Welcome to Hive Gamma 3,
If you already have ties to the Inquisition word would have reached you through those channels otherwise it came directly from the Adeptus Arbites.  An "invitation" to meet with Arbitrator Kaesor at the primary Arbites fortress of Gamma 3.  It sits roughly at the border between the Upper Hive and Middle Hive, and is effectively a self-contained town at the shell of the Hive that has its own landing port, independent air, water and power systems and multi-meter thick walls lined with automated defenses and bunkers.  It is home a few thousand Arbites and support staff, including support from Forge World Phaelos.
To even enter the fortress feels like transferring starships in deep space, the Gatehouse has 3 sets of airlocked doors, only one of which is open at any moment.  Murder holes, hard mounted spray nozzles and a floor the subtly slopes towards drains in the corners imply things your mind would rather not dwell on.  Any weapons, or equipment you have is stored in lockers near the entrance, a handful among hundreds.
So you have found yourself in waiting room Epsilon Seven, having been escorted here by a young trooper.  The chairs a cheap mass produced metal variety, the walls painted with overly thick, grey paint interrupted only by faded recruitment posters and a small shrine in one corner to the Emperor of All.  The room is slightly too cold, not enough for actual problems, just enough to be mildly uncomfortable and it almost feels like there is slightly too much air in the room.  While the room could comfortably hold around 25 people, it currently only has around half a dozen of you.
