Yep. All done in Photoshop ('liquify tool')
A white star may be a bit flat/bland?
I prefer the yellow, but it's your Chapter!
Philip
Hmmm... I definitely see what you mean; yellow did have that "eye catching" property. Still, white seems more uniform in regards to how other Chapters apply their heraldry. Thanks for that; much appreciated and all. :rolleyes:
@ Brother Arius - You need an image manipulation program that can handle layers like Photoshop (expensive) or a free open source program like GIMP (GNU (General Public License) Image Manipulation Program) or Paint.net. I'll add this info to the first post.
@ Heru Talon - ^_^ That's not an IA! Is this the final version? I ask because if you are still in development of your chapters IA you may want to change it again in the future (many people do as they develop their chapters), and that means I have to keep updating the image in the gallery. Are you posting your IA soon? As I would rather wait until you have a finished IA up and update the gallery with the 100% final version of your Chapter's colour scheme (edit - updated while I was messing about with the Aurora Knights ;) )
@ Viray - You're welcome :P - grab the one you want so I can delete them from my gallery.
Philip
Edited by Philip S
sons of hephaestus vetern
http://http//www.bolterandchainsword.com/sm/bpe=D61E1E&bpj=D61E1E&bp=D61E1E&bpc=D61E1E&hdt=FFFFFF&hdm=FFFFFF&hdl=FFFFFF&ey=FFFFFF&er=FFFFFF&pi=FFFFFF&nk=D61E1E&ch=D61E1E&eg=FFFFFF&sk=FFFFFF&abs=D61E1E&bt=D61E1E&cod=D61E1E&ull=D61E1E&lk=D61E1E&lll=D61E1E&lft=D61E1E&url=D61E1E&rk=D61E1E&lrl=D61E1E&rft=D61E1E&slt=FFFFFF&sli=D61E1E&srt=FFFFFF&sri=49F558&ula=D61E1E&lel=D61E1E&lla=D61E1E&lw=D61E1E&lh=D61E1E&ura=D61E1E&rel=D61E1E&rla=D61E1E&rw=D61E1E&rh=D61E1E&bg=FFFFFF&rb=FFFFFF&gr=FFFFFF&wg=true&be=BBBBCC&laurel=true&cloak=AA0000&jmp=AAAAAA&jmph=777799&robes=32ED3B&ti=FFFFFF&blt=000000&/spacemarine.jpg
helmet colur is taned flesh
ia is busy gettin dun
Edited by gazmac
Hi,
cool to see you put my guys in already, here is the IA for my Paladins of Puccina. I am currently revising a lot of it, streamlining some, expanding other parts, and I may also change the name, although I do like how you spell them better than how I did (I spelled it 'Pucchina' originally, as you can see in the IA). There is a colour scheme pic in the IA that you can use.
I'll post here again if I change their name (except for that h, that you can consider changed, even if I'll only put it in the IA when I update the rest of it).
@ Heru Talon - :huh: That's not an IA! Is this the final version? I ask because if you are still in development of your chapters IA you may want to change it again in the future (many people do as they develop their chapters), and that means I have to keep updating the image in the gallery. Are you posting your IA soon? As I would rather wait until you have a finished IA up and update the gallery with the 100% final version of your Chapter's colour scheme (edit - updated while I was messing about with the Aurora Knights ;) )
It's the final version of the scheme. I won't be asking you to update anymore of my listed Chapters (they are all final now, Dragons of Gaea was the last that needed an update).
Edited by Heru Talon
Hmmm, an excellent excuse to drag out the old Crimson Lions project:
http://i4.photobucket.com/albums/y136/schoon9953/CrimsonLionsTrp.jpg
Origins
Established in the 10th Founding from Imperial Fist geneseed, the founding fleet of the Crimson Lions never made planetfall on their intended homeworld of Rho Pardus. Forces of the archenemy, in league with informants of the Alpha Legion, set upon the fleet at the divide between Segmentum Solar and the Ultima Segmentum. The escorting vessels were able the atve off the attack, but at terrible cost. Few ships had escaped damage, and many would never sail the tides of the Empyrean again.
In a gambit to save as much material as possible, the Tech Priests attending the fleet made a hulk of three titanic mass-conveyor vessels in the hopes that it might limp to the closest Imperial system. However, surpassing even their own calculations, the amalgam of vessels proved remarkably resilient. This formed the core of what would eventually become the Spelaeum Leonis, the unplanned monastery barge of the chapter. The chapter's artificers have added to it considerably in the intervening millennia, expanding both its size and capabilities, but it will never be accused of either beauty or speed.
The Master of the Fleet for the chapter must possess a a keen, strategic mind to plot the best course for the lumbering barge, taking into account the needs of both the chapter and the Imperium.
Recruitment
The roaming course of the monastery makes consistent recruiting a challenge, and this difficulty in maintaining a regular flow of aspirants has led to a slight variance in their implantation process. The chapter strives to maintain a small pool of recruits that train and receive hypno-therapy prior to any gene-seed implantation. Occasionally an aspirant will grow too old or prove unsuitable during this process, and these are typically handed over to the Schola Progenium. Aspirants from this pool begin gene-seed implantation as required to maintain chapter numbers. The additional therapy is thought to increase chances of successful geneseed implantation, and tends to produce a cannier, less reckless scout.
Beliefs
The 10th founding was a transition period for many new Space Marine chapters. The concept of the Emperor's divinity had already gained widespread acceptance throughout both populace and Adeptus Terra, though not yet amongst the Adeptus Astartes. The duality of belief for the Crimson Lions reflects this transitional period.
Like many other venerable chapters, they look at the Emperor as a father, albeit an extraordinarily gifted one. However, they also see him as the living vessel for human divinity, a Divine Avatar to borrow a Thorian term. Though many outside the chapter have difficulty reconciling these two views, with the exception of some members of the Inquisition, they view it as an innate duality in the Emperor's physical and Warp manifestations.
More to come...
@ Race Bannon - Do you have a chapter symbol? (Your scheme needs a chapter symbol applied to the shoulder before I'll include it.)
@ Heru Talon - Cheers mate ^_^ - are you going to post any IA drafts I can link to? Even a brief description of the concept would be cool.
@ schoon - Nice chapter, can you post it as a IA on this board: + LIBER ASTARTES + (it where all the DIY chapters are posted on B+C, and my favourite place to link to from the gallery)
Philip
Hey Philip, no need to change the name, I think I'll stick with this one, taking away that h somehow makes it look a lot better. Do you link directly to the IA when you implement that, or should I keep you up to date with any changes I make to the IA?
@ Wolf Priest Haelaeif - the gallery directly links to a Chapter's IA. I've updated the new gallery (the one that will replace the old one) and your Chapter is currently on page 28. If you click your Chapter it will take you to your IA :devil:
Philip
Philip,
No symbol. The shoulder pad IS the symbol. :tu: Hence, the "Red Shoulders" Chapter.
If this does not fit the scheme ... well, that was the plan. But for your project, if that presents complications then I guess I'll have to back out :P
Register a new account
Sign in
