TrawlingCleaner Posted February 16, 2022 Share Posted February 16, 2022 (edited) The Runes have been cast and sacrafices have been made. The Warbands of Chaos and the Hosts of Aeldari March to war!Greeting Denizens of the Webway!As you will have probably seen from this announcement in the NRBA forum, we're running a Chaos and Aeldari Joint event in the build up to codex releases. Each Vow you complete will be added to your factions total, as well as subfactions you complete vows for.To get down to Brass Taxes, the rules are as follows: As long as it has a 40k Power Level, it can be Vowed - This includes Legends Units as long as they have Power Levels You may Vow for these Subfactions: Craftworld Eldar (Ynnari), Dark Eldar and Outcasts (Including Harlequins, Exodites and Corsairs) Vowed units can be any amount of models. Partial units will still count their full Power level You need to provide a photo of the unit/s when starting the Vow and once the Vow is complete You can Vow units you've not yet built but we need to see the sprue in the photo Vowed units cannot be painted any further than a spraycoat to start the Vow (sprayed black, silver, grey etc) Models must be painted to your own standard, basing is optional but everything needs 3 colours minimum You may Vow for both Chaos and Aeldari however whichever faction you vow first for is the faction your Powerlevel goes towards. Anything you paint for the second side is not counted. For example, I vow for Craftworlds first and then Chaos, anything I paint for Chaos is not scored. You can Vow for any of the included forums any amount of times but you cannot get more than one "Most painted" awards. You must complete the previous Vow before Vowing again You won't lose your side points for not completing Vows, however unfinished units will not count towards the total An Example vow would look like this:I, TrawlingCleaner, vow to complete: 1 Autarch, 5 Rangers and 3 Shroudrunner jetbikes, for a total of 12 Power Level by May 16th(Photo of vow) Each Participant can add one of these Badges to their signature if you've completed a Vow for that subforum: As mentioned above, there will be additional Badges awarded for those who paint the most per-subfaction as well as the hard working Frater that paints the most for Aeldari as a whole The event will run from today (16th February) until 16th May 5PM GMT. You can start painting as soon as you've vowed.If you've got any questions at all, please drop me a PM I will update Vow totals here for each Frater, each Subfaction's total and will also update the Faction as a whole's total Vows made: Dosjetka - 6PL Dwango - 154PL Halandaar - 105PL TrawlingCleaner - 45PL Nemesor Tyriks - 69PL mithrilforge - 12PL The Blood Raven - 83PL dice4thedicegod - 83PL Iron Father Ferrum - 29PL Urkh - 12PL 01RTB01 - 14PL ThePenitentOne - 3PL Prot - 76PL Dread - 37PL Brother Argent - 21PL Snazzy - 5PL 9x19 Parabellum - 12PL Jack Burton - 42PL Xenith - 6PL Vows Completed: Halandaar - 143PL dice4thedicegod - 71PL TrawlingCleaner - 45PL The Blood Raven - 89PL Prot - 53PL Dwango - 154PL Jack Burton - 42PL Urkh - 12PL mithrilforge - 12PL Brother Argent - 21PL Snazzy - 5PL Subfaction Total: Craftworlds: 477PL Dark Eldar: 102PL Outcasts: 53PL Total Vowed: 852PL Completion Total: 670PL Edited May 16, 2022 by TrawlingCleaner The Yncarne, Karhedron, Mithrilforge and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/ Share on other sites More sharing options...
Halandaar Posted February 16, 2022 Share Posted February 16, 2022 Seeing as Eldar are my primary focus for the foreseeable future, it would be rude not to join! Quick question; is there a cap on the total number of vows you can make (like in ETL)? Or can I just keep vowing new units each time I finish one? TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797013 Share on other sites More sharing options...
TrawlingCleaner Posted February 16, 2022 Author Share Posted February 16, 2022 Seeing as Eldar are my primary focus for the foreseeable future, it would be rude not to join! Quick question; is there a cap on the total number of vows you can make (like in ETL)? Or can I just keep vowing new units each time I finish one? There aren't any caps on the total number of Vows, you can Vow as many times as you like Halandaar 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797020 Share on other sites More sharing options...
Dosjetka Posted February 16, 2022 Share Posted February 16, 2022 Seeing as Eldar are my primary focus for the foreseeable future, it would be rude not to join! Quick question; is there a cap on the total number of vows you can make (like in ETL)? Or can I just keep vowing new units each time I finish one? There aren't any caps on the total number of Vows, you can Vow as many times as you like And I presume that one must finish a vow before making another? Also, just to be clear, may I make a vow with Drukhari models? TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797026 Share on other sites More sharing options...
TrawlingCleaner Posted February 16, 2022 Author Share Posted February 16, 2022 And I presume that one must finish a vow before making another? Also, just to be clear, may I make a vow with Drukhari models? Apologies, I should have made that clearer. You have to finish a Vow before moving onto a new one and you absolutely can make a Vow with Drukhari models I've made it clearer now in the Rules above now too Dosjetka 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797032 Share on other sites More sharing options...
Dosjetka Posted February 16, 2022 Share Posted February 16, 2022 (edited) Great! In that case: I, Dosjetka, vow to complete 10 Drukhari Wyches worth 6 PL by 16th May 2022. Once I've picked up my sprues from the club, I'll post a "before" picture. Edit: Picture added. Edited February 16, 2022 by Dosjetka TrawlingCleaner, Dwango, Iron Father Ferrum and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797044 Share on other sites More sharing options...
Dwango Posted February 16, 2022 Share Posted February 16, 2022 Yes, yes and yes. Definitely partaking. Just painted 3 wave serpents and on with an avatar now! Sadly its too far on to vow for this event. I, Dwango, vow to complete: 10 wraithguard for a total of 19 Power Level by May 16th Mithrilforge, TrawlingCleaner and Iron Father Ferrum 3 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797052 Share on other sites More sharing options...
Khulu Posted February 16, 2022 Share Posted February 16, 2022 Is there a limit to the number of vows we can do in total? TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797062 Share on other sites More sharing options...
Dosjetka Posted February 16, 2022 Share Posted February 16, 2022 Is there a limit to the number of vows we can do in total? There aren't any caps on the total number of Vows, you can Vow as many times as you like :) TrawlingCleaner and Khulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797068 Share on other sites More sharing options...
Halandaar Posted February 16, 2022 Share Posted February 16, 2022 There aren't any caps on the total number of Vows, you can Vow as many times as you like Great! In which case I'll start easy with a Farseer Skyrunner and Bonesinger for a total of 11 Power. Iron Father Ferrum, Dwango, Mithrilforge and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797070 Share on other sites More sharing options...
TrawlingCleaner Posted February 16, 2022 Author Share Posted February 16, 2022 Welcome Brothers Dosjetka, Dwango and Halandaar! Dos, you were the first Vow of the event! Maybe you'll be the first comepletion too Aeldari are storming out of the gates so far! Is there a limit to the number of vows we can do in total? There's no limit to the amount of Vows you make or for the factions you Vow for as long as you complete the previous Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797082 Share on other sites More sharing options...
Trokair Posted February 16, 2022 Share Posted February 16, 2022 (edited) I’d like to take part as I do have a Eldar conversion count as army that I have been meaning to work on since last year. I just have been pushing back the start while waiting for the codex. So subject to that, and mod approval for the count as/conversion being acceptable for B&C (they are a bit far from 40k - I have already asked a while back, just need to submit some actual conversion sample pictures once I have gotten that far) On a tangent, are Aeronautica Imperialis planes allowed? The big 40k scale versions have power levels. Edited February 16, 2022 by Trokair TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797095 Share on other sites More sharing options...
TrawlingCleaner Posted February 16, 2022 Author Share Posted February 16, 2022 On a tangent, are Aeronautica Imperialis planes allowed? The big 40k scale versions have power levels. On the Tiny Planes and also Tiny Titan front, it's a no unfortunately. While the 40k scale versions have PLs, the size difference would be a bit unfair to those potentially painting the same thing just way bigger Hopefully your conversions get the O.K and you can join in on the event, Trokair! Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797136 Share on other sites More sharing options...
Khulu Posted February 16, 2022 Share Posted February 16, 2022 Is there a limit to the number of vows we can do in total? There aren't any caps on the total number of Vows, you can Vow as many times as you like :):)Guess I shouldn't post first thing after waking up! I'll make a vow when I get home, I am gonna be painting a ton of Eldar anyway TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797137 Share on other sites More sharing options...
TrawlingCleaner Posted February 16, 2022 Author Share Posted February 16, 2022 I, TrawlingCleaner, vow to complete: 1 Autarch, 5 Rangers and 3 Shroudrunner jetbikes, for a total of 12 Power Level by May 16th Khulu, Trokair, Dwango and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797286 Share on other sites More sharing options...
Khulu Posted February 17, 2022 Share Posted February 17, 2022 (edited) I vow to paint by May 16: 10 Rangers, 6 Shroudrunners, 1 Farseer (converted), 1 Wave Serpent, 5 Wraithguard, 5 Warlocks, 12 Fire Dragons. I think that is probably best totaled to 69PL. You could do the Warlocks as individuals and the Fire Dragons as two squads of 6 but I think it'd be more reasonable to count the Warlocks as a Conclave and the Fire Dragons as one squad of 7 and one of 5 for the sake of being sporting. Edit: I'm tired, my math may be off Edited February 17, 2022 by Nemesor Tyriks Trokair, WrathOfTheLion, TrawlingCleaner and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797374 Share on other sites More sharing options...
Mithrilforge Posted February 17, 2022 Share Posted February 17, 2022 (edited) I Mithrilforge, Vow to complete - 1x Death Jester, 1x Troupe Master & 1 x Solitaire - For a Total of 12 Power On or Before May 16th. Mithril Edited February 17, 2022 by mithrilforge Dwango, TrawlingCleaner, WrathOfTheLion and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797397 Share on other sites More sharing options...
TrawlingCleaner Posted February 17, 2022 Author Share Posted February 17, 2022 Welcome Nemesor Tyriks and mithrilforge! Tyriks, that Vow is huge! Isha's speed to you brother As you noted Tyriks, we'll be using the most sporting method for unit sizes and Power Level Mithrilforge and Khulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797428 Share on other sites More sharing options...
Dwango Posted February 17, 2022 Share Posted February 17, 2022 I Mithrilforge, Vow to complete 1x Death Jester, 1x Troupe Master & 1 x Solitaire - For a Total of 12 Power* On or Before May 16th. (Pictures will be added tomorrow.) Mithril * - I grabbed these Numbers off the Net so if this is incorrect please let me know as I don't have the Harlequin's Codex. I can confirm the PL is correct. TrawlingCleaner and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797431 Share on other sites More sharing options...
Urkh Posted February 17, 2022 Share Posted February 17, 2022 These rules seem super open, but I am going to ask. I have my own craftworld (craftworld etruria), but I am also painting my friend's dark eldar (in exchange, he is building me a wartable). I feel with these rules I can vow both sides, and they would both count for eldar, yes? If so, I'll come up with a vow soon. Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797612 Share on other sites More sharing options...
TrawlingCleaner Posted February 17, 2022 Author Share Posted February 17, 2022 These rules seem super open, but I am going to ask. I have my own craftworld (craftworld etruria), but I am also painting my friend's dark eldar (in exchange, he is building me a wartable). I feel with these rules I can vow both sides, and they would both count for eldar, yes? If so, I'll come up with a vow soon. Absolutely, here's the rules you're after on factions and subfactions. You can even Vow for Chaos afterwards if you want to You'll need to Vow for either Craftworlds or Drukhari first and the when that Vow is complete, Vow for the other You may Vow for these Subfactions: Craftworld Eldar (Ynnari), Dark Eldar and Outcasts (Including Harlequins, Exodites and Corsairs) You may Vow for both Chaos and Aeldari however whichever faction you vow first for is the faction your Powerlevel goes towards. Anything you paint for the second side is not counted. For example, I vow for Craftworlds first and then Chaos, anything I paint for Chaos is not scored. You can Vow for any of the included forums any amount of times but you cannot get more than one "Most painted" awards. You must complete the previous Vow before Vowing again Urkh 1 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797613 Share on other sites More sharing options...
01RTB01 Posted February 18, 2022 Share Posted February 18, 2022 Right... We've got a local crusade starting up and I'm on pointy eared duty. Once I figure out who I am I'll commit to a vow. The one guarantee is they'll be black armoured with yellow helms :) TrawlingCleaner and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5797813 Share on other sites More sharing options...
The Yncarne Posted February 20, 2022 Share Posted February 20, 2022 For my first vow I pledge: Jain Zar (first image) fire dragon squad (first image) spiritseer (first image) for a current power level sum of 22. Dwango, Mithrilforge and TrawlingCleaner 3 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5798310 Share on other sites More sharing options...
Dread Posted February 21, 2022 Share Posted February 21, 2022 (edited) Ill get in on this soon. Have to finish my daughters of khaine first. Have them sold as soon as theyre done. Then i can get some of the new units. This will be fun. Edited February 21, 2022 by Dread TrawlingCleaner, Dwango and Mithrilforge 3 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5798368 Share on other sites More sharing options...
dice4thedicegod Posted February 21, 2022 Share Posted February 21, 2022 (edited) Wow - just missed including my first drukhari models (painted drazhar and a dozen kabbalites during the last week). For my first vow, I pledge: Raider, Venom, 5 wyches Succubus PL 17 Edited February 21, 2022 by dice4thedicegod TrawlingCleaner, Mithrilforge, The Yncarne and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/373348-anger-and-arrogance-event/#findComment-5798394 Share on other sites More sharing options...
