Necronaut Posted February 5, 2025 Share Posted February 5, 2025 4 minutes ago, Trokair said: So the marines make a new friend and try to eat her, meanwhile the mortals make a new friend that wants to eat them... To quote George Lucas, "It's like poetry, it rhymes." Mazer Rackham and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092885 Share on other sites More sharing options...
A.T. Posted February 5, 2025 Share Posted February 5, 2025 5 hours ago, Mazer Rackham said: GM: @A.T. are you still outside? I would imagine so as Xerxes wouldn't be able to move and sustain overwatch. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092887 Share on other sites More sharing options...
Mazer Rackham Posted February 5, 2025 Author Share Posted February 5, 2025 13 minutes ago, A.T. said: I would imagine so as Xerxes wouldn't be able to move and sustain overwatch. Save yourself. Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092890 Share on other sites More sharing options...
Lysimachus Posted February 5, 2025 Share Posted February 5, 2025 (edited) Quote +++Let us be off. I will take the van+++ Sorry, tickled me for a moment... Edited February 5, 2025 by Lysimachus Necronaut, Trokair and Mazer Rackham 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092902 Share on other sites More sharing options...
Necronaut Posted February 5, 2025 Share Posted February 5, 2025 @Lysimachus game, match, set. Lysimachus and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092905 Share on other sites More sharing options...
Trokair Posted February 5, 2025 Share Posted February 5, 2025 15 minutes ago, Mazer Rackham said: Environment: It is half-lit, this means the penalties to Tests for fighting in darkness are Difficult (-10). Only the Players suffer this. Do the Preysense Goggles help with this? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092918 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 (edited) 27 minutes ago, Trokair said: Do the Preysense Goggles help with this? Good query. I will check how your equipment interacts with the environmental effects (I will place an update referring to the Halon gas etc upon ruling). EDIT: FOG, MIST, SHADOW OR SMOKE (BC Core) Ballistic Skill Tests made to attack targets concealed by fog, mist, shadow, or smoke are Hard (–20). While a character is concealed by fog, mist, or shadow, Concealment Skill Tests are Ordinary (+10). DARKNESS (BC Core) Weapon Skill Tests made in darkness are regarded as Hard (–20), while Ballistic Skill Tests are regarded as Very Hard (–30). While a character is concealed by darkness, Concealment Skill Tests are Routine (+20). After careful consideration, I will rule thusly: Because of the half-light, each Difficulty for the actions listed in these two sections as quoted above will be reduced by One Step, (-20 becomes -10, etc) with the Highest Difficulty applying. Equipment providing Dark Sight, or Thermal VIsion suffer obscuration from the Halon gas and smoke fog, and do not suffer any Penalties for fighting in Darkness. Does that make sense? Edited February 6, 2025 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092921 Share on other sites More sharing options...
Trokair Posted February 6, 2025 Share Posted February 6, 2025 36 minutes ago, Mazer Rackham said: Equipment providing Dark Sight, or Thermal VIsion suffer obscuration from the Halon gas and smoke fog, and do not suffer any Penalties for fighting in Darkness. So, is the miasma of halon gas that is mentioned in point two of the enviromental enough to cause obscuration? If yes then i take it that Dark Sight/Termal Vission is not going to help with the semi darkenss? If no then having those will help to reduce the penalty to 0? Mazer Rackham and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092926 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 3 minutes ago, Trokair said: So, is the miasma of halon gas that is mentioned in point two of the enviromental enough to cause obscuration? Yes. 3 minutes ago, Trokair said: If yes then i take it that Dark Sight/Termal Vission is not going to help with the semi darkenss? If no then having those will help to reduce the penalty to 0? Due to your gear, you don't suffer the semi-darkness, you only suffer the obscuration, and only the worst penalty. Simply put - you only take -10 to BS tests. That's it, that's all you need to worry about mechanically. The rest is unaffected, so you do get some benefit from your gear, which I felt was appropriate. Narratively, the shape of the enemy will wax and wane as the fog moves around due to movement. You can still see a couple of feet in front of you, so nobody will trip, either. The guys who don't have dark sight or thermal have to use the Darkness penalties, so they get -10 to WS Tests, and -20 to BS Tests, but they don't add more for the fog. Any help? Trokair and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092927 Share on other sites More sharing options...
Trokair Posted February 6, 2025 Share Posted February 6, 2025 right, now I get it, sorry sleep brain Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092928 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 Never need to apologise for a good query that helps everyone (including me). Get some kip, dude, you've done good work today. Necronaut 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092929 Share on other sites More sharing options...
Machine God Posted February 6, 2025 Share Posted February 6, 2025 Kraggan has an Optical Mechandendrite Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092942 Share on other sites More sharing options...
Lord_Ikka Posted February 6, 2025 Share Posted February 6, 2025 As Crux'as has Radiant Prescence, anyone within 20m of him gets +10 to Fear/Intimidation tests. Unfortunately, this doesn't apply to himself... Machine God and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092961 Share on other sites More sharing options...
Machine God Posted February 6, 2025 Share Posted February 6, 2025 Kraggan challenges the Dark once more: https://youtu.be/9D9_5Qiik9c?si=OKQVUoQ9URklTEsg Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092970 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 3 hours ago, Machine God said: Kraggan has an Optical Mechandendrite No worries, the entry for this item states it works like infragoggles, so therefore, you simply take the penalties under 'obscured'. Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6092975 Share on other sites More sharing options...
Necronaut Posted February 6, 2025 Share Posted February 6, 2025 WHO WANTS TO PARTAAAAAAYY?? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093020 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 (edited) I love how Xenomorphs are trouble, even in 40k, but if they were discovered they wouldn't last five minutes. Then the Crezzymen at GW go, yep, 11's our favourite number, and crunch the jackassery factor all the way up, and Genestealers are like REAL trouble because they cut out the middleman, have hands that can do dishes, and have foreheads that can stop bullets. Edited February 6, 2025 by Mazer Rackham Necronaut 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093028 Share on other sites More sharing options...
A.T. Posted February 6, 2025 Share Posted February 6, 2025 11 minutes ago, Necronaut said: WHO WANTS TO PARTAAAAAAYY?? Xerxes did manage to snag a krak grenade before the mission... https://youtu.be/F4Z9LePKtdw?feature=shared&t=12 Actually if everyone else teams up and grapples the thing so it can't dodge then point blank full auto from his lightning weapon should do the trick. Just hold it for a few rounds while he recharges the gun and clears out the smoke. Trokair, Xin Ceithan, Mazer Rackham and 1 other 1 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093029 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 Newsflash! Local men try to pet a dinosaur! More at 11! Spoiler Xin Ceithan, Trokair and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093032 Share on other sites More sharing options...
Machine God Posted February 6, 2025 Share Posted February 6, 2025 Missed out Dodge. Post edited: https://bolterandchainsword.com/topic/383296-bc-the-blackest-heart-ic/page/22/#findComment-6093005 Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093051 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 (edited) Cheers, no reason not to use it! Play continues with our next contestant... Tarh Teshub, come on down! Edited February 6, 2025 by Mazer Rackham Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093052 Share on other sites More sharing options...
Trokair Posted February 6, 2025 Share Posted February 6, 2025 is the papa steeler still in melee with Kraggan? trying to work out my shoot Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093061 Share on other sites More sharing options...
Mazer Rackham Posted February 6, 2025 Author Share Posted February 6, 2025 2 minutes ago, Trokair said: is the papa steeler still in melee with Kraggan? Yes. Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093064 Share on other sites More sharing options...
Machine God Posted February 7, 2025 Share Posted February 7, 2025 https://youtu.be/Fv9_YOL38MM?si=YDv6CrxoYgPdTrcm Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093235 Share on other sites More sharing options...
Trokair Posted February 7, 2025 Share Posted February 7, 2025 Placeholder filled https://bolterandchainsword.com/topic/383296-bc-the-blackest-heart-ic/page/22/#findComment-6093065 I know we where briefly in touch with the Marines, before we left the comms bunker thing was there any way for us to have let them know of our change in location or such? Mazer Rackham and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/383216-bc-the-blackest-heart-ooc/page/40/#findComment-6093254 Share on other sites More sharing options...
