If you want to drop a post you've got in mind, that's not a problem at all - essentially we've reached Ikka's 'go' in the turn, and depending on his choices, we may or may not get plot...
Nah, nothing that doesn't involve next Actions... :thumbsup:
Ooo, intrigue! :tongue:
2 hours ago, Mazer Rackham said:
Hybrid 1:
Half Action Move
Half Action Knock Down (Opposed Strength or Kraggan is knocked prone)
D100: PASS Plus 4 DoS (inc 2 DoS Unnat Str) (5 DoS Total)
If wins: Dam, Body: 8, AP 0 + 1 Level Fatigue
Hybrid has Multiple Arms, Claw Attack:
D100: Hit (if Prone with 1 DoS) 1 Hit (can't be dodged)
Hit 1, Right Arm, Dam: 18 Pen 5 (Razor Sharp does not activate)
Hanged Men:
Half Action; Half Move (to allow Hybrid through)
Half Action, Standard Attack (Axe Rake)
D100: MISS - by 1...
For my own understanding:
  • Is the hybrid with the minning laser now detached from horde and is in melee with Kraggan, horde is seperatly also in melee with Kraggan?
  • Is the hybrid with the minning laser still attached to horde, but it shuffled on the spot so Hybrid is now at the front and it and horde are in combat with Kraggan together
Edited by Trokair
I think that's my fault for trying to help by adding numbers to the map without checking with Mazer... sorry all!
As far as I can tell:
The CCW Hybrid that was in combat with Ukalegon (I had it marked as H1) got splatted by mind bullets?
H2 was supposed to be the Mining Laser, it is still hidden in Horde 1 and both are Engaged with Kraggan?
H3 is the Rockhammer and is hidden in Horde 2?
Correct.
Correct.
Correct.
IIRC there's a fourth Hybrid with CCW's in Horde 2 as well. It should be on the initial roster. I'll double check.
EDIT: Yes there is.
On 2/11/2025 at 10:37 PM, Mazer Rackham said:
EDIT: Player information. Now you're in the room you see the following targets working at, repairing or lurking behind the cogitator banks:
  • 1 x 20 Mag Horde, Autoguns and axe-rakes, 1 x Hybrid with 2 x CCW (and claw), 1 x Hybrid with heavy weapon (Mining Laser) (and claw).
  • 1 x 20 Mag Horde, Autoguns and axe-rakes, 2 x Hybrid with 2H (Rockhammer) CCW (and claw)
  • 1 x Auto-turret with Multi-laser.
  • I will require Called Shots to independently target the Hybrids - yes, they are bigger than the cultists, but this is a swirling melee. Likewise, individuals in a Horde can Dodge, and be Dodged by Players (not just Mortals).
Right, so we'll adjust to Lysi's nomenclature - and I'll change it in post:
  • Hybrid 1 (CCW) attacked Ukalegon, breaking off from the Horde 1 (Top of map). It was killed by a Psychic Power
  • Hybrid 2 (Mining Laser) remains part of and leading Horde 1 (Top of map)
    • They are currently beating the snot out of Kraggan.
  • Hybrid 3 (Rockhammer) remains part of and leads Horde 2 (right of map)
  • Hybrid 4 (CCW) remains part of and leads Horde 2 (right of map).
  • All Hybrids are Elite Adversaries and thereby may join Hordes or act independently.
  • All Hanged Men are Troop Adversaries, and therefore must act as a single entity.
Does this help at all?
Edited by Mazer Rackham
Derp, he's absolutely right, somehow I read all 3 types of Hybrids as being 1 of each!
So, the map for R3 should look something like this:
large.large.Floor1.jpg.79cacfa7ef9619d86
1 minute ago, Lysimachus said:
I knew what I was planning to do, but I've just done my roll and I am very, very happy! :biggrin:
Forward, or Swiss?
Just need to amend my fluff a bit...
No picking your navel in public, young man! :eek:
He shouldn't take any Damage from the Knock Down (unless that ignores Armour or something? Edit: nope, not that I can see, so that should be ok...) but the Claw hit will do some harm?
18 Pen 5 vs TB4 and AV9(8+1) = 10 Wounds suffered, I think? Leaving him on 6, if he hasn't taken any previous damage?
Maybe worth spending an Infamy Point to recover 1d5+1 Wounds?
Then maybe ask Xin if Cyrandras can jump in and assist to give Kraggan time to stand up?
Edited by Lysimachus
Solid Plan ! :thumbsup:
Rakash’s certainly into giving someone a hand ( and maybe building a up bit of favour in the process) :wink:
Just make sure he isn’t walking into a turret salvo in the process…
Being in combat makes him a little bit safer from that, at least! :laugh:
Meanwhile, the GM:
Spoiler
On a serious note, since Kraggan is actually prone and completely covered by the cogitator banks, if you should choose to fire a weapon or psychic power without and AoE, I will waive the -20 for being in Melee.
Its AV8 as Armour-Monger is already factored in.
Ah, fair enough! I had just assumed it was heavy carapace (but now I think about it, maybe that was beyond our starting gear Acquisitions?)
Oh well, I guess that's 5 Wounds remaining then... :confused:
@Mazer Rackham, could Tarh see enough to tell if these were puprle lot or not?
Just thinking ahead to next turn, if they are not hostile (which i do think is unlikly) then shoting them might be bad.
