A.T. Posted January 18, 2025 Share Posted January 18, 2025 3 hours ago, Xin Ceithan said: the mortals should also have an easier time scouting / grappling other objectives moving in amidst the battle without something as obvious as a SpaceMarine among them. There are enough of the stations void-suits here that the humans could go dressed as locals, albeit oddly armed. Lysimachus, Necronaut, Mazer Rackham and 1 other 2 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088472 Share on other sites More sharing options...
Trokair Posted January 18, 2025 Share Posted January 18, 2025 1 hour ago, A.T. said: There are enough of the stations void-suits here that the humans could go dressed as locals, albeit oddly armed. While that does sound like it will help with sneaking around, I would worry that it could lead to friendly fire if/when we meet up with other Corsair forces. Lysimachus, Necronaut and Mazer Rackham 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088499 Share on other sites More sharing options...
Lysimachus Posted January 18, 2025 Share Posted January 18, 2025 Did we decide who was taking the second microbead from the wreck? If Hagga and Xerxes have both got one, both groups should be able make contact if they encounter the other 'friendlies'. By the way, in that regard would our group's callsign be something like 'Krokodil 4' or 'Target Gamma' or something? We didn't actually state it before launch, but I assume it would have been part of our briefing? Mazer Rackham and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088501 Share on other sites More sharing options...
Mazer Rackham Posted January 18, 2025 Author Share Posted January 18, 2025 18 minutes ago, Trokair said: While that does sound like it will help with sneaking around, I would worry that it could lead to friendly fire if/when we meet up with other Corsair forces. 5 minutes ago, Lysimachus said: Did we decide who was taking the second microbead from the wreck? If Hagga and Xerxes have both got one, both groups should be able make contact if they encounter the other 'friendlies'. Yes, as long as you have the frequencies (which you would) and sing out early and repeatedly with your unit ID, I think you'll be fine. 5 minutes ago, Lysimachus said: By the way, in that regard would our group's callsign be something like 'Krokodil 4' or 'Target Gamma' or something? We didn't actually state it before launch, but I assume it would have been part of our briefing? Yes, you can apply it retrospectively, no problem. Necronaut and Lysimachus 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088506 Share on other sites More sharing options...
Lysimachus Posted January 18, 2025 Share Posted January 18, 2025 Just checking, GM, you want us to narratively open the door and then pause, right? Do you want us to make any rolls for anything yet? Should the Scouts keep rolling as many Navigate Tests are needed until they have gained the 6 successes, then we know how many Encounter rolls we need to make in total? (Would that help with your planning?) Or do you want us to do it one bit at a time, and stick to 1 Nav roll and 1 Encounter roll per group? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088549 Share on other sites More sharing options...
Mazer Rackham Posted January 18, 2025 Author Share Posted January 18, 2025 4 minutes ago, Lysimachus said: Just checking, GM, you want us to narratively open the door and then pause, right? Yeah, if you want to pop the door, do that, mention it opening, nowt else. 4 minutes ago, Lysimachus said: Do you want us to make any rolls for anything yet? Not yet, since I need to know how your party is split, and where they're going. 4 minutes ago, Lysimachus said: Should the Scouts keep rolling as many Navigate Tests are needed until they have gained the 6 successes, then we know how many Encounter rolls we need to make in total? (Would that help with your planning?) Or do you want us to do it one bit at a time, and stick to 1 Nav roll and 1 Encounter roll per group? The latter. Do the rolls, form up some narrative, and inter-party banter if you bonce it up, then hang fire. If the Nav test is failed, the Enounter test still needs to be rolled, because you could end up blundering into something. If things drag, I have tools to move it along. Machine God, Lysimachus and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088552 Share on other sites More sharing options...
Lysimachus Posted January 19, 2025 Share Posted January 19, 2025 (edited) @Trokair don't forget about your +10 for having the Map, so you're all good for your first Nav test! Edit: also, I assume these: (1)LB - (2)B - (3)GR - (3A)WP mean something. I'd guess LB is Landing Bay, B could be Brig...? I'm not 100% on the other two... Edited January 19, 2025 by Lysimachus Mazer Rackham and Trokair 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088669 Share on other sites More sharing options...
Mazer Rackham Posted January 19, 2025 Author Share Posted January 19, 2025 3 hours ago, Lysimachus said: I'd guess LB is Landing Bay, B could be Brig...? I'm not 100% on the other two... Correctly guessed. Those two correspond to your maps. Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088703 Share on other sites More sharing options...
Machine God Posted January 19, 2025 Share Posted January 19, 2025 Ah Arcturion.... Mazer Rackham, Necronaut and Xin Ceithan 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088814 Share on other sites More sharing options...
Lysimachus Posted January 19, 2025 Share Posted January 19, 2025 (edited) Hmm, is the 'otherness' @Xin Ceithan mentions something to do with the psy test earlier? Any chance of Cyrandras filling us in? Side point: Mining suits and purple scarfs? It might be a red herring but that feels very GS Cult...? A possible explanation for the factions on the station? Edited January 19, 2025 by Lysimachus Xin Ceithan, Necronaut and Trokair 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088822 Share on other sites More sharing options...
Viking Slade Posted January 19, 2025 Share Posted January 19, 2025 My apologies for going MIA. Our vehicle was broken into over the holidays, and among the things that were stolen were my phone and laptop (and my external storage drive). I've been using an older (ancient) phone to get by, but purely as a phone. It's been stressful and crazy the last several weeks, and I haven't been able to catch up on anything. Just wanted to pop in now that I have a new phone that can access the Internet and say I'm still alive. Xin Ceithan, Trokair, Mazer Rackham and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088828 Share on other sites More sharing options...
Mazer Rackham Posted January 19, 2025 Author Share Posted January 19, 2025 (edited) 33 minutes ago, Viking Slade said: My apologies for going MIA. Our vehicle was broken into over the holidays, and among the things that were stolen were my phone and laptop (and my external storage drive). I've been using an older (ancient) phone to get by, but purely as a phone. It's been stressful and crazy the last several weeks, and I haven't been able to catch up on anything. Just wanted to pop in now that I have a new phone that can access the Internet and say I'm still alive. I'm glad you're well and safe. Sorry to hear about this, not good at all. I'm glad to see you back, though. Don't worry about catching up, we'll be ready when you are. Edited January 19, 2025 by Mazer Rackham Lysimachus, Necronaut and Trokair 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088838 Share on other sites More sharing options...
Necronaut Posted January 19, 2025 Share Posted January 19, 2025 (edited) 1 hour ago, Viking Slade said: My apologies for going MIA. Our vehicle was broken into over the holidays, and among the things that were stolen were my phone and laptop (and my external storage drive). I've been using an older (ancient) phone to get by, but purely as a phone. It's been stressful and crazy the last several weeks, and I haven't been able to catch up on anything. Just wanted to pop in now that I have a new phone that can access the Internet and say I'm still alive. I'm so sorry to hear this. I had that happen to me a few years ago, except it was my work laptop that got boosted. Plus I had the extreme inconvenience of having to replace a window, which I am sure was the same for you. Edited January 19, 2025 by Necronaut Lysimachus and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088863 Share on other sites More sharing options...
Xin Ceithan Posted January 20, 2025 Share Posted January 20, 2025 11 hours ago, Viking Slade said: My apologies for going MIA. Our vehicle was broken into over the holidays, and among the things that were stolen were my phone and laptop (and my external storage drive). I've been using an older (ancient) phone to get by, but purely as a phone. It's been stressful and crazy the last several weeks, and I haven't been able to catch up on anything. Just wanted to pop in now that I have a new phone that can access the Internet and say I'm still alive. Sorry to hear that It’s bugger enough by itself, but these days you sort of lose half your life when your IT stuff breaks down or gets lifted. Good to hear you are managing Mazer Rackham, Lysimachus and Necronaut 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088960 Share on other sites More sharing options...
Lysimachus Posted January 20, 2025 Share Posted January 20, 2025 (edited) Agreed with all of the above, it's a royal pain and glad you are getting sorted! I've never had anything of value nicked out of my car, but a couple of years ago I did get a piece of work equipment stolen. What was really galling about the whole thing was that the gear was worth pretty much nothing (especially 2nd hand) and far, far less than it cost me to fix the window! I looked at it the next morning and I was like '...thanks. Thanks very much.' Side point @Xin Ceithan don't forget you have +20 for 2 Assists as all Astartes have Navigate and either +10 or a reroll from the fact we have a map (I'm not sure but I think mathematically the reroll might actually create better odds than the +10...?) Edit: yep, target 75 is obviously a 75% success rate, target 65 with a reroll is 87.75% success rate! (I think... ) Edit: second side point @Mazer Rackham now Cyrandras has revealed stuff, can we read the spoilered Psy test bits? (Or at least the Marines he is with, anyway?) Edited January 20, 2025 by Lysimachus Xin Ceithan and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088981 Share on other sites More sharing options...
Mazer Rackham Posted January 20, 2025 Author Share Posted January 20, 2025 (edited) 25 minutes ago, Lysimachus said: Side point @Xin Ceithan don't forget you have +20 for 2 Assists as all Astartes have Navigate Yep, taken into account. 25 minutes ago, Lysimachus said: Edit: second side point @Mazer Rackham now Cyrandras has revealed stuff, can we read the spoilered Psy test bits? (Or at least the Marines he is with, anyway?) I'm tempted to say yes, since you're sporting folks and I love you all for it, but sadly I must say no, not just yet. We need the Mortals to catch up first.... Edited January 20, 2025 by Mazer Rackham Lysimachus, Xin Ceithan and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6088986 Share on other sites More sharing options...
Lysimachus Posted January 20, 2025 Share Posted January 20, 2025 Fair enough, boss @Trokair I was just wondering about the maths, and I realised that the reroll for the map is better than the +10 for Tarh as well! Either 45+10=55% Or 45 + (0.55×0.45×100=24.75) = 69.75% Quite an improvement! Necronaut, Trokair and Mazer Rackham 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089040 Share on other sites More sharing options...
Mazer Rackham Posted January 20, 2025 Author Share Posted January 20, 2025 7 minutes ago, Lysimachus said: Either 45+10=55% Or 45 + (0.55×0.45×100=24.75) = 69.75% Quite an improvement! With all these calcs, I'm beginning to suspect we have a Life Assurance/Investment Advisor in our midst. Maybe I should set game up as a thinly veiled pension calculator and have you lads do all the working out.... Lysimachus, Xin Ceithan and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089045 Share on other sites More sharing options...
Necronaut Posted January 20, 2025 Share Posted January 20, 2025 27 minutes ago, Mazer Rackham said: With all these calcs, I'm beginning to suspect we have a Life Assurance/Investment Advisor in our midst. Maybe I should set game up as a thinly veiled pension calculator and have you lads do all the working out.... How does the Crimson Permanent Assurance strike you for a chaos warband name? Trokair, Mazer Rackham, Lysimachus and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089049 Share on other sites More sharing options...
Mazer Rackham Posted January 20, 2025 Author Share Posted January 20, 2025 (edited) Well dagnabbit, that there's the best idea since the Shotgun Wedding Insurance Company! Edited January 20, 2025 by Mazer Rackham Necronaut, Lysimachus and Xin Ceithan 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089053 Share on other sites More sharing options...
Necronaut Posted January 20, 2025 Share Posted January 20, 2025 "Your valuables or your life insurance!" "My what?!" "Your valuables or -- am I speaking Gothic? I'm speaking Gothic, am I not lads?" "Right you are, sir!" "He's speaking Gothic, alright!" "Hear, hear!" "Right. Now then my good fellow, our demands are simple: give us your valuables or sign this form here for a very reasonable, fixed rate life insurance policy..." Lysimachus, Trokair, Mazer Rackham and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089057 Share on other sites More sharing options...
Lysimachus Posted January 20, 2025 Share Posted January 20, 2025 It's all imaginary anyway. Watch as Tro and Xin choose the reroll rather than +10, then all of their results are 46-55 (or 66-75 in Xin's case) where they would have been successes, but now aren't! Lies, damn lies and math-hammer... Mazer Rackham, Trokair, Necronaut and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089059 Share on other sites More sharing options...
Mazer Rackham Posted January 20, 2025 Author Share Posted January 20, 2025 To be fair, it's not the Nav Test, it's the Encounter roll... Necronaut, Xin Ceithan and Lysimachus 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089069 Share on other sites More sharing options...
Trokair Posted January 20, 2025 Share Posted January 20, 2025 I have put anothe placeholder in with rolls as skimming over it looked like i was holding things up. will try to catch up on reading both threads and such when i can Machine God, Xin Ceithan, Necronaut and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089126 Share on other sites More sharing options...
Trokair Posted January 22, 2025 Share Posted January 22, 2025 All three placeholder filled, and a question from my fellow mortals, combat or more sneaking in tunnels? On 1/19/2025 at 9:34 PM, Viking Slade said: My apologies for going MIA. Our vehicle was broken into over the holidays, and among the things that were stolen were my phone and laptop (and my external storage drive). I've been using an older (ancient) phone to get by, but purely as a phone. It's been stressful and crazy the last several weeks, and I haven't been able to catch up on anything. Just wanted to pop in now that I have a new phone that can access the Internet and say I'm still alive. Welcome back, and very much echo the others, that sucks and I hope you can get your life back on track. On 1/20/2025 at 2:22 PM, Mazer Rackham said: With all these calcs, I'm beginning to suspect we have a Life Assurance/Investment Advisor in our midst. Maybe I should set game up as a thinly veiled pension calculator and have you lads do all the working out.... Necronaut, Mazer Rackham and Lysimachus 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/29/#findComment-6089436 Share on other sites More sharing options...
