH edition? It feels like a game that needs more time between editions to build a proper playerbase. Theres barely a community in my country... Hopefully its not a new edition, but just a new starter/expansion box...maybe another sub campaign or similar based around Istvaan without a new ruleset, especially given how recently we have had nice books. A Legion Telemon would be nice, hopefully nothing larger as i think bigger isnt necessarily better....take off custodes bling and put on legion functionality and firepower and design themes. Ill def be after a couple of them. Just nothing much bigger. Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046295 Share on other sites More sharing options...
OttoVonAwesome Posted June 19, 2024 Share Posted June 19, 2024 I wouldn't be mad if they put out a revised edition and army lists (custodes). Wotc is putting out a revised 5e ruleset and it's pretty hype. Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046297 Share on other sites More sharing options...
Aarik Posted June 19, 2024 Share Posted June 19, 2024 I wouldn't mind a new edition, so long as it is essentially a 2.5 edition that iterates and improves on the current one, rather than tearing everything down and starting from scratch. Give the marine list a balance pass and hopefully pump up underperforming units and tone down overpowered ones, tweak any legion rules that need it, and make the other armies more effective. Marshal Rohr, Dalmyth, irlLordy and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046305 Share on other sites More sharing options...
Joe Posted June 19, 2024 Share Posted June 19, 2024 More 0-1 on certain units wouldn't go undesired. Marshal Loss 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046323 Share on other sites More sharing options...
Mandragola Posted June 19, 2024 Share Posted June 19, 2024 Curses, now I want to make a new iron warriors or salamander army. I painted a couple of Sallies for a kill team and it’s a cool scheme. Weirdly, nothing in this box sounds right for my Raven Guard. Mk2, terminators, a massive dreadnought and a gun turret are not what I need. You’d think there’d be something in there to tempt me but nope. Unless they’re OP of course! LameBeard and W.A.Rorie 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046349 Share on other sites More sharing options...
Hfran Morkai Posted June 20, 2024 Share Posted June 20, 2024 Colour me intrigued! Although the mark I'm really waiting for is upscaled MkIV (my favourite) and I'd love to see Tartaros/Cataphractii upscaled too with more weapon options. Always happy to see more Heresy stuff come, even if I'm not active in the hobby at the moment. ThaneOfTas, CL_Mission and Khulu 3 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046387 Share on other sites More sharing options...
LSM Posted June 20, 2024 Share Posted June 20, 2024 (edited) 8 hours ago, Hfran Morkai said: ...and I'd love to see Tartaros/Cataphractii upscaled too with more weapon options... I think the tendency with an upscale is to lose options. Like the MkIII went from three full sprues (for 10 Marines) with Bolters and Chainswords, a pair of special weapons, a Heavy Bolter, and an assortment of sgt. options, to the new MkIII being a single full sprue (for 5 Marines) with Bolters, plus the shared Tactical Accoutrements sprue. Upscaled Tartaros probably loose their Lightning Claws, Cataphractii their Chainfists (and probably have to rethink the design of the Lightning Claws, so that they and the Power Fist can share arms and just be a finger swap). Edited June 20, 2024 by LSM LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/383105-rumor-via-cm-valrak-salamander-vs-iron-warrior-box/page/4/#findComment-6046454 Share on other sites More sharing options...
